SSD1306Ascii-Lib New Font with German Umlauts
Hello everybody,
I'm working on a small project where I have to display some data on a normal OLED-display. I used the "SSD1306Ascii" library. Everything works fine, but now I want to write data with german umlauts (e.g. ä, ö, ü ...). Because the Library don't support this in the standard version, I have to create a new font with this special letters. I read this post, but I've problems with the named software "openGLCDFontCreator". I downloaded it, but there are only ".java" and ".class"-files. I tried the full afternoon to open this files or as an alternative, to create a ".exe" or a ".jar"-file. Nothing works.
Does anybody know how to open the software or how to include these special letters into the library?
Hi @model_railroader
I believe that the Adafruit SSD1306 library uses the code page 437 character set, which contains characters with umlauts:
Looking at https://github.com/greiman/SSD1306Ascii/blob/master/src/fonts/Adafruit5x7.h
// standard ascii 5x7 font
// Restrict to 96 characters
#define ADAFRUIT_ASCII96 1
GLCDFONTDECL(Adafruit5x7) = {
Just change to
#define ADAFRUIT_ASCII96 0 //use the full-fat 255 letters
It looks as if most of the other fonts are 96 letters. But there are lots of PC programs that will generate fonts in this format.
David.
Busy, busy days before Christmas. Everything is a little bit chaotic this year. Sorry for my late answer. And, to top it all off, all your messages went into the spam inbox. :expressionless:
@MartinL Yes, it does! But the reason, why I'm using the SSD1306 lib is, that it doesn't use much storage and it's easy to use for my purposes. It'd be great when there is a solution for the SSD1306Ascii library.
@david_prentice Thanks for that advice. I tried it, but my oled shows me some very cryptic letters. And there is another problem: When I saw it right, Adafruit5x7 is the only font, which uses 255 chars. And I need at least 2 fonts with 2 different sizes.
Do you have an example? I tried "GLCD Font Creator" from MicroElectronica, but when I copy the exported lines into a script, it isn't working anyway. The displays shows me nothing. Here's my created file:
//Font Generated by MikroElektronika GLCD Font Creator 1.2.0.0
//MikroElektrnika 2011
//http://www.mikroe.com
//GLCD FontName : Arial_bold_14_G
//GLCD FontSize : 19 x 22
#define ARIAL_BOLD_14_G_WIDTH 19
#define ARIAL_BOLD_14_G_HEIGHT 22
GLCDFONTDECL(Arial_bold_14_G) = {
   0x00,
   0x00,
   0x20,0x00,
   0xFF,0x00,
   0x16,
   0x00,
   0x01,0x88,0x03,0x00,
   0x04,0x9E,0x03,0x00,
   0x08,0xB4,0x03,0x00,
   0x0B,0xCA,0x03,0x00,
   0x0A,0xF6,0x03,0x00,
   0x10,0x22,0x04,0x00,
   0x0E,0x4E,0x04,0x00,
   0x04,0x7A,0x04,0x00,
   0x06,0x90,0x04,0x00,
   0x05,0xA6,0x04,0x00,
   0x06,0xBC,0x04,0x00,
   0x0B,0xD2,0x04,0x00,
   0x04,0xFE,0x04,0x00,
   0x06,0x14,0x05,0x00,
   0x04,0x2A,0x05,0x00,
   0x05,0x40,0x05,0x00,
   0x0A,0x56,0x05,0x00,
   0x08,0x82,0x05,0x00,
   0x0A,0x98,0x05,0x00,
   0x0A,0xC4,0x05,0x00,
   0x0A,0xF0,0x05,0x00,
   0x0A,0x1C,0x06,0x00,
   0x0A,0x48,0x06,0x00,
   0x0A,0x74,0x06,0x00,
   0x0A,0xA0,0x06,0x00,
   0x0A,0xCC,0x06,0x00,
   0x05,0xF8,0x06,0x00,
   0x05,0x0E,0x07,0x00,
   0x0A,0x24,0x07,0x00,
   0x0A,0x50,0x07,0x00,
   0x0A,0x7C,0x07,0x00,
   0x0B,0xA8,0x07,0x00,
   0x13,0xD4,0x07,0x00,
   0x0D,0x16,0x08,0x00,
   0x0D,0x42,0x08,0x00,
   0x0D,0x6E,0x08,0x00,
   0x0D,0x9A,0x08,0x00,
   0x0C,0xC6,0x08,0x00,
   0x0B,0xF2,0x08,0x00,
   0x0E,0x1E,0x09,0x00,
   0x0C,0x4A,0x09,0x00,
   0x04,0x76,0x09,0x00,
   0x0A,0x8C,0x09,0x00,
   0x0D,0xB8,0x09,0x00,
   0x0B,0xE4,0x09,0x00,
   0x10,0x10,0x0A,0x00,
   0x0C,0x3C,0x0A,0x00,
   0x0E,0x68,0x0A,0x00,
   0x0C,0x94,0x0A,0x00,
   0x0F,0xC0,0x0A,0x00,
   0x0D,0xEC,0x0A,0x00,
   0x0C,0x18,0x0B,0x00,
   0x0C,0x44,0x0B,0x00,
   0x0C,0x70,0x0B,0x00,
   0x0D,0x9C,0x0B,0x00,
   0x11,0xC8,0x0B,0x00,
   0x0C,0x0A,0x0C,0x00,
   0x0C,0x36,0x0C,0x00,
   0x0B,0x62,0x0C,0x00,
   0x06,0x8E,0x0C,0x00,
   0x05,0xA4,0x0C,0x00,
   0x05,0xBA,0x0C,0x00,
   0x0A,0xD0,0x0C,0x00,
   0x0B,0xFC,0x0C,0x00,
   0x04,0x28,0x0D,0x00,
   0x0B,0x3E,0x0D,0x00,
   0x0B,0x6A,0x0D,0x00,
   0x0A,0x96,0x0D,0x00,
   0x0B,0xC2,0x0D,0x00,
   0x0A,0xEE,0x0D,0x00,
   0x07,0x1A,0x0E,0x00,
   0x0B,0x30,0x0E,0x00,
   0x0B,0x5C,0x0E,0x00,
   0x04,0x88,0x0E,0x00,
   0x04,0x9E,0x0E,0x00,
   0x0A,0xB4,0x0E,0x00,
   0x04,0xE0,0x0E,0x00,
   0x10,0xF6,0x0E,0x00,
   0x0B,0x22,0x0F,0x00,
   0x0B,0x4E,0x0F,0x00,
   0x0B,0x7A,0x0F,0x00,
   0x0B,0xA6,0x0F,0x00,
   0x08,0xD2,0x0F,0x00,
   0x0A,0xE8,0x0F,0x00,
   0x06,0x14,0x10,0x00,
   0x0B,0x2A,0x10,0x00,
   0x0A,0x56,0x10,0x00,
   0x0F,0x82,0x10,0x00,
   0x0A,0xAE,0x10,0x00,
   0x0B,0xDA,0x10,0x00,
   0x09,0x06,0x11,0x00,
   0x07,0x32,0x11,0x00,
   0x03,0x48,0x11,0x00,
   0x06,0x5E,0x11,0x00,
   0x0A,0x74,0x11,0x00,
   0x05,0xA0,0x11,0x00,
   0x01,0xB6,0x11,0x00,
   0x01,0xCC,0x11,0x00,
   0x01,0xE2,0x11,0x00,
   0x01,0xF8,0x11,0x00,
   0x01,0x0E,0x12,0x00,
   0x01,0x24,0x12,0x00,
   0x01,0x3A,0x12,0x00,
   0x01,0x50,0x12,0x00,
   0x01,0x66,0x12,0x00,
   0x01,0x7C,0x12,0x00,
   0x01,0x92,0x12,0x00,
   0x01,0xA8,0x12,0x00,
   0x01,0xBE,0x12,0x00,
   0x01,0xD4,0x12,0x00,
   0x01,0xEA,0x12,0x00,
   0x01,0x00,0x13,0x00,
   0x01,0x16,0x13,0x00,
   0x01,0x2C,0x13,0x00,
   0x01,0x42,0x13,0x00,
   0x01,0x58,0x13,0x00,
   0x01,0x6E,0x13,0x00,
   0x01,0x84,0x13,0x00,
   0x01,0x9A,0x13,0x00,
   0x01,0xB0,0x13,0x00,
   0x01,0xC6,0x13,0x00,
   0x01,0xDC,0x13,0x00,
   0x01,0xF2,0x13,0x00,
   0x01,0x08,0x14,0x00,
   0x01,0x1E,0x14,0x00,
   0x01,0x34,0x14,0x00,
   0x01,0x4A,0x14,0x00,
   0x01,0x60,0x14,0x00,
   0x01,0x76,0x14,0x00,
   0x05,0x8C,0x14,0x00,
   0x0B,0xA2,0x14,0x00,
   0x0B,0xCE,0x14,0x00,
   0x0A,0xFA,0x14,0x00,
   0x0B,0x26,0x15,0x00,
   0x03,0x52,0x15,0x00,
   0x0A,0x68,0x15,0x00,
   0x06,0x94,0x15,0x00,
   0x0E,0xAA,0x15,0x00,
   0x06,0xD6,0x15,0x00,
   0x0A,0xEC,0x15,0x00,
   0x0A,0x18,0x16,0x00,
   0x06,0x44,0x16,0x00,
   0x0E,0x5A,0x16,0x00,
   0x0B,0x86,0x16,0x00,
   0x07,0xB2,0x16,0x00,
   0x0B,0xC8,0x16,0x00,
   0x05,0xF4,0x16,0x00,
   0x06,0x0A,0x17,0x00,
   0x06,0x20,0x17,0x00,
   0x0A,0x36,0x17,0x00,
   0x0A,0x62,0x17,0x00,
   0x05,0x8E,0x17,0x00,
   0x05,0xA4,0x17,0x00,
