How to control heating rate?
Hello guys
I'm chemistry student and i have no privous knowledg about arduino, am traying to make heater that allows a final temperature set-point and a rate to be specified. (example : Final temp. : 550C at 10C/min.
So Is that possible to do such a project using arduino ?
My heater will be cylindrical with diameter 2inches and the length will be about 35cm
am using ceramic beads as a heating element with up to 3000W and up to 20 amps
Any recommendation is appreciated.
AC or DC?
i believe AC
I'm intrigued about the statement that you are using ceramic beads as a heating element. Most ceramic materials are insulators.
I've seen them fitted over metallic heating elements to insulate the element from the surroundings, but not used as the actual heater itself.
Also it is best not to mix Imperial and metric units; you mentioned 2inches, and 35cm.
For a first attempt, you can calculate the desired temperature at the moment, measure what it actually is and turn the heater on if it's too low.
It sounds as though you are thinking you'll have proportional control of the amount of heating, so you may want to consider PID if the first method isn't accurate enough.
Hello chemeagel
Well, I think a two-point control with hysteresis will do this job properly.
To find a proper sensor and actuator a view into the WWW will help.
Yes. What makes your problem a bit more exciting is your desire to not only reach an end temperature but to get there at a steady rate.
You will need an variable source of heat, PWM generated by the Arduino has been mentioned. Although it may be that on/off will suffice, thermal systems are a bit different.
How close to N degrees per unit of time are you hoping to achieve?
You will need a control loop to stay on the temperature rate of increase, PID has been mentioned but there are other control loop methods. I do not know if any are more appropriate for this use car.
Lastly, measurement of the temperature needs to correlate to the heat absorbed, which it should kinda by definition, but if the heated material is not evenly heated or stirred or whatever you will be reacting to spurious or less meaningful and accurate numbers coming from your sensor.
Sounds like fun! The Arduino and heating control PWM will not be the limiting factor for good performance. It is the algorithm and the adjustments (tuning) that makes or breaks it.
a7
check here for more about ceramic beads.
sorry for mixing the two unit systems, but where i came from we use th Imperial system for measuring pipes diameters.
Another consideration is to give the Arduino more data so it can determine whether the request is doable. Volume of material to be heated and specific heat capacity would help it calculate whether to get on with it or light an error condition LED marked as "You must be joking".
Depending on insulation of course, it may be that even if the Arduino thinks it can be done that reaching the target may not be attainable.
Welcome to the forum.
Have you done any heating runs with samples loaded to establish if your heater can out perform the rate of increase you are aiming for?
If your heater cannot output the goods to at least when ON fully maintain the required increase in temperature rate your program most certainly won't.
Tom... :grinning: :+1: :coffee: :australia:
a7,
Thanks for your attention, i found this project while am searching and i'm pretty sure is it similar to what am trying to do, but the proplem is this project was done 10 yers ago and there's no clear information for me.
Wolud you please take a look and tell me is that poject good for applying ?
CE
Nice find. That is indeed just what you trying to do. Looks like that project worked very well.
Computers work pretty much they way they did 10 years ago, as do mathematics, Ohm’s Law and all that stuff, so you good. All the pieces are there, I’d be surprised if an accomplished enthusiast could not wrangle that into a slightly more modern version that used most of the code and functioned identically.
Pretend like you know way more than you might and start reading the code in the github repository. I find that squinting while doing helps a great deal. Fear not. All this is hard until it is easy.
Meanwhile start playing with an Arduino. Step by step here: dunno if you are literally a total noob to programming or maybe just a bit without experience dealing with tiny systems like this.
It is often suggested to get things like this working a piece at a time. Simply measuring the temperature and turning off the heater at a given point would test most of the basic hardware.
Worry about rates and PID and tuning later.
If you are truly a beginner, start with getting an LED to blink, srsly that gets you past many hurdles. It is the “Hello World!” first program in the embedded systems area, a simple program that shows you’ve installed all the tools and can see a program, upload it and execute it.
Make an LED display the state of a pushbutton.
Turn off and on an LED with a pushbutton. One press ON, one press OFF rinse and repeat.
Then the fun can begin. Next I would just get the temperature readings happening.
And so forth.
Some questions have been raised here. Does the heater have the power to do the work? What accuracy do you hope to attain?
And I am curious how that linked project handled the landing phase, that is the approach to the set point. Obvsly the heating rate can’t go from 10 degrees C per minute to 0 instantly… part of the tuning will be inevitable tradeoffs between holding to the linear increase of temperature and avoiding overshooting or oscillation.
I am actually envious, you get to do this and it is what you are supposed to be doing.
a7
Those consist of resistance wire covered with ceramic beads. If the power source is AC, PWM control of a Solid State Relay (SSR) will work well to control the heating rate.
There are plenty of Arduino projects that turn a toaster oven into a PCB solder reflow oven using that technique. Google "arduino reflow oven"
Hello there,
I am currently working on a project similar to yours, did you make any progress with yours. If so can you help me out or do you have recommendation. Would be much appreciated.
Same here..... insulators around a heater wire...... "60 /16 CORE WIRE"
Do not hitchhike a thread.
Open a new topic with your current questions about your project and a reference to this topic.
They specifically asked the OP how the project's coming on- seems a pretty sensible thing to do.
OK thank you, I will. I am a newbie to this forum and couldn't find anything that resembles to what I am looking for.
Thanks for the uneeded follow up, keep the toxicity to yourself.
What was toxic about agreeing with you that asking this thread's OP if they had made any progress was a good idea?
