Impossible to upload Blynk exemple sketch on arduino ESP32
Hello all, I'm a noob regarding Blynk so thank you in advance for your help!
I try to upload a sketch on my esp32.
The goal of the sketch is simple, I want to be able to read the state of the Blynk switch, start a pump and turn off the Blynk switch.
I tried to use the exemple on the Blynk website but my code won't even upload...
I tried to upload the sketch exemple ESP32_WIFI wich worked so the problem seem to be with the readingof the switch itself.
Here's the code of the code from the blynk website (That's not the code I want to use, I try to be at leat able to make a switch work for now):
#define BLYNK_PRINT Serial
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "XXXXXXXXX";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "XXXXXXXXX";
char pass[] = "XXXXXXXXX";
// Select your pin with physical button
const int btnPin = 1;
WidgetLED led3(V3);
BlynkTimer timer;
// V3 LED Widget represents the physical button state
boolean btnState = false;
void buttonLedWidget()
  // Read button
  boolean isPressed = (digitalRead(btnPin) == LOW);
  // If state has changed...
  if (isPressed != btnState) {
    if (isPressed) {
      led3.on();
      led3.off();
    btnState = isPressed;
  // Debug console
  Blynk.begin(auth, ssid, pass);
  // You can also specify server:
  //Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
  //Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
  // Setup physical button pin (active low)
  pinMode(btnPin, INPUT_PULLUP);
  timer.setInterval(500L, buttonLedWidget);
  Blynk.run();
  timer.run();
Here's the code of the error:
Arduino:1.8.13 (Windows Store 1.8.42.0) (Windows 10), Carte : "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
In file included from C:\Users\joell\OneDrive\Documents\Arduino\DOSSIER TEST\2021-03-18_test_blynk_esp32\2021-03-18_test_blynk_esp32.ino:6:0:
C:\Users\joell\OneDrive\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32.h: In member function 'void BlynkWifi::connectWiFi(const char*, const char*)':
C:\Users\joell\OneDrive\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32.h:37:14: error: 'class WiFiClass' has no member named 'mode'
         WiFi.mode(WIFI_STA);
C:\Users\joell\OneDrive\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32.h:37:19: error: 'WIFI_STA' was not declared in this scope
C:\Users\joell\OneDrive\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32.h:39:34: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
             WiFi.begin(ssid, pass);
In file included from C:\Users\joell\OneDrive\Documents\Arduino\DOSSIER TEST\2021-03-18_test_blynk_esp32\2021-03-18_test_blynk_esp32.ino:4:0:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\libraries\WiFi\src/WiFi.h:79:9: note:   initializing argument 1 of 'int WiFiClass::begin(char*, const char*)'
     int begin(char* ssid, const char *passphrase);
C:\Users\joell\OneDrive\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32.h:41:28: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
             WiFi.begin(ssid);
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\libraries\WiFi\src/WiFi.h:60:9: note:   initializing argument 1 of 'int WiFiClass::begin(char*)'
     int begin(char* ssid);
exit status 1
Erreur de compilation pour la carte ESP32 Dev Module
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
I've been struggling on this for days now so, your help is very appreciated. Thank you!