   0x04,0xBA,0x17,0x00,
   0x07,0xD0,0x17,0x00,
   0x0A,0xE6,0x17,0x00,
   0x10,0x12,0x18,0x00,
   0x0F,0x3E,0x18,0x00,
   0x10,0x6A,0x18,0x00,
   0x0B,0x96,0x18,0x00,
   0x0D,0xC2,0x18,0x00,
   0x0D,0xEE,0x18,0x00,
   0x0D,0x1A,0x19,0x00,
   0x0D,0x46,0x19,0x00,
   0x0D,0x72,0x19,0x00,
   0x0D,0x9E,0x19,0x00,
   0x12,0xCA,0x19,0x00,
   0x0D,0x0C,0x1A,0x00,
   0x0C,0x38,0x1A,0x00,
   0x0C,0x64,0x1A,0x00,
   0x0C,0x90,0x1A,0x00,
   0x0C,0xBC,0x1A,0x00,
   0x04,0xE8,0x1A,0x00,
   0x05,0xFE,0x1A,0x00,
   0x05,0x14,0x1B,0x00,
   0x06,0x2A,0x1B,0x00,
   0x0D,0x40,0x1B,0x00,
   0x0C,0x6C,0x1B,0x00,
   0x0E,0x98,0x1B,0x00,
   0x0E,0xC4,0x1B,0x00,
   0x0E,0xF0,0x1B,0x00,
   0x0E,0x1C,0x1C,0x00,
   0x0E,0x48,0x1C,0x00,
   0x0A,0x74,0x1C,0x00,
   0x0F,0xA0,0x1C,0x00,
   0x0C,0xCC,0x1C,0x00,
   0x0C,0xF8,0x1C,0x00,
   0x0C,0x24,0x1D,0x00,
   0x0C,0x50,0x1D,0x00,
   0x0C,0x7C,0x1D,0x00,
   0x0C,0xA8,0x1D,0x00,
   0x0B,0xD4,0x1D,0x00,
   0x0B,0x00,0x1E,0x00,
   0x0B,0x2C,0x1E,0x00,
   0x0B,0x58,0x1E,0x00,
   0x0B,0x84,0x1E,0x00,
   0x0B,0xB0,0x1E,0x00,
   0x0B,0xDC,0x1E,0x00,
   0x10,0x08,0x1F,0x00,
   0x0A,0x34,0x1F,0x00,
   0x0A,0x60,0x1F,0x00,
   0x0A,0x8C,0x1F,0x00,
   0x0A,0xB8,0x1F,0x00,
   0x0A,0xE4,0x1F,0x00,
   0x04,0x10,0x20,0x00,
   0x05,0x26,0x20,0x00,
   0x05,0x3C,0x20,0x00,
   0x06,0x52,0x20,0x00,
   0x0B,0x68,0x20,0x00,
   0x0B,0x94,0x20,0x00,
   0x0B,0xC0,0x20,0x00,
   0x0B,0xEC,0x20,0x00,
   0x0B,0x18,0x21,0x00,
   0x0B,0x44,0x21,0x00,
   0x0B,0x70,0x21,0x00,
   0x0B,0x9C,0x21,0x00,
   0x0B,0xC8,0x21,0x00,
   0x0B,0xF4,0x21,0x00,
   0x0B,0x20,0x22,0x00,
   0x0B,0x4C,0x22,0x00,
   0x0B,0x78,0x22,0x00,
   0x0B,0xA4,0x22,0x00,
   0x0B,0xD0,0x22,0x00,
   0x0B,0xFC,0x22,0x00,
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 32
   0x00,0x00,0x00,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x04,0x04,0x00,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00, // Code for char num 33
   0x00,0x00,0x00,0x00,0xEE,0xEE,0xEE,0xEE,0xEE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 34
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x03,0x30,0x03,0x98,0x01,0xFF,0x07,0xFF,0x07,0x98,0x01,0x98,0x01,0xCC,0x00,0xFF,0x07,0xFF,0x07,0xCC,0x00,0xCC,0x00,0x66,0x00,0x66,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 35
   0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0xF8,0x00,0xFC,0x01,0xAE,0x03,0xAE,0x03,0x2E,0x00,0x3E,0x00,0xFC,0x00,0xF0,0x01,0xE0,0x03,0xA0,0x03,0xAE,0x03,0xAE,0x03,0xFC,0x01,0xF8,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,0x00, // Code for char num 36
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x18,0x66,0x0C,0x66,0x0C,0x66,0x06,0x66,0x06,0x66,0x06,0x3C,0x03,0x00,0x03,0x80,0x79,0x80,0xCD,0xC0,0xCC,0xC0,0xCC,0x60,0xCC,0x60,0xCC,0x30,0x78,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 37
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x00,0xFC,0x03,0x9C,0x03,0x9C,0x03,0x9C,0x03,0xF8,0x01,0xF8,0x00,0xFC,0x04,0xCE,0x1D,0xCE,0x0F,0x8E,0x07,0x8E,0x1F,0xFC,0x3F,0xF8,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 38
   0x00,0x00,0x00,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 39
   0x00,0x00,0x00,0x00,0x30,0x18,0x18,0x1C,0x1C,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x1C,0x1C,0x18,0x18,0x30, // Code for char num 40
   0x00,0x00,0x00,0x00,0x03,0x06,0x06,0x0E,0x0C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x0E,0x0E,0x06,0x06,0x03, // Code for char num 41
   0x00,0x00,0x00,0x00,0x0C,0x2D,0x3F,0x0C,0x1E,0x33,0x12,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 42
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0xFF,0x07,0xFF,0x07,0xFF,0x07,0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 43
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x0E,0x0E,0x08,0x0C,0x06,0x00, // Code for char num 44
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3E,0x3E,0x3E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 45
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00, // Code for char num 46
   0x00,0x00,0x00,0x00,0x18,0x18,0x0C,0x0C,0x0C,0x0C,0x0C,0x06,0x06,0x06,0x06,0x06,0x03,0x03,0x00,0x00,0x00,0x00, // Code for char num 47
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0xFC,0x01,0xDC,0x01,0x8E,0x03,0x8E,0x03,0x8E,0x03,0x8E,0x03,0x8E,0x03,0x8E,0x03,0x8E,0x03,0x8E,0x03,0xDC,0x01,0xFC,0x01,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 48
   0x00,0x00,0x00,0x00,0xC0,0xE0,0xF8,0xFC,0xEC,0xE4,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0x00,0x00,0x00,0x00, // Code for char num 49
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x00,0xFC,0x01,0x8E,0x03,0x8E,0x03,0x80,0x03,0x80,0x03,0xC0,0x01,0xE0,0x01,0xF0,0x00,0x78,0x00,0x38,0x00,0x1C,0x00,0xFE,0x03,0xFE,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 50
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x00,0xFC,0x01,0x8E,0x03,0x8E,0x03,0x80,0x03,0xE0,0x01,0xE0,0x01,0x80,0x03,0x80,0x03,0x80,0x03,0x8E,0x03,0x8E,0x03,0xFC,0x01,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 51
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0xF0,0x00,0xF0,0x00,0xF8,0x00,0xF8,0x00,0xEC,0x00,0xEC,0x00,0xE6,0x00,0xE3,0x00,0xFF,0x03,0xFF,0x03,0xE0,0x00,0xE0,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 52
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x01,0xF8,0x01,0x1C,0x00,0x1C,0x00,0xFC,0x00,0xFE,0x01,0xCE,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x8E,0x03,0xDE,0x01,0xFC,0x01,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 53
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x00,0xFC,0x01,0x9C,0x03,0x0E,0x00,0xEE,0x00,0xFE,0x01,0xDE,0x03,0x8E,0x03,0x8E,0x03,0x8E,0x03,0x8E,0x03,0xDC,0x01,0xFC,0x01,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 54
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x03,0xFE,0x03,0x80,0x03,0xC0,0x01,0xE0,0x00,0x70,0x00,0x70,0x00,0x38,0x00,0x38,0x00,0x38,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 55
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x00,0xFC,0x01,0x8E,0x03,0x8E,0x03,0x8E,0x03,0xDC,0x01,0xF8,0x00,0xF8,0x00,0xDC,0x01,0x8E,0x03,0x8E,0x03,0x8E,0x03,0xFC,0x01,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 56
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0xFC,0x01,0xDC,0x01,0x8E,0x03,0x8E,0x03,0x8E,0x03,0x8E,0x03,0xDE,0x03,0xFC,0x03,0xB8,0x03,0x80,0x03,0xCE,0x01,0xFC,0x01,0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 57
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x1C,0x1C,0x00,0x00,0x00,0x00,0x00,0x1C,0x1C,0x1C,0x00,0x00,0x00,0x00, // Code for char num 58
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x1C,0x1C,0x00,0x00,0x00,0x00,0x00,0x1C,0x1C,0x1C,0x10,0x18,0x0C,0x00, // Code for char num 59
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x80,0x03,0xF0,0x03,0xFC,0x00,0x1E,0x00,0x1E,0x00,0xFC,0x00,0xF0,0x03,0x80,0x03,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 60
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x03,0xFE,0x03,0xFE,0x03,0x00,0x00,0x00,0x00,0xFE,0x03,0xFE,0x03,0xFE,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 61
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x00,0x0E,0x00,0x7E,0x00,0xF8,0x01,0xC0,0x03,0xC0,0x03,0xF8,0x01,0x7E,0x00,0x0E,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 62
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x01,0xFC,0x03,0x9E,0x07,0x0E,0x07,0x80,0x07,0xC0,0x03,0xE0,0x01,0xF0,0x00,0x70,0x00,0x70,0x00,0x00,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 63
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x1F,0x00,0xE0,0x7F,0x00,0x70,0xE0,0x00,0x38,0xF7,0x01,0x9C,0xBF,0x03,0xCC,0x38,0x03,0xCE,0x38,0x03,0x66,0x38,0x03,0x66,0x18,0x03,0x66,0x18,0x03,0x66,0x9C,0x01,0x66,0xDC,0x01,0xCE,0xFF,0x00,0x8C,0x3B,0x00,0x1C,0x00,0x07,0x78,0xC0,0x03,0xE0,0xFF,0x01,0x80,0x3F,0x00, // Code for char num 64
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xB8,0x03,0xB8,0x03,0xB8,0x03,0x1C,0x07,0x1C,0x07,0xFC,0x07,0xFE,0x0F,0xFE,0x0F,0x0E,0x0E,0x07,0x1C,0x07,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 65
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x03,0xFE,0x07,0xFE,0x0F,0x0E,0x0E,0x0E,0x0E,0xFE,0x07,0xFE,0x07,0xFE,0x0F,0x0E,0x1C,0x0E,0x1C,0x0E,0x1C,0xFE,0x1F,0xFE,0x0F,0xFE,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 66
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x03,0xF8,0x0F,0xFC,0x0F,0x1C,0x1E,0x0E,0x0C,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x0C,0x1C,0x1E,0xFC,0x0F,0xF8,0x0F,0xE0,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 67
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x03,0xFE,0x07,0xFE,0x0F,0x0E,0x0E,0x0E,0x1C,0x0E,0x1C,0x0E,0x1C,0x0E,0x1C,0x0E,0x1C,0x0E,0x1C,0x0E,0x0E,0xFE,0x0F,0xFE,0x07,0xFE,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 68
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x0F,0xFE,0x0F,0xFE,0x0F,0x0E,0x00,0x0E,0x00,0xFE,0x07,0xFE,0x07,0xFE,0x07,0x0E,0x00,0x0E,0x00,0x0E,0x00,0xFE,0x0F,0xFE,0x0F,0xFE,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 69
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x07,0xFE,0x07,0xFE,0x07,0x0E,0x00,0x0E,0x00,0xFE,0x03,0xFE,0x03,0xFE,0x03,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 70
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x07,0xF8,0x1F,0xFC,0x1F,0x3C,0x3C,0x1E,0x18,0x0E,0x00,0x0E,0x00,0x0E,0x3F,0x0E,0x3F,0x1E,0x3F,0x3C,0x38,0xFC,0x3F,0xF8,0x1F,0xE0,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 71
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0xFE,0x0F,0xFE,0x0F,0xFE,0x0F,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 72
   0x00,0x00,0x00,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00, // Code for char num 73
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x87,0x03,0x87,0x03,0xFF,0x03,0xFE,0x01,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 74
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x1E,0x0E,0x0F,0x8E,0x07,0xCE,0x03,0xCE,0x01,0xEE,0x00,0xFE,0x01,0xFE,0x03,0x9E,0x03,0x0E,0x07,0x0E,0x07,0x0E,0x0E,0x0E,0x1C,0x0E,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 75
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0xFE,0x07,0xFE,0x07,0xFE,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 76
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3E,0xF8,0x3E,0xF8,0x7E,0xFC,0x6E,0xEC,0x6E,0xEC,0x6E,0xEC,0xEE,0xEE,0xCE,0xE6,0xCE,0xE6,0xCE,0xE6,0xCE,0xE7,0x8E,0xE3,0x8E,0xE3,0x8E,0xE3,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 77
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x0E,0x1E,0x0E,0x3E,0x0E,0x3E,0x0E,0x7E,0x0E,0x6E,0x0E,0xEE,0x0E,0xCE,0x0E,0xCE,0x0F,0x8E,0x0F,0x8E,0x0F,0x0E,0x0F,0x0E,0x0F,0x0E,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 78
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x03,0xF8,0x0F,0xFC,0x1F,0x3C,0x1E,0x1E,0x3C,0x0E,0x38,0x0E,0x38,0x0E,0x38,0x0E,0x38,0x1E,0x3C,0x3C,0x1E,0xFC,0x1F,0xF8,0x0F,0xE0,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 79
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x03,0xFE,0x07,0xFE,0x0F,0x0E,0x0F,0x0E,0x0E,0x0E,0x0F,0xFE,0x0F,0xFE,0x07,0xFE,0x03,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 80
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x03,0xF8,0x0F,0xFC,0x1F,0x3C,0x1E,0x1E,0x3C,0x0E,0x38,0x0E,0x38,0x0E,0x38,0x0E,0x39,0x9E,0x3B,0x3C,0x1F,0xFC,0x1F,0xF8,0x3F,0xE0,0x7B,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 81
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x03,0xFE,0x07,0xFE,0x0F,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0xFE,0x07,0xFE,0x07,0xFE,0x01,0xCE,0x03,0x8E,0x07,0x0E,0x07,0x0E,0x0F,0x0E,0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 82
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x01,0xFC,0x07,0xFE,0x07,0x0E,0x0F,0x0E,0x0E,0x3E,0x00,0xFC,0x01,0xF8,0x07,0x80,0x0F,0x0E,0x0E,0x1E,0x0E,0xFC,0x0F,0xFC,0x07,0xF0,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 83
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x0F,0xFE,0x0F,0xFE,0x0F,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 84
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x1E,0x0F,0xFC,0x07,0xFC,0x07,0xF0,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 85
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x1C,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x1C,0x07,0x1C,0x07,0x1C,0x07,0xB8,0x03,0xB8,0x03,0xB8,0x03,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 86
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x87,0xC3,0x01,0x87,0xC3,0x01,0xC7,0xC7,0x01,0xCE,0xE7,0x00,0xCE,0xE6,0x00,0xCE,0xE6,0x00,0xEE,0xEE,0x00,0xEE,0xEE,0x00,0x6E,0xEC,0x00,0x6E,0xEC,0x00,0x7C,0x7C,0x00,0x7C,0x7C,0x00,0x3C,0x78,0x00,0x3C,0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 87
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x0E,0x0E,0x0E,0x1C,0x07,0xB8,0x03,0xB8,0x03,0xF0,0x01,0xE0,0x00,0xE0,0x00,0xF0,0x01,0xB8,0x03,0xB8,0x03,0x1C,0x07,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 88
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x0E,0x0E,0x0E,0x1C,0x07,0x1C,0x07,0xB8,0x03,0xF0,0x01,0xF0,0x01,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 89
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x07,0xFE,0x07,0xFE,0x07,0x80,0x07,0xC0,0x03,0xE0,0x01,0xF0,0x00,0x78,0x00,0x3C,0x00,0x1E,0x00,0x0F,0x00,0xFF,0x07,0xFF,0x07,0xFF,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 90
   0x00,0x00,0x00,0x00,0x3E,0x3E,0x3E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x3E,0x3E,0x3E, // Code for char num 91
   0x00,0x00,0x00,0x00,0x03,0x03,0x06,0x06,0x06,0x06,0x06,0x0C,0x0C,0x0C,0x0C,0x0C,0x18,0x18,0x00,0x00,0x00,0x00, // Code for char num 92
   0x00,0x00,0x00,0x00,0x1F,0x1F,0x1F,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1F,0x1F,0x1F, // Code for char num 93
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0x70,0x00,0xF8,0x00,0xD8,0x00,0xDC,0x01,0x8C,0x01,0x8E,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 94
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x07,0xFF,0x07, // Code for char num 95
   0x00,0x00,0x00,0x00,0x07,0x06,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 96
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x00,0xFC,0x01,0x86,0x03,0xC0,0x03,0xF8,0x03,0xBC,0x03,0x8E,0x03,0x8E,0x03,0xCE,0x03,0xFC,0x03,0x38,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 97
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0xEE,0x01,0xFE,0x03,0x9E,0x03,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9E,0x03,0xFE,0x03,0xEE,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 98
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x00,0xFC,0x01,0x9C,0x03,0x0E,0x01,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x01,0x9C,0x03,0xFC,0x01,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 99
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x00,0x07,0x00,0x07,0x78,0x07,0xFC,0x07,0x9C,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9C,0x07,0xFC,0x07,0x78,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 100
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x00,0xFC,0x01,0x8C,0x03,0x8E,0x03,0xFE,0x03,0xFE,0x03,0x0E,0x00,0x0E,0x00,0x9C,0x03,0xFC,0x01,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 101
   0x00,0x00,0x00,0x00,0x7C,0x7E,0x0E,0x3F,0x3F,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00, // Code for char num 102
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x78,0x07,0xFC,0x07,0x9C,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9C,0x07,0xFC,0x07,0x78,0x07,0x00,0x07,0x0E,0x07,0xFE,0x03,0xF8,0x01, // Code for char num 103
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0xEE,0x01,0xFE,0x03,0x1E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 104
   0x00,0x00,0x00,0x00,0x0E,0x0E,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00, // Code for char num 105
   0x00,0x00,0x00,0x00,0x0E,0x0E,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0F,0x07, // Code for char num 106
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x8E,0x03,0xCE,0x01,0xEE,0x00,0x7E,0x00,0x7E,0x00,0xFE,0x00,0xEE,0x00,0xCE,0x01,0xCE,0x01,0x8E,0x03,0x8E,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 107
   0x00,0x00,0x00,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00, // Code for char num 108
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xEE,0x38,0xFE,0x7D,0x9E,0xE7,0x8E,0xE3,0x8E,0xE3,0x8E,0xE3,0x8E,0xE3,0x8E,0xE3,0x8E,0xE3,0x8E,0xE3,0x8E,0xE3,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 109
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xEE,0x01,0xFE,0x03,0x9E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 110
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x00,0xFC,0x03,0x9C,0x03,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9C,0x03,0xFC,0x03,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 111
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xEE,0x01,0xFE,0x03,0x9E,0x03,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9E,0x03,0xFE,0x03,0xEE,0x01,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00, // Code for char num 112
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x78,0x07,0xFC,0x07,0x9E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9C,0x07,0xFC,0x07,0x78,0x07,0x00,0x07,0x00,0x07,0x00,0x07,0x00,0x07, // Code for char num 113
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xEE,0xFE,0x1E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00, // Code for char num 114
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x00,0xFC,0x01,0x8E,0x03,0x0E,0x00,0x7E,0x00,0xFC,0x01,0xF0,0x03,0x80,0x03,0x8E,0x03,0xFC,0x01,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 115
   0x00,0x00,0x00,0x00,0x08,0x0C,0x0E,0x3F,0x3F,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x3E,0x3C,0x00,0x00,0x00,0x00, // Code for char num 116
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9E,0x07,0xFC,0x07,0x78,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 117
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8E,0x03,0x8E,0x03,0x8E,0x03,0x8C,0x01,0xDC,0x01,0xDC,0x01,0xD8,0x00,0xF8,0x00,0xF8,0x00,0x70,0x00,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 118
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC7,0x71,0xC7,0x71,0xC6,0x31,0xEE,0x3B,0x6E,0x3B,0x6C,0x1B,0x6C,0x1B,0x7C,0x1F,0x3C,0x1E,0x38,0x0E,0x38,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 119
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8E,0x03,0x8E,0x03,0xDC,0x01,0xF8,0x00,0xF8,0x00,0x70,0x00,0xF8,0x00,0xF8,0x00,0xDC,0x01,0x8E,0x03,0x8E,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 120
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x8E,0x03,0x8E,0x03,0x8E,0x03,0xDC,0x01,0xDC,0x01,0xD8,0x00,0xF8,0x00,0xF8,0x00,0x70,0x00,0x70,0x00,0x38,0x00,0x3E,0x00,0x1E,0x00, // Code for char num 121
