I'm running over flash memory limit on my Atmega328p. It is running a ILI9341 based 240x320 TFT LCD screen via PDQ GFX Library
The library is based on Adafruit GFX library thus, I can use Adafruit fontconverter to convert true type fonts such as FreeSansBold to header file for a specified ascii range. That's great to reduce the size of the program. Basically I type into the cmd: fontconvert c:\Users\UserName\Desktop\FontConvert-master\FreeSansBold.ttf 24 48 57 > FreeSansBold24pt7b_48_57 to obtain number only font.
But I don't want to designate a range only, I want to choose which characters will be included precisely so that I can reduce the file size enough. For example for FreeSansBold I want to combine:
Character vs Ascii Code
'%' -> 37
'*' -> 42
'.' -> 46
'0' -> 48
'1' -> 49
'2' -> 50
'3' -> 51
'4' -> 52
'5' -> 53
'6' -> 54
'7' -> 55
'8' -> 56
'9' -> 57
':' -> 58
'C' -> 67
To do so, I've generated fonts with fontconverter for these ranges: 37-37, 42-42, 46-46, 48-58 and 67-67 then combined them in another header file. I changed the first number out of six of "const GFXglyph FreeSansBold24pt7b_ReducedGlyphs[] PROGMEM =" array members, which relate to characters, to put them in an order. Long story short, it prints random mixed up characters, I don't eleborate this process as it failed. Would be great if someone who understands header font format explains what to edit maybe?
Can you help me to generate the font header file for only required characters?
FreeSansBold24pt7b original header file for experts to suggest me how to edit for my needs:
// Original Font is downloaded from https://fontmeme.com/fonts/freesans-font/
const uint8_t FreeSansBold24pt7b_FULLBitmaps[] PROGMEM = {
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFB, 0xF7, 0xEF,
0xDF, 0xBF, 0x7C, 0xF9, 0xF1, 0xE3, 0xC7, 0x8F, 0x1C, 0x00, 0x00, 0x07,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0xFE, 0x1F, 0xFF, 0x87, 0xFF, 0xE1,
0xFF, 0xF8, 0x7F, 0xFE, 0x1F, 0xFF, 0x87, 0xF7, 0xE0, 0xFD, 0xF0, 0x3E,
0x7C, 0x0F, 0x9F, 0x01, 0xE3, 0x80, 0x70, 0xE0, 0x1C, 0x00, 0x7C, 0x3E,
0x00, 0x3E, 0x0F, 0x80, 0x0F, 0x83, 0xE0, 0x03, 0xE0, 0xF8, 0x00, 0xF8,
0x3E, 0x00, 0x3E, 0x1F, 0x00, 0x1F, 0x07, 0xC0, 0x07, 0xC1, 0xF0, 0x7F,
0xFF, 0xFF, 0xDF, 0xFF, 0xFF, 0xF7, 0xFF, 0xFF, 0xFD, 0xFF, 0xFF, 0xFF,
0x7F, 0xFF, 0xFF, 0xC0, 0xF8, 0x3E, 0x00, 0x3E, 0x0F, 0x80, 0x0F, 0x87,
0xC0, 0x07, 0xC1, 0xF0, 0x01, 0xF0, 0x7C, 0x00, 0x7C, 0x1F, 0x00, 0x1F,
0x07, 0xC0, 0xFF, 0xFF, 0xFF, 0x3F, 0xFF, 0xFF, 0xCF, 0xFF, 0xFF, 0xF3,
0xFF, 0xFF, 0xFC, 0xFF, 0xFF, 0xFF, 0x03, 0xE1, 0xF0, 0x01, 0xF0, 0x7C,
0x00, 0x7C, 0x1F, 0x00, 0x1F, 0x07, 0xC0, 0x07, 0xC1, 0xF0, 0x01, 0xF0,
0xF8, 0x00, 0xF8, 0x3E, 0x00, 0x3E, 0x0F, 0x80, 0x0F, 0x83, 0xE0, 0x00,
0x00, 0x3C, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x3C, 0x00, 0x01, 0xFF, 0xC0,
0x07, 0xFF, 0xE0, 0x1F, 0xFF, 0xF8, 0x3F, 0xFF, 0xF8, 0x3F, 0xFF, 0xFC,
0x7F, 0x3C, 0xFE, 0x7E, 0x3C, 0x7E, 0x7E, 0x3C, 0x7E, 0x7E, 0x3C, 0x7E,
0x7E, 0x3C, 0x7E, 0x7E, 0x3C, 0x00, 0x7F, 0x3C, 0x00, 0x7F, 0xBC, 0x00,
0x3F, 0xFC, 0x00, 0x3F, 0xFF, 0x00, 0x1F, 0xFF, 0xC0, 0x07, 0xFF, 0xF0,
0x03, 0xFF, 0xF8, 0x00, 0x7F, 0xFC, 0x00, 0x3F, 0xFE, 0x00, 0x3D, 0xFE,
0x00, 0x3C, 0x7E, 0x00, 0x3C, 0x7F, 0xFC, 0x3C, 0x7F, 0xFC, 0x3C, 0x3F,
0xFE, 0x3C, 0x7F, 0xFE, 0x3C, 0x7E, 0x7F, 0x3C, 0xFE, 0x7F, 0xBD, 0xFE,
0x3F, 0xFF, 0xFC, 0x3F, 0xFF, 0xFC, 0x0F, 0xFF, 0xF0, 0x07, 0xFF, 0xE0,
0x00, 0xFF, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x3C, 0x00,
0x00, 0x3C, 0x00, 0x00, 0x3C, 0x00, 0x03, 0xE0, 0x00, 0x1E, 0x00, 0x0F,
0xFC, 0x00, 0x3C, 0x00, 0x1F, 0xFE, 0x00, 0x3C, 0x00, 0x3F, 0xFF, 0x00,
0x78, 0x00, 0x7F, 0xFF, 0x00, 0x70, 0x00, 0x7C, 0x1F, 0x80, 0xF0, 0x00,
0xF8, 0x0F, 0x80, 0xE0, 0x00, 0xF8, 0x0F, 0x81, 0xE0, 0x00, 0xF8, 0x07,
0x81, 0xC0, 0x00, 0xF8, 0x07, 0x83, 0xC0, 0x00, 0xF8, 0x0F, 0x83, 0x80,
0x00, 0x7C, 0x1F, 0x87, 0x80, 0x00, 0x7F, 0x7F, 0x0F, 0x00, 0x00, 0x3F,
0xFF, 0x0F, 0x00, 0x00, 0x3F, 0xFE, 0x1E, 0x00, 0x00, 0x0F, 0xFC, 0x1C,
0x00, 0x00, 0x07, 0xF0, 0x3C, 0x02, 0x00, 0x00, 0x00, 0x38, 0x1F, 0xE0,
0x00, 0x00, 0x78, 0x7F, 0xF8, 0x00, 0x00, 0x70, 0xFF, 0xFC, 0x00, 0x00,
0xF0, 0xFF, 0xFC, 0x00, 0x00, 0xE1, 0xF8, 0x7E, 0x00, 0x01, 0xE1, 0xF0,
0x3E, 0x00, 0x01, 0xC3, 0xE0, 0x1E, 0x00, 0x03, 0xC3, 0xE0, 0x1F, 0x00,
0x07, 0x83, 0xE0, 0x1F, 0x00, 0x07, 0x83, 0xE0, 0x1E, 0x00, 0x0F, 0x01,
0xF0, 0x3E, 0x00, 0x0E, 0x01, 0xF8, 0x7E, 0x00, 0x1E, 0x01, 0xFF, 0xFC,
0x00, 0x1C, 0x00, 0xFF, 0xFC, 0x00, 0x3C, 0x00, 0x7F, 0xF8, 0x00, 0x38,
0x00, 0x1F, 0xE0, 0x00, 0x78, 0x00, 0x03, 0x00, 0x00, 0x7E, 0x00, 0x00,
0x07, 0xFE, 0x00, 0x00, 0x7F, 0xFE, 0x00, 0x01, 0xFF, 0xF8, 0x00, 0x0F,
0xFF, 0xF0, 0x00, 0x7F, 0x8F, 0xC0, 0x01, 0xFC, 0x3F, 0x00, 0x07, 0xE0,
0x7C, 0x00, 0x1F, 0x81, 0xF0, 0x00, 0x7F, 0x0F, 0xC0, 0x00, 0xFE, 0x3F,
0x00, 0x03, 0xFD, 0xF8, 0x00, 0x07, 0xFF, 0xE0, 0x00, 0x0F, 0xFF, 0x00,
0x00, 0x3F, 0xF0, 0x00, 0x00, 0xFF, 0x80, 0x00, 0x07, 0xFF, 0x03, 0xE0,
0x7F, 0xFC, 0x0F, 0x83, 0xFF, 0xF8, 0x3E, 0x1F, 0xEF, 0xF1, 0xF8, 0x7F,
0x1F, 0xE7, 0xE3, 0xF8, 0x3F, 0xDF, 0x0F, 0xC0, 0x7F, 0xFC, 0x3F, 0x00,
0xFF, 0xF0, 0xFC, 0x03, 0xFF, 0x83, 0xF0, 0x07, 0xFE, 0x0F, 0xC0, 0x0F,
0xF0, 0x3F, 0x80, 0x3F, 0xC0, 0xFF, 0x03, 0xFF, 0x81, 0xFF, 0x3F, 0xFF,
0x07, 0xFF, 0xFF, 0xFE, 0x0F, 0xFF, 0xFF, 0xFC, 0x1F, 0xFF, 0xC7, 0xF0,
0x3F, 0xFE, 0x0F, 0xE0, 0x1F, 0xC0, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xDF, 0xBE, 0x7C, 0xF8, 0xE1, 0xC0, 0x01, 0xF0, 0x3E, 0x03, 0xE0,
0x7C, 0x07, 0xC0, 0xF8, 0x0F, 0x81, 0xF8, 0x1F, 0x03, 0xF0, 0x3E, 0x07,
0xE0, 0x7E, 0x07, 0xE0, 0x7C, 0x0F, 0xC0, 0xFC, 0x0F, 0xC0, 0xFC, 0x0F,
0xC0, 0xFC, 0x0F, 0xC0, 0xFC, 0x0F, 0xC0, 0xFC, 0x0F, 0xC0, 0xFC, 0x0F,
0xC0, 0x7C, 0x07, 0xE0, 0x7E, 0x07, 0xE0, 0x3E, 0x03, 0xF0, 0x1F, 0x01,
0xF8, 0x1F, 0x80, 0xF8, 0x07, 0xC0, 0x7C, 0x03, 0xE0, 0x3E, 0x01, 0xF0,
0xF8, 0x07, 0xC0, 0x7C, 0x03, 0xE0, 0x3F, 0x01, 0xF0, 0x1F, 0x80, 0xF8,
0x0F, 0xC0, 0xFC, 0x07, 0xC0, 0x7E, 0x07, 0xE0, 0x3E, 0x03, 0xF0, 0x3F,
0x03, 0xF0, 0x3F, 0x03, 0xF0, 0x1F, 0x01, 0xF0, 0x1F, 0x01, 0xF0, 0x1F,
0x03, 0xF0, 0x3F, 0x03, 0xF0, 0x3F, 0x03, 0xF0, 0x3E, 0x07, 0xE0, 0x7E,
0x07, 0xC0, 0xFC, 0x0F, 0xC0, 0xF8, 0x1F, 0x81, 0xF0, 0x3F, 0x03, 0xE0,
0x7E, 0x07, 0xC0, 0xF8, 0x00, 0x03, 0xC0, 0x03, 0xC0, 0x03, 0xC0, 0x03,
0xC0, 0x73, 0xCE, 0xFF, 0xFE, 0xFF, 0xFF, 0x3F, 0xFC, 0x07, 0xE0, 0x0F,
0xE0, 0x0F, 0xF0, 0x1E, 0x78, 0x3C, 0x7C, 0x1C, 0x38, 0x08, 0x10, 0x00,
0x7E, 0x00, 0x00, 0xFC, 0x00, 0x01, 0xF8, 0x00, 0x03, 0xF0, 0x00, 0x07,
0xE0, 0x00, 0x0F, 0xC0, 0x00, 0x1F, 0x80, 0x00, 0x3F, 0x00, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xC0, 0x1F, 0x80, 0x00, 0x3F, 0x00, 0x00, 0x7E, 0x00,
0x00, 0xFC, 0x00, 0x01, 0xF8, 0x00, 0x03, 0xF0, 0x00, 0x07, 0xE0, 0x00,
