// Include Libraries
#include "Arduino.h"
#include "Button.h"
// Pin Definitions
#define REFLECTIVEIR_PIN_COLL A3
#define REFLECTIVEIR_PIN_COLL_M A5
// object initialization
Button ReflectiveIR(REFLECTIVEIR_PIN_COLL);
Button ReflectiveIR_M(REFLECTIVEIR_PIN_COLL_M);
// define vars for testing menu
const int timeout = 10000; //define timeout of 10 sec
char menuOption = 0;
long time0;
#include <Servo.h>
#define redpin 5
#define bluepin 6
#define greenpin 7
#define redpin_M 8
#define bluepin_M 9
#define greenpin_M 10
int plasticsensor=A0;
int anothersensor=A2;
int metalsensor=A4;
int metalsensor_M=A6;
Servo myservo; // create servo object to control a servo
Servo myservo_M; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 165; // variable to store the servo position
int pos_M = 158; // variable to store the servo position
myservo.attach(11); // attaches the servo on pin 9 to the servo object
myservo_M.attach(12); // attaches the servo on pin 9 to the servo object
pinMode(redpin,OUTPUT);
pinMode(bluepin,OUTPUT);
pinMode(greenpin,OUTPUT);
//metal sensor
pinMode(redpin_M,OUTPUT);
pinMode(bluepin_M,OUTPUT);
pinMode(greenpin_M,OUTPUT);
pinMode(plasticsensor,INPUT_PULLUP);
pinMode(metalsensor,INPUT_PULLUP);
pinMode(anothersensor,INPUT_PULLUP);
pinMode(metalsensor_M,INPUT_PULLUP);
analogWrite(redpin,255);
analogWrite(bluepin,0255);
analogWrite(greenpin,255);
analogWrite(redpin_M,255);
analogWrite(bluepin_M,0255);
analogWrite(greenpin_M,255);
ReflectiveIR.init();
ReflectiveIR_M.init();
int sensor_read=digitalRead(plasticsensor);
int sensor_read_m=digitalRead(metalsensor);
int sensor_read_mm=digitalRead(metalsensor_M);
Serial.println("plastic sensor");
Serial.println(sensor_read);
Serial.println("metal sensor");
Serial.println(sensor_read_m);
Serial.println(sensor_read_mm);
bool ReflectiveIR_Val = ReflectiveIR.read();
bool ReflectiveIR_Val_M = ReflectiveIR_M.read();
//Plastic bin
if((sensor_read==0)&&(sensor_read_m!=1)){
for (pos = 160; pos >= 90; pos -= 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(1); // waits 15ms for the servo to reach the position
analogWrite(bluepin,0);
delay(2500);
for (pos = 90; pos <= 160; pos += 1) { // goes from 180 degrees to 0 degrees
analogWrite(redpin,0);
analogWrite(greenpin,0);
else if(ReflectiveIR_Val==1){ //checking the volume of the trash
analogWrite(bluepin,255);
else{
//metal sensor
if(sensor_read_mm==1){
for (pos_M = 160; pos_M >= 90; pos_M -= 1) { // goes from 0 degrees to 180 degrees
myservo_M.write(pos_M); // tell servo to go to position in variable 'pos'
analogWrite(bluepin_M,0);
delay(2500);
for (pos_M = 90; pos_M <= 160; pos_M += 1) { // goes from 180 degrees to 0 degrees
analogWrite(redpin_M,0);
analogWrite(greenpin_M,0);
else if(ReflectiveIR_Val_M==1){
analogWrite(bluepin_M,255);
else{