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x01,0xFE,0x01,0xC0,0x01,0xE0,0x00,0x70,0x00,0x78,0x00,0x38,0x00,0x1C,0x00,0x0E,0x00,0xFE,0x01,0xFE,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 122
   0x00,0x00,0x00,0x00,0x70,0x78,0x18,0x18,0x18,0x18,0x18,0x1C,0x0E,0x0E,0x1C,0x18,0x18,0x18,0x18,0x18,0x78,0x70, // Code for char num 123
   0x00,0x00,0x00,0x00,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06, // Code for char num 124
   0x00,0x00,0x00,0x00,0x07,0x0F,0x0C,0x0C,0x0C,0x0C,0x0C,0x1C,0x38,0x38,0x1C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0F,0x07, // Code for char num 125
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x02,0xFF,0x03,0xFF,0x03,0xE1,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 126
   0x00,0x00,0x00,0x00,0x00,0x1F,0x1B,0x1B,0x1B,0x1B,0x1B,0x1B,0x1B,0x1B,0x1B,0x1B,0x1F,0x00,0x00,0x00,0x00,0x00, // Code for char num 127
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 128
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 129
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 130
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 131
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 132
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 133
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 134
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 135
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 136
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 137
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 138
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 139
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 140
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 141
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 142
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 143
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 144
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 145
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 146
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 147
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 148
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 149
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 150
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 151
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 152
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 153
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 154
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 155
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 156
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 157
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 158
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 159
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 160
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x1C,0x1C,0x00,0x08,0x08,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C, // Code for char num 161
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x00,0x03,0x00,0x01,0xF0,0x01,0xFC,0x01,0x9C,0x03,0x8E,0x07,0x4E,0x00,0x4E,0x00,0x4E,0x00,0x2E,0x07,0xBC,0x03,0xFC,0x03,0xF8,0x01,0x10,0x00,0x10,0x00,0x08,0x00,0x08,0x00, // Code for char num 162
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x00,0xFC,0x01,0xCE,0x03,0x8E,0x03,0x0E,0x00,0x0E,0x00,0x7F,0x00,0x7F,0x00,0x1C,0x00,0x1C,0x00,0x0E,0x00,0x7F,0x02,0xFF,0x07,0xE2,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 163
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x84,0x00,0xFE,0x01,0xFF,0x03,0xCE,0x01,0x86,0x01,0x86,0x01,0xCE,0x01,0xFF,0x03,0xFE,0x01,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 164
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x07,0x8E,0x03,0x8E,0x03,0xDC,0x01,0xDC,0x01,0xF8,0x00,0xFE,0x03,0xFE,0x03,0x70,0x00,0xFE,0x03,0xFE,0x03,0x70,0x00,0x70,0x00,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 165
   0x00,0x00,0x00,0x00,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x00,0x00,0x00,0x06,0x06,0x06,0x06,0x06,0x06,0x06, // Code for char num 166
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x78,0x00,0xFC,0x00,0xCE,0x01,0x0E,0x00,0x1C,0x00,0x7C,0x00,0xFE,0x00,0xE7,0x01,0xC7,0x03,0x8F,0x03,0x9E,0x03,0xFC,0x01,0xF8,0x00,0xE0,0x01,0xCE,0x01,0xCE,0x01,0xFC,0x00,0x78,0x00, // Code for char num 167
   0x00,0x00,0x00,0x00,0x33,0x33,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 168
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x01,0x18,0x06,0x04,0x08,0xE2,0x11,0x32,0x13,0x19,0x20,0x19,0x20,0x19,0x20,0x19,0x20,0x32,0x13,0xE2,0x11,0x04,0x08,0x18,0x06,0xE0,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 169
   0x00,0x00,0x00,0x00,0x1E,0x33,0x30,0x3E,0x33,0x33,0x3E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 170
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x03,0x98,0x01,0xDC,0x01,0xCC,0x00,0xEE,0x00,0xCC,0x00,0xDC,0x01,0x98,0x01,0x30,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 171
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x03,0xFE,0x03,0xFE,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 172
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3E,0x3E,0x3E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 173
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x01,0x18,0x06,0x04,0x08,0xF2,0x11,0x32,0x13,0x31,0x23,0x31,0x23,0xF1,0x21,0xB1,0x21,0x32,0x13,0x32,0x13,0x04,0x08,0x18,0x06,0xE0,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 174
   0x00,0x00,0x00,0x00,0xFF,0x07,0xFF,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 175
   0x00,0x00,0x00,0x00,0x3C,0x7E,0x66,0x66,0x7E,0x3C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 176
   0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0xFF,0x07,0xFF,0x07,0xFF,0x07,0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x00,0x00,0xFF,0x07,0xFF,0x07,0xFF,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 177
   0x00,0x00,0x00,0x00,0x0E,0x1B,0x18,0x1C,0x0E,0x07,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 178
   0x00,0x00,0x00,0x00,0x1E,0x33,0x30,0x1C,0x30,0x33,0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 179
   0x00,0x00,0x00,0x00,0x38,0x18,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 180
