Hey guys! I'm using an ArduCAM OV5642 hooked up to an Arduino Nano 33 BLE Sense for this project of mine and I am having a little bit of trouble with getting the images out of the module. Using the example sketches I can get the module and Arduino to interface with the host program but now I just want to have the Arduino spit the bytes of the JPEG image to the Serial monitor so I can use PySerial to read them. I tried reaching out to the ArduCAM forum but have yet to get a response yet so I was hoping someone here had an idea. Currently I have the Arduino spitting out bytes into the Serial starting from when it sees FF D8 (JPEG start) and stopping when it sees FF D9 (JPEG end) and have this small python script to write it to a file. It would be easier to just have the Arduino save the bytes to an SD card, but for my use case I won't be able to do that. Thank you in advance for any and all help!
// Modification of Example: ArduCAM_Mini_5MP_Plus_Multi_Capture2SD
#include "memorysaver.h"
#include <ArduCAM.h>
#include <SPI.h>
#include <Wire.h>
//This demo can only work on OV5640_MINI_5MP_PLUS or OV5642_MINI_5MP_PLUS platform.
#if !(defined(OV5640_MINI_5MP_PLUS) || defined(OV5642_MINI_5MP_PLUS))
#error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
#endif
#define FRAMES_NUM 0x00
// set pin 7 as the slave select for the digital port for ArduCam:
const int CS = 7;
#define BYTE_PACKET_SIZE 256
bool is_header = false;
int total_time = 0;
#if defined(OV5640_MINI_5MP_PLUS)
ArduCAM myCAM(OV5640, CS);
#else
ArduCAM myCAM(OV5642, CS);
#endif
uint8_t read_fifo_burst(ArduCAM myCAM);
void dump_buffer(byte buffer[], int index);
int add_to_buffer(byte buffer[], int index, byte elem);
uint8_t vid, pid;
uint8_t temp;
#if defined(__SAM3X8E__)
Wire1.begin();
#else
Wire.begin();
#endif
Serial.begin(921600);
Serial.println(F("ArduCAM Start!"));
// set the CS as an output:
pinMode(CS, OUTPUT);
digitalWrite(CS, HIGH);
// initialize SPI:
SPI.begin();
//Reset the CPLD
myCAM.write_reg(0x07, 0x80);
delay(100);
myCAM.write_reg(0x07, 0x00);
delay(100);
while (1) {
//Check if the ArduCAM SPI bus is OK
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
temp = myCAM.read_reg(ARDUCHIP_TEST1);
if (temp != 0x55) {
Serial.println(F("SPI interface Error!"));
continue;
Serial.println(F("SPI interface OK."));
while (1) {
//Check if the camera module type is OV5640
myCAM.rdSensorReg16_8(OV5640_CHIPID_HIGH, &vid);
myCAM.rdSensorReg16_8(OV5640_CHIPID_LOW, &pid);
if ((vid != 0x56) || (pid != 0x40)) {
Serial.println(F("Can't find OV5640 module!"));
continue;
Serial.println(F("OV5640 detected."));
#else
while (1) {
//Check if the camera module type is OV5642
myCAM.rdSensorReg16_8(OV5642_CHIPID_HIGH, &vid);
myCAM.rdSensorReg16_8(OV5642_CHIPID_LOW, &pid);
if ((vid != 0x56) || (pid != 0x42)) {
Serial.println(F("Can't find OV5642 module!"));
continue;
Serial.println(F("OV5642 detected."));
#endif
//Change to JPEG capture mode and initialize the OV5640 module
myCAM.set_format(JPEG);
myCAM.InitCAM();
myCAM.set_bit(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);
myCAM.clear_fifo_flag();
myCAM.write_reg(ARDUCHIP_FRAMES, FRAMES_NUM);
myCAM.flush_fifo();
myCAM.OV5640_set_JPEG_size(OV5640_2592x1944);
#else
myCAM.OV5642_set_JPEG_size(OV5642_320x240);
#endif
if (Serial.available() && Serial.read() == 65) {
//Start capture
myCAM.start_capture();
Serial.println(F("start capture."));
total_time = millis();
while (!myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK));
Serial.println(F("CAM Capture Done."));
total_time = millis() - total_time;
Serial.print(F("capture total_time used (in miliseconds):"));
Serial.println(total_time, DEC);
read_fifo_burst(myCAM);
Serial.print(F("save capture total_time used (in miliseconds):"));
//Clear the capture done flag
delay(5000);
Serial.println("Waiting for command (A to start capture)!");
uint8_t read_fifo_burst(ArduCAM myCAM) {
uint8_t currByte = 0;
uint8_t prevByte = 0;
uint32_t length = myCAM.read_fifo_length();
static int i = 0;
byte buffer[BYTE_PACKET_SIZE];
Serial.print("The FIFO length is: ");
Serial.println(length, DEC);
if (length >= MAX_FIFO_SIZE) {
Serial.println("Over size image.");
return 0;
} else if (length == 0) {
Serial.println("Empty image");
return 0;
Serial.println("Begin image processing");
myCAM.CS_LOW();
myCAM.set_fifo_burst();
while (length--) {
prevByte = currByte;
currByte = SPI.transfer(0x00);
Serial.println(currByte, HEX);
if ((currByte == 0xD9) && (prevByte == 0xFF)) {
// buffer[i++] = currByte;
i = add_to_buffer(buffer, i, currByte);
myCAM.CS_HIGH();
dump_buffer(buffer, i);
Serial.println("End read");
is_header = false;
myCAM.CS_LOW();
i = 0;
myCAM.CS_HIGH();
return 1;
} else if ((currByte == 0xD8) && (prevByte == 0xFF)) {
Serial.println("Found header");
is_header = true;
myCAM.CS_HIGH();
myCAM.CS_LOW();
// buffer[i++] = prevByte;
i = add_to_buffer(buffer, i, prevByte);
} else if (is_header) {
myCAM.CS_HIGH();
myCAM.CS_LOW();
return 0;
void dump_buffer(byte buffer[], int index) {
for (int i = 0; i < index; i++) {
Serial.println(buffer[i], HEX);
int add_to_buffer(byte buffer[], int index, byte elem) {
if (index < BYTE_PACKET_SIZE) {
buffer[index] = elem;
return index + 1;
dump_buffer(buffer, BYTE_PACKET_SIZE);
buffer[0] = elem;
return 1;
import serial
from binascii import unhexlify
arduino = serial.Serial(port='COM4', baudrate=921600)
doCapture = False
while not doCapture:
doCapture = input("Start capture? ") == "A"
buffer = []
arduino.write(bytes("A", 'utf-8'))
prevByte = b""
currByte = b""
line = arduino.readline().strip()
while True:
if (b"length" in line):
print(line)
if len(line) == 1:
currByte = unhexlify(b'0' + line)
if (prevByte == b"\xff" and currByte == b"\xd8"):
buffer = [b"\xff", b"\xd8"]
print("found a new start")
else:
buffer.append(currByte)
if len(line) == 2:
currByte = unhexlify(line)
else:
if line == b"End read" or (prevByte == b"\xff" and currByte == b"\xd9"):
break
prevByte = currByte
data = b"".join(buffer)
print(data)
with open("/path/to/image/test.jpg", "wb") as f:
f.write(data)
arduino.close()
