How to divide 48 equal parts on a circle ?
Hi all.
The code:
 // Draw 12 lines
  for(int i = 0; i<360; i+= 30) {
    sx = cos((i-90)*0.0174532925);
    sy = sin((i-90)*0.0174532925);
    x0 = sx*114+120;
    yy0 = sy*114+120;
    x1 = sx*100+120;
    yy1 = sy*100+120;
    tft.drawLine(x0, yy0, x1, yy1, TFT_GREEN);
draw 12 lines on circle of clock.
how to get 48 equal parts lines on a circle? the interval will be 7.5 degree.
Thanks
Adam
 An example analogue clock using a TFT LCD screen to show the time
 use of some of the drawing commands with the library.
 For a more accurate clock, it would be better to use the RTClib library.
 But this is just a demo.
 This sketch uses font 4 only.
 Make sure all the display driver and pin connections are correct by
 editing the User_Setup.h file in the TFT_eSPI library folder.
 ###### DON'T FORGET TO UPDATE THE User_Setup.h FILE IN THE LIBRARY ######
 Based on a sketch by Gilchrist 6/2/2014 1.0
#include <SPI.h>
#include <TFT_eSPI.h> // Hardware-specific library
#define TFT_GREY 0x5AEB
TFT_eSPI tft = TFT_eSPI();       // Invoke custom library
float sx = 0, sy = 1, mx = 1, my = 0, hx = -1, hy = 0;    // Saved H, M, S x & y multipliers
float sdeg=0, mdeg=0, hdeg=0;
uint16_t osx=120, osy=120, omx=120, omy=120, ohx=120, ohy=120;  // Saved H, M, S x & y coords
uint16_t x0=0, x1=0, yy0=0, yy1=0;
uint32_t targetTime = 0;                    // for next 1 second timeout
static uint8_t conv2d(const char* p); // Forward declaration needed for IDE 1.6.x
uint8_t hh=conv2d(__TIME__), mm=conv2d(__TIME__+3), ss=conv2d(__TIME__+6);  // Get H, M, S from compile time
bool initial = 1;
void setup(void) {
  tft.init();
  tft.setRotation(0);
  //tft.fillScreen(TFT_BLACK);
  //tft.fillScreen(TFT_RED);
  //tft.fillScreen(TFT_GREEN);
  //tft.fillScreen(TFT_BLUE);
  tft.fillScreen(TFT_GREY);
  tft.setTextColor(TFT_WHITE, TFT_GREY);  // Adding a background colour erases previous text automatically
  // Draw clock face
  tft.fillCircle(120, 120, 118, TFT_GREEN);
  tft.fillCircle(120, 120, 110, TFT_BLACK);
  // Draw 12 lines
    x0 = sx*114+120;
    yy0 = sy*114+120;
    x1 = sx*100+120;
    yy1 = sy*100+120;
  // Draw 60 dots
  for(int i = 0; i<360; i+= 6) {
    x0 = sx*102+120;
    yy0 = sy*102+120;
    // Draw minute markers
    tft.drawPixel(x0, yy0, TFT_WHITE);
    // Draw main quadrant dots
    if(i==0 || i==180) tft.fillCircle(x0, yy0, 2, TFT_WHITE);
    if(i==90 || i==270) tft.fillCircle(x0, yy0, 2, TFT_WHITE);
  tft.fillCircle(120, 121, 3, TFT_WHITE);
  // Draw text at position 120,260 using fonts 4
  // Only font numbers 2,4,6,7 are valid. Font 6 only contains characters [space] 0 1 2 3 4 5 6 7 8 9 : . - a p m
  // Font 7 is a 7 segment font and only contains characters [space] 0 1 2 3 4 5 6 7 8 9 : .