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8E,0x03,0x8E,0x03,0x8E,0x03,0x8E,0x03,0x8E,0x03,0x8E,0x03,0x8E,0x03,0x8E,0x03,0xDE,0x03,0xFE,0x03,0xAE,0x03,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00, // Code for char num 181
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFC,0x03,0xFE,0x03,0xBF,0x01,0xBF,0x01,0xBF,0x01,0xBF,0x01,0xBE,0x01,0xBC,0x01,0xB0,0x01,0xB0,0x01,0xB0,0x01,0xB0,0x01,0xB0,0x01,0xB0,0x01,0xB0,0x01,0xB0,0x01,0xB0,0x01,0xB0,0x01, // Code for char num 182
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x1C,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 183
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x18,0x0F,0x00, // Code for char num 184
   0x00,0x00,0x00,0x00,0x0C,0x0E,0x0F,0x0C,0x0C,0x0C,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 185
   0x00,0x00,0x00,0x00,0x3C,0x66,0x66,0x66,0x66,0x66,0x3C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 186
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x66,0x00,0xCC,0x00,0xDC,0x01,0x98,0x01,0xB8,0x03,0x98,0x01,0xDC,0x01,0xCC,0x00,0x66,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 187
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x0C,0x1C,0x0C,0x1E,0x06,0x18,0x06,0x18,0x03,0x18,0x03,0x98,0x01,0x80,0x61,0xC0,0x70,0x60,0x70,0x60,0x68,0x30,0x64,0x30,0xFC,0x18,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 188
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x0C,0x0E,0x0C,0x0F,0x06,0x0C,0x03,0x0C,0x03,0x8C,0x01,0x8C,0x01,0xC0,0x38,0x60,0x6C,0x60,0x60,0x30,0x70,0x30,0x38,0x18,0x1C,0x0C,0x7C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 189
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x18,0x33,0x0C,0x30,0x0C,0x1C,0x06,0x30,0x06,0x33,0x03,0x9E,0x01,0x80,0x61,0xC0,0x70,0xC0,0x70,0x60,0x68,0x60,0x64,0x30,0xFC,0x18,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 190
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0x00,0x00,0xE0,0x00,0xE0,0x00,0xF0,0x00,0x78,0x00,0x3C,0x00,0x1E,0x00,0x0E,0x00,0x0E,0x07,0x9E,0x07,0xFC,0x03,0xF0,0x01, // Code for char num 191
   0x70,0x00,0x60,0x00,0xC0,0x00,0x00,0x00,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xB8,0x03,0xB8,0x03,0xB8,0x03,0x1C,0x07,0x1C,0x07,0xFC,0x07,0xFE,0x0F,0xFE,0x0F,0x0E,0x0E,0x07,0x1C,0x07,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 192
   0xC0,0x01,0xC0,0x00,0x60,0x00,0x00,0x00,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xB8,0x03,0xB8,0x03,0xB8,0x03,0x1C,0x07,0x1C,0x07,0xFC,0x07,0xFE,0x0F,0xFE,0x0F,0x0E,0x0E,0x07,0x1C,0x07,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 193
   0x00,0x00,0xE0,0x00,0xB0,0x01,0x00,0x00,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xB8,0x03,0xB8,0x03,0xB8,0x03,0x1C,0x07,0x1C,0x07,0xFC,0x07,0xFE,0x0F,0xFE,0x0F,0x0E,0x0E,0x07,0x1C,0x07,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 194
   0x60,0x02,0xF0,0x03,0x90,0x01,0x00,0x00,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xB8,0x03,0xB8,0x03,0xB8,0x03,0x1C,0x07,0x1C,0x07,0xFC,0x07,0xFE,0x0F,0xFE,0x0F,0x0E,0x0E,0x07,0x1C,0x07,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 195
   0x00,0x00,0x30,0x03,0x30,0x03,0x00,0x00,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xB8,0x03,0xB8,0x03,0xB8,0x03,0x1C,0x07,0x1C,0x07,0xFC,0x07,0xFE,0x0F,0xFE,0x0F,0x0E,0x0E,0x07,0x1C,0x07,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 196
   0x00,0x00,0xC0,0x00,0x20,0x01,0x20,0x01,0xF0,0x01,0xF0,0x01,0xF0,0x01,0xB8,0x03,0xB8,0x03,0xB8,0x03,0x1C,0x07,0x1C,0x07,0xFC,0x07,0xFE,0x0F,0xFE,0x0F,0x0E,0x0E,0x07,0x1C,0x07,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 197
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xFF,0x03,0xE0,0xFF,0x03,0xE0,0xFF,0x03,0x70,0x07,0x00,0x70,0x07,0x00,0x38,0xFF,0x01,0x38,0xFF,0x01,0x1C,0xFF,0x01,0xFC,0x07,0x00,0xFE,0x07,0x00,0xFE,0x07,0x00,0x07,0xFF,0x03,0x07,0xFF,0x03,0x03,0xFF,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 198
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x03,0xF8,0x0F,0xFC,0x0F,0x1C,0x1E,0x0E,0x0C,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x0C,0x1C,0x1E,0xFC,0x0F,0xF8,0x0F,0xE0,0x03,0xE0,0x01,0x80,0x01,0xF0,0x00,0x00,0x00, // Code for char num 199
   0x70,0x00,0x60,0x00,0xC0,0x00,0x00,0x00,0xFE,0x0F,0xFE,0x0F,0xFE,0x0F,0x0E,0x00,0x0E,0x00,0xFE,0x07,0xFE,0x07,0xFE,0x07,0x0E,0x00,0x0E,0x00,0x0E,0x00,0xFE,0x0F,0xFE,0x0F,0xFE,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 200
   0xC0,0x01,0xC0,0x00,0x60,0x00,0x00,0x00,0xFE,0x0F,0xFE,0x0F,0xFE,0x0F,0x0E,0x00,0x0E,0x00,0xFE,0x07,0xFE,0x07,0xFE,0x07,0x0E,0x00,0x0E,0x00,0x0E,0x00,0xFE,0x0F,0xFE,0x0F,0xFE,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 201
   0x00,0x00,0xE0,0x00,0xB0,0x01,0x00,0x00,0xFE,0x0F,0xFE,0x0F,0xFE,0x0F,0x0E,0x00,0x0E,0x00,0xFE,0x07,0xFE,0x07,0xFE,0x07,0x0E,0x00,0x0E,0x00,0x0E,0x00,0xFE,0x0F,0xFE,0x0F,0xFE,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 202
   0x00,0x00,0x30,0x03,0x30,0x03,0x00,0x00,0xFE,0x0F,0xFE,0x0F,0xFE,0x0F,0x0E,0x00,0x0E,0x00,0xFE,0x07,0xFE,0x07,0xFE,0x07,0x0E,0x00,0x0E,0x00,0x0E,0x00,0xFE,0x0F,0xFE,0x0F,0xFE,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 203
   0x07,0x06,0x0C,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00, // Code for char num 204
   0x1C,0x0C,0x06,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00, // Code for char num 205
   0x00,0x0E,0x1B,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00, // Code for char num 206
   0x00,0x33,0x33,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00, // Code for char num 207
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x03,0xFE,0x07,0xFE,0x0F,0x0E,0x0E,0x0E,0x1C,0x0E,0x1C,0x7F,0x1C,0x7F,0x1C,0x0E,0x1C,0x0E,0x1C,0x0E,0x0E,0xFE,0x0F,0xFE,0x07,0xFE,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 208
   0x60,0x02,0xF0,0x03,0x90,0x01,0x00,0x00,0x1E,0x0E,0x1E,0x0E,0x3E,0x0E,0x3E,0x0E,0x7E,0x0E,0x6E,0x0E,0xEE,0x0E,0xCE,0x0E,0xCE,0x0F,0x8E,0x0F,0x8E,0x0F,0x0E,0x0F,0x0E,0x0F,0x0E,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 209
   0xC0,0x01,0x80,0x01,0x00,0x03,0x00,0x00,0xE0,0x03,0xF8,0x0F,0xFC,0x1F,0x3C,0x1E,0x1E,0x3C,0x0E,0x38,0x0E,0x38,0x0E,0x38,0x0E,0x38,0x1E,0x3C,0x3C,0x1E,0xFC,0x1F,0xF8,0x0F,0xE0,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 210
