How to control servo motor using switch case statement
I want to control the servo motor using switch case statement but i stuck. The servo something working fine when i enter the alphabet but sometimes its cannot detect when i enter the value. Please help me. i post my code here for review
#include <Servo.h>
Servo myservo;
//char myCol[20];
int pos = 0;
  myservo.attach(9);
  myservo.write(pos);
  Serial.println("Press E for easy level mode");
  Serial.println("Press N for normal level mode");
  Serial.println("Press H for hard level mode");
  if (Serial.available())
    Serial.readBytes(myCol, 1);
  //char level = Serial.readBytes(myCol, 1);
  //char level = Serial.read();
  int input = Serial.read();
  switch (input)
    case 'E':    // easy level
      //(strcmp(myCol, "E") == 0);
      //pos = 30;
      for (pos = 0; pos <= 30; pos += 10){
        myservo.write(pos);}
      for (pos = 30; pos >= 0; pos -= 10){
        myservo.write(pos);
    case 'N':     // normal level
      //(strcmp(myCol, "N") == 0);
      //pos = 60;
      for (pos = 0; pos <= 60; pos += 10){
     for (pos = 60; pos >= 0; pos -= 10){
        myservo.write(pos);
    case 'H':     // hard level
      //(strcmp(myCol, "H") == 0);
      // pos = 90;
      for (pos = 0; pos <= 90; pos += 10){
      for (pos = 90; pos <= 0; pos -= 10){
        myservo.write(pos);
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
You may wish to review your closing braces
Hi, @doreamon11
If you press [ CTRL ] [ T ] , auto format, to align your brackets, you will find the switch.. case format does not line up.
Here is your code formatted.
#include <Servo.h>
Servo myservo;
//char myCol[20];
int pos = 0;
  myservo.attach(9);
  myservo.write(pos);
  switch (input)
      //pos = 30;
        myservo.write(pos);
        myservo.write(pos);
        //pos = 60;
          myservo.write(pos);
          myservo.write(pos);
          // pos = 90;
            myservo.write(pos);
            myservo.write(pos);
Tom... :grinning: :+1: :coffee: :australia:
code is missing closing braces in several locations
code has commented out definition for myCol
there's a conditional check if serial data is available, but regardless of that check, the input is read and processed
another approach is simply to skip further processing is NO serial data is available
  if (! Serial.available())
      return;
