How to connect wokwi to blnyk?
I have a project on wokwi using ESP32 and I'm having a hard time connecting it to blynk due to the lack of tutorials available,maybe someone can help me tell me what to do. here my projects :
sorry typo, i mean blynk
this seems to compile
not sure it does work though...
i want to use lcd in blynk... so ..does this program have the correct code?
and how to get auth in blynk?
seems you have a lot of ground work to cover... get a real ESP32 to play with...
If you scroll up to your first post, you can edit the title. Use the correct spelling "Blynk" so others can recognize and find it.
Image result for How to connect wokwi to blynk?
  1. Make sure your device is powered on and waiting for connection.
    tap Go to Settings;
    select your Device in Wi-Fi settings.
    return back to the Blynk application.
    tap Already connected;
    if asked, allow Blynk application to connect to devices in your local network;
    proceed with common add device flow.