   0x80,0x03,0x80,0x01,0xC0,0x00,0x00,0x00,0xE0,0x03,0xF8,0x0F,0xFC,0x1F,0x3C,0x1E,0x1E,0x3C,0x0E,0x38,0x0E,0x38,0x0E,0x38,0x0E,0x38,0x1E,0x3C,0x3C,0x1E,0xFC,0x1F,0xF8,0x0F,0xE0,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 211
   0x00,0x00,0xC0,0x01,0x60,0x03,0x00,0x00,0xE0,0x03,0xF8,0x0F,0xFC,0x1F,0x3C,0x1E,0x1E,0x3C,0x0E,0x38,0x0E,0x38,0x0E,0x38,0x0E,0x38,0x1E,0x3C,0x3C,0x1E,0xFC,0x1F,0xF8,0x0F,0xE0,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 212
   0xC0,0x04,0xE0,0x07,0x20,0x03,0x00,0x00,0xE0,0x03,0xF8,0x0F,0xFC,0x1F,0x3C,0x1E,0x1E,0x3C,0x0E,0x38,0x0E,0x38,0x0E,0x38,0x0E,0x38,0x1E,0x3C,0x3C,0x1E,0xFC,0x1F,0xF8,0x0F,0xE0,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 213
   0x00,0x00,0x60,0x06,0x60,0x06,0x00,0x00,0xE0,0x03,0xF8,0x0F,0xFC,0x1F,0x3C,0x1E,0x1E,0x3C,0x0E,0x38,0x0E,0x38,0x0E,0x38,0x0E,0x38,0x1E,0x3C,0x3C,0x1E,0xFC,0x1F,0xF8,0x0F,0xE0,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 214
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x01,0x8E,0x03,0xDC,0x01,0xF8,0x00,0x70,0x00,0xF8,0x00,0xDC,0x01,0x8E,0x03,0x04,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 215
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0xE0,0x63,0xF8,0x3F,0xFC,0x1F,0x3C,0x1E,0x1E,0x3E,0x0E,0x3B,0x8E,0x39,0xCE,0x38,0x6E,0x38,0x3E,0x3C,0x3C,0x1E,0xFC,0x1F,0xFE,0x0F,0xF3,0x03,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 216
   0x70,0x00,0x60,0x00,0xC0,0x00,0x00,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x1E,0x0F,0xFC,0x07,0xFC,0x07,0xF0,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 217
   0xC0,0x01,0xC0,0x00,0x60,0x00,0x00,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x1E,0x0F,0xFC,0x07,0xFC,0x07,0xF0,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 218
   0x00,0x00,0xE0,0x00,0xB0,0x01,0x00,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x1E,0x0F,0xFC,0x07,0xFC,0x07,0xF0,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 219
   0x00,0x00,0x30,0x03,0x30,0x03,0x00,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x1E,0x0F,0xFC,0x07,0xFC,0x07,0xF0,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 220
   0xC0,0x01,0xC0,0x00,0x60,0x00,0x00,0x00,0x0E,0x0E,0x0E,0x0E,0x1C,0x07,0x1C,0x07,0xB8,0x03,0xF0,0x01,0xF0,0x01,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 221
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x00,0x1C,0x00,0xFC,0x03,0xFC,0x07,0xFC,0x0F,0x1C,0x0E,0x1C,0x0E,0x1C,0x0E,0xFC,0x0F,0xFC,0x07,0xFC,0x03,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 222
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x00,0xFC,0x01,0xCE,0x01,0xCE,0x01,0xCE,0x01,0xEE,0x00,0xEE,0x00,0xEE,0x01,0xCE,0x03,0x8E,0x07,0x0E,0x07,0x2E,0x07,0xFE,0x07,0xEE,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 223
   0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0x60,0x00,0xC0,0x00,0x00,0x00,0xF8,0x00,0xFC,0x01,0x86,0x03,0xC0,0x03,0xF8,0x03,0xBC,0x03,0x8E,0x03,0x8E,0x03,0xCE,0x03,0xFC,0x03,0x38,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 224
   0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0x60,0x00,0x30,0x00,0x00,0x00,0xF8,0x00,0xFC,0x01,0x86,0x03,0xC0,0x03,0xF8,0x03,0xBC,0x03,0x8E,0x03,0x8E,0x03,0xCE,0x03,0xFC,0x03,0x38,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 225
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0xD8,0x00,0x00,0x00,0xF8,0x00,0xFC,0x01,0x86,0x03,0xC0,0x03,0xF8,0x03,0xBC,0x03,0x8E,0x03,0x8E,0x03,0xCE,0x03,0xFC,0x03,0x38,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 226
   0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x01,0xF8,0x01,0xC8,0x00,0x00,0x00,0xF8,0x00,0xFC,0x01,0x86,0x03,0xC0,0x03,0xF8,0x03,0xBC,0x03,0x8E,0x03,0x8E,0x03,0xCE,0x03,0xFC,0x03,0x38,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 227
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x98,0x01,0x98,0x01,0x00,0x00,0xF8,0x00,0xFC,0x01,0x86,0x03,0xC0,0x03,0xF8,0x03,0xBC,0x03,0x8E,0x03,0x8E,0x03,0xCE,0x03,0xFC,0x03,0x38,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 228
   0x00,0x00,0x00,0x00,0x60,0x00,0x90,0x00,0x90,0x00,0x60,0x00,0x00,0x00,0xF8,0x00,0xFC,0x01,0x86,0x03,0xC0,0x03,0xF8,0x03,0xBC,0x03,0x8E,0x03,0x8E,0x03,0xCE,0x03,0xFC,0x03,0x38,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 229
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x3C,0xFC,0x7F,0x86,0x63,0x80,0xE3,0xE0,0xFF,0xFC,0xFF,0x9E,0x03,0x8E,0x03,0xCE,0xE7,0xFE,0x7F,0x7C,0x3C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 230
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x00,0xFC,0x01,0x9C,0x03,0x0E,0x01,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x01,0x9C,0x03,0xFC,0x01,0xF0,0x00,0xF0,0x00,0xC0,0x00,0x78,0x00,0x00,0x00, // Code for char num 231
   0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0x60,0x00,0xC0,0x00,0x00,0x00,0xF0,0x00,0xFC,0x01,0x8C,0x03,0x8E,0x03,0xFE,0x03,0xFE,0x03,0x0E,0x00,0x0E,0x00,0x9C,0x03,0xFC,0x01,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 232
   0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0x60,0x00,0x30,0x00,0x00,0x00,0xF0,0x00,0xFC,0x01,0x8C,0x03,0x8E,0x03,0xFE,0x03,0xFE,0x03,0x0E,0x00,0x0E,0x00,0x9C,0x03,0xFC,0x01,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 233
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0xD8,0x00,0x00,0x00,0xF0,0x00,0xFC,0x01,0x8C,0x03,0x8E,0x03,0xFE,0x03,0xFE,0x03,0x0E,0x00,0x0E,0x00,0x9C,0x03,0xFC,0x01,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 234
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x98,0x01,0x98,0x01,0x00,0x00,0xF0,0x00,0xFC,0x01,0x8C,0x03,0x8E,0x03,0xFE,0x03,0xFE,0x03,0x0E,0x00,0x0E,0x00,0x9C,0x03,0xFC,0x01,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 235
   0x00,0x00,0x00,0x07,0x06,0x0C,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00, // Code for char num 236
   0x00,0x00,0x00,0x1C,0x0C,0x06,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00, // Code for char num 237
   0x00,0x00,0x00,0x00,0x0E,0x1B,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00, // Code for char num 238
   0x00,0x00,0x00,0x00,0x33,0x33,0x00,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x00,0x00,0x00,0x00, // Code for char num 239
