How to convert the captured image with ov2640 Mini 2MP on my PC?
Hi guys,
I am using the Arduino Nano 33 BLE Sense board on which I connected the Arducam 2MP Mini module. I am able to take an image and based on the provided functions save it in jpeg_buffer. Then I use BLE to send the data to my PC and it works (all 3080 bytes are received every time). Now, I am trying to decode the received byte array in Python using base64 decoder and pillow library but unfortunately, I am not able to do that as the final data is not an image. Can you please help me to find where the issue is?
P.S. I receive some weird values in my byte array such as \xe3\xfe\xb95-Fp\x1e\x1f\x9e8|A4p\xb7\
You need code to convert raw data into an image file. Since there exist various preprogrammed image converters, it doesn't matter much which type of file you write in the first place.
The early IBM "bitmap" (*.bmp) files are pretty simple in structure, so that could be a place to start. There are plenty of code examples in C and C++ for that, and maybe in python.
Alternatively, if the data are already in the form of an image file, transmit that instead of raw data.
Sounds like data transmission errors. If so, you will need error checking for the transmission protocol. Always useful!
No, we cannot because you failed to post your code.
In my case, all bytes from SPI are saved into buffer and then using the JpegDec.decodeArray(jpeg_buffer, jpeg_length) function it is decoded. I do not think the issue is related to the transmission part as I checked the BLE implementation and checked also the number of sent and received bytes.
Here is the code where the image is captured and decoded:
/* Copyright 2019 The TensorFlow Authors. All Rights Reserved.
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
    http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
#include "image_provider.h"
 * The sample requires the following third-party libraries to be installed and
 * configured:
 * Arducam
 * 1. Download https://github.com/ArduCAM/Arduino and copy its `ArduCAM`
 *    subdirectory into `Arduino/libraries`. Commit #e216049 has been tested
 *    with this code.
 * 2. Edit `Arduino/libraries/ArduCAM/memorysaver.h` and ensure that
 *    "#define OV2640_MINI_2MP_PLUS" is not commented out. Ensure all other
 *    defines in the same section are commented out.
 * JPEGDecoder
 * 1. Install "JPEGDecoder" 1.8.0 from the Arduino library manager.
 * 2. Edit "Arduino/Libraries/JPEGDecoder/src/User_Config.h" and comment out
 *    "#define LOAD_SD_LIBRARY" and "#define LOAD_SDFAT_LIBRARY".
#if defined(ARDUINO) && !defined(ARDUINO_ARDUINO_NANO33BLE)
#define ARDUINO_EXCLUDE_CODE
#endif  // defined(ARDUINO) && !defined(ARDUINO_ARDUINO_NANO33BLE)
#ifndef ARDUINO_EXCLUDE_CODE
// Required by Arducam library
#include <SPI.h>
#include <Wire.h>
#include <memorysaver.h>
// Arducam library
#include <ArduCAM.h>
// JPEGDecoder library
#include <JPEGDecoder.h>
// Checks that the Arducam library has been correctly configured
#if !(defined OV2640_MINI_2MP_PLUS)
#error Please select the hardware platform and camera module in the Arduino/libraries/ArduCAM/memorysaver.h
#endif
// The size of our temporary buffer for holding
// JPEG data received from the Arducam module
#define MAX_JPEG_BYTES 4096
// The pin connected to the Arducam Chip Select
#define CS 7
int8_t* image_send;
int index_test;
// Camera library instance
ArduCAM myCAM(OV2640, CS);
// Temporary buffer for holding JPEG data from camera
uint8_t jpeg_buffer[MAX_JPEG_BYTES] = {0};
// Length of the JPEG data currently in the buffer
uint32_t jpeg_length = 0;
// Get the camera module ready
TfLiteStatus InitCamera(tflite::ErrorReporter* error_reporter) {
  TF_LITE_REPORT_ERROR(error_reporter, "Attempting to start Arducam");
  // Enable the Wire library
  Wire.begin();
  // Configure the CS pin
  pinMode(CS, OUTPUT);
  digitalWrite(CS, HIGH);
  // initialize SPI
  SPI.begin();
  /* Additional part related to SPI that enables the camera to work properly */
  SPI.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
  // Reset the CPLD
  myCAM.write_reg(0x07, 0x80);
  delay(100);
  myCAM.write_reg(0x07, 0x00);
  delay(100);
  // Test whether we can communicate with Arducam via SPI
  myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
  uint8_t test;
  test = myCAM.read_reg(ARDUCHIP_TEST1);
  if (test != 0x55) {
    TF_LITE_REPORT_ERROR(error_reporter, "Can't communicate with Arducam");
    return kTfLiteError;
  // Use JPEG capture mode, since it allows us to specify
  // a resolution smaller than the full sensor frame
  myCAM.set_format(JPEG);
  myCAM.InitCAM();
  // Specify the smallest possible resolution
