I want to set a callback member function that could return any printable type, not only String or char[]. How can I do that?
#include <List.hpp>
* @brief Class that extends the LiquidCrystal_I2C library to add some features such as message queueing and scrolling.
class LCD_I2C_Extended : public LiquidCrystal_I2C {
public:
List<String (*)()> getCallbacks() {return _callbacks;};
// Would like to have something more generic such as Print
void addCallback(String (*callback)()) {
_callbacks.add(callback);
private:
// HOW TO GET callbacks with return type that are printables such as String, char*, int, ...
List<String (*)()> _callbacks;
#endif
I've tried with Printables, but without success.
Thanks for any help!
Juraj
April 18, 2023, 1:44pm
3
could you show us some example how do you want to use it?
Something around this.
#include "LCD_I2C_Extended.h"
LCD_I2C_Extended lcd (0x27, 16, 2);
String testCallbacks() {
return "Potatoes!";
lcd.init();
lcd.addCallback(testCallbacks);
lcd.upate();
The goal is to create an LCD that is going to scroll through messages at a given interval. These messages are returned by functions.
Juraj
April 18, 2023, 2:04pm
5
remove the * from String (*)()
I need the * because it's a function pointer. The list will contains function pointers to call.
Like I said, I would like to have some callbacks more generic than "String". I though there was a generic printable type.
return "Potatoes!";
String testCallbacks2() {
return "Apple!";
//lcd.init();
lcd.addCallback(testCallbacks2);
lcd.update();
Class
#ifndef LCD_I2C_EXTENDED_H
#define LCD_I2C_EXTENDED_H
#include "Printable.h"
#include <Arduino.h>
#include <Wire.h>
#include <List.hpp>
public:
LCD_I2C_Extended (uint8_t lcd_Addr,uint8_t lcd_cols,uint8_t lcd_rows) : LiquidCrystal_I2C(lcd_Addr, lcd_cols,lcd_rows) {};
void setMessageInterval(int interval) {_interval = interval ;};
void update();
void addCallback(String (* callback)()) {
private:
unsigned int _interval = 3000;
unsigned long currentTime = 0;
int _currentIdx = 0;
// List of callbacks that returns String
void LCD_I2C_Extended::update(){
static unsigned long lastTime = 0;
currentTime = millis();
if (currentTime - lastTime < _interval) return;
if (_callbacks.isEmpty()) return;
lastTime = currentTime;
Serial.print(_callbacks.getValue(_currentIdx++)());
_currentIdx = _currentIdx > _callbacks.getSize() - 1 ? 0 : _currentIdx;
#endif
westfw
April 18, 2023, 4:39pm
9
I don't believe that this is possible. C++ polymorphism is a compile-time feature, and values do not include type information at run-time.
(I mean, you can CREATE objects that potentially include a "print" method, and have a higher-level printer that invokes those methods, but that's not how the Arduino print functions work.)
Inheriting from Printable allows a class to print itself via the Print class. So if you make your callbacks classes that inherit from Printable :
class Callback : public Printable {
public:
virtual size_t printTo(Print &p) const = 0;
class StringCallback : public Callback {
public:
virtual size_t printTo(Print &p) const {
return p.println("Potatoes");
class NumberCallback : public Callback {
public:
return p.println(number, 5);
private:
float number = 3.14159;
delay(2000);
StringCallback cb1;
NumberCallback cb2;
Callback *callbacks[] = {&cb1, &cb2};
Serial.print(*callbacks[0]);
Serial.print(*callbacks[1]);
Output:
Potatoes
3.14159
westfw
April 18, 2023, 6:49pm
11
I hadn't noticed Printable.h before! Neat.
However:
[want to print] any printable type, not only String or char[].
Printable.h says:
The Printable class provides a way for new classes to allow themselves to be printed.
The "new classes" is significant. In order for something to be "Printable", it has to be a class, and it has to have inherited from the Printable class, and defined a printTo() method. Basic types like int or char[] are not printable (and a bit strangely, Arduino's "String" type doesn't seem to be Printable, either.)
The Print class already knows how to print those types. The purpose of the Printable class is to allow the Print class to print custom types (classes & structs) by having the type itself implement printTo(). The class then "prints itself" anyway it wants using the Print class reference that's passed in.
I guess the Print class with printTo() is similar to public override string ToString(){/**/} in C#.
