system
January 4, 2013, 1:49pm
1
I am planning to use teensy uart for LIN recepition but I have not seen any good examples how to detect 13 bit long serial break. Should I use uart and wait until 0x00 is received or should I use pinmode and count bit low times with delays?
Regards,
Jaanus
cmiyc
January 4, 2013, 2:07pm
2
Hi James!
Do you know how the code in the link works? There are some parts of the code that i don't understand and could really use some help!
I tried a few thing and found that this worked out alright for me to detect a serial break on the hardware serial
#include <TimerOne.h>
volatile unsigned long tmr1,baud1;
volatile uint8_t n;
void timeout_1(){
Timer1.StopTimer();
if(digitalRead(0)==HIGH){
Serial.begin(baud1);
Serial.println("Data Byte"+String(n));
else{
Serial.println("Serial Break"+String(n));
baud1=9600;
pinMode(0,INPUT);
tmr1 = 500000/baud1; //timer1 period in microseconds
Serial.println("READY!");
if(Serial.available()) {
n = Serial.read();
Serial.end();
Timer1.EnableTimerInterrupt(timeout_1,tmr1); //set timer interrupt(period=1/(2*Baud)). Call 'timeout_1' on interrupt
