How to drive 80 RGB Leds separately?
Hallo everyone,
my question is: how can i control 80 rgb leds separately with my arduino uno deveice? I already know that i need some kind of shift register, but i'm not sure about the wiring. And an additional problem is the limitation of the pwm channels (arduino uno does only have 6 of them). Is it possible to realize? Do I need arduino mega in this case?
Thank you
Here is a project very close to yours:
Thank you for quick reply. To be honest the project is close to my. thats true. But in your link there is a ready platform which you can solder and programm on your own.
At the page you gave there was a link about the how to make it -> Page 9
Uptown:
http://s3.amazonaws.com/evilmadscience/KitInstrux/MeggyJrInstrux_Sm.pdf
As far as i understood they use 3 x Atmega 168 microcontroller
I just need a kind of shift register ( without additional parts ) for the huge number of rgb leds (80 and more). if somebody has an idea how to do this with only one microcontroller (using only Arduino uno as a master with a lot of slaves --> shift registers), a scheme maybe?
No, they use the STP16DP05B1R LED drivers (and one ATmega168).
http://arduino.cc/playground/Main/InterfacingWithHardware#LED
To Florinc
I would keep the hardware as simple as possible. In my case i need to drive 80 pins for the red, green and blue color. That are 240 leds total.
So I have to wire this chip 6 times behind each other only to control the red color. right?
scheme
| Arduino |
| |(PWM channel)--> to 16 bit chip ->to 16 bit chip ->to 16 bit chip ->to 16 bit chip ->to 16 bit chip ->to 16 bit chip -> control of 80 red leds
Does it works with pwm?
To Magician
thank you Magician for the link. There are a lot of solution. But I'm not genius I doubt about the wiring of al those 240 separate leds. In your link there is a one interesting method of controlling, using a TLC5940, a 16 bit chip. could I solve my problem by attaching this chip six time behind each other to provide a single channel for every led? and this for red green an blue?
Assuming a 5 (rows) x16 (columns) RGB LED matrix, you can use 3 chained 16-bit shift registers for columns and 5 transistors for the rows.
This is the schematic for Meggy Jr RGB:
Does it works with pwn?
Yes.
florinc:
is it fast enough to renew approx. 25 times a second (25 Hertz)?
have you a wiring scheme? its a bit difficult to realize your suggest. thanks a lot!!!
Yes.
ClockTHREE (Wise time with Arduino: ClockTHREE v2) was built based on the same schematic, and it has 16x10 RGB LEDs.
that is close to my idea. The negative aspect is, it's a board.
Let me explain what I thought about. I though 16 rgb led build the first circle, then there come the next 16 leds. this creates 5 circles á 16 leds
https://docs.google.com/open?id=0B4lnJ_IJ9FMNc0Z1NHVLQU9mMTQ
so in this case i can't use a ready made shield, do you know how can i wire it?
You can still wire the RGB LEDs in an array of 5x16, but arrange them physically in circles.
in case I will do it on my own: Just correct me if i understood it right.
i connect to some pins of arduino a 16- bit-chip and to some other a 8-bit-chip ( but i use only 5 of 8 outputs). this lead to a 16 x 8 matrix (controlled by using I2C or SPI). right?
what i didn't understand is how can I control each color in my matrix, please explain.
p.s. in your link there is no concrete sketch about the wiring
There is one more link in my favorite: LED Cylinder Schematic, instructions, even PCB!
"magician " thanks this is good
You are welcome. I like it too, keep in bookmarks for a year. :slight_smile:
thanks all who paid attention till now for my little project.
I thought a lot about it and I had an interesting idea.
I create a 16x16 matrix (by using a 4 x 8-bit chips 74HC595). 80 channels I use for each color, so totaly use 240 of 256 channels. I hope this should keep my project simple and clear to overview.
Is it possible?
I'm also doubting how can I communicate with all them at same time.
At this page
I found the way of connecting, see picture, but there is only place for the one spi device.
how can I manage it?
could be this the solution to my problem ?
https://docs.google.com/open?id=0B4lnJ_IJ9FMNRndkWjExTVFlUUE (Arduino cook book )
Is it possible?
No, multiplexing with such high (16) ratio would make brightness of display really low. And you can't multiplex RGB led's in this manner, as there is only 1 common pin (anode or cathode) for 3 colors, so ratio 1:3 should be observed.
80 : 3, as it was advised somewhere in the beginning of this topic, IMHO, the optimal value between soldering/wiring workload and brightness.
10 IC 74HC595 plus three transistors.
I just finished my new (toy) project with 9 74HC595, only I have smaller number of leds - 24 strips, there is no multiplexing for color, just 1 linear array so I get maximum brightness level from leds. Video clips still uploading to youtube.
http://coolarduino.wordpress.com/2012/06/21/tears-of-rainbow/
Magician could you explain me the ratio and brightness you refered to in your post.
You also spoke about
How should I image / realize this?
When you organize LED in matrix configuration ( to save on hardware/ and assembly time), you "lighting-up" one column of matrix at a time. Periodically "scanning" every column, (refresh rate ~60 Hz) all LED's will have a chance to lights-up. But there is nothing for free, as "lighting" time of each column getting shorter T = 1 / N, where N number of column, brightness goes down directly proportional to this coefficient.
To fix it you can "bump-up" current inside time-slot, but there is a limits, pulse current to DC ratio can't be more than ~5-8
edited: after searching on google , ~ 2-3
, and even less for high power leds. So matrix size couldn't be extended above 8 w/o noticeable losses in brightness level.
Quote
You connecting all LEDs common pins to 74HC595 pins, 10 IC = 8 x 10 = 80 pins.
All red pin connected together and goes to transistor. Same with green and blue.
In software you selecting "color" than outputing "brightness" train for all 80 LEDs. There would be 3 time slot, so you better to "bump-up " a current x3 times to get full luminosity of display.
I missed resistors, common anodes/cathodes, PNP/NPN etc as it all depents on part number you select for LED