  myCAM.OV2640_set_JPEG_size(OV2640_160x120);
  delay(100);
  return kTfLiteOk;
// Begin the capture and wait for it to finish
TfLiteStatus PerformCapture(tflite::ErrorReporter* error_reporter) {
  TF_LITE_REPORT_ERROR(error_reporter, "Starting capture");
  // Make sure the buffer is emptied before each capture
  myCAM.flush_fifo();
  myCAM.clear_fifo_flag();
  // Start capture
  myCAM.start_capture();
  // Wait for indication that it is done
  while (!myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK)) {
  TF_LITE_REPORT_ERROR(error_reporter, "Image captured");
  delay(50);
  // Clear the capture done flag
  return kTfLiteOk;
// Read data from the camera module into a local buffer
TfLiteStatus ReadData(tflite::ErrorReporter* error_reporter) {
  // This represents the total length of the JPEG data
  jpeg_length = myCAM.read_fifo_length();
  TF_LITE_REPORT_ERROR(error_reporter, "Reading %d bytes from Arducam",
                       jpeg_length);
  // Ensure there's not too much data for our buffer
  if (jpeg_length > MAX_JPEG_BYTES) {
    TF_LITE_REPORT_ERROR(error_reporter, "Too many bytes in FIFO buffer (%d)",
                         MAX_JPEG_BYTES);
  if (jpeg_length == 0) {
    TF_LITE_REPORT_ERROR(error_reporter, "No data in Arducam FIFO buffer");
  myCAM.CS_LOW();
  myCAM.set_fifo_burst();
  for (int index = 0; index < jpeg_length; index++) {
    jpeg_buffer[index] = SPI.transfer(0x00);
  delayMicroseconds(15);
  TF_LITE_REPORT_ERROR(error_reporter, "Finished reading");
  myCAM.CS_HIGH();
  return kTfLiteOk;
// Decode the JPEG image, crop it, and convert it to greyscale
TfLiteStatus DecodeAndProcessImage(tflite::ErrorReporter* error_reporter,
                                   int image_width, int image_height,
                                   int8_t* image_data) {
                       "Decoding JPEG and converting to greyscale");
  // Parse the JPEG headers. The image will be decoded as a sequence of Minimum
  // Coded Units (MCUs), which are 16x8 blocks of pixels.
  JpegDec.decodeArray(jpeg_buffer, jpeg_length);
  // Crop the image by keeping a certain number of MCUs in each dimension
  const int keep_x_mcus = image_width / JpegDec.MCUWidth;
  const int keep_y_mcus = image_height / JpegDec.MCUHeight;
  // Calculate how many MCUs we will throw away on the x axis
  const int skip_x_mcus = JpegDec.MCUSPerRow - keep_x_mcus;
  // Roughly center the crop by skipping half the throwaway MCUs at the
  // beginning of each row
  const int skip_start_x_mcus = skip_x_mcus / 2;
  // Index where we will start throwing away MCUs after the data
  const int skip_end_x_mcu_index = skip_start_x_mcus + keep_x_mcus;
  // Same approach for the columns
  const int skip_y_mcus = JpegDec.MCUSPerCol - keep_y_mcus;
  const int skip_start_y_mcus = skip_y_mcus / 2;
  const int skip_end_y_mcu_index = skip_start_y_mcus + keep_y_mcus;
  // Pointer to the current pixel
  uint16_t* pImg;
  // Color of the current pixel
  uint16_t color;
  // Loop over the MCUs
  while (JpegDec.read()) {
    // Skip over the initial set of rows
    if (JpegDec.MCUy < skip_start_y_mcus) {
      continue;
    // Skip if we're on a column that we don't want
    if (JpegDec.MCUx < skip_start_x_mcus ||
        JpegDec.MCUx >= skip_end_x_mcu_index) {
      continue;
    // Skip if we've got all the rows we want
    if (JpegDec.MCUy >= skip_end_y_mcu_index) {
      continue;
    pImg = JpegDec.pImage;
    // The x and y indexes of the current MCU, ignoring the MCUs we skip
    int relative_mcu_x = JpegDec.MCUx - skip_start_x_mcus;
    int relative_mcu_y = JpegDec.MCUy - skip_start_y_mcus;
    // The coordinates of the top left of this MCU when applied to the output
    // image
    int x_origin = relative_mcu_x * JpegDec.MCUWidth;
    int y_origin = relative_mcu_y * JpegDec.MCUHeight;
    // Loop through the MCU's rows and columns
    for (int mcu_row = 0; mcu_row < JpegDec.MCUHeight; mcu_row++) {
      // The y coordinate of this pixel in the output index
      int current_y = y_origin + mcu_row;
      for (int mcu_col = 0; mcu_col < JpegDec.MCUWidth; mcu_col++) {
        // Read the color of the pixel as 16-bit integer
        color = *pImg++;
        // Extract the color values (5 red bits, 6 green, 5 blue)
        uint8_t r, g, b;
        r = ((color & 0xF800) >> 11) * 8;
        g = ((color & 0x07E0) >> 5) * 4;
        b = ((color & 0x001F) >> 0) * 8;
        // Convert to grayscale by calculating luminance
        // See https://en.wikipedia.org/wiki/Grayscale for magic numbers
        float gray_value = (0.2126 * r) + (0.7152 * g) + (0.0722 * b);
        // Convert to signed 8-bit integer by subtracting 128.
        gray_value -= 128;
        // The x coordinate of this pixel in the output image
        int current_x = x_origin + mcu_col;
        // The index of this pixel in our flat output buffer
        int index = (current_y * image_width) + current_x;
        image_data[index] = static_cast<int8_t>(gray_value);
        /* Additional part needed for BLE image transfer */
        index_test = index;
        image_send[index] = static_cast<int8_t>(gray_value);
  TF_LITE_REPORT_ERROR(error_reporter, "Image decoded and processed");
  return kTfLiteOk;
// Get an image from the camera module
TfLiteStatus GetImage(tflite::ErrorReporter* error_reporter, int image_width,
                      int image_height, int channels, int8_t* image_data) {
  static bool g_is_camera_initialized = false;
  if (!g_is_camera_initialized) {
    TfLiteStatus init_status = InitCamera(error_reporter);
    if (init_status != kTfLiteOk) {
      TF_LITE_REPORT_ERROR(error_reporter, "InitCamera failed");
      return init_status;
    g_is_camera_initialized = true;
  TfLiteStatus capture_status = PerformCapture(error_reporter);
  if (capture_status != kTfLiteOk) {
    TF_LITE_REPORT_ERROR(error_reporter, "PerformCapture failed");
    return capture_status;
  TfLiteStatus read_data_status = ReadData(error_reporter);
  if (read_data_status != kTfLiteOk) {
    TF_LITE_REPORT_ERROR(error_reporter, "ReadData failed");
    return read_data_status;
  TfLiteStatus decode_status = DecodeAndProcessImage(
      error_reporter, image_width, image_height, image_data);
  if (decode_status != kTfLiteOk) {
    TF_LITE_REPORT_ERROR(error_reporter, "DecodeAndProcessImage failed");
    return decode_status;
  return kTfLiteOk;
#endif  // ARDUINO_EXCLUDE_CODE
I focus on this jpeg_buffer and I tried to send it via BLE to my PC. For that part I am using BLE:
int counter = 0;
      int i=0;
      for(i; i<jpeg_length; i+=RX_BUFFER_SIZE){
        txChar.writeValue(jpeg_buffer+i, 220);
        //Serial.println(jpeg_buffer+i);
        counter+=1;
And this is the part that I am using on the PC side for converting the byte array into image (this is the Python code):
self.dataByte = data //bytes received from BLE
final_image = base64.b64encode(self.dataByte)
img = Image.open(io.BytesIO(final_image))
img.save("x.png")
img.show
I hope this will help a bit to understand my issue and maybe provide me some possible solution/advice. Thanks!
Instead of decoding the jpeg image, then sending the decoded bytes, just transmit the image bytes.
Save the .jpg image at the other end.
Yes, I tried in that way just to send jpeg_buffer immediately after SPI transfer is finished but then I got the weird byte array structure with some classic data such as 0x00 but also some weird \xff!Q\ (something like this). I am not able to find a way to decode such a data structure in Python on the other side. Is there any way to decode an image byte array in C using some other traditional methods?
As I mentioned before, you appear to have transmission errors. An error checking method is required for large data transfers.
Do you maybe know how can I implement it for the BLE transmission in order to remove some wrong bytes?
BLE is not designed or suitable for transfer of large amounts of data, especially images.
Choose another method of data transfer. TTL serial is fine, and if you get that working, you could try the SerialTransfer Arduino library.
I really need to use BLE as it is most power efficient comparing to other technologies that can be used for the image transfer. The image file that I am trying to send now is 3080 bytes, which I think is not too heavy to be sent via BLE, no? Once the application is flashed on the device, I will disconnect my device from USB and use some other external power sources so in that case BLE is my only solution. Maybe I can also try to see if the image is taken from the camera properly. Maybe there can also be some format that must be converted into string/byte array don't know and after that sent to the PC?
Utter nonsense. Wires are ORDERS of MAGNITUDE more efficient.
