HOW TO DISPLAY DELAY IN SERIAL MONITOR?
can anyone help me?
this is my code
how can i display delay in serial monitor.
serial.print(delay) // its like this but i know this is not the code
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
void loop(){
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(ledPin, HIGH);
Serial.println("PLEASE WAIT WHILE REFUELING");
Serial.print('\n');
delay(9000);
digitalWrite(ledPin, LOW); // turn the LED off by making the voltage LOW
Serial.println("price 40");
Serial.print('\n');
Serial.print('\n');
Serial.println("liters 1");
else {
// turn LED off:
please repz.... :blush:
Welcome to the Forum. Please read the two posts by Nick gammon at the top of this Forum for guidelines on making a post, especially the use of code tags when posting code. It will help us help you.
araneil16:
delay() means 'stop program execution at once, wait until time is over, then continue'.
What do you really want?
Something that looks like a 'progress bar' in the serial monitor to visualize the waiting time?
void loop(){
    // turn LED on:
    Serial.print('\n');
    for(int i=0;i<90;i++) Serial.print('.'); // print empty 'progress bar' of length
    for(int i=0;i<90;i++)  // then print real 'progress bar' with delay up to the length
     delay(100);
     Serial.print('*');
    Serial.print('\n');
    Serial.print('\n');
  else {
    // turn LED off:
araneil16:
That is not the code for two reasons:
It's "Serial", not "serial". Case matters.
You left off the ';' at the end of the statement.
Why do you want to print the value of a function pointer?
You'll have to cast it to a plain numeric type, like "unsigned int"
By the way, a thread bump after nine minutes is a little . . . needy.