Juraj
April 19, 2023, 4:52am
14
class IPAddress is Printable
hamarn
April 19, 2023, 9:52am
15
I added the "unsigned long" type to your code for reference.
Click here: Wokwi Simulattion
return "Potatoes!";
return "Apple!";
unsigned long testCallbacks3() {
return -1;
//lcd.init();
lcd.addCallback(testCallbacks3);
lcd.update();
Class:
#include <Wire.h>
#include <List.hpp>
public:
LCD_I2C_Extended (uint8_t lcd_Addr, uint8_t lcd_cols, uint8_t lcd_rows) : LiquidCrystal_I2C(lcd_Addr, lcd_cols, lcd_rows) {};
void update();
return _callbacks;
void addCallback(unsigned long (* callback)()) {
_ulCallbacks.add(callback);
private:
int _currentULIdx = 0;
int _typeIdx = 0;
List<unsigned long (*)()> _ulCallbacks;
void LCD_I2C_Extended::update() {
switch (_typeIdx) {
case 0:
Serial.println(_callbacks.getValue(_currentIdx++)());
if (_currentIdx > _callbacks.getSize() - 1) {
_currentIdx = 0;
_typeIdx++;
case 1:
if (_ulCallbacks.isEmpty()) return;
Serial.println(_ulCallbacks.getValue(_currentULIdx++)());
if (_currentULIdx > _ulCallbacks.getSize() - 1) {
_currentULIdx = 0;
_typeIdx = (_typeIdx + 1) % 2; // Max Type = 2;
#endif
You can also return a variant type. C++17 has std::variant, but I don't think most Arduino packages have that version. But, you can roll your own. I wrote this code for a somewhat related forum question:
class BaseClass {
public:
class VariantType {
public:
enum DataType {NO_TYPE, U32_TYPE, I32_TYPE, FLOAT_TYPE, STRING_TYPE};
VariantType(): dataType(NO_TYPE) {
VariantType(uint32_t u) : dataType(U32_TYPE), u32(u) {
VariantType(int32_t i) : dataType(I32_TYPE), i32(i) {
VariantType(float f) : dataType(FLOAT_TYPE), fl(f) {
VariantType(const String s) : dataType(STRING_TYPE), str(new String(s)) {
VariantType(const VariantType &rhs) {
copyMove(const_cast<VariantType &>(rhs));
VariantType(VariantType &&rhs) {
copyMove(rhs, true);
VariantType &operator=(const VariantType &rhs) {
if (dataType == STRING_TYPE) {
delete str;
return *this;
VariantType &operator=(VariantType &&rhs) {
delete str;
return *this;
~VariantType() {
delete str;
DataType getType() const {
return dataType;
uint32_t getU32() const {
return u32;
int32_t getI32() const {
return i32;
float getFloat() const {
return fl;
const String &getString() const {
return *str;
private:
DataType dataType;
union {
uint32_t u32;
int32_t i32;
float fl;
String *str;
void copyMove(VariantType &other, bool move = false) {
dataType = other.dataType;
if (move) {
other.dataType = NO_TYPE;
switch (dataType) {
case U32_TYPE:
u32 = other.u32;
case I32_TYPE:
i32 = other.i32;
case FLOAT_TYPE:
fl = other.fl;
case STRING_TYPE:
if (move) {
str = other.str;
other.str = nullptr;
str = new String(*other.str);
default:
virtual VariantType getValue() const = 0;
template<class T>
class TemplateDerived : public BaseClass {
public:
TemplateDerived(const T &v): value(v) {
virtual VariantType getValue() const override {
VariantType variant {value};
return variant;
private:
T value;
BaseClass *baseArray[] = {
new TemplateDerived<uint32_t>(1000),
new TemplateDerived<int32_t>(-5000),
new TemplateDerived<float>(3.14159),
new TemplateDerived<String>("Hello World")
for (auto p : baseArray) {
BaseClass::VariantType variant = p->getValue();
switch (variant.getType()) {
case BaseClass::VariantType::U32_TYPE:
Serial.println(variant.getU32());
case BaseClass::VariantType::I32_TYPE:
Serial.println(variant.getI32());
case BaseClass::VariantType::FLOAT_TYPE:
Serial.println(variant.getFloat(), 5);
case BaseClass::VariantType::STRING_TYPE:
Serial.println(variant.getString());
default:
