Hi all,
First of all, thanks for the instructions for flashing the modules.
Unfortunately, I had several issues with flashing the firmware on a module and, too sad, jailed one of mine... but finally, I was successful!
Perhabs my solution is helpful for someone.
My configuration:
Win 7 64-bit
USB-UART CP2104 converter
Arduino Pro Mini 3V3 8MHz
First, I was not able to run CCLoader.exe nor CCLoader_x86_64.exe. Windows responds with a compatibility issue.
Solved by using DevC++ and recompiled the source code from github. This was easier than it sounds!
Second, the CCLoader was not able to comunicate with the Arduino properly. Waiting for respond from Arduino...
I assumed, that the issue is the serial baud rate. I reduced the speed in the C source code and the Arduino source code to 19200. Unfortunately, this did not solve the issue.
Checked the connection and found, that I did not disconnect the DSR pin from the Serial converter to the Arduino (it resets the arduino to upload the sketch). Ich checked the C code and believed, it is disabled. However, I disconnected it and this did the trick.
Well, when checking the Arduino code, I also commented the line required for Leonardo boards. I was wondering, why this is not the default.
I checked, if the Pro Mini 3V3 is able to run at 115200 baud and it looks like, this is indeed too fast for it. Well, upload is slow, but for one or two modules it is fine.
I attach my files and hope, it helps. Good luck!
Cheers,
iBuddy
CCLoader_Win7-64_19200.zip (131 KB)
