How to fix no matching function for call to 'Button::Button(const int8_t arduino
here is the code I used for the Trash separator project and when I compile it the error message is
{ no matching function for call to 'Button::Button(const uint8_t&)' }
and the error is at line (10)
THE CODE
// Include Libraries
#include "Arduino.h"
#include "Button.h"
// Pin Definitions
#define REFLECTIVEIR_PIN_COLL A3
#define REFLECTIVEIR_PIN_COLL_M A5}
// object initialization
Button ReflectiveIR(REFLECTIVEIR_PIN_COLL);
Button ReflectiveIR_M(REFLECTIVEIR_PIN_COLL_M);
// define vars for testing menu
const int timeout = 10000; //define timeout of 10 sec
char menuOption = 0;
long time0;
#include <Servo.h>
#define redpin 5
#define bluepin 6
#define greenpin 7
#define redpin_M 8
#define bluepin_M 9
#define greenpin_M 10
int plasticsensor=A0;
int anothersensor=A2;
int metalsensor=A4;
int metalsensor_M=A6;
Servo myservo; // create servo object to control a servo
Servo myservo_M; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 165; // variable to store the servo position
int pos_M = 158; // variable to store the servo position
myservo.attach(11); // attaches the servo on pin 9 to the servo object
myservo_M.attach(12); // attaches the servo on pin 9 to the servo object
pinMode(redpin,OUTPUT);
pinMode(bluepin,OUTPUT);
pinMode(greenpin,OUTPUT);
//metal sensor
pinMode(redpin_M,OUTPUT);
pinMode(bluepin_M,OUTPUT);
pinMode(greenpin_M,OUTPUT);
pinMode(plasticsensor,INPUT_PULLUP);
pinMode(metalsensor,INPUT_PULLUP);
pinMode(anothersensor,INPUT_PULLUP);
pinMode(metalsensor_M,INPUT_PULLUP);
analogWrite(redpin,255);
analogWrite(bluepin,0255);
analogWrite(greenpin,255);
analogWrite(redpin_M,255);
analogWrite(bluepin_M,0255);
analogWrite(greenpin_M,255);
ReflectiveIR.init();
ReflectiveIR_M.init();
int sensor_read=digitalRead(plasticsensor);
int sensor_read_m=digitalRead(metalsensor);
int sensor_read_mm=digitalRead(metalsensor_M);
Serial.println("plastic sensor");
Serial.println(sensor_read);
Serial.println("metal sensor");
Serial.println(sensor_read_m);
Serial.println(sensor_read_mm);
bool ReflectiveIR_Val = ReflectiveIR.read();
bool ReflectiveIR_Val_M = ReflectiveIR_M.read();
//Plastic bin
if((sensor_read==0)&&(sensor_read_m!=1)){
for (pos = 160; pos >= 90; pos -= 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(1); // waits 15ms for the servo to reach the position
analogWrite(bluepin,0);
delay(2500);
for (pos = 90; pos <= 160; pos += 1) { // goes from 180 degrees to 0 degrees
 analogWrite(redpin,0);
  analogWrite(greenpin,0);
else if(ReflectiveIR_Val==1){ //checking the volume of the trash
analogWrite(bluepin,255);
else{
//metal sensor
  if(sensor_read_mm==1){
for (pos_M = 160; pos_M >= 90; pos_M -= 1) { // goes from 0 degrees to 180 degrees
myservo_M.write(pos_M); // tell servo to go to position in variable 'pos'
analogWrite(bluepin_M,0);
delay(2500);
for (pos_M = 90; pos_M <= 160; pos_M += 1) { // goes from 180 degrees to 0 degrees
  analogWrite(redpin_M,0);
analogWrite(greenpin_M,0);
else if(ReflectiveIR_Val_M==1){
analogWrite(bluepin_M,255);
else{
Try removing the } at the end of this line.
Still got the same error
https://dreamyage.blogspot.com/2019/08/arduino-trash-separation-project.html
Is this the sketch you are trying to compile? If you change the .init() lines to .begin() the code compiles.
#include "Button.h"
// Pin Definitions
long time0;
#include <Servo.h>
#define redpin 5
#define bluepin 6
#define greenpin 7
#define redpin_M 8
#define bluepin_M 9
int plasticsensor = A0;
int anothersensor = A2;
int metalsensor = A4;
int metalsensor_M = A6;
  pinMode(redpin, OUTPUT);
  pinMode(bluepin, OUTPUT);
  pinMode(greenpin, OUTPUT);
  //metal sensor
  pinMode(redpin_M, OUTPUT);
  pinMode(bluepin_M, OUTPUT);
  pinMode(greenpin_M, OUTPUT);
  pinMode(plasticsensor, INPUT_PULLUP);
  pinMode(metalsensor, INPUT_PULLUP);
  pinMode(anothersensor, INPUT_PULLUP);
  pinMode(metalsensor_M, INPUT_PULLUP);
  analogWrite(redpin, 255);
  analogWrite(bluepin, 0255);
  analogWrite(greenpin, 255);
  analogWrite(redpin_M, 255);
  analogWrite(bluepin_M, 0255);
  analogWrite(greenpin_M, 255);
  //ReflectiveIR.init();
  //ReflectiveIR_M.init();
  ReflectiveIR.begin();
  ReflectiveIR_M.begin();
  int sensor_read = digitalRead(plasticsensor);
  int sensor_read_m = digitalRead(metalsensor);
  int sensor_read_mm = digitalRead(metalsensor_M);
  //Plastic bin
  if ((sensor_read == 0) && (sensor_read_m != 1)) {
    analogWrite(bluepin, 0);
    delay(2500);
    analogWrite(redpin, 0);
    analogWrite(greenpin, 0);
  else if (ReflectiveIR_Val == 1) { //checking the volume of the trash
    analogWrite(bluepin, 255);
  else {
  //metal sensor
  if (sensor_read_mm == 1) {
    analogWrite(bluepin_M, 0);
    delay(2500);
    analogWrite(redpin_M, 0);
    analogWrite(greenpin_M, 0);
  else if (ReflectiveIR_Val_M == 1) {
    analogWrite(bluepin_M, 255);
  else {
yes that's the sketch I'm using
but how can I change them ?
and which lines are the .init() and which are the .begin() ?
These are the last lines of setup().
I changed them and still got the same error
this is the error line
You should post code by using code-tags. Do not post an image of your code.
There is an automatic function for doing this in the Arduino-IDE. Just three steps
1)press Ctrl-T for autoformatting your code
2)do a rightclick with the mouse and choose "copy for forum"
3)paste clipboard into write-window of a posting
Copy and paste the complete error message you are getting as well.
#include "Button.h"
// Pin Definitions
long time0;
#include <Servo.h>
#define redpin 5
#define bluepin 6
#define greenpin 7
#define redpin_M 8
#define bluepin_M 9
  //metal sensor
  //Plastic bin
    delay(2500);
  else {
  //metal sensor
    delay(2500);
  else {
the error message
Trash_sepeation:8:42: error: no matching function for call to 'Button::Button(const uint8_t&)'
In file included from C:\Users\zizo\Documents\Arduino\Trash_sepeation\Trash_sepeation.ino:3:0:
C:\Users\zizo\Documents\Arduino\libraries\Arduino-Library-Button-main/Button.h:27:5: note: candidate: Button::Button(int, bool, unsigned char*)
     Button(int myBit, bool myMode, unsigned char *myRegister);
C:\Users\zizo\Documents\Arduino\libraries\Arduino-Library-Button-main/Button.h:27:5: note:   candidate expects 3 arguments, 1 provided
C:\Users\zizo\Documents\Arduino\libraries\Arduino-Library-Button-main/Button.h:26:5: note: candidate: Button::Button(int, bool)
     Button(int myPin, bool myMode);
C:\Users\zizo\Documents\Arduino\libraries\Arduino-Library-Button-main/Button.h:26:5: note:   candidate expects 2 arguments, 1 provided
C:\Users\zizo\Documents\Arduino\libraries\Arduino-Library-Button-main/Button.h:21:7: note: candidate: constexpr Button::Button(const Button&)
 class Button {
C:\Users\zizo\Documents\Arduino\libraries\Arduino-Library-Button-main/Button.h:21:7: note:   no known conversion for argument 1 from 'const uint8_t {aka const unsigned char}' to 'const Button&'
C:\Users\zizo\Documents\Arduino\libraries\Arduino-Library-Button-main/Button.h:21:7: note: candidate: constexpr Button::Button(Button&&)
C:\Users\zizo\Documents\Arduino\libraries\Arduino-Library-Button-main/Button.h:21:7: note:   no known conversion for argument 1 from 'const uint8_t {aka const unsigned char}' to 'Button&&'
Trash_sepeation:9:46: error: no matching function for call to 'Button::Button(const uint8_t&)'
 class Button {
C:\Users\zizo\Documents\Arduino\Trash_sepeation\Trash_sepeation.ino: In function 'void setup()':
Trash_sepeation:56:16: error: 'class Button' has no member named 'begin'
Trash_sepeation:57:18: error: 'class Button' has no member named 'begin'
C:\Users\zizo\Documents\Arduino\Trash_sepeation\Trash_sepeation.ino: In function 'void loop()':
Trash_sepeation:71:40: error: 'class Button' has no member named 'read'
Trash_sepeation:72:44: error: 'class Button' has no member named 'read'
exit status 1
#include "Button.h"
The sketch is written for a library called Button by Michael Adams. It can be installed through the library manager. I can compile the sketch for an Uno without error.
I'm not clear what library you are using, or where you got it from, but I would delete it and reinstall the library I referenced through the library manager.
EDIT: I think you are trying to use this library
https://github.com/carlynorama/Arduino-Library-Button/blob/main/Button.h
I think you have installed a library called Button-Arduino by Davide Palladino. That's not the library the sketch is written to use.
thnx man
It compiled fine when I installed Michael Adams library