0x0F, 0xC0, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x87, 0x0E, 0x1C,
0x79, 0xEF, 0xDF, 0x38, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFC, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x80, 0x00, 0x38,
0x03, 0xC0, 0x1C, 0x00, 0xE0, 0x07, 0x00, 0x78, 0x03, 0x80, 0x1C, 0x01,
0xE0, 0x0E, 0x00, 0x70, 0x03, 0x80, 0x3C, 0x01, 0xC0, 0x0E, 0x00, 0x70,
0x07, 0x00, 0x38, 0x01, 0xC0, 0x1E, 0x00, 0xE0, 0x07, 0x00, 0x38, 0x03,
0x80, 0x1C, 0x00, 0xE0, 0x0F, 0x00, 0x70, 0x03, 0x80, 0x1C, 0x01, 0xC0,
0x0E, 0x00, 0x70, 0x07, 0x80, 0x38, 0x00, 0x00, 0xFE, 0x00, 0x07, 0xFF,
0x80, 0x1F, 0xFF, 0x80, 0x7F, 0xFF, 0x81, 0xFF, 0xFF, 0x87, 0xF8, 0xFF,
0x0F, 0xE0, 0x7F, 0x1F, 0x80, 0xFE, 0x7F, 0x00, 0xFC, 0xFE, 0x01, 0xFD,
0xF8, 0x03, 0xFB, 0xF0, 0x07, 0xF7, 0xE0, 0x0F, 0xFF, 0xC0, 0x0F, 0xFF,
0x80, 0x1F, 0xFF, 0x00, 0x3F, 0xFE, 0x00, 0x7F, 0xFC, 0x00, 0xFF, 0xF8,
0x01, 0xFF, 0xF0, 0x03, 0xFF, 0xE0, 0x07, 0xEF, 0xC0, 0x0F, 0xDF, 0x80,
0x1F, 0xBF, 0x00, 0x7F, 0x7E, 0x00, 0xFE, 0xFE, 0x01, 0xFD, 0xFC, 0x03,
0xF1, 0xF8, 0x0F, 0xE3, 0xF8, 0x3F, 0xC7, 0xFF, 0xFF, 0x07, 0xFF, 0xFE,
0x07, 0xFF, 0xF8, 0x07, 0xFF, 0xE0, 0x07, 0xFF, 0x80, 0x03, 0xFC, 0x00,
0x00, 0x3E, 0x00, 0x7C, 0x01, 0xF8, 0x07, 0xF0, 0x3F, 0xE7, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0x03, 0xF8, 0x07, 0xF0, 0x0F,
0xE0, 0x1F, 0xC0, 0x3F, 0x80, 0x7F, 0x00, 0xFE, 0x01, 0xFC, 0x03, 0xF8,
0x07, 0xF0, 0x0F, 0xE0, 0x1F, 0xC0, 0x3F, 0x80, 0x7F, 0x00, 0xFE, 0x01,
0xFC, 0x03, 0xF8, 0x07, 0xF0, 0x0F, 0xE0, 0x1F, 0xC0, 0x3F, 0x80, 0x7F,
0x00, 0xFE, 0x00, 0xFF, 0x00, 0x0F, 0xFF, 0x80, 0x3F, 0xFF, 0xC0, 0xFF,
0xFF, 0xC3, 0xFF, 0xFF, 0xC7, 0xFC, 0xFF, 0x8F, 0xE0, 0x7F, 0xBF, 0x80,
0x7F, 0x7F, 0x00, 0xFE, 0xFC, 0x00, 0xFD, 0xF8, 0x01, 0xFB, 0xF0, 0x03,
0xF0, 0x00, 0x0F, 0xE0, 0x00, 0x1F, 0xC0, 0x00, 0x3F, 0x00, 0x00, 0xFE,
0x00, 0x03, 0xF8, 0x00, 0x0F, 0xF0, 0x00, 0x3F, 0xC0, 0x01, 0xFF, 0x00,
0x07, 0xFC, 0x00, 0x3F, 0xE0, 0x00, 0xFF, 0x80, 0x03, 0xFC, 0x00, 0x0F,
0xF0, 0x00, 0x3F, 0xC0, 0x00, 0xFF, 0x00, 0x01, 0xFC, 0x00, 0x07, 0xFF,
0xFF, 0xEF, 0xFF, 0xFF, 0xDF, 0xFF, 0xFF, 0xBF, 0xFF, 0xFF, 0x7F, 0xFF,
0xFF, 0xFF, 0xFF, 0xFC, 0x00, 0xFF, 0x00, 0x0F, 0xFF, 0x80, 0x3F, 0xFF,
0x80, 0xFF, 0xFF, 0x83, 0xFF, 0xFF, 0x87, 0xF8, 0xFF, 0x9F, 0xC0, 0x7F,
0x3F, 0x80, 0xFE, 0x7E, 0x01, 0xFC, 0xFC, 0x01, 0xF9, 0xF8, 0x03, 0xF0,
0x00, 0x0F, 0xE0, 0x00, 0x1F, 0x80, 0x00, 0x7F, 0x00, 0x07, 0xFC, 0x00,
0x3F, 0xF0, 0x00, 0x7F, 0xC0, 0x00, 0xFF, 0xE0, 0x01, 0xFF, 0xE0, 0x00,
0x3F, 0xE0, 0x00, 0x1F, 0xC0, 0x00, 0x1F, 0xC0, 0x00, 0x3F, 0x80, 0x00,
0x3F, 0xFE, 0x00, 0x7F, 0xFC, 0x00, 0xFD, 0xF8, 0x03, 0xFB, 0xF8, 0x07,
0xF7, 0xF8, 0x1F, 0xEF, 0xFF, 0xFF, 0x8F, 0xFF, 0xFF, 0x0F, 0xFF, 0xFC,
0x0F, 0xFF, 0xF0, 0x0F, 0xFF, 0x80, 0x03, 0xFC, 0x00, 0x00, 0x0F, 0xF0,
0x00, 0x1F, 0xF0, 0x00, 0x1F, 0xF0, 0x00, 0x3F, 0xF0, 0x00, 0x7F, 0xF0,
0x00, 0x7F, 0xF0, 0x00, 0xFF, 0xF0, 0x00, 0xFF, 0xF0, 0x01, 0xF7, 0xF0,
0x03, 0xE7, 0xF0, 0x03, 0xE7, 0xF0, 0x07, 0xC7, 0xF0, 0x07, 0x87, 0xF0,
0x0F, 0x87, 0xF0, 0x1F, 0x07, 0xF0, 0x1F, 0x07, 0xF0, 0x3E, 0x07, 0xF0,
0x3C, 0x07, 0xF0, 0x7C, 0x07, 0xF0, 0xF8, 0x07, 0xF0, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0x00, 0x07, 0xF0, 0x00, 0x07, 0xF0, 0x00, 0x07, 0xF0,
0x00, 0x07, 0xF0, 0x00, 0x07, 0xF0, 0x00, 0x07, 0xF0, 0x00, 0x07, 0xF0,
0x0F, 0xFF, 0xFC, 0x1F, 0xFF, 0xF8, 0x3F, 0xFF, 0xF0, 0x7F, 0xFF, 0xE1,
0xFF, 0xFF, 0xC3, 0xFF, 0xFF, 0x87, 0xC0, 0x00, 0x0F, 0x80, 0x00, 0x1F,
0x00, 0x00, 0x3E, 0x00, 0x00, 0xF8, 0x00, 0x01, 0xF3, 0xFC, 0x03, 0xFF,
0xFE, 0x07, 0xFF, 0xFE, 0x0F, 0xFF, 0xFE, 0x1F, 0xFF, 0xFE, 0x7F, 0x83,
0xFC, 0xFE, 0x03, 0xFC, 0x00, 0x03, 0xF8, 0x00, 0x07, 0xF0, 0x00, 0x07,
0xE0, 0x00, 0x0F, 0xC0, 0x00, 0x1F, 0x80, 0x00, 0x3F, 0xFE, 0x00, 0xFF,
0xFC, 0x01, 0xFD, 0xF8, 0x07, 0xFB, 0xF8, 0x1F, 0xE7, 0xFF, 0xFF, 0xC7,
0xFF, 0xFF, 0x0F, 0xFF, 0xFC, 0x07, 0xFF, 0xF0, 0x07, 0xFF, 0xC0, 0x03,
0xFC, 0x00, 0x00, 0xFE, 0x00, 0x0F, 0xFF, 0x00, 0xFF, 0xFE, 0x07, 0xFF,
0xFC, 0x1F, 0xFF, 0xF8, 0xFF, 0x1F, 0xE7, 0xF0, 0x1F, 0x9F, 0xC0, 0x7F,
0x7E, 0x00, 0x03, 0xF8, 0x00, 0x0F, 0xC0, 0x00, 0x3F, 0x00, 0x00, 0xFC,
0x3F, 0x03, 0xF3, 0xFF, 0x0F, 0xDF, 0xFE, 0x3F, 0xFF, 0xFC, 0xFF, 0xFF,
0xFB, 0xFF, 0x3F, 0xEF, 0xF0, 0x3F, 0xFF, 0x80, 0x7F, 0xFC, 0x00, 0xFF,
0xF0, 0x03, 0xFF, 0xC0, 0x0F, 0xFF, 0x00, 0x3F, 0xFC, 0x00, 0xFF, 0xF0,
0x03, 0xFF, 0xE0, 0x1F, 0xDF, 0x80, 0x7F, 0x7F, 0x03, 0xF8, 0xFF, 0xFF,
0xE3, 0xFF, 0xFF, 0x07, 0xFF, 0xFC, 0x0F, 0xFF, 0xE0, 0x1F, 0xFE, 0x00,
0x0F, 0xE0, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x00, 0x00, 0xFC,
0x00, 0x01, 0xFC, 0x00, 0x01, 0xF8, 0x00, 0x03, 0xF0, 0x00, 0x07, 0xF0,
0x00, 0x07, 0xE0, 0x00, 0x0F, 0xC0, 0x00, 0x1F, 0xC0, 0x00, 0x1F, 0x80,
0x00, 0x3F, 0x80, 0x00, 0x3F, 0x00, 0x00, 0x7F, 0x00, 0x00, 0x7E, 0x00,
0x00, 0xFE, 0x00, 0x00, 0xFC, 0x00, 0x00, 0xFC, 0x00, 0x01, 0xFC, 0x00,
0x01, 0xF8, 0x00, 0x01, 0xF8, 0x00, 0x01, 0xF8, 0x00, 0x03, 0xF8, 0x00,
0x03, 0xF8, 0x00, 0x03, 0xF0, 0x00, 0x03, 0xF0, 0x00, 0x03, 0xF0, 0x00,
0x07, 0xF0, 0x00, 0x07, 0xF0, 0x00, 0x00, 0xFF, 0x00, 0x03, 0xFF, 0xC0,
0x0F, 0xFF, 0xE0, 0x1F, 0xFF, 0xF0, 0x3F, 0xFF, 0xF8, 0x3F, 0xE7, 0xFC,
0x7F, 0x01, 0xFC, 0x7E, 0x00, 0xFC, 0x7E, 0x00, 0x7E, 0x7E, 0x00, 0x7E,
0x7E, 0x00, 0x7C, 0x7E, 0x00, 0xFC, 0x3F, 0x00, 0xFC, 0x3F, 0x83, 0xF8,
0x1F, 0xFF, 0xF0, 0x07, 0xFF, 0xE0, 0x0F, 0xFF, 0xE0, 0x1F, 0xFF, 0xF8,
0x3F, 0xFF, 0xFC, 0x7F, 0x81, 0xFC, 0x7F, 0x00, 0xFE, 0xFE, 0x00, 0x7E,
0xFE, 0x00, 0x7E, 0xFE, 0x00, 0x7F, 0xFE, 0x00, 0x7F, 0xFE, 0x00, 0x7F,
0xFE, 0x00, 0x7E, 0xFF, 0x00, 0xFE, 0x7F, 0x81, 0xFE, 0x7F, 0xFF, 0xFC,
0x3F, 0xFF, 0xFC, 0x1F, 0xFF, 0xF8, 0x0F, 0xFF, 0xF0, 0x07, 0xFF, 0xC0,
0x00, 0xFF, 0x00, 0x00, 0xFE, 0x00, 0x07, 0xFF, 0x00, 0x3F, 0xFF, 0x80,
0xFF, 0xFF, 0x83, 0xFF, 0xFF, 0x07, 0xFD, 0xFF, 0x1F, 0xC0, 0x7E, 0x3F,
0x80, 0xFE, 0x7E, 0x00, 0xFD, 0xFC, 0x01, 0xFB, 0xF8, 0x03, 0xFF, 0xF0,
0x03, 0xFF, 0xE0, 0x0F, 0xFF, 0xC0, 0x1F, 0xDF, 0x80, 0x3F, 0xBF, 0x00,
0x7F, 0x7F, 0x01, 0xFE, 0xFF, 0x8F, 0xFC, 0xFF, 0xFF, 0xF8, 0xFF, 0xFF,
0xF1, 0xFF, 0xF7, 0xE0, 0xFF, 0xCF, 0xC0, 0xFF, 0x1F, 0x80, 0x00, 0x7F,
0x00, 0x00, 0xFC, 0x00, 0x01, 0xF9, 0xF8, 0x03, 0xF3, 0xF0, 0x0F, 0xE7,
0xF0, 0x3F, 0x8F, 0xFF, 0xFF, 0x0F, 0xFF, 0xFC, 0x0F, 0xFF, 0xF0, 0x0F,
0xFF, 0xC0, 0x0F, 0xFF, 0x00, 0x07, 0xF8, 0x00, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xC0, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0x0E, 0x1C, 0x38, 0x71, 0xDF, 0xBE, 0x70, 0x00, 0x00, 0x06,
0x00, 0x00, 0x7C, 0x00, 0x07, 0xF8, 0x00, 0x3F, 0xF0, 0x03, 0xFF, 0xE0,
0x3F, 0xFF, 0x01, 0xFF, 0xF0, 0x1F, 0xFF, 0x00, 0xFF, 0xF0, 0x01, 0xFF,
0x00, 0x03, 0xF8, 0x00, 0x07, 0xE0, 0x00, 0x0F, 0xF8, 0x00, 0x1F, 0xFE,
0x00, 0x1F, 0xFF, 0x80, 0x07, 0xFF, 0xE0, 0x01, 0xFF, 0xF8, 0x00, 0xFF,
0xFC, 0x00, 0x3F, 0xF8, 0x00, 0x0F, 0xF0, 0x00, 0x03, 0xE0, 0x00, 0x01,
0xC0, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xFF, 0xFF,
0xFF, 0xFE, 0xC0, 0x00, 0x01, 0xF0, 0x00, 0x03, 0xF8, 0x00, 0x07, 0xFE,
0x00, 0x0F, 0xFF, 0x80, 0x07, 0xFF, 0xC0, 0x03, 0xFF, 0xF0, 0x00, 0xFF,
0xFC, 0x00, 0x3F, 0xFE, 0x00, 0x0F, 0xFC, 0x00, 0x03, 0xF8, 0x00, 0x03,
0xF0, 0x00, 0x3F, 0xE0, 0x03, 0xFF, 0xC0, 0x3F, 0xFE, 0x03, 0xFF, 0xF0,
0x3F, 0xFF, 0x01, 0xFF, 0xF0, 0x03, 0xFF, 0x80, 0x07, 0xF8, 0x00, 0x0F,
0x80, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x0F, 0xFF, 0x80,
0x3F, 0xFF, 0x80, 0xFF, 0xFF, 0x83, 0xFF, 0xFF, 0x8F, 0xFF, 0xFF, 0x9F,
0xE0, 0xFF, 0x3F, 0x80, 0xFF, 0xFE, 0x00, 0xFF, 0xFC, 0x01, 0xFF, 0xF8,
0x03, 0xFF, 0xE0, 0x07, 0xF0, 0x00, 0x0F, 0xE0, 0x00, 0x1F, 0xC0, 0x00,
0x7F, 0x80, 0x01, 0xFE, 0x00, 0x07, 0xF8, 0x00, 0x1F, 0xF0, 0x00, 0x7F,
0x80, 0x01, 0xFE, 0x00, 0x07, 0xF8, 0x00, 0x0F, 0xE0, 0x00, 0x1F, 0x80,
0x00, 0x3F, 0x00, 0x00, 0x7C, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x1F, 0xC0, 0x00, 0x3F, 0x80, 0x00,
0x7F, 0x00, 0x00, 0xFE, 0x00, 0x01, 0xFC, 0x00, 0x03, 0xF8, 0x00, 0x00,
0x00, 0x3F, 0xF0, 0x00, 0x00, 0x00, 0x1F, 0xFF, 0xF0, 0x00, 0x00, 0x07,
0xFF, 0xFF, 0xC0, 0x00, 0x01, 0xFF, 0xFF, 0xFE, 0x00, 0x00, 0x7F, 0x80,
0x07, 0xF8, 0x00, 0x0F, 0xE0, 0x00, 0x1F, 0xC0, 0x01, 0xF8, 0x00, 0x00,
0x7E, 0x00, 0x3F, 0x00, 0x00, 0x03, 0xF0, 0x07, 0xE0, 0x00, 0x00, 0x1F,
0x80, 0x7C, 0x00, 0x00, 0x00, 0xF8, 0x0F, 0x80, 0x00, 0x00, 0x07, 0xC1,
0xF0, 0x01, 0xFC, 0x78, 0x3C, 0x1E, 0x00, 0x7F, 0xE7, 0x83, 0xE3, 0xE0,
0x0F, 0xFF, 0x78, 0x1E, 0x3C, 0x01, 0xF8, 0x7F, 0x81, 0xE3, 0xC0, 0x3E,
0x03, 0xF0, 0x1E, 0x7C, 0x03, 0xC0, 0x1F, 0x01, 0xE7, 0x80, 0x7C, 0x01,
0xF0, 0x1E, 0x78, 0x07, 0x80, 0x1E, 0x01, 0xF7, 0x80, 0xF0, 0x01, 0xE0,
0x1E, 0xF8, 0x0F, 0x00, 0x1E, 0x01, 0xEF, 0x80, 0xF0, 0x01, 0xE0, 0x1E,
0xF8, 0x1F, 0x00, 0x3C, 0x03, 0xEF, 0x81, 0xF0, 0x03, 0xC0, 0x3E, 0xF8,
0x1F, 0x00, 0x7C, 0x07, 0xCF, 0x81, 0xF0, 0x07, 0xC0, 0x7C, 0x78, 0x1F,
0x00, 0xF8, 0x0F, 0x87, 0xC0, 0xF8, 0x1F, 0xC1, 0xF8, 0x7C, 0x0F, 0xFF,
0xFE, 0xFF, 0x03, 0xC0, 0x7F, 0xFB, 0xFF, 0xE0, 0x3E, 0x03, 0xFF, 0x1F,
0xF8, 0x03, 0xF0, 0x1F, 0xE0, 0xFE, 0x00, 0x1F, 0x80, 0x00, 0x00, 0x00,
0x00, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x00,
0x3F, 0x80, 0x00, 0x00, 0x00, 0x01, 0xFE, 0x00, 0x03, 0x00, 0x00, 0x0F,
0xFC, 0x07, 0xF0, 0x00, 0x00, 0x7F, 0xFF, 0xFF, 0x80, 0x00, 0x01, 0xFF,
0xFF, 0xF8, 0x00, 0x00, 0x03, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x0F, 0xF0,
0x00, 0x00, 0x0F, 0xF8, 0x00, 0x00, 0x1F, 0xF8, 0x00, 0x00, 0x1F, 0xFC,
0x00, 0x00, 0x1F, 0xFC, 0x00, 0x00, 0x3F, 0xFC, 0x00, 0x00, 0x3F, 0xFE,
0x00, 0x00, 0x3F, 0xFE, 0x00, 0x00, 0x7F, 0xFE, 0x00, 0x00, 0x7F, 0x7F,
0x00, 0x00, 0x7E, 0x7F, 0x00, 0x00, 0xFE, 0x7F, 0x00, 0x00, 0xFE, 0x3F,
0x80, 0x01, 0xFC, 0x3F, 0x80, 0x01, 0xFC, 0x3F, 0x80, 0x01, 0xFC, 0x1F,
0xC0, 0x03, 0xF8, 0x1F, 0xC0, 0x03, 0xF8, 0x1F, 0xC0, 0x03, 0xF8, 0x0F,
0xE0, 0x07, 0xF0, 0x0F, 0xE0, 0x07, 0xF0, 0x0F, 0xE0, 0x07, 0xFF, 0xFF,
0xF0, 0x0F, 0xFF, 0xFF, 0xF0, 0x0F, 0xFF, 0xFF, 0xF0, 0x0F, 0xFF, 0xFF,
0xF8, 0x1F, 0xFF, 0xFF, 0xF8, 0x1F, 0xFF, 0xFF, 0xF8, 0x1F, 0xC0, 0x01,
0xFC, 0x3F, 0x80, 0x01, 0xFC, 0x3F, 0x80, 0x01, 0xFC, 0x7F, 0x80, 0x00,
0xFE, 0x7F, 0x00, 0x00, 0xFE, 0x7F, 0x00, 0x00, 0xFF, 0xFF, 0x00, 0x00,
0x7F, 0xFF, 0xFF, 0xF0, 0x1F, 0xFF, 0xFF, 0x83, 0xFF, 0xFF, 0xFC, 0x7F,
0xFF, 0xFF, 0x8F, 0xFF, 0xFF, 0xF9, 0xFF, 0xFF, 0xFF, 0xBF, 0x80, 0x0F,
0xF7, 0xF0, 0x00, 0xFE, 0xFE, 0x00, 0x1F, 0xDF, 0xC0, 0x01, 0xFB, 0xF8,
0x00, 0x7F, 0x7F, 0x00, 0x0F, 0xEF, 0xE0, 0x03, 0xF9, 0xFF, 0xFF, 0xFF,
0x3F, 0xFF, 0xFF, 0x87, 0xFF, 0xFF, 0xE0, 0xFF, 0xFF, 0xFE, 0x1F, 0xFF,
0xFF, 0xE3, 0xFF, 0xFF, 0xFE, 0x7F, 0x00, 0x3F, 0xEF, 0xE0, 0x01, 0xFD,
0xFC, 0x00, 0x1F, 0xFF, 0x80, 0x03, 0xFF, 0xF0, 0x00, 0x3F, 0xFE, 0x00,
0x0F, 0xFF, 0xC0, 0x01, 0xFF, 0xF8, 0x00, 0x3F, 0xFF, 0x00, 0x1F, 0xFF,
0xFF, 0xFF, 0xFD, 0xFF, 0xFF, 0xFF, 0xBF, 0xFF, 0xFF, 0xE7, 0xFF, 0xFF,
0xF8, 0xFF, 0xFF, 0xFC, 0x1F, 0xFF, 0xFE, 0x00, 0x00, 0x0F, 0xE0, 0x00,
0x01, 0xFF, 0xF8, 0x00, 0x1F, 0xFF, 0xF0, 0x00, 0xFF, 0xFF, 0xF0, 0x07,
0xFF, 0xFF, 0xE0, 0x3F, 0xFF, 0xFF, 0xC1, 0xFF, 0xC3, 0xFF, 0x07, 0xF8,
0x03, 0xFE, 0x3F, 0xC0, 0x03, 0xF8, 0xFE, 0x00, 0x0F, 0xF7, 0xF8, 0x00,
0x1F, 0xDF, 0xC0, 0x00, 0x7F, 0x7F, 0x00, 0x00, 0x03, 0xFC, 0x00, 0x00,
0x0F, 0xE0, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x03,
0xF8, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x00, 0xFE,
0x00, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x0F, 0xF0, 0x00, 0x00, 0x1F, 0xC0,
0x00, 0x7F, 0x7F, 0x00, 0x01, 0xFD, 0xFC, 0x00, 0x07, 0xF7, 0xF8, 0x00,
0x3F, 0xCF, 0xF0, 0x00, 0xFE, 0x3F, 0xE0, 0x07, 0xF8, 0x7F, 0xC0, 0x7F,
0xC0, 0xFF, 0xFF, 0xFF, 0x03, 0xFF, 0xFF, 0xF8, 0x07, 0xFF, 0xFF, 0xC0,
0x07, 0xFF, 0xFE, 0x00, 0x0F, 0xFF, 0xE0, 0x00, 0x07, 0xFC, 0x00, 0xFF,
0xFF, 0xE0, 0x0F, 0xFF, 0xFF, 0x80, 0xFF, 0xFF, 0xFE, 0x0F, 0xFF, 0xFF,
0xF0, 0xFF, 0xFF, 0xFF, 0x0F, 0xFF, 0xFF, 0xF8, 0xFE, 0x00, 0x7F, 0xCF,
0xE0, 0x03, 0xFC, 0xFE, 0x00, 0x1F, 0xEF, 0xE0, 0x00, 0xFE, 0xFE, 0x00,
0x0F, 0xEF, 0xE0, 0x00, 0xFE, 0xFE, 0x00, 0x07, 0xFF, 0xE0, 0x00, 0x7F,
0xFE, 0x00, 0x07, 0xFF, 0xE0, 0x00, 0x7F, 0xFE, 0x00, 0x07, 0xFF, 0xE0,
0x00, 0x7F, 0xFE, 0x00, 0x07, 0xFF, 0xE0, 0x00, 0x7F, 0xFE, 0x00, 0x07,
0xFF, 0xE0, 0x00, 0xFF, 0xFE, 0x00, 0x0F, 0xEF, 0xE0, 0x00, 0xFE, 0xFE,
0x00, 0x1F, 0xEF, 0xE0, 0x01, 0xFE, 0xFE, 0x00, 0x3F, 0xCF, 0xE0, 0x0F,
0xFC, 0xFF, 0xFF, 0xFF, 0x8F, 0xFF, 0xFF, 0xF0, 0xFF, 0xFF, 0xFE, 0x0F,
0xFF, 0xFF, 0xC0, 0xFF, 0xFF, 0xF8, 0x0F, 0xFF, 0xFC, 0x00, 0xFF, 0xFF,
0xFF, 0x7F, 0xFF, 0xFF, 0xBF, 0xFF, 0xFF, 0xDF, 0xFF, 0xFF, 0xEF, 0xFF,
0xFF, 0xF7, 0xFF, 0xFF, 0xFB, 0xF8, 0x00, 0x01, 0xFC, 0x00, 0x00, 0xFE,
0x00, 0x00, 0x7F, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x1F, 0xC0, 0x00, 0x0F,
0xE0, 0x00, 0x07, 0xFF, 0xFF, 0xF3, 0xFF, 0xFF, 0xF9, 0xFF, 0xFF, 0xFC,
0xFF, 0xFF, 0xFE, 0x7F, 0xFF, 0xFF, 0x3F, 0xFF, 0xFF, 0x9F, 0xC0, 0x00,
0x0F, 0xE0, 0x00, 0x07, 0xF0, 0x00, 0x03, 0xF8, 0x00, 0x01, 0xFC, 0x00,
0x00, 0xFE, 0x00, 0x00, 0x7F, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x1F, 0xC0,
0x00, 0x0F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xC0, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0x00, 0x01, 0xFE, 0x00, 0x00, 0xFF, 0x00,
0x00, 0x7F, 0x80, 0x00, 0x3F, 0xC0, 0x00, 0x1F, 0xE0, 0x00, 0x0F, 0xF0,
0x00, 0x07, 0xFF, 0xFF, 0xF3, 0xFF, 0xFF, 0xF9, 0xFF, 0xFF, 0xFC, 0xFF,
0xFF, 0xFE, 0x7F, 0xFF, 0xFF, 0x3F, 0xFF, 0xFF, 0x9F, 0xE0, 0x00, 0x0F,
0xF0, 0x00, 0x07, 0xF8, 0x00, 0x03, 0xFC, 0x00, 0x01, 0xFE, 0x00, 0x00,
0xFF, 0x00, 0x00, 0x7F, 0x80, 0x00, 0x3F, 0xC0, 0x00, 0x1F, 0xE0, 0x00,
0x0F, 0xF0, 0x00, 0x07, 0xF8, 0x00, 0x03, 0xFC, 0x00, 0x01, 0xFE, 0x00,
0x00, 0xFF, 0x00, 0x00, 0x7F, 0x80, 0x00, 0x00, 0x00, 0x07, 0xF8, 0x00,
0x00, 0xFF, 0xFE, 0x00, 0x03, 0xFF, 0xFF, 0x00, 0x1F, 0xFF, 0xFF, 0x00,
0x7F, 0xFF, 0xFF, 0x01, 0xFF, 0xFF, 0xFF, 0x07, 0xFF, 0x03, 0xFF, 0x0F,
0xF8, 0x01, 0xFE, 0x3F, 0xC0, 0x01, 0xFE, 0x7F, 0x00, 0x01, 0xFD, 0xFE,
0x00, 0x03, 0xFB, 0xF8, 0x00, 0x03, 0xF7, 0xF0, 0x00, 0x00, 0x1F, 0xE0,
0x00, 0x00, 0x3F, 0x80, 0x00, 0x00, 0x7F, 0x00, 0x00, 0x00, 0xFE, 0x00,
0x3F, 0xFF, 0xFC, 0x00, 0x7F, 0xFF, 0xF8, 0x00, 0xFF, 0xFF, 0xF0, 0x01,
0xFF, 0xFF, 0xE0, 0x03, 0xFF, 0xFF, 0xC0, 0x07, 0xFF, 0xFF, 0xC0, 0x00,
0x1F, 0xBF, 0x80, 0x00, 0x3F, 0x7F, 0x00, 0x00, 0x7E, 0xFF, 0x00, 0x00,
0xFC, 0xFF, 0x00, 0x03, 0xF9, 0xFF, 0x00, 0x0F, 0xF1, 0xFF, 0x00, 0x3F,
0xE3, 0xFF, 0x83, 0xFF, 0xC3, 0xFF, 0xFF, 0xFF, 0x83, 0xFF, 0xFF, 0xEF,
0x03, 0xFF, 0xFF, 0x9E, 0x03, 0xFF, 0xFE, 0x3C, 0x01, 0xFF, 0xF0, 0x78,
0x00, 0x7F, 0x80, 0x00, 0xFE, 0x00, 0x07, 0xFF, 0xE0, 0x00, 0x7F, 0xFE,
0x00, 0x07, 0xFF, 0xE0, 0x00, 0x7F, 0xFE, 0x00, 0x07, 0xFF, 0xE0, 0x00,
0x7F, 0xFE, 0x00, 0x07, 0xFF, 0xE0, 0x00, 0x7F, 0xFE, 0x00, 0x07, 0xFF,
0xE0, 0x00, 0x7F, 0xFE, 0x00, 0x07, 0xFF, 0xE0, 0x00, 0x7F, 0xFE, 0x00,
0x07, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x00, 0x07, 0xFF, 0xE0,
0xFF, 0xE0, 0x00, 0x7F, 0xFE, 0x00, 0x07, 0xFF, 0xE0, 0x00, 0x7F, 0xFE,
0xE0, 0x00, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0x00, 0x01, 0xFC,
0x00, 0x07, 0xF0, 0x00, 0x1F, 0xC0, 0x00, 0x7F, 0x00, 0x01, 0xFC, 0x00,
0x07, 0xF0, 0x00, 0x1F, 0xC0, 0x00, 0x7F, 0x00, 0x01, 0xFC, 0x00, 0x07,
0xF0, 0x00, 0x1F, 0xC0, 0x00, 0x7F, 0x00, 0x01, 0xFC, 0x00, 0x07, 0xF0,
0x00, 0x1F, 0xC0, 0x00, 0x7F, 0x00, 0x01, 0xFC, 0x00, 0x07, 0xF0, 0x00,
0x1F, 0xC0, 0x00, 0x7F, 0x00, 0x01, 0xFF, 0xF8, 0x07, 0xFF, 0xE0, 0x1F,
0xFF, 0x80, 0x7F, 0xFE, 0x01, 0xFF, 0xF8, 0x07, 0xFF, 0xE0, 0x1F, 0xFF,
0xC0, 0xFF, 0x7F, 0x87, 0xF9, 0xFF, 0xFF, 0xE7, 0xFF, 0xFF, 0x8F, 0xFF,
0xFC, 0x1F, 0xFF, 0xE0, 0x3F, 0xFF, 0x00, 0x1F, 0xE0, 0x00, 0xFF, 0x00,
0x0F, 0xF9, 0xFE, 0x00, 0x3F, 0xE3, 0xFC, 0x00, 0xFF, 0x87, 0xF8, 0x01,
0xFE, 0x0F, 0xF0, 0x07, 0xF8, 0x1F, 0xE0, 0x1F, 0xE0, 0x3F, 0xC0, 0x7F,
0x80, 0x7F, 0x81, 0xFE, 0x00, 0xFF, 0x07, 0xF8, 0x01, 0xFE, 0x1F, 0xE0,
0x03, 0xFC, 0x7F, 0x80, 0x07, 0xF9, 0xFE, 0x00, 0x0F, 0xF3, 0xF8, 0x00,
0x1F, 0xEF, 0xF0, 0x00, 0x3F, 0xFF, 0xC0, 0x00, 0x7F, 0xFF, 0x80, 0x00,
0xFF, 0xFF, 0x80, 0x01, 0xFF, 0xFF, 0x80, 0x03, 0xFF, 0xFF, 0x80, 0x07,
0xFE, 0x7F, 0x00, 0x0F, 0xF8, 0xFF, 0x00, 0x1F, 0xF0, 0xFF, 0x00, 0x3F,
0xC0, 0xFF, 0x00, 0x7F, 0x81, 0xFF, 0x00, 0xFF, 0x01, 0xFE, 0x01, 0xFE,
0x01, 0xFE, 0x03, 0xFC, 0x01, 0xFE, 0x07, 0xF8, 0x03, 0xFE, 0x0F, 0xF0,
0x03, 0xFC, 0x1F, 0xE0, 0x03, 0xFC, 0x3F, 0xC0, 0x03, 0xFC, 0x7F, 0x80,
0x07, 0xFC, 0xFF, 0x00, 0x07, 0xFD, 0xFE, 0x00, 0x07, 0xF8, 0xFE, 0x00,
0x01, 0xFC, 0x00, 0x03, 0xF8, 0x00, 0x07, 0xF0, 0x00, 0x0F, 0xE0, 0x00,
0x1F, 0xC0, 0x00, 0x3F, 0x80, 0x00, 0x7F, 0x00, 0x00, 0xFE, 0x00, 0x01,
0xFC, 0x00, 0x03, 0xF8, 0x00, 0x07, 0xF0, 0x00, 0x0F, 0xE0, 0x00, 0x1F,
0xC0, 0x00, 0x3F, 0x80, 0x00, 0x7F, 0x00, 0x00, 0xFE, 0x00, 0x01, 0xFC,
0x00, 0x03, 0xF8, 0x00, 0x07, 0xF0, 0x00, 0x0F, 0xE0, 0x00, 0x1F, 0xC0,
0x00, 0x3F, 0x80, 0x00, 0x7F, 0x00, 0x00, 0xFE, 0x00, 0x01, 0xFC, 0x00,
0x03, 0xF8, 0x00, 0x07, 0xF0, 0x00, 0x0F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC,
0xFF, 0xE0, 0x01, 0xFF, 0xFF, 0xF0, 0x01, 0xFF, 0xFF, 0xF8, 0x00, 0xFF,
0xFF, 0xFC, 0x00, 0x7F, 0xFF, 0xFF, 0x00, 0x3F, 0xFF, 0xFF, 0x80, 0x1F,
0xFF, 0xFF, 0xC0, 0x1F, 0xFF, 0xFF, 0xE0, 0x0F, 0xFF, 0xFF, 0xF8, 0x07,
0xFF, 0xFF, 0x7C, 0x03, 0xFF, 0xFF, 0xBE, 0x03, 0xFF, 0xFF, 0xDF, 0x01,
0xF7, 0xFF, 0xEF, 0xC0, 0xFB, 0xFF, 0xF3, 0xE0, 0x7D, 0xFF, 0xF9, 0xF0,
0x3E, 0xFF, 0xFC, 0xF8, 0x3F, 0x7F, 0xFE, 0x7C, 0x1F, 0x3F, 0xFF, 0x1F,
0x0F, 0x9F, 0xFF, 0x8F, 0x87, 0xCF, 0xFF, 0xC7, 0xC7, 0xE7, 0xFF, 0xE3,
0xE3, 0xE3, 0xFF, 0xF1, 0xF9, 0xF1, 0xFF, 0xF8, 0x7C, 0xF8, 0xFF, 0xFC,
0x3E, 0x7C, 0x7F, 0xFE, 0x1F, 0x7E, 0x3F, 0xFF, 0x0F, 0xBE, 0x1F, 0xFF,
0x83, 0xFF, 0x0F, 0xFF, 0xC1, 0xFF, 0x87, 0xFF, 0xE0, 0xFF, 0xC3, 0xFF,
0xF0, 0x7F, 0xC1, 0xFF, 0xF8, 0x1F, 0xE0, 0xFF, 0xFC, 0x0F, 0xF0, 0x7F,
0xFE, 0x07, 0xF8, 0x3F, 0xFF, 0x03, 0xF8, 0x1F, 0xC0, 0xFF, 0x00, 0x07,
0xFF, 0xF0, 0x00, 0x7F, 0xFF, 0x80, 0x07, 0xFF, 0xFC, 0x00, 0x7F, 0xFF,
0xC0, 0x07, 0xFF, 0xFE, 0x00, 0x7F, 0xFF, 0xE0, 0x07, 0xFF, 0xFF, 0x00,
0x7F, 0xFF, 0xF8, 0x07, 0xFF, 0xFF, 0x80, 0x7F, 0xFF, 0xFC, 0x07, 0xFF,
0xEF, 0xC0, 0x7F, 0xFE, 0x7E, 0x07, 0xFF, 0xE7, 0xE0, 0x7F, 0xFE, 0x3F,
0x07, 0xFF, 0xE3, 0xF8, 0x7F, 0xFE, 0x1F, 0x87, 0xFF, 0xE1, 0xFC, 0x7F,
0xFE, 0x0F, 0xC7, 0xFF, 0xE0, 0x7E, 0x7F, 0xFE, 0x07, 0xF7, 0xFF, 0xE0,
0x3F, 0x7F, 0xFE, 0x03, 0xFF, 0xFF, 0xE0, 0x1F, 0xFF, 0xFE, 0x01, 0xFF,
0xFF, 0xE0, 0x0F, 0xFF, 0xFE, 0x00, 0x7F, 0xFF, 0xE0, 0x07, 0xFF, 0xFE,
0x00, 0x3F, 0xFF, 0xE0, 0x03, 0xFF, 0xFE, 0x00, 0x1F, 0xFF, 0xE0, 0x00,
0xFF, 0xFE, 0x00, 0x0F, 0xFF, 0xE0, 0x00, 0x7F, 0x00, 0x07, 0xF0, 0x00,
0x00, 0x1F, 0xFF, 0x00, 0x00, 0x3F, 0xFF, 0xE0, 0x00, 0x7F, 0xFF, 0xF8,
0x00, 0x7F, 0xFF, 0xFF, 0x00, 0x7F, 0xFF, 0xFF, 0xC0, 0x7F, 0xF0, 0x7F,
0xE0, 0x3F, 0xE0, 0x0F, 0xF8, 0x3F, 0xC0, 0x03, 0xFE, 0x1F, 0xC0, 0x00,
0xFF, 0x1F, 0xE0, 0x00, 0x3F, 0xCF, 0xE0, 0x00, 0x1F, 0xE7, 0xF0, 0x00,
0x07, 0xF7, 0xF8, 0x00, 0x03, 0xFB, 0xF8, 0x00, 0x01, 0xFF, 0xFC, 0x00,
0x00, 0x7F, 0xFE, 0x00, 0x00, 0x3F, 0xFF, 0x00, 0x00, 0x1F, 0xFF, 0x80,
0x00, 0x0F, 0xFF, 0xC0, 0x00, 0x07, 0xFF, 0xE0, 0x00, 0x03, 0xFF, 0xF0,
0x00, 0x01, 0xFF, 0xF8, 0x00, 0x01, 0xFF, 0xFE, 0x00, 0x00, 0xFE, 0x7F,
0x00, 0x00, 0x7F, 0x3F, 0xC0, 0x00, 0x7F, 0x9F, 0xE0, 0x00, 0x7F, 0x87,
0xF8, 0x00, 0x3F, 0xC3, 0xFE, 0x00, 0x7F, 0xC0, 0xFF, 0xC0, 0x7F, 0xE0,
0x3F, 0xFF, 0xFF, 0xE0, 0x0F, 0xFF, 0xFF, 0xE0, 0x03, 0xFF, 0xFF, 0xE0,
0x00, 0xFF, 0xFF, 0xE0, 0x00, 0x1F, 0xFF, 0xC0, 0x00, 0x01, 0xFF, 0x00,
0x00, 0xFF, 0xFF, 0xF0, 0x3F, 0xFF, 0xFF, 0x0F, 0xFF, 0xFF, 0xE3, 0xFF,
0xFF, 0xFC, 0xFF, 0xFF, 0xFF, 0x3F, 0xFF, 0xFF, 0xEF, 0xE0, 0x07, 0xFB,
0xF8, 0x00, 0xFE, 0xFE, 0x00, 0x3F, 0xFF, 0x80, 0x07, 0xFF, 0xE0, 0x01,
0xFF, 0xF8, 0x00, 0x7F, 0xFE, 0x00, 0x3F, 0xFF, 0x80, 0x0F, 0xEF, 0xE0,
0x07, 0xFB, 0xF8, 0x03, 0xFE, 0xFF, 0xFF, 0xFF, 0x3F, 0xFF, 0xFF, 0xCF,
0xFF, 0xFF, 0xE3, 0xFF, 0xFF, 0xF0, 0xFF, 0xFF, 0xF8, 0x3F, 0xFF, 0xF0,
0x0F, 0xE0, 0x00, 0x03, 0xF8, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x3F, 0x80,
0x00, 0x0F, 0xE0, 0x00, 0x03, 0xF8, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x3F,
0x80, 0x00, 0x0F, 0xE0, 0x00, 0x03, 0xF8, 0x00, 0x00, 0xFE, 0x00, 0x00,
0x3F, 0x80, 0x00, 0x00, 0x00, 0x07, 0xF0, 0x00, 0x00, 0x1F, 0xFF, 0x00,
0x00, 0x3F, 0xFF, 0xE0, 0x00, 0x7F, 0xFF, 0xFC, 0x00, 0x7F, 0xFF, 0xFF,
0x00, 0x7F, 0xFF, 0xFF, 0xC0, 0x7F, 0xF0, 0x7F, 0xE0, 0x3F, 0xE0, 0x0F,
