Hi! I'm a beginner at using arduino and I'm trying to make an energy consumption meter that would transmit data via wifi to ThingSpeak, but can't seem to get proper results in the serial monitor. What would seem to be the problem?
I am using an NodeMCU v1.0 (ESP12E-Module) with a CH340 chip and a PZEM-004T 100A v3.0
Any replies would be appreciated!
Here is my code:
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <PZEM004Tv30.h>
PZEM004Tv30 pzem(Serial, 14, 12);
const char *ssid = "SSID";
const char *password = "PASSWORD";
const char *myWriteAPIKey = "";
WiFiClient client;
unsigned long lastTime = 0;
unsigned long timerDelay = 5000;
pzem.resetEnergy();
WiFi.begin(ssid, password);
Serial.println("");
Serial.print("Connecting");
delay(5000);
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println(WiFi.localIP()); //IP address assigned to your ESP
Serial.print("Custom Address:");
Serial.println(pzem.readAddress(), HEX);
// Read the data from the sensor
float voltage = pzem.voltage();
float current = pzem.current();
float power = pzem.power();
float energy = pzem.energy();
float frequency = pzem.frequency();
float pf = pzem.pf();
// Check if the data is valid
if (isnan(voltage)) {
Serial.println("Error reading voltage");
} else if (isnan(current)) {
Serial.println("Error reading current");
} else if (isnan(power)) {
Serial.println("Error reading power");
} else if (isnan(energy)) {
Serial.println("Error reading energy");
} else if (isnan(frequency)) {
Serial.println("Error reading frequency");
} else if (isnan(pf)) {
Serial.println("Error reading power factor");
// Print the values to the Serial console
Serial.print("Voltage: ");
Serial.print(voltage);
Serial.println("V");
Serial.print("Current: ");
Serial.print(current);
Serial.println("A");
Serial.print("Power: ");
Serial.print(power);
Serial.println("W");
Serial.print("Energy: ");
Serial.print(energy, 3);
Serial.println("kWh");
Serial.print("Frequency: ");
Serial.print(frequency, 1);
Serial.println("Hz");
Serial.print("PF: ");
Serial.println(pf);
delay(5000); //Post Data at every 5 seconds
Here is what is appearing on the serial monitor:
