How to fix this problem ?
Sketch uses 9544 bytes (29%) of program storage space. Maximum is 32256 bytes.
Global variables use 953 bytes (46%) of dynamic memory, leaving 1095 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\ASUS\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\ASUS\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM3" -b115200 -D "-Uflash:w:C:\Users\ASUS\AppData\Local\Temp\arduino\sketches\ECF8139F31287DDFFF43C8DA18746F48/projekan.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\ASUS\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x41
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