0xF8, 0x3F, 0xE0, 0x01, 0xFE, 0x1F, 0xE0, 0x00, 0xFF, 0x1F, 0xE0, 0x00,
0x3F, 0xCF, 0xE0, 0x00, 0x0F, 0xE7, 0xF0, 0x00, 0x07, 0xF7, 0xF8, 0x00,
0x03, 0xFF, 0xF8, 0x00, 0x00, 0xFF, 0xFC, 0x00, 0x00, 0x7F, 0xFE, 0x00,
0x00, 0x3F, 0xFF, 0x00, 0x00, 0x1F, 0xFF, 0x80, 0x00, 0x0F, 0xFF, 0xC0,
0x00, 0x07, 0xFF, 0xE0, 0x00, 0x03, 0xFF, 0xF0, 0x00, 0x01, 0xFF, 0xFC,
0x00, 0x21, 0xFE, 0xFE, 0x00, 0x38, 0xFE, 0x7F, 0x00, 0x3E, 0x7F, 0x3F,
0xC0, 0x3F, 0xFF, 0x8F, 0xE0, 0x0F, 0xFF, 0x87, 0xF8, 0x03, 0xFF, 0xC1,
0xFE, 0x00, 0xFF, 0xC0, 0xFF, 0xC0, 0x7F, 0xE0, 0x3F, 0xFF, 0xFF, 0xF0,
0x0F, 0xFF, 0xFF, 0xFC, 0x03, 0xFF, 0xFF, 0xFF, 0x00, 0xFF, 0xFF, 0xFF,
0xC0, 0x1F, 0xFF, 0xCF, 0xC0, 0x01, 0xFF, 0x03, 0xC0, 0x00, 0x00, 0x00,
0xC0, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFC, 0x0F, 0xFF, 0xFF, 0xF0,
0xFF, 0xFF, 0xFF, 0x8F, 0xFF, 0xFF, 0xFC, 0xFF, 0xFF, 0xFF, 0xCF, 0xFF,
0xFF, 0xFE, 0xFE, 0x00, 0x1F, 0xEF, 0xE0, 0x00, 0xFE, 0xFE, 0x00, 0x0F,
0xEF, 0xE0, 0x00, 0xFE, 0xFE, 0x00, 0x0F, 0xEF, 0xE0, 0x00, 0xFE, 0xFE,
0x00, 0x0F, 0xEF, 0xE0, 0x01, 0xFC, 0xFE, 0x00, 0xFF, 0xCF, 0xFF, 0xFF,
0xF8, 0xFF, 0xFF, 0xFE, 0x0F, 0xFF, 0xFF, 0xC0, 0xFF, 0xFF, 0xFF, 0x0F,
0xFF, 0xFF, 0xF8, 0xFE, 0x00, 0xFF, 0xCF, 0xE0, 0x03, 0xFC, 0xFE, 0x00,
0x1F, 0xCF, 0xE0, 0x01, 0xFC, 0xFE, 0x00, 0x1F, 0xCF, 0xE0, 0x01, 0xFC,
0xFE, 0x00, 0x1F, 0xCF, 0xE0, 0x01, 0xFC, 0xFE, 0x00, 0x1F, 0xCF, 0xE0,
0x01, 0xFC, 0xFE, 0x00, 0x1F, 0xCF, 0xE0, 0x01, 0xFE, 0xFE, 0x00, 0x0F,
0xEF, 0xE0, 0x00, 0xFF, 0x00, 0x7F, 0x80, 0x00, 0x3F, 0xFF, 0x00, 0x0F,
0xFF, 0xFC, 0x01, 0xFF, 0xFF, 0xF0, 0x3F, 0xFF, 0xFF, 0x07, 0xFF, 0xFF,
0xF8, 0x7F, 0x80, 0x7F, 0xCF, 0xF0, 0x03, 0xFC, 0xFE, 0x00, 0x1F, 0xCF,
0xE0, 0x00, 0xFC, 0xFE, 0x00, 0x0F, 0xEF, 0xE0, 0x00, 0x00, 0xFF, 0x00,
0x00, 0x0F, 0xFC, 0x00, 0x00, 0x7F, 0xF8, 0x00, 0x07, 0xFF, 0xFC, 0x00,
0x3F, 0xFF, 0xFC, 0x01, 0xFF, 0xFF, 0xF0, 0x07, 0xFF, 0xFF, 0x80, 0x0F,
0xFF, 0xFC, 0x00, 0x07, 0xFF, 0xE0, 0x00, 0x07, 0xFE, 0x00, 0x00, 0x1F,
0xE0, 0x00, 0x00, 0xFF, 0x00, 0x00, 0x07, 0xFF, 0xC0, 0x00, 0x7F, 0xFE,
0x00, 0x07, 0xFF, 0xE0, 0x00, 0x7F, 0xFF, 0x00, 0x0F, 0xE7, 0xF8, 0x01,
0xFE, 0x7F, 0xFF, 0xFF, 0xC3, 0xFF, 0xFF, 0xFC, 0x1F, 0xFF, 0xFF, 0x80,
0xFF, 0xFF, 0xF0, 0x03, 0xFF, 0xFC, 0x00, 0x0F, 0xFE, 0x00, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xC0, 0x0F, 0xE0, 0x00, 0x01, 0xFC,
0x00, 0x00, 0x3F, 0x80, 0x00, 0x07, 0xF0, 0x00, 0x00, 0xFE, 0x00, 0x00,
0x1F, 0xC0, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x7F, 0x00, 0x00, 0x0F, 0xE0,
0x00, 0x01, 0xFC, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x07, 0xF0, 0x00, 0x00,
0xFE, 0x00, 0x00, 0x1F, 0xC0, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x7F, 0x00,
0x00, 0x0F, 0xE0, 0x00, 0x01, 0xFC, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x07,
0xF0, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x1F, 0xC0, 0x00, 0x03, 0xF8, 0x00,
0x00, 0x7F, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x01, 0xFC, 0x00, 0x00, 0x3F,
0x80, 0x00, 0x07, 0xF0, 0x00, 0xFE, 0x00, 0x0F, 0xFF, 0xC0, 0x01, 0xFF,
0xF8, 0x00, 0x3F, 0xFF, 0x00, 0x07, 0xFF, 0xE0, 0x00, 0xFF, 0xFC, 0x00,
0x1F, 0xFF, 0x80, 0x03, 0xFF, 0xF0, 0x00, 0x7F, 0xFE, 0x00, 0x0F, 0xFF,
0xC0, 0x01, 0xFF, 0xF8, 0x00, 0x3F, 0xFF, 0x00, 0x07, 0xFF, 0xE0, 0x00,
0xFF, 0xFC, 0x00, 0x1F, 0xFF, 0x80, 0x03, 0xFF, 0xF0, 0x00, 0x7F, 0xFE,
0x00, 0x0F, 0xFF, 0xC0, 0x01, 0xFF, 0xF8, 0x00, 0x3F, 0xFF, 0x00, 0x07,
0xFF, 0xE0, 0x00, 0xFF, 0xFC, 0x00, 0x1F, 0xFF, 0x80, 0x03, 0xFF, 0xF0,
0x00, 0x7F, 0xFE, 0x00, 0x0F, 0xFF, 0xC0, 0x03, 0xFF, 0xF8, 0x00, 0x7F,
0x7F, 0x80, 0x1F, 0xE7, 0xFC, 0x0F, 0xFC, 0xFF, 0xFF, 0xFF, 0x0F, 0xFF,
0xFF, 0xC0, 0xFF, 0xFF, 0xF8, 0x0F, 0xFF, 0xFC, 0x00, 0x7F, 0xFF, 0x00,
0x01, 0xFF, 0x00, 0x00, 0xFE, 0x00, 0x03, 0xFB, 0xF8, 0x00, 0x1F, 0xDF,
0xC0, 0x01, 0xFC, 0xFE, 0x00, 0x0F, 0xE3, 0xF8, 0x00, 0x7F, 0x1F, 0xC0,
0x03, 0xF0, 0xFE, 0x00, 0x3F, 0x83, 0xF8, 0x01, 0xFC, 0x1F, 0xC0, 0x0F,
0xC0, 0xFE, 0x00, 0xFE, 0x03, 0xF0, 0x07, 0xF0, 0x1F, 0xC0, 0x3F, 0x00,
0xFE, 0x01, 0xF8, 0x03, 0xF0, 0x1F, 0xC0, 0x1F, 0xC0, 0xFC, 0x00, 0xFE,
0x07, 0xE0, 0x03, 0xF0, 0x7F, 0x00, 0x1F, 0x83, 0xF0, 0x00, 0xFE, 0x1F,
0x80, 0x03, 0xF0, 0xFC, 0x00, 0x1F, 0x8F, 0xC0, 0x00, 0xFE, 0x7E, 0x00,
0x03, 0xF3, 0xF0, 0x00, 0x1F, 0xBF, 0x00, 0x00, 0xFF, 0xF8, 0x00, 0x03,
0xFF, 0xC0, 0x00, 0x1F, 0xFC, 0x00, 0x00, 0xFF, 0xE0, 0x00, 0x03, 0xFF,
0x00, 0x00, 0x1F, 0xF0, 0x00, 0x00, 0x7F, 0x80, 0x00, 0x03, 0xFC, 0x00,
0x00, 0x1F, 0xC0, 0x00, 0x00, 0x7E, 0x00, 0x00, 0xFE, 0x00, 0x3F, 0x80,
0x1F, 0xFF, 0xC0, 0x0F, 0xF0, 0x03, 0xFB, 0xFC, 0x01, 0xFE, 0x00, 0x7F,
0x3F, 0x80, 0x3F, 0xC0, 0x0F, 0xE7, 0xF0, 0x07, 0xFC, 0x03, 0xF8, 0xFE,
0x01, 0xFF, 0x80, 0x7F, 0x0F, 0xC0, 0x3F, 0xF0, 0x0F, 0xE1, 0xFC, 0x07,
0xFE, 0x01, 0xFC, 0x3F, 0x80, 0xFB, 0xE0, 0x3F, 0x07, 0xF0, 0x1F, 0x7C,
0x0F, 0xE0, 0x7E, 0x07, 0xEF, 0x81, 0xFC, 0x0F, 0xE0, 0xF9, 0xF0, 0x3F,
0x81, 0xFC, 0x1F, 0x3E, 0x07, 0xE0, 0x1F, 0x83, 0xE3, 0xE0, 0xFC, 0x03,
0xF0, 0x7C, 0x7C, 0x3F, 0x80, 0x7E, 0x1F, 0x8F, 0x87, 0xE0, 0x0F, 0xE3,
0xE1, 0xF0, 0xFC, 0x00, 0xFC, 0x7C, 0x3E, 0x1F, 0x80, 0x1F, 0x8F, 0x83,
0xE3, 0xF0, 0x03, 0xF1, 0xF0, 0x7C, 0xFC, 0x00, 0x7E, 0x7C, 0x0F, 0x9F,
0x80, 0x07, 0xEF, 0x81, 0xF3, 0xF0, 0x00, 0xFD, 0xF0, 0x1F, 0x7E, 0x00,
0x1F, 0xBE, 0x03, 0xEF, 0x80, 0x01, 0xF7, 0xC0, 0x7F, 0xF0, 0x00, 0x3F,
0xF0, 0x0F, 0xFE, 0x00, 0x07, 0xFE, 0x01, 0xFF, 0x80, 0x00, 0xFF, 0xC0,
0x1F, 0xF0, 0x00, 0x0F, 0xF8, 0x03, 0xFE, 0x00, 0x01, 0xFF, 0x00, 0x7F,
0xC0, 0x00, 0x3F, 0xC0, 0x0F, 0xF0, 0x00, 0x03, 0xF8, 0x01, 0xFE, 0x00,
0x00, 0x7F, 0x00, 0x1F, 0xC0, 0x00, 0x0F, 0xE0, 0x03, 0xF0, 0x00, 0x7F,
0x80, 0x07, 0xF9, 0xFF, 0x00, 0x3F, 0xC3, 0xFC, 0x00, 0xFF, 0x07, 0xF8,
0x07, 0xF8, 0x1F, 0xE0, 0x3F, 0xC0, 0x3F, 0xC0, 0xFF, 0x00, 0x7F, 0x07,
0xF8, 0x01, 0xFE, 0x1F, 0xC0, 0x03, 0xF8, 0xFF, 0x00, 0x0F, 0xF3, 0xF8,
0x00, 0x1F, 0xFF, 0xC0, 0x00, 0x3F, 0xFF, 0x00, 0x00, 0xFF, 0xF8, 0x00,
0x01, 0xFF, 0xE0, 0x00, 0x07, 0xFF, 0x00, 0x00, 0x0F, 0xF8, 0x00, 0x00,
0x1F, 0xE0, 0x00, 0x00, 0xFF, 0x80, 0x00, 0x03, 0xFF, 0x00, 0x00, 0x1F,
0xFE, 0x00, 0x00, 0xFF, 0xF8, 0x00, 0x03, 0xFF, 0xF0, 0x00, 0x1F, 0xFF,
0xC0, 0x00, 0x7F, 0x3F, 0x80, 0x03, 0xF8, 0xFF, 0x00, 0x1F, 0xE1, 0xFC,
0x00, 0x7F, 0x07, 0xF8, 0x03, 0xFC, 0x0F, 0xF0, 0x1F, 0xE0, 0x3F, 0xC0,
0x7F, 0x80, 0x7F, 0x83, 0xFC, 0x01, 0xFE, 0x0F, 0xF0, 0x03, 0xFC, 0x7F,
0x80, 0x0F, 0xFB, 0xFE, 0x00, 0x1F, 0xE0, 0x7F, 0x00, 0x07, 0xF9, 0xFE,
0x00, 0x1F, 0xE3, 0xF8, 0x00, 0xFF, 0x0F, 0xF0, 0x03, 0xFC, 0x1F, 0xC0,
0x0F, 0xE0, 0x7F, 0x80, 0x7F, 0x80, 0xFE, 0x01, 0xFC, 0x03, 0xFC, 0x0F,
0xF0, 0x07, 0xF0, 0x3F, 0x80, 0x1F, 0xE1, 0xFE, 0x00, 0x3F, 0x87, 0xF0,
0x00, 0xFF, 0x1F, 0xC0, 0x01, 0xFC, 0xFE, 0x00, 0x03, 0xF3, 0xF8, 0x00,
0x0F, 0xFF, 0xC0, 0x00, 0x1F, 0xFF, 0x00, 0x00, 0x7F, 0xF8, 0x00, 0x00,
