Hi
Does anyone know how I could convert char *variable for exemple
char *message="Hello";
to a string, to have
string messconv="Hello"; after doing a conversion ?
Thank you
Hi
Thank you
Have you try this:
char buf[] = "hello";
String mystring(buf); //convert char array to string here.
arduino_new:
Have you try this:char buf[] = "hello";
No, I didn't understand how to implement your exemple. I also tried and it didn't work. Also, as we can see in my first post I have char *message. There is a star. In your exemple, there is no star after the char.
I found this:
char *message = "Hello";
String myString = String(message);
from this: byte array to String - Programming Questions - Arduino Forum
Also:
and
char message[] = "Hello";
are essentially the same. The only different is where the "Hello" resides in memory.
Perhaps equally important is why you would want to do that? A string built from a char array is going to use fewer resources than the String class.
arduino_new:
Also:char *message = "Hello";and
char message[] = "Hello";are essentially the same. The only different is where the "Hello" resides in memory.
no, that is not correct.
this defines a pointer to a string literal
the string in this case is immutable
this defines an array of characters initialized with "Hello":
this string may be modified.
OP just needs to read about the String class
