I want to upgrade/uplopad a new Arduino program .hex or .bin file through micro sd card without using arduino IDE many times...
As per my requirement,
If we insert micro sd card in micro sd adapter and that adapter is connected to Arduino mega 2560,if we keep .bin file in that micro sd card,it should flash that .bin code to arduino mega 2560 ....
for that i searched in forum....finally,i found below link
in above link,they are saying
"if it is set to 0xF0 bootloader will look for a bin file on the sdcard named
firmware.bin and use it to flash the firmware then reset the byte to 0xFF so it
does this only once"
In the above only once means,if we want to upgrade more times code through sd card ... is it possible?
so, can you please suggest correct procedure to upload code from sd card multiple times??
sailaja:
“if it is set to 0xF0 bootloader will look for a bin file on the sdcard named
does this only once”
In the above only once means,if we want to upgrade more times code through sd card … is it possible?
Of course.
sailaja: can you please suggest correct procedure to upload code from sd card multiple times??
I copied hardware folder to my windows arduino path…then i opened arduino IDE…but i didn’t see under tools → boards → Arduino mega 2560 (Dual sd bootloader)
I follwed below link
In my arduino IDE i checked in tools…but i didnt get any new board…but warning showing in arduino IDE console…that warning is below
Could not find boards.txt in C:\Users\Admin\Documents\Arduino\hardware\microbridge\bootloaders. Is it pre-1.5?
WARNING: Error loading hardware folder C:\Users\Admin\Documents\Arduino\hardware\microbridge
No valid hardware definitions found in folder microbridge.
can you please tell me,how to get that Arduino mega 2560 (Dual sd bootloader) display in tools of arduino IDE?…And im using windows7 laptop…
The problem is that hardware package is in the Arduino IDE 1.0.x format so it's not compatible with the recent versions of the Arduino IDE. This issue was reported:
But unfortunately it appears that project has been abandoned years ago.
You should be able to use it with Arduino IDE 1.0.6, which you can download here: https://www.arduino.cc/en/Main/OldSoftwareReleases#1.0.x
It should also be fairly easy to update the hardware package to work with Arduino IDE 1.6.x and newer. You will find a guide to the changes that need to be made here:
The immediate problem is that the 1.5.x hardware package format requires the package to be within an architecture folder. So you're getting this error:
because it's treating the bootloaders folder as the architecture folder, which is wrong. That's an easy fix, you only need to create a folder C:\Users\Admin\Documents\Arduino\hardware\microbridge\avr and then move everything from C:\Users\Admin\Documents\Arduino\hardware\microbridge to C:\Users\Admin\Documents\Arduino\hardware\microbridge\avr. After doing that and restarting the IDE the board will appear in the Tools > Board menu but you will likely encounter some other errors. The solution for those are explained in the link above.
hi sir,i tried to check second method of this link...
In the above link,
they mentioned like below "After recompiling the bootloader’s source files, I flashed the new bootloader using AVR ISP MK II. I also had to make sure that the BOOTRST fuse was set in the ATmega2560’s fuse settings."....here new bootloader means exactly,which file i need to flash....
can u please suggest linux commands to flash bootloader using arduino uno as isp programmer to arduino mega 2560?
Thank you in advance
File > Preferences > Show verbose output during: upload (check) > OK
Select the board from the Tools > Board menu
Tools > Programmer > Arduino as ISP
Tools > Burn Bootloader
After the process completes examine the output in the black console window at the bottom of the Arduino IDE window. You will need to scroll up to see it all. There you will find the necessary commands. Note that there are two processes. First the fuses are set. This only needs to be done once. Next the bootloader is flashed.
" Install Arduino IDE 1.0.6 File > Preferences > Show verbose output during: upload (check) > OK Select the board from the Tools > Board menu Tools > Programmer > Arduino as ISP Tools > Burn Bootloader "
After above procedure, I converted basic blink example .hex file to .bin file....
i kept that .bin file name as FIRMWARE.BIN.....
i copied .bin file into formatted sd card....
i connected arduino mega 2560 with micro sd card adapter(i kept sd card inside adapter)
I tried what ever you suggested all those ....but i didnt get "uploading/flashing .hex or .bin from sd card to arduino mega 2560 without using arduino ide ".....
The main problem for sailaja was that they are using an ATmega2560, which is not well supported by avr_boot (though people have provided solutions for that issue since the last time I posted here.