0xFF, 0xE0, 0x00, 0x03, 0xFF, 0x00, 0x00, 0x07, 0xFC, 0x00, 0x00, 0x1F,
0xE0, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x03, 0xF8,
0x00, 0x00, 0x0F, 0xE0, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x00, 0xFE, 0x00,
0x00, 0x03, 0xF8, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x00, 0x3F, 0x80, 0x00,
0x00, 0xFE, 0x00, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x00,
0x3F, 0x80, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0x00,
0x07, 0xF8, 0x00, 0x03, 0xFE, 0x00, 0x00, 0xFF, 0x00, 0x00, 0x7F, 0x80,
0x00, 0x3F, 0xC0, 0x00, 0x1F, 0xF0, 0x00, 0x07, 0xF8, 0x00, 0x03, 0xFC,
0x00, 0x01, 0xFE, 0x00, 0x00, 0xFF, 0x80, 0x00, 0x7F, 0xC0, 0x00, 0x1F,
0xE0, 0x00, 0x0F, 0xF0, 0x00, 0x07, 0xF8, 0x00, 0x03, 0xFE, 0x00, 0x00,
0xFF, 0x00, 0x00, 0x7F, 0x80, 0x00, 0x3F, 0xC0, 0x00, 0x1F, 0xF0, 0x00,
0x0F, 0xF8, 0x00, 0x03, 0xFC, 0x00, 0x01, 0xFE, 0x00, 0x00, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xF8, 0x3F, 0x07, 0xE0, 0xFC, 0x1F, 0x83, 0xF0, 0x7E, 0x0F, 0xC1,
0xF8, 0x3F, 0x07, 0xE0, 0xFC, 0x1F, 0x83, 0xF0, 0x7E, 0x0F, 0xC1, 0xF8,
0x3F, 0x07, 0xE0, 0xFC, 0x1F, 0x83, 0xF0, 0x7E, 0x0F, 0xC1, 0xF8, 0x3F,
0x07, 0xE0, 0xFC, 0x1F, 0x83, 0xF0, 0x7E, 0x0F, 0xC1, 0xF8, 0x3F, 0x07,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x80, 0xF0, 0x00, 0xE0, 0x01, 0xC0, 0x03,
0xC0, 0x03, 0x80, 0x07, 0x00, 0x0F, 0x00, 0x0E, 0x00, 0x1C, 0x00, 0x38,
0x00, 0x38, 0x00, 0x70, 0x00, 0xE0, 0x00, 0xE0, 0x01, 0xC0, 0x03, 0x80,
0x03, 0x80, 0x07, 0x00, 0x0E, 0x00, 0x0E, 0x00, 0x1C, 0x00, 0x38, 0x00,
0x38, 0x00, 0x70, 0x00, 0xE0, 0x01, 0xE0, 0x01, 0xC0, 0x03, 0x80, 0x07,
0x80, 0x07, 0x00, 0x0E, 0x00, 0x1E, 0x00, 0x1C, 0x00, 0x38, 0x00, 0x78,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x0F, 0xC1, 0xF8, 0x3F, 0x07,
0xE0, 0xFC, 0x1F, 0x83, 0xF0, 0x7E, 0x0F, 0xC1, 0xF8, 0x3F, 0x07, 0xE0,
0xFC, 0x1F, 0x83, 0xF0, 0x7E, 0x0F, 0xC1, 0xF8, 0x3F, 0x07, 0xE0, 0xFC,
0x1F, 0x83, 0xF0, 0x7E, 0x0F, 0xC1, 0xF8, 0x3F, 0x07, 0xE0, 0xFC, 0x1F,
0x83, 0xF0, 0x7E, 0x0F, 0xC1, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x80,
0x00, 0xFC, 0x00, 0x07, 0xF0, 0x00, 0x1F, 0xC0, 0x00, 0xFF, 0x80, 0x03,
0xFE, 0x00, 0x0F, 0xFC, 0x00, 0x7D, 0xF0, 0x01, 0xF7, 0xC0, 0x0F, 0xDF,
0x80, 0x3E, 0x3E, 0x00, 0xF8, 0xFC, 0x07, 0xE1, 0xF0, 0x1F, 0x07, 0xC0,
0xFC, 0x1F, 0x83, 0xE0, 0x3E, 0x0F, 0x80, 0xFC, 0x7E, 0x01, 0xF1, 0xF0,
0x07, 0xC7, 0xC0, 0x1F, 0xBE, 0x00, 0x3E, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0xFC, 0x3E, 0x0F, 0x87, 0xC1, 0xF0,
0x78, 0x1E, 0x00, 0x7E, 0x00, 0x07, 0xFF, 0xC0, 0x0F, 0xFF, 0xF0, 0x1F,
0xFF, 0xF8, 0x3F, 0xFF, 0xF8, 0x3F, 0xFF, 0xFC, 0x7F, 0x01, 0xFC, 0x7F,
0x00, 0xFC, 0x7E, 0x00, 0xFC, 0x00, 0x01, 0xFC, 0x00, 0x07, 0xFC, 0x00,
0xFF, 0xFC, 0x0F, 0xFF, 0xFC, 0x1F, 0xFF, 0xFC, 0x3F, 0xFC, 0xFC, 0x7F,
0xC0, 0xFC, 0x7F, 0x00, 0xFC, 0xFE, 0x00, 0xFC, 0xFE, 0x01, 0xFC, 0xFE,
0x01, 0xFC, 0xFE, 0x03, 0xFC, 0xFF, 0x8F, 0xFC, 0x7F, 0xFF, 0xFC, 0x7F,
0xFF, 0xFC, 0x3F, 0xFE, 0xFE, 0x1F, 0xF8, 0xFF, 0x07, 0xE0, 0x00, 0xFC,
0x00, 0x00, 0xFC, 0x00, 0x00, 0xFC, 0x00, 0x00, 0xFC, 0x00, 0x00, 0xFC,
0x1F, 0x00, 0xFC, 0x7F, 0xC0, 0xFD, 0xFF, 0xF0, 0xFD, 0xFF, 0xF8, 0xFF,
0xFF, 0xF8, 0xFF, 0xFF, 0xFC, 0xFF, 0x83, 0xFE, 0xFF, 0x00, 0xFE, 0xFF,
0x00, 0xFE, 0xFE, 0x00, 0x7F, 0xFE, 0x00, 0x7F, 0xFE, 0x00, 0x7F, 0xFC,
0x00, 0x7F, 0xFC, 0x00, 0x7F, 0xFC, 0x00, 0x7F, 0xFC, 0x00, 0x7F, 0xFE,
0x00, 0x7F, 0xFE, 0x00, 0x7F, 0xFE, 0x00, 0xFE, 0xFF, 0x00, 0xFE, 0xFF,
0x81, 0xFE, 0xFF, 0xE7, 0xFC, 0xFF, 0xFF, 0xFC, 0xFF, 0xFF, 0xF8, 0xFD,
0xFF, 0xF0, 0xFC, 0xFF, 0xE0, 0x00, 0x3F, 0x80, 0x00, 0x7C, 0x00, 0x07,
0xFF, 0x00, 0x3F, 0xFF, 0x80, 0xFF, 0xFF, 0x83, 0xFF, 0xFF, 0x8F, 0xFF,
0xFF, 0x1F, 0xE0, 0x7F, 0x3F, 0x80, 0xFE, 0xFE, 0x00, 0xFD, 0xFC, 0x01,
0xFB, 0xF0, 0x00, 0x07, 0xE0, 0x00, 0x0F, 0xC0, 0x00, 0x1F, 0x80, 0x00,
0x3F, 0x00, 0x00, 0x7E, 0x00, 0x00, 0xFC, 0x00, 0x01, 0xFC, 0x01, 0xFF,
0xF8, 0x03, 0xF7, 0xF0, 0x0F, 0xE7, 0xF0, 0x1F, 0xCF, 0xF8, 0xFF, 0x0F,
0xFF, 0xFE, 0x0F, 0xFF, 0xF8, 0x0F, 0xFF, 0xE0, 0x0F, 0xFF, 0x80, 0x07,
0xF8, 0x00, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x1F, 0xC0, 0x00, 0x0F, 0xE0,
0x00, 0x07, 0xF0, 0x00, 0x03, 0xF8, 0x00, 0x01, 0xFC, 0x00, 0x00, 0xFE,
0x00, 0x00, 0x7F, 0x00, 0x78, 0x3F, 0x81, 0xFF, 0x9F, 0xC1, 0xFF, 0xEF,
0xE1, 0xFF, 0xFF, 0xF1, 0xFF, 0xFF, 0xF9, 0xFF, 0xFF, 0xFC, 0xFF, 0x07,
0xFE, 0xFF, 0x01, 0xFF, 0x7F, 0x00, 0x7F, 0xBF, 0x80, 0x3F, 0xDF, 0x80,
0x0F, 0xFF, 0xC0, 0x07, 0xFF, 0xE0, 0x03, 0xFF, 0xF0, 0x01, 0xFF, 0xF8,
0x00, 0xFF, 0xFC, 0x00, 0x7F, 0x7E, 0x00, 0x3F, 0xBF, 0x80, 0x3F, 0xDF,
0xC0, 0x1F, 0xEF, 0xF0, 0x1F, 0xF3, 0xF8, 0x1F, 0xF9, 0xFF, 0xBF, 0xFC,
0x7F, 0xFF, 0xFE, 0x1F, 0xFF, 0xFF, 0x0F, 0xFF, 0xBF, 0x81, 0xFF, 0x9F,
0xC0, 0x3F, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x03, 0xFF, 0x80, 0x07, 0xFF,
0xE0, 0x0F, 0xFF, 0xF0, 0x1F, 0xFF, 0xF8, 0x3F, 0xC7, 0xFC, 0x7F, 0x01,
0xFC, 0x7F, 0x00, 0xFE, 0x7E, 0x00, 0xFE, 0xFE, 0x00, 0x7E, 0xFE, 0x00,
0x7E, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFE, 0x00, 0x00, 0xFE, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x7E, 0x00,
0x00, 0x7E, 0x00, 0x7E, 0x7F, 0x00, 0xFE, 0x3F, 0x81, 0xFC, 0x3F, 0xFF,
0xFC, 0x1F, 0xFF, 0xF8, 0x0F, 0xFF, 0xF0, 0x07, 0xFF, 0xC0, 0x00, 0xFF,
0x00, 0x03, 0xF8, 0x1F, 0xE0, 0xFF, 0x83, 0xFE, 0x1F, 0xF8, 0x7F, 0x01,
0xFC, 0x07, 0xF0, 0x1F, 0xC3, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xF1, 0xFC, 0x07, 0xF0, 0x1F, 0xC0, 0x7F, 0x01, 0xFC, 0x07, 0xF0,
0x1F, 0xC0, 0x7F, 0x01, 0xFC, 0x07, 0xF0, 0x1F, 0xC0, 0x7F, 0x01, 0xFC,
0x07, 0xF0, 0x1F, 0xC0, 0x7F, 0x01, 0xFC, 0x07, 0xF0, 0x1F, 0xC0, 0x7F,
0x00, 0x00, 0xF0, 0x00, 0x0F, 0xF8, 0xFC, 0x3F, 0xFD, 0xF8, 0xFF, 0xFB,
0xF3, 0xFF, 0xFF, 0xE7, 0xFF, 0xFF, 0xDF, 0xE0, 0xFF, 0xBF, 0x80, 0xFF,
0xFE, 0x00, 0xFF, 0xFC, 0x01, 0xFF, 0xF8, 0x01, 0xFF, 0xE0, 0x03, 0xFF,
0xC0, 0x07, 0xFF, 0x80, 0x0F, 0xFF, 0x00, 0x1F, 0xFE, 0x00, 0x3F, 0xFC,
0x00, 0x7F, 0xFC, 0x00, 0xFF, 0xF8, 0x03, 0xFF, 0xF8, 0x07, 0xF7, 0xF8,
0x1F, 0xEF, 0xFD, 0xFF, 0xCF, 0xFF, 0xFF, 0x9F, 0xFF, 0xFF, 0x1F, 0xFF,
0x7E, 0x0F, 0xFC, 0xFC, 0x0F, 0xE1, 0xF8, 0x00, 0x03, 0xF0, 0x00, 0x07,
0xFF, 0xC0, 0x1F, 0xFF, 0xC0, 0x3F, 0xBF, 0xC1, 0xFE, 0x7F, 0xFF, 0xFC,
0x7F, 0xFF, 0xF0, 0x3F, 0xFF, 0x80, 0x1F, 0xFC, 0x00, 0xFE, 0x00, 0x03,
0xF8, 0x00, 0x0F, 0xE0, 0x00, 0x3F, 0x80, 0x00, 0xFE, 0x00, 0x03, 0xF8,
0x00, 0x0F, 0xE0, 0x00, 0x3F, 0x80, 0x00, 0xFE, 0x0F, 0x03, 0xF8, 0xFF,
0x8F, 0xEF, 0xFF, 0x3F, 0xFF, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xF8, 0x3F, 0xFF, 0xC0, 0x7F, 0xFE, 0x00, 0xFF, 0xF8, 0x03, 0xFF, 0xE0,
0x0F, 0xFF, 0x80, 0x3F, 0xFE, 0x00, 0xFF, 0xF8, 0x03, 0xFF, 0xE0, 0x0F,
0xFF, 0x80, 0x3F, 0xFE, 0x00, 0xFF, 0xF8, 0x03, 0xFF, 0xE0, 0x0F, 0xFF,
