I have a metal case that I plan to use to house some stuff; an Arduino, a Raspberry Pi, a few power cables with adapters and such.
How should I fix the Uno to the back of the plate of the case? I know it has 4 holes for mounting but should I put something between the Arduino and the metal case back?
There are various spacers or [u]standoffs[/u] that are commonly used. Some kind of plastic hardware is "safer" than metal because you won't accidently short something out.
Commercial products usually have threaded metal standoffs swaged (pressed) into the metal box but that takes an arbor press with the correct tooling.
Several years ago when I was going-through a "lazy phase" I was super-gluing 4 "cubes" of cut [u]foam weather stripping[/u] between the case and a perfboard. (I glued it where there was no circuitry.) It's easy, fast, and cheap, and it "worked perfectly and permanently" (I never had a board fall off) but it's kind-of "Mickey Mouse"...
i was trying out some nylon standoffs I have and was able to get 3 of them in, but the 4th one, near the reset button I couldnt get the nut in because it overlaps the last pin and the ICSP pins. But I get the gist of it.
So I could get the same size screws for both so long as theyre 3.175mm, right? I mean I know the math is there, but Im wondering if I could expect any noticeable wobble? I dont have any 2.5mm screws, Ill go get some tomorrow, but if I could get the same size for both devices Id go ahead and do that.
I do not do 3D printing and don't know anyone who does. So I shop on Shapeways. I have a similar requirement for a project I am working on, and I found this mount for the Uno that will work for my project:
I bought a pile of these to have on hand. Cheap, and generally sticky enough if you don't keep pulling it off and sticking it somewhere else. Available in different heights. Fits 3mm holes.