  tft.drawCentreString("Time flies",120,260,4);
  targetTime = millis() + 1000;
  if (targetTime < millis()) {
    targetTime += 1000;
    ss++;              // Advance second
    if (ss==60) {
      ss=0;
      mm++;            // Advance minute
      if(mm>59) {
        mm=0;
        hh++;          // Advance hour
        if (hh>23) {
          hh=0;
    // Pre-compute hand degrees, x & y coords for a fast screen update
    sdeg = ss*6;                  // 0-59 -> 0-354
    mdeg = mm*6+sdeg*0.01666667;  // 0-59 -> 0-360 - includes seconds
    hdeg = hh*30+mdeg*0.0833333;  // 0-11 -> 0-360 - includes minutes and seconds
    hx = cos((hdeg-90)*0.0174532925);
    hy = sin((hdeg-90)*0.0174532925);
    mx = cos((mdeg-90)*0.0174532925);
    my = sin((mdeg-90)*0.0174532925);
    sx = cos((sdeg-90)*0.0174532925);
    sy = sin((sdeg-90)*0.0174532925);
    if (ss==0 || initial) {
      initial = 0;
      // Erase hour and minute hand positions every minute
      tft.drawLine(ohx, ohy, 120, 121, TFT_BLACK);
      ohx = hx*62+121;
      ohy = hy*62+121;
      tft.drawLine(omx, omy, 120, 121, TFT_BLACK);
      omx = mx*84+120;
      omy = my*84+121;
      // Redraw new hand positions, hour and minute hands not erased here to avoid flicker
      tft.drawLine(osx, osy, 120, 121, TFT_BLACK);
      osx = sx*90+121;
      osy = sy*90+121;
      tft.drawLine(osx, osy, 120, 121, TFT_RED);
      tft.drawLine(ohx, ohy, 120, 121, TFT_WHITE);
      tft.drawLine(omx, omy, 120, 121, TFT_WHITE);
    tft.fillCircle(120, 121, 3, TFT_RED);
static uint8_t conv2d(const char* p) {
  uint8_t v = 0;
  if ('0' <= *p && *p <= '9')
    v = *p - '0';
  return 10 * v + *++p - '0';
Hello shanren
Keep in mind the trigonometry is using radians.
Take a view here to gain the knowledge:
Great!
Thank you.
Use polar coordinates
If r is the radius you want from the center of the clock and a the CCW angle with horizontal axis going through the center of the clock (so from 0 to 352.5 in 7.5° increments but in radians), then you can use
X = r cos(a)
Y = r sin(a)
Thank you.
#define N   48
#define Rad 20
#define X0  30
#define Y0  30
char t [20];
char u [20];
char v [20];
char w [80];
void setup ()
    Serial.begin (9600);
    for (float ang = 0; ang < 360; ang += 360.0 / N) {
        float x = X0 + Rad * cos(ang * PI / 180);
        float y = Y0 + Rad * sin(ang * PI / 180);
        dtostrf (ang, 6, 2, t);
        dtostrf (x, 6, 2, u);
        dtostrf (y, 6, 2, v);
        sprintf (w, " %s %s %s", u, v, t);
        Serial.println (w);
void loop ()
  50.00  30.00   0.00
  49.83  32.61   7.50
  49.32  35.18  15.00
  48.48  37.65  22.50
  47.32  40.00  30.00
  45.87  42.18  37.50
  44.14  44.14  45.00
  42.18  45.87  52.50
  40.00  47.32  60.00
  37.65  48.48  67.50
  35.18  49.32  75.00
  32.61  49.83  82.50
  30.00  50.00  90.00
  27.39  49.83  97.50
  24.82  49.32 105.00
  22.35  48.48 112.50
  20.00  47.32 120.00
  17.82  45.87 127.50
  15.86  44.14 135.00
  14.13  42.18 142.50
  12.68  40.00 150.00
  11.52  37.65 157.50
  10.68  35.18 165.00
  10.17  32.61 172.50
  10.00  30.00 180.00
  10.17  27.39 187.50
  10.68  24.82 195.00
  11.52  22.35 202.50
  12.68  20.00 210.00
  14.13  17.82 217.50
  15.86  15.86 225.00
  17.82  14.13 232.50
  20.00  12.68 240.00
  22.35  11.52 247.50
  24.82  10.68 255.00
  27.39  10.17 262.50
  30.00  10.00 270.00
  32.61  10.17 277.50
  35.18  10.68 285.00
  37.65  11.52 292.50
  40.00  12.68 300.00
  42.18  14.13 307.50
  44.14  15.86 315.00
  45.87  17.82 322.50
  47.32  20.00 330.00
  48.48  22.35 337.50
  49.32  24.82 345.00
  49.83  27.39 352.50
Thanks for all.