0x80, 0x3F, 0xFE, 0x00, 0xFF, 0xF8, 0x03, 0xFF, 0xE0, 0x0F, 0xFF, 0x80,
0x3F, 0xFE, 0x00, 0xFF, 0xF8, 0x03, 0xF0, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xC0, 0x00, 0x01, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFC, 0x1F, 0xC7, 0xF1, 0xFC, 0x7F, 0x1F, 0xC7, 0xF0, 0x00, 0x00, 0x00,
0x07, 0xF1, 0xFC, 0x7F, 0x1F, 0xC7, 0xF1, 0xFC, 0x7F, 0x1F, 0xC7, 0xF1,
0xFC, 0x7F, 0x1F, 0xC7, 0xF1, 0xFC, 0x7F, 0x1F, 0xC7, 0xF1, 0xFC, 0x7F,
0x1F, 0xC7, 0xF1, 0xFC, 0x7F, 0x1F, 0xC7, 0xF1, 0xFC, 0x7F, 0x1F, 0xC7,
0xF1, 0xFF, 0xFF, 0xFF, 0xFF, 0xEF, 0xFB, 0xFC, 0xFC, 0x00, 0x01, 0xF8,
0x00, 0x03, 0xF0, 0x00, 0x07, 0xE0, 0x00, 0x0F, 0xC0, 0x00, 0x1F, 0x80,
0x00, 0x3F, 0x00, 0x00, 0x7E, 0x00, 0x00, 0xFC, 0x00, 0x01, 0xF8, 0x07,
0xFB, 0xF0, 0x1F, 0xC7, 0xE0, 0x7F, 0x8F, 0xC1, 0xFE, 0x1F, 0x83, 0xF8,
0x3F, 0x0F, 0xE0, 0x7E, 0x3F, 0x80, 0xFC, 0xFE, 0x01, 0xFB, 0xF8, 0x03,
0xFF, 0xF0, 0x07, 0xFF, 0xE0, 0x0F, 0xFF, 0xE0, 0x1F, 0xFF, 0xC0, 0x3F,
0xFF, 0xC0, 0x7F, 0xBF, 0xC0, 0xFE, 0x3F, 0x81, 0xFC, 0x7F, 0x83, 0xF0,
0x7F, 0x07, 0xE0, 0x7F, 0x0F, 0xC0, 0xFF, 0x1F, 0x80, 0xFE, 0x3F, 0x01,
0xFE, 0x7E, 0x01, 0xFC, 0xFC, 0x03, 0xFD, 0xF8, 0x03, 0xF8, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFC, 0x00, 0x1F, 0x00, 0x7C, 0x0F, 0xC7, 0xFC, 0x1F,
0xF8, 0xFC, 0xFF, 0xE3, 0xFF, 0xCF, 0xDF, 0xFF, 0x7F, 0xFE, 0xFF, 0xFF,
0xFF, 0xFF, 0xEF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFF, 0x07, 0xFE, 0x0F, 0xFF,
0xE0, 0x3F, 0xC0, 0x7F, 0xFE, 0x03, 0xF8, 0x07, 0xFF, 0xE0, 0x3F, 0x80,
0x7F, 0xFC, 0x03, 0xF8, 0x07, 0xFF, 0xC0, 0x3F, 0x80, 0x7F, 0xFC, 0x03,
0xF8, 0x07, 0xFF, 0xC0, 0x3F, 0x80, 0x7F, 0xFC, 0x03, 0xF8, 0x07, 0xFF,
0xC0, 0x3F, 0x80, 0x7F, 0xFC, 0x03, 0xF8, 0x07, 0xFF, 0xC0, 0x3F, 0x80,
0x7F, 0x00, 0x0F, 0x81, 0xFC, 0xFF, 0xC3, 0xFB, 0xFF, 0xC7, 0xFF, 0xFF,
0xCF, 0xFF, 0xFF, 0xDF, 0xFF, 0xFF, 0xBF, 0xE0, 0xFF, 0x7F, 0x80, 0xFF,
0xFE, 0x00, 0xFF, 0xFC, 0x01, 0xFF, 0xF8, 0x03, 0xFF, 0xF0, 0x07, 0xFF,
0xE0, 0x0F, 0xFF, 0xC0, 0x1F, 0xFF, 0x80, 0x3F, 0xFF, 0x00, 0x7F, 0xFE,
0x00, 0xFF, 0xFC, 0x01, 0xFF, 0xF8, 0x03, 0xFF, 0xF0, 0x07, 0xFF, 0xE0,
0x0F, 0xFF, 0xC0, 0x1F, 0xFF, 0x80, 0x3F, 0xFF, 0x00, 0x7F, 0xFE, 0x00,
0xFF, 0xFC, 0x01, 0xFC, 0x00, 0x7E, 0x00, 0x01, 0xFF, 0xE0, 0x03, 0xFF,
0xFC, 0x03, 0xFF, 0xFF, 0x03, 0xFF, 0xFF, 0xC1, 0xFF, 0xFF, 0xF1, 0xFE,
0x07, 0xF8, 0xFE, 0x01, 0xFE, 0xFE, 0x00, 0x7F, 0x7F, 0x00, 0x3F, 0xBF,
0x80, 0x0F, 0xDF, 0x80, 0x07, 0xFF, 0xC0, 0x03, 0xFF, 0xE0, 0x01, 0xFF,
0xF0, 0x00, 0xFF, 0xF8, 0x00, 0x7F, 0xFE, 0x00, 0x3F, 0xFF, 0x00, 0x1F,
0xBF, 0x80, 0x1F, 0xCF, 0xE0, 0x0F, 0xE7, 0xF8, 0x0F, 0xE3, 0xFF, 0x1F,
0xF0, 0xFF, 0xFF, 0xF0, 0x3F, 0xFF, 0xF0, 0x0F, 0xFF, 0xF0, 0x03, 0xFF,
0xF0, 0x00, 0x3F, 0xC0, 0x00, 0x00, 0x1F, 0x00, 0xFC, 0x7F, 0xC0, 0xFC,
0xFF, 0xF0, 0xFD, 0xFF, 0xF8, 0xFF, 0xFF, 0xF8, 0xFF, 0xFF, 0xFC, 0xFF,
0x83, 0xFE, 0xFF, 0x01, 0xFE, 0xFE, 0x00, 0xFE, 0xFE, 0x00, 0x7F, 0xFE,
0x00, 0x7F, 0xFC, 0x00, 0x7F, 0xFC, 0x00, 0x7F, 0xFC, 0x00, 0x7F, 0xFC,
0x00, 0x7F, 0xFC, 0x00, 0x7F, 0xFE, 0x00, 0x7F, 0xFE, 0x00, 0x7F, 0xFE,
0x00, 0xFE, 0xFF, 0x00, 0xFE, 0xFF, 0x81, 0xFE, 0xFF, 0xE7, 0xFC, 0xFF,
0xFF, 0xFC, 0xFD, 0xFF, 0xF8, 0xFD, 0xFF, 0xF0, 0xFC, 0xFF, 0xE0, 0xFC,
0x3F, 0x80, 0xFC, 0x00, 0x00, 0xFC, 0x00, 0x00, 0xFC, 0x00, 0x00, 0xFC,
0x00, 0x00, 0xFC, 0x00, 0x00, 0x00, 0x78, 0x00, 0x01, 0xFF, 0x1F, 0xC1,
0xFF, 0xEF, 0xE1, 0xFF, 0xF7, 0xF1, 0xFF, 0xFF, 0xF9, 0xFF, 0xFF, 0xFC,
0xFF, 0x07, 0xFE, 0xFF, 0x01, 0xFF, 0x7F, 0x00, 0x7F, 0xBF, 0x80, 0x3F,
0xDF, 0x80, 0x0F, 0xFF, 0xC0, 0x07, 0xFF, 0xE0, 0x03, 0xFF, 0xF0, 0x01,
0xFF, 0xF8, 0x00, 0xFF, 0xFC, 0x00, 0x7F, 0x7E, 0x00, 0x3F, 0xBF, 0x00,
0x3F, 0xDF, 0xC0, 0x1F, 0xEF, 0xE0, 0x1F, 0xF3, 0xF8, 0x1F, 0xF9, 0xFF,
0x1F, 0xFC, 0x7F, 0xFF, 0xFE, 0x3F, 0xFF, 0xFF, 0x0F, 0xFF, 0xBF, 0x83,
0xFF, 0x9F, 0xC0, 0x7F, 0x0F, 0xE0, 0x00, 0x07, 0xF0, 0x00, 0x03, 0xF8,
0x00, 0x01, 0xFC, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x7F, 0x00, 0x00, 0x3F,
0x80, 0x00, 0x1F, 0xC0, 0x00, 0x0F, 0xE0, 0x00, 0x07, 0xF0, 0x00, 0x0F,
0xF8, 0xFF, 0xEF, 0xFF, 0xBF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xE0,
0xFF, 0x03, 0xF8, 0x0F, 0xE0, 0x3F, 0x80, 0xFE, 0x03, 0xF8, 0x0F, 0xE0,
0x3F, 0x80, 0xFE, 0x03, 0xF8, 0x0F, 0xE0, 0x3F, 0x80, 0xFE, 0x03, 0xF8,
0x0F, 0xE0, 0x3F, 0x80, 0xFE, 0x03, 0xF8, 0x00, 0x00, 0x7E, 0x00, 0x07,
0xFF, 0x80, 0x3F, 0xFF, 0xC0, 0xFF, 0xFF, 0xC3, 0xFF, 0xFF, 0xC7, 0xF8,
0xFF, 0x9F, 0xC0, 0x7F, 0x3F, 0x80, 0x7F, 0x7F, 0x00, 0xFE, 0xFF, 0x80,
0x01, 0xFF, 0xE0, 0x01, 0xFF, 0xF8, 0x03, 0xFF, 0xFF, 0x01, 0xFF, 0xFF,
0x00, 0xFF, 0xFF, 0x00, 0x3F, 0xFF, 0x00, 0x0F, 0xFE, 0x00, 0x03, 0xFC,
0x00, 0x01, 0xFF, 0xF0, 0x03, 0xF7, 0xF0, 0x0F, 0xEF, 0xF0, 0x3F, 0xDF,
0xFF, 0xFF, 0x1F, 0xFF, 0xFE, 0x1F, 0xFF, 0xF8, 0x1F, 0xFF, 0xE0, 0x07,
0xFE, 0x00, 0x1F, 0x80, 0xFC, 0x07, 0xE0, 0x3F, 0x01, 0xF8, 0x0F, 0xC0,
0x7E, 0x1F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF1, 0xF8, 0x0F,
0xC0, 0x7E, 0x03, 0xF0, 0x1F, 0x80, 0xFC, 0x07, 0xE0, 0x3F, 0x01, 0xF8,
0x0F, 0xC0, 0x7E, 0x03, 0xF0, 0x1F, 0x80, 0xFC, 0x07, 0xF0, 0x3F, 0x81,
0xFF, 0x8F, 0xFC, 0x3F, 0xE1, 0xFF, 0x03, 0xF8, 0xFC, 0x00, 0xFF, 0xF0,
0x03, 0xFF, 0xC0, 0x0F, 0xFF, 0x00, 0x3F, 0xFC, 0x00, 0xFF, 0xF0, 0x03,
0xFF, 0xC0, 0x0F, 0xFF, 0x00, 0x3F, 0xFC, 0x00, 0xFF, 0xF0, 0x03, 0xFF,
0xC0, 0x0F, 0xFF, 0x00, 0x3F, 0xFC, 0x00, 0xFF, 0xF0, 0x03, 0xFF, 0xC0,
0x0F, 0xFF, 0x00, 0x3F, 0xFC, 0x00, 0xFF, 0xF0, 0x07, 0xFF, 0xE0, 0x1F,
0xFF, 0xC0, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF7, 0xFF, 0xEF, 0xCF,
0xFF, 0xBF, 0x1F, 0xF8, 0xFC, 0x1F, 0xC0, 0x00, 0xFE, 0x00, 0x7F, 0xFE,
0x00, 0x7F, 0x7E, 0x00, 0xFE, 0x7F, 0x00, 0xFE, 0x7F, 0x00, 0xFE, 0x3F,
0x00, 0xFC, 0x3F, 0x81, 0xFC, 0x3F, 0x81, 0xF8, 0x1F, 0x81, 0xF8, 0x1F,
0xC3, 0xF8, 0x1F, 0xC3, 0xF0, 0x0F, 0xC3, 0xF0, 0x0F, 0xC3, 0xF0, 0x07,
0xE7, 0xE0, 0x07, 0xE7, 0xE0, 0x07, 0xE7, 0xE0, 0x03, 0xF7, 0xC0, 0x03,
0xFF, 0xC0, 0x03, 0xFF, 0xC0, 0x01, 0xFF, 0x80, 0x01, 0xFF, 0x80, 0x01,
0xFF, 0x80, 0x00, 0xFF, 0x00, 0x00, 0xFF, 0x00, 0x00, 0xFF, 0x00, 0xFE,
0x01, 0xFC, 0x07, 0xF7, 0xE0, 0x1F, 0xC0, 0x7E, 0x7F, 0x03, 0xFC, 0x07,
0xE7, 0xF0, 0x3F, 0xC0, 0xFE, 0x3F, 0x03, 0xFE, 0x0F, 0xE3, 0xF0, 0x3F,
0xE0, 0xFC, 0x3F, 0x87, 0xFE, 0x0F, 0xC3, 0xF8, 0x7F, 0xE1, 0xFC, 0x1F,
0x87, 0xFE, 0x1F, 0x81, 0xF8, 0x7D, 0xF1, 0xF8, 0x1F, 0xC7, 0x9F, 0x1F,
0x80, 0xFC, 0xF9, 0xF1, 0xF8, 0x0F, 0xCF, 0x9F, 0x3F, 0x00, 0xFC, 0xF8,
0xF3, 0xF0, 0x0F, 0xCF, 0x8F, 0xBF, 0x00, 0x7F, 0xF0, 0xFB, 0xF0, 0x07,
0xFF, 0x0F, 0xBE, 0x00, 0x7F, 0xF0, 0xFF, 0xE0, 0x03, 0xFF, 0x07, 0xFE,
0x00, 0x3F, 0xE0, 0x7F, 0xC0, 0x03, 0xFE, 0x07, 0xFC, 0x00, 0x3F, 0xE0,
0x7F, 0xC0, 0x01, 0xFE, 0x07, 0xFC, 0x00, 0x1F, 0xC0, 0x3F, 0x80, 0x01,
0xFC, 0x03, 0xF8, 0x00, 0xFF, 0x00, 0xFE, 0x7F, 0x81, 0xFE, 0x3F, 0x81,
0xFC, 0x3F, 0xC3, 0xF8, 0x1F, 0xC7, 0xF8, 0x0F, 0xE7, 0xF0, 0x0F, 0xFF,
0xE0, 0x07, 0xFF, 0xE0, 0x03, 0xFF, 0xC0, 0x03, 0xFF, 0x80, 0x01, 0xFF,
0x80, 0x00, 0xFF, 0x00, 0x00, 0xFF, 0x00, 0x01, 0xFF, 0x80, 0x01, 0xFF,
0x80, 0x03, 0xFF, 0xC0, 0x07, 0xFF, 0xE0, 0x07, 0xFF, 0xE0, 0x0F, 0xE7,
0xF0, 0x1F, 0xE7, 0xF8, 0x1F, 0xC3, 0xF8, 0x3F, 0xC3, 0xFC, 0x7F, 0x81,
0xFC, 0x7F, 0x01, 0xFE, 0xFF, 0x00, 0xFF, 0x7F, 0x00, 0x3F, 0xBF, 0x80,
0x1F, 0xDF, 0xE0, 0x0F, 0xC7, 0xF0, 0x0F, 0xE3, 0xF8, 0x07, 0xF0, 0xFC,
0x03, 0xF0, 0x7F, 0x01, 0xF8, 0x3F, 0x81, 0xFC, 0x0F, 0xC0, 0xFC, 0x07,
0xF0, 0x7E, 0x03, 0xF8, 0x7F, 0x00, 0xFC, 0x3F, 0x00, 0x7F, 0x1F, 0x80,
0x3F, 0x8F, 0x80, 0x0F, 0xCF, 0xC0, 0x07, 0xE7, 0xE0, 0x03, 0xFB, 0xE0,
0x00, 0xFF, 0xF0, 0x00, 0x7F, 0xF8, 0x00, 0x1F, 0xF8, 0x00, 0x0F, 0xFC,
0x00, 0x07, 0xFE, 0x00, 0x01, 0xFE, 0x00, 0x00, 0xFF, 0x00, 0x00, 0x7F,
0x80, 0x00, 0x1F, 0x80, 0x00, 0x0F, 0xC0, 0x00, 0x07, 0xE0, 0x00, 0x07,
0xE0, 0x00, 0x07, 0xF0, 0x00, 0x3F, 0xF8, 0x00, 0x1F, 0xF8, 0x00, 0x0F,
0xFC, 0x00, 0x07, 0xFC, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x7F, 0xFF, 0xFB,
0xFF, 0xFF, 0xDF, 0xFF, 0xFE, 0xFF, 0xFF, 0xF7, 0xFF, 0xFF, 0x80, 0x07,
0xF8, 0x00, 0x7F, 0x80, 0x07, 0xF8, 0x00, 0x7F, 0xC0, 0x03, 0xFC, 0x00,
0x3F, 0xC0, 0x03, 0xFC, 0x00, 0x3F, 0xC0, 0x03, 0xFC, 0x00, 0x3F, 0xE0,
0x01, 0xFE, 0x00, 0x1F, 0xE0, 0x01, 0xFE, 0x00, 0x1F, 0xE0, 0x01, 0xFE,
0xFF, 0xFF, 0xF8, 0x03, 0xF8, 0x3F, 0xC3, 0xFE, 0x1F, 0xF0, 0xFE, 0x07,
0xC0, 0x3E, 0x01, 0xF0, 0x0F, 0x80, 0x7C, 0x03, 0xE0, 0x1F, 0x00, 0xF8,
0x07, 0xC0, 0x3E, 0x01, 0xF0, 0x0F, 0x80, 0xFC, 0x07, 0xE1, 0xFE, 0x0F,
0xE0, 0x7C, 0x03, 0xFC, 0x1F, 0xE0, 0x1F, 0x80, 0xFC, 0x03, 0xE0, 0x1F,
0x00, 0xF8, 0x07, 0xC0, 0x3E, 0x01, 0xF0, 0x0F, 0x80, 0x7C, 0x03, 0xE0,
0x1F, 0x00, 0xF8, 0x07, 0xC0, 0x3F, 0x01, 0xFF, 0x0F, 0xF8, 0x3F, 0xC0,
0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x80, 0xFE, 0x03, 0xFC, 0x0F, 0xF8, 0x3F,
0xE0, 0x1F, 0xC0, 0x3F, 0x00, 0xFC, 0x03, 0xF0, 0x0F, 0xC0, 0x3F, 0x00,
0xFC, 0x03, 0xF0, 0x0F, 0xC0, 0x3F, 0x00, 0xFC, 0x03, 0xF0, 0x0F, 0xC0,
0x3F, 0x00, 0xFC, 0x01, 0xFC, 0x07, 0xFC, 0x07, 0xF0, 0x3F, 0xC1, 0xFF,
0x07, 0xE0, 0x3F, 0x00, 0xFC, 0x03, 0xF0, 0x0F, 0xC0, 0x3F, 0x00, 0xFC,
0x03, 0xF0, 0x0F, 0xC0, 0x3F, 0x00, 0xFC, 0x03, 0xF0, 0x0F, 0xC0, 0x3F,
0x01, 0xFC, 0x3F, 0xE0, 0xFF, 0x83, 0xFC, 0x0F, 0xE0, 0x00, 0x0F, 0x00,
0x01, 0xFE, 0x01, 0xDF, 0xF8, 0x0E, 0xFF, 0xF0, 0xFF, 0x0F, 0xEF, 0xF8,
0x3F, 0xFB, 0xC0, 0x7F, 0xC0, 0x01, 0xFC };
const GFXglyph FreeSansBold24pt7b_FULLGlyphs[] PROGMEM = {
{ 0, 0, 0, 13, 0, 1 }, // 0x20 ' '
{ 0, 7, 34, 16, 5, -33 }, // 0x21 '!'
{ 30, 18, 12, 22, 2, -33 }, // 0x22 '"'
{ 57, 26, 34, 26, 0, -32 }, // 0x23 '#'
{ 168, 24, 42, 26, 1, -35 }, // 0x24 '$'
{ 294, 40, 34, 42, 1, -32 }, // 0x25 '%'
{ 464, 30, 35, 34, 3, -33 }, // 0x26 '&'
{ 596, 7, 12, 11, 2, -33 }, // 0x27 '''
{ 607, 12, 43, 16, 2, -33 }, // 0x28 '('
{ 672, 12, 43, 16, 1, -33 }, // 0x29 ')'
{ 737, 16, 15, 18, 1, -33 }, // 0x2A '*'
{ 767, 23, 22, 27, 2, -21 }, // 0x2B '+'
{ 831, 7, 15, 13, 3, -6 }, // 0x2C ','
{ 845, 13, 6, 16, 1, -15 }, // 0x2D '-'
{ 855, 7, 7, 13, 3, -6 }, // 0x2E '.'
{ 862, 13, 35, 13, 0, -33 }, // 0x2F '/'
{ 919, 23, 35, 26, 1, -33 }, // 0x30 '0'
{ 1020, 15, 33, 26, 3, -32 }, // 0x31 '1'
{ 1082, 23, 34, 26, 1, -33 }, // 0x32 '2'
{ 1180, 23, 35, 26, 1, -33 }, // 0x33 '3'
{ 1281, 24, 33, 26, 1, -32 }, // 0x34 '4'
{ 1380, 23, 34, 26, 1, -32 }, // 0x35 '5'
{ 1478, 22, 35, 26, 2, -33 }, // 0x36 '6'
{ 1575, 24, 33, 26, 1, -32 }, // 0x37 '7'
{ 1674, 24, 35, 26, 1, -33 }, // 0x38 '8'
{ 1779, 23, 35, 26, 1, -33 }, // 0x39 '9'
{ 1880, 7, 24, 16, 5, -23 }, // 0x3A ':'
{ 1901, 7, 32, 16, 5, -23 }, // 0x3B ';'
{ 1929, 23, 22, 27, 2, -21 }, // 0x3C '<'
{ 1993, 23, 17, 27, 2, -18 }, // 0x3D '='
{ 2042, 23, 22, 27, 2, -21 }, // 0x3E '>'
{ 2106, 23, 35, 29, 3, -34 }, // 0x3F '?'
{ 2207, 44, 41, 46, 1, -34 }, // 0x40 '@'
{ 2433, 32, 34, 34, 1, -33 }, // 0x41 'A'
{ 2569, 27, 34, 34, 4, -33 }, // 0x42 'B'
{ 2684, 30, 36, 34, 2, -34 }, // 0x43 'C'
{ 2819, 28, 34, 34, 4, -33 }, // 0x44 'D'
{ 2938, 25, 34, 31, 4, -33 }, // 0x45 'E'
{ 3045, 25, 34, 29, 3, -33 }, // 0x46 'F'
{ 3152, 31, 36, 37, 2, -34 }, // 0x47 'G'
{ 3292, 28, 34, 34, 3, -33 }, // 0x48 'H'
{ 3411, 7, 34, 13, 3, -33 }, // 0x49 'I'
{ 3441, 22, 35, 26, 1, -33 }, // 0x4A 'J'
{ 3538, 31, 34, 34, 3, -33 }, // 0x4B 'K'
{ 3670, 23, 34, 29, 4, -33 }, // 0x4C 'L'
{ 3768, 33, 34, 39, 3, -33 }, // 0x4D 'M'
{ 3909, 28, 34, 34, 3, -33 }, // 0x4E 'N'
{ 4028, 33, 36, 37, 2, -34 }, // 0x4F 'O'
{ 4177, 26, 34, 31, 4, -33 }, // 0x50 'P'
{ 4288, 33, 38, 37, 2, -34 }, // 0x51 'Q'
{ 4445, 28, 34, 34, 4, -33 }, // 0x52 'R'
{ 4564, 28, 36, 31, 2, -34 }, // 0x53 'S'
{ 4690, 27, 34, 29, 1, -33 }, // 0x54 'T'
{ 4805, 27, 35, 34, 4, -33 }, // 0x55 'U'
{ 4924, 29, 34, 31, 1, -33 }, // 0x56 'V'
{ 5048, 43, 34, 44, 1, -33 }, // 0x57 'W'
{ 5231, 30, 34, 31, 1, -33 }, // 0x58 'X'
{ 5359, 30, 34, 31, 1, -33 }, // 0x59 'Y'
{ 5487, 26, 34, 29, 1, -33 }, // 0x5A 'Z'
{ 5598, 11, 43, 16, 3, -33 }, // 0x5B '['
{ 5658, 15, 35, 13, -1, -33 }, // 0x5C '\'
{ 5724, 11, 43, 16, 1, -33 }, // 0x5D ']'
{ 5784, 22, 20, 27, 3, -32 }, // 0x5E '^'
{ 5839, 28, 3, 26, -1, 7 }, // 0x5F '_'
{ 5850, 9, 7, 16, 1, -35 }, // 0x60 '`'
{ 5858, 24, 27, 26, 1, -25 }, // 0x61 'a'
{ 5939, 24, 35, 29, 3, -33 }, // 0x62 'b'
{ 6044, 23, 27, 26, 2, -25 }, // 0x63 'c'
{ 6122, 25, 35, 29, 1, -33 }, // 0x64 'd'
{ 6232, 24, 27, 26, 1, -25 }, // 0x65 'e'
{ 6313, 14, 34, 16, 1, -33 }, // 0x66 'f'
{ 6373, 23, 36, 29, 2, -25 }, // 0x67 'g'
{ 6477, 22, 34, 29, 3, -33 }, // 0x68 'h'
{ 6571, 7, 34, 13, 3, -33 }, // 0x69 'i'
{ 6601, 10, 44, 13, 0, -33 }, // 0x6A 'j'
{ 6656, 23, 34, 26, 3, -33 }, // 0x6B 'k'
{ 6754, 7, 34, 13, 3, -33 }, // 0x6C 'l'
{ 6784, 36, 26, 42, 3, -25 }, // 0x6D 'm'
{ 6901, 23, 26, 29, 3, -25 }, // 0x6E 'n'
{ 6976, 25, 27, 29, 2, -25 }, // 0x6F 'o'
{ 7061, 24, 36, 29, 3, -25 }, // 0x70 'p'
{ 7169, 25, 36, 29, 1, -25 }, // 0x71 'q'
{ 7282, 14, 26, 18, 3, -25 }, // 0x72 'r'
{ 7328, 23, 27, 26, 1, -25 }, // 0x73 's'
{ 7406, 13, 33, 16, 1, -31 }, // 0x74 't'
{ 7460, 22, 26, 29, 3, -24 }, // 0x75 'u'
{ 7532, 24, 25, 26, 1, -24 }, // 0x76 'v'
{ 7607, 36, 25, 37, 0, -24 }, // 0x77 'w'
{ 7720, 24, 25, 26, 1, -24 }, // 0x78 'x'
{ 7795, 25, 35, 26, 0, -24 }, // 0x79 'y'
{ 7905, 21, 25, 24, 1, -24 }, // 0x7A 'z'
{ 7971, 13, 43, 18, 2, -33 }, // 0x7B '{'
{ 8041, 3, 43, 13, 5, -33 }, // 0x7C '|'
{ 8058, 14, 43, 18, 3, -33 }, // 0x7D '}'
{ 8134, 21, 8, 27, 3, -14 } }; // 0x7E '~'
const GFXfont FreeSansBold24pt7b_FULL PROGMEM = {
(uint8_t *)FreeSansBold24pt7b_FULLBitmaps,
(GFXglyph *)FreeSansBold24pt7b_FULLGlyphs,
0x20, 0x7E, 65 };
// Approx. 8827 bytes