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x01,0xE0,0x00,0x90,0x01,0x70,0x03,0xFC,0x03,0x9C,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9C,0x03,0xFC,0x03,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 240
   0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x01,0xF8,0x01,0xC8,0x00,0x00,0x00,0xEE,0x01,0xFE,0x03,0x9E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 241
   0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0x60,0x00,0xC0,0x00,0x00,0x00,0xF0,0x00,0xFC,0x03,0x9C,0x03,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9C,0x03,0xFC,0x03,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 242
   0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0x60,0x00,0x30,0x00,0x00,0x00,0xF0,0x00,0xFC,0x03,0x9C,0x03,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9C,0x03,0xFC,0x03,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 243
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0xB0,0x01,0x00,0x00,0xF0,0x00,0xFC,0x03,0x9C,0x03,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9C,0x03,0xFC,0x03,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 244
   0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x01,0xF8,0x01,0xC8,0x00,0x00,0x00,0xF0,0x00,0xFC,0x03,0x9C,0x03,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9C,0x03,0xFC,0x03,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 245
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x98,0x01,0x98,0x01,0x00,0x00,0xF0,0x00,0xFC,0x03,0x9C,0x03,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9C,0x03,0xFC,0x03,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 246
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x00,0x00,0xFF,0x07,0xFF,0x07,0xFF,0x07,0x00,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 247
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x70,0x06,0xFC,0x03,0x9C,0x03,0x8E,0x03,0xCE,0x07,0x6E,0x07,0x3E,0x07,0x1E,0x07,0x9C,0x03,0xFC,0x03,0xE6,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 248
   0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0x60,0x00,0xC0,0x00,0x00,0x00,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9E,0x07,0xFC,0x07,0x78,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 249
   0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x01,0xC0,0x00,0x60,0x00,0x00,0x00,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9E,0x07,0xFC,0x07,0x78,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 250
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0xB0,0x01,0x00,0x00,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9E,0x07,0xFC,0x07,0x78,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 251
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x98,0x01,0x98,0x01,0x00,0x00,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9E,0x07,0xFC,0x07,0x78,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Code for char num 252
   0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0x60,0x00,0x30,0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x8E,0x03,0x8E,0x03,0x8E,0x03,0xDC,0x01,0xDC,0x01,0xD8,0x00,0xF8,0x00,0xF8,0x00,0x70,0x00,0x70,0x00,0x38,0x00,0x3E,0x00,0x1E,0x00, // Code for char num 253
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0xEE,0x01,0xFE,0x03,0x9E,0x03,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x0E,0x07,0x9E,0x03,0xFE,0x03,0xEE,0x01,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00, // Code for char num 254
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x98,0x01,0x98,0x01,0x00,0x00,0x07,0x07,0x07,0x07,0x8E,0x03,0x8E,0x03,0x8E,0x03,0xDC,0x01,0xDC,0x01,0xD8,0x00,0xF8,0x00,0xF8,0x00,0x70,0x00,0x70,0x00,0x38,0x00,0x3E,0x00,0x1E,0x00 // Code for char num 255
Last but not least: I wish everybody who is reading this lines a merry little Christmas, here in Germany we are celebrating Christmas already today at Christmas Eve!!!
At last, I figured out how to use umlauts and special characters in the library. For everybody, who maybe has the same problem, here's a possible solution:
The library uses for fonts the GLCDFONTDECL-format. It is possible to create or import a new font from windows with openGLCDFontCreator. You only have to install Java Runtime. Unfortunalety, the software can't export space, so you have to insert it by hand.
If you want to display a new character on the display, you're not able to do this:
oled.println("German umlauts: ÄÖÜ äöü");
You have to display the characters with the Ascii-Decimal-Number and his code:
oled.write(uint8_t c);
oled.write(196); // e.g. for Umlaut 'Ä'
If you want to display umlauts in a ticker as well, you have to replace some Ascii-characters with the characters you want. For example:
I replaced "%" with the umlaut "ä" by hand in the font. So now, if you want to write "Veränderung" (in english: change), you have to do it like this in your code:
oled.println("Ver%nderung");
Here are some links to read with further information:
GitHub Issue
Structure GLCDFONTDECL (in german)
If you have further questions, just ask me. Everything is a little bit tricky.
Everybody all the best 2022!
Yes, GLCDFontCreator will produce fonts for you.
  1. unpack ZIP. install in its own directory.
  2. click on "start.bat"
  3. File->New Font. edit suitable font name e.g. Arial16
  4. Import Font->select suitable font e.g. Arial
  5. Select Size e.g. 16
  6. Configure Char Count, Start Index
  7. click [OK]
  8. edit the font (if you want)
  9. Export->Export Font.
If you want to use the extended Ascii characters you will have to embed an escape into a quoted string. Or write individual characters.
If you want to program regular human readable text you need to use UTF8 capable library e.g. Ug2lib
David.
Sure, you can use e.g. Ug2lib anyway. But it's a good solution, if you don't want to rewrite all the code to another lib. And Ug2lib uses lot of RAM/memory.... :wink:
Yes, I agree. It is painful to re-write existing code.
You have to weigh up the convenience of readable UTF8 text versus re-writing code.
U8g2lib is frugal with SRAM but uses quite a lot of Flash. Mostly down to using multiple Fonts.
Personally, I am happier with Adafruit_GFX style graphics. And I can always add UTF8 and fancy Fonts via U8g2_for_Adafruit_GFX library.
You should choose whichever style of library that you are happiest with.
David.
