Hello,
I'm new to coding and am currently working on a light-up ukulele to show people where to place their fingers when learning to play basic chords and scales. I'm also using a 16X2 LCD screen with an I2C module controlled by push buttons to change between screens (when a chord/scale is selected the LED's in the ukulele fretboard will light up as well). I am having a bit of trouble with getting the LCD screen reacting to when the push buttons are pressed. I'm running all this through an Arduino Microcontroller.
How the buttons are meant to work:
Home button to set the screens back to the home screen (chords/scales)
The cycle button to cycle between screens (between chords or scales)(or note quality or notes)
The select button to select when screen you want to continue with ( e.g. choose "chords")
(please find a map of the screens attached)
Any help would be much appreciated.
Thank you.
Here is the code I have so far:
//This program will allow users to control an lcd screen and leds lights using push buttons.
//different libraries to include
#include <Wire.h> // Allows the use and communication of an I2C device.(device connected to LCD screen)
#include <LiquidCrystal_I2C.h> // Allows use and control of LCD Screen
#include <Adafruit_NeoPixel.h> //Allows use of WS2812B RGB LEDs (LEDs that can be individually addressed)
#include <FastLED.h> // Allows the programing of individually addressable LEDs
// set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd {0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE};
//Constants that cannot be changed
//Assigning Button Pins
const int Home_buttonPin = 2; // Go to home page (chords and scales). - - - Connect to Pin 2 on Arduino
const int Cycle_buttonPin = 3; // Select a chord or scale. - - - Connect to Pin 3 on Arduino
const int Select_buttonPin = 4; // Cycle through different categories until one is selected. - - - Connect to Pin 4 on Arduino
int page_counter = 1; //To move beetwen pages
int subpage1_counter = 0; //To move submenu 1 Chords - Major/Minor
int subpage2_counter = 0; //To move submenu 2 Scales - Major/Minor
int subpage1_1_counter = 0; //To move submenu 1.1 Chords - Major/A,B,C,D,E,F,G
int subpage2_1_counter = 0; //To move submenu 2.1 Chords - Minor/A,B,C,D,E,F,G
int subpage1_2_counter = 0; //To move submenu 1.2 Scales - Major/A,B,C,D,E,F,G
int subpage2_2_counter = 0; //To move submenu 2.2 Scales - Minor/A,B,C,D,E,F,G
//Assigning LED pins
const int LED_Pin = 9; // lED pin connected to arduino. - - - Connect to Pin 9 on Arduino
//Stating the Number of LEDs to be used
const int NUM_LEDS = 52; // Number of lEDs used
//Stating the mode of colour
CRGB leds[NUM_LEDS]; // Colour mode
// - - - Connect to Pin A4 on Arduino
//Stating the variables that will change
//Button States
boolean Home_buttonState = 0; // Current state of the home button
boolean Home_buttonStateLast = 0; // Previous state of the home button
boolean Home_buttonStateHeld = 0;
boolean Cycle_buttonState = 0; // Current state of the cycle button
boolean Cycle_buttonStateLast = 0; // Previous state of the cycle button
boolean Select_buttonState = 0; // Current state of the select button
boolean Select_buttonStateLast = 0; // Previous state of the select button
//LED Brightness
int brightness = 120;
int charindex = 0;
int charsSize = 0;
Serial.begin(9600); // Sets the data rate in bits per second
FastLED.addLeds<WS2812B, LED_Pin, GRB>(leds, NUM_LEDS); // Identify type of LED strip?
// initialise LCD screen
lcd.begin(16, 2); // Tells LCD to begin with 16 characters and 2 lines displayed
lcd.clear(); // Clears all text from LCD Screen
lcd.setCursor(0, 0); // Sets cursor to top left corner.
lcd.print("Guitar Aid"); // Print opening Text - - - - - Remember to change name here.
delay(3000); // Leaves opening text on screen for 5 seconds
lcd.clear();
//5V LED supply
// pinMode(ledSupplyEnablePin, OUTPUT);
// digitalWrite(ledSupplyEnablePin, 0);
// initialise the pushbutton pin as an input:
pinMode (Home_buttonPin, INPUT_PULLUP); //Set home button as an imput.
pinMode (Cycle_buttonPin, INPUT_PULLUP); //Set cycle button as an imput.
pinMode (Select_buttonPin, INPUT_PULLUP); //Set select button as an imput.
// Initialise the pushbuttons
Home_buttonStateLast = Home_buttonState;
Cycle_buttonStateLast = Cycle_buttonState;
Select_buttonStateLast = Select_buttonState;
Home_buttonState = digitalRead (Home_buttonPin);
Cycle_buttonState = digitalRead (Cycle_buttonPin);
Select_buttonState = digitalRead (Select_buttonPin);
//Change pages
if (Home_buttonStateLast == LOW && Home_buttonState == HIGH) { //Home button pressed
Home_buttonStateLast == Home_buttonStateHeld;
page_counter = 1 ;
if (Cycle_buttonStateLast == LOW && Cycle_buttonState == HIGH) { //cycle button pressed
page_counter = 2;
if (page_counter < 2) { //Page counter not higher than 2 (total of pages for home)
page_counter = page_counter + 1; //Page up
else {
page_counter = 1; //If higher than 2 (last page) change back to page 1
switch (page_counter) {
case 1: { //Design of home page 1
lcd.print("Chords");
}//case 1 end
case 2: { //Design of home page 2
lcd.print("Scales");
}//case 2 end
// Sub1 counter control
if (Select_buttonStateLast == LOW && Select_buttonState == HIGH) { //select button pressed
subpage1_counter = 2;
if (subpage1_counter < 2) { // SubPage counter not higher than 2 (total of pages for home)
subpage1_counter = subpage1_counter + 1; //Page up
subpage1_counter ++; //subcounter to move beetwen submenu
else { //If subpage higher than 2 (total of items) return to first item
subpage1_counter = 1;
switch (subpage1_counter) {
case 1: { //Design of note quality page 1
lcd.print("Chords: Major");
}//case 1 end
case 2: { //Design of note quality page 2
lcd.print("Chords: Minor");
}//case 2 end
// Sub2 counter control
subpage2_counter = 2;
if (subpage2_counter < 2) { // SubPage counter not higher than 2 (total of pages for home)
subpage2_counter = subpage1_counter + 1; //Page up
subpage2_counter ++; //subcounter to move beetwen submenu
subpage2_counter = 1;
switch (subpage2_counter) {
lcd.print("Scales: Major");
}//case 1 end
lcd.print("Scales: Minor");
}//case 2 end
// Sub1_1 counter control
subpage1_1_counter = 7;
if (subpage1_1_counter < 7) { // SubPage counter not higher than 7 (total of pages for home)
subpage1_1_counter = subpage1_counter + 1; //Page up
subpage1_1_counter ++; //subcounter to move beetwen submenu
else { //If subpage higher than 7 (total of items) return to first item
subpage1_1_counter = 1;
// Select_buttonStateLast = Select_buttonState;
switch (subpage1_1_counter) {
case 1: {
lcd.print("Chords: A Major");
}//case 1 end
case 2: {
lcd.print("Chords: B Major");
}//case 1 end
case 3: {
lcd.print("Chords: C Major");
}//case 1 end
case 4: {
lcd.print("Chords: D Major");
}//case 1 end
case 5: {
lcd.print("Chords: E Major");
}//case 1 end
case 6: {
lcd.print("Chords: F Major");
}//case 1 end
case 7: {
lcd.print("Chords: G Major");
}//case 1 end
// Sub2_1 counter control
subpage2_1_counter = 7;
if (subpage2_1_counter < 7) { // SubPage counter not higher than 7 (total of pages for home)
subpage2_1_counter = subpage1_counter + 1; //Page up
subpage2_1_counter ++; //subcounter to move beetwen submenu
subpage2_1_counter = 1;
switch (subpage2_1_counter) {
case 1: {
}//case 1 end
case 2: {
}//case 1 end
case 3: {
}//case 1 end
case 4: {
}//case 1 end
case 5: {
}//case 1 end
case 6: {
}//case 1 end
case 7: {
}//case 1 end
// Sub1_2 counter control
subpage1_2_counter = 7;
if (subpage1_2_counter < 7) { // SubPage counter not higher than 7 (total of pages for home)
subpage1_2_counter = subpage1_counter + 1; //Page up
subpage1_2_counter ++; //subcounter to move beetwen submenu
subpage1_2_counter = 1;
switch (subpage1_2_counter) {
case 1: {
lcd.print("Chords: A Minor");
}//case 1 end
case 2: {
lcd.print("Chords: B Minor");
}//case 1 end
case 3: {
lcd.print("Chords: C Minor");
}//case 1 end
case 4: {
lcd.print("Chords: D Minor");
}//case 1 end
case 5: {
lcd.print("Chords: E Minor");
}//case 1 end
case 6: {
lcd.print("Chords: F Minor");
}//case 1 end
case 7: {
lcd.print("Chords: G Minor");
}//case 1 end
// Sub2_2 counter control
subpage2_2_counter = 7;
if (subpage2_2_counter < 7) { // SubPage counter not higher than 7 (total of pages for home)
subpage2_2_counter = subpage1_counter + 1; //Page up
subpage2_2_counter ++; //subcounter to move beetwen submenu
subpage2_2_counter = 1;
switch (subpage2_2_counter) {
case 1: {
}//case 1 end
case 2: {
}//case 1 end
case 3: {
}//case 1 end
case 4: {
}//case 1 end
case 5: {
}//case 1 end
case 6: {
}//case 1 end
case 7: {
}//case 1 end
