How to design 64x32 LED Matrix?
I plan to design a 64x32 RGB LED Matrix and need some guidance from experts here...
  1. Project has to be extremely light-weight.
  2. Circuitry should be small size (excluding the Matrix)
  3. What Multiplexers, shift registers OR PWM I should be using.
  4. Should be cost effective but do not not want to compromise on size.
  5. Input Voltage <= 5V (as low as possible).
List of components would be great :slight_smile:
Forgot to mention that each of RGB LED needs around 20mA.
Hi amudliar and welcome.
Your requirements will not be easy, especially for a beginner!
What level of colour control do you need?
Have you looked for comercially available panels?
How about 2 of these? 32x32 RGB LED Matrix Panel - 4mm Pitch : ID 607 : $29.95 : Adafruit Industries, Unique & fun DIY electronics and kits
Paul
64x32 RGB is really 64x96, or 192x32, depending on how you arrange it, with either 3 anodes or 3 cathodes at every position.
I think I would go with 192X32, with common cathode RGB LEDs.
Use 192 anode drivers coming from 24 parts like cd74ac164, and some decent N-channel MOSFETs controlled by 4 shift registers for the cathodes. 192 * .02A = 3.84A, so you definitely want low Rds parts. Maybe even break the cathode drive section into halves.
Power dissipated in the part determines how hot it will run. P=IV, V=IR, subbing in you get P= IIR.
This one has .005ohm Rds, so would dissipate 3.843.84.005 = 73mW
With 32 columns, 24 Hz refresh rate, can leave each column on for 1/24/32 = 1300microseconds.
Use SPI.transfer to send data from arrays to the anode shift registers and cathode shift registers for fast updates and maximum on time per column.
PaulRB:
How about 2 of these? 32x32 RGB LED Matrix Panel - 4mm Pitch : ID 607 : Adafruit Industries, Unique & fun DIY electronics and kits
Thanks @Paul. I plan to build it on my own using either 5050 or 3528 SMDs.
Paul
CrossRoads:
AOI516 Alpha & Omega Semiconductor Inc. | Discrete Semiconductor Products | DigiKey
Thanks @CrossRoads. I have started looking into your recommended approach.
CrossRoads:
Started working on this and got few questions
  1. What difference it will make if I do Common Anode?
  2. In your above approach you are recommending how many MOSFETS? 32 I believe using 4 shift registers (Cathode connected)
  3. In the image attached (thank you!) I see you connected 6 pins to 2 LEDs (3 pins of each RGB LED) and since I need 64 LEDs. Does that mean I will need 32 shift register just to connect Anodes?
  4. What do you mean by 24 parts above?
  5. Is there a way I can minimize amount of components by replacing with ICs or something?
Building a 192x32 matrix is no easy task, consider other options first, eg:
(just some WS2811 LED strips fixed to a board, can be built in half a day)
  1. With common anode, you need P-channel MOSFETs to source current, and parts like TPIC6B595 to sink current.
  2. 32, yes.
  3. 192/8 = 24 shift registers
  4. 24 shift registers
  5. Replace resistors with multi-resistor packs. See Isolated Resistor pack as an example
    http://www.bourns.com/data/global/PDFs/4100R.pdf
    4116R-1-221LF Bourns Inc. | Resistors | DigiKey
Or, use strings as suggested, skip the multiplexing and send out (64x32)x(3 bytes/LED minimum) bytes of data to update the display using parts like WS2812, an integrated RGD LED/control chip.
WS2812.pdf (272 KB)
You could try designing it is segments, using 8 Atmegas to drive 4 8x8 led matrices each, and linking them together with SPI.
Probably not the cheapest option, but easily scale-able up to any size, up to 127 modules (but that would take tons of power)
