i'm unable to control nema 23 with motor driver TB6600 for line following purpose and control the robot via bluetooth can any one help
I moved your topic to an appropriate forum category @chackzz.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
that is a bit vauge - what is it not doing that you expect it to do?
what host microcontroller are you using?
does the Nema work ok in a sperate test program?
does the Bluetooth work OK in a seperate test program?
upload your code - select < CODE/ > and paste the code or text where it says “type or paste code here”
upload a schematic of the circuit
can you contact via this mail id basithrafeequemohasin@gmail.com
