hi:
i am working on magnetic levitation project. my problem is magnetic field provided by the Electromagnet Lift Solenoid is oscillating a lot, i try to use a voltage regulator, but it doesn't help. the voltage supplied to the solenoid is still oscillating, and so is the magnetic field. is there any way to get the magnetic field stable? or is is the problem of the solenoid?
If you use a voltage regulator you'll magnetic field will almost surely become unstable and start fluctuating. Try the same with a constant current regulator!
Magnetic field are created by a current through a conductor. Of course the voltage is important, it's the pressure of the current, but it's the current that gives the field.
If you use a constant voltage regulator the current still bounces up and down.
If you use a constant current the voltage will fluctuate, but that's ok.
Shahriah of The Signal Path does a tutorial on this very subject.
He is very intelligent and great at explaining things, everyone here should have his blog and youtube channel bookmarked!
thank you, i will do the research on current regulator.
chen
?? Only if you are overloading the voltage regulator.
Is this a project from someone's website? Link? I see a MOSFET in the schematic. Using PWM with feedback means you must manage the feedback.
Do you know what PID is? Without it, it is like you trying to drive a car by turning the steering wheel all the way left or right to correct for the car being a little off from center.
It has nothing to do with voltage versus current regulators. In this circuit, it is much simpler to use a constant voltage supply.
Hi, can you redraw the diagram and replace 1,2,3 of the mosfet with gate ,drain and source.
Also where is the gnd of the arduino and the gnd of the power supply connection?
The way you have it at the moment you have no control because the gnd of the arduino is not connected to the rest of the circuit it is trying to control.
I agree with previous comments and advice , you need to control current and to do that you will need to monitor and feed back the coil current.
polymorph:
Well, getting a LM317 and adjusting it from constant voltage to constant current is a minor adjustment.
And as i said before, the strength of a magnetic field is made by the current, the voltage is just "nice to have" in the equation.
You should have learned from that reaction that handling these questions through a forum trumps doing those things in private messages, as others (perhaps just reading here) have the opportunity to learn from it too without even participating in the thread.
MAS3:
No, I was mocking lazy thinking and thus encouraging open discussion rather than solving an individuals problems.
C-F-K:
