Hello everyone!
I would like to carry out the project initiated here: Final MAGIC SWITCH BOX a great magic illusion trick
Unfortunately, I was unable to get this code to work.
First, I tried to make "PinChangeInt.h" work with the examples here: https://github.com/GreyGnome/PinChangeInt/tree/master/Examples
But none of them seem to work... It seems that the library is now deprecated.
So I switched to the "PinChangeInterrupt.h" library (version 1.2.9). I tested the examples here: https://github.com/NicoHood/PinChangeInterrupt/tree/master/examples
And these work work!
And now, a question appears: how do I retrieve the last interrupted pin so that the code can run normally?
Here's the code I'm using for the moment (I've replaced what I'm looking for with "?") :
// This software uses an ARDUINO NANO to make a "MAGIC SWITCH BOX". A great magic illusion trick.
// If you using other type of ARDUINO board, please adjust for used light- and switch- pins.
// What is a "MAGIC SWITCH BOX"?? .... check on youtube! http://www.youtube.com/watch?v=0lGP8nQLANU
// My verion have the function for user to secretly select 4 versions of lamp-light sequense.
// Written by Hans Naesstroem Stockholm SWEDEN jun 2014. The program is free to use by anyone.
// The order of lamps is default 1-2-3-4 and after that set by last switch turned off and time out.
// If last switch off = 2 gets seq 2 = 2-1-3-4. 3 gets seq 3 = 3-4-1-2. and 4 gets seq 4 = 4-3-2-1.
// Condition for reset is: All switches off AND done>0 AND reset_time elapsed --- then resets to new
// seq determent by last switch off, 1-2-3 or 4.
// Remember to start unit with all switches in OFF (open) state.
#include <PinChangeInterrupt.h>
#define pin_sw1 2 // defines for interrups.
#define pin_sw2 3 // pin_sw2 (switch 2) is connected to digital pin 3 and Ground. Switch NO.
#define pin_sw3 4
#define pin_sw4 5
// #define NO_PORTB_PINCHANGES ( Port B is all needed for this project).
#define NO_PORTC_PINCHANGES // not used, so save time and memory.
#define NO_PORTD_PINCHANGES
uint8_t latest_interrupted_pin = -1;
// `latest_interrupted_pin` will allways show what pin that trigged the latest interrupt
const int pin_la1 = 10; // pin_la1 (lamp 1) connected to digital pin 10 and Ground.
const int pin_la2 = 11;
const int pin_la3 = 12;
const int pin_la4 = 13;
int swi[] = {0, 0, 0, 0}; // switches related to lamps, (to be lerned in program run).
int stat[] = {1, 1, 1, 1}; // initiate status of switches, active low.
int seq = 1; // sequence to lit lamps, 1=1234, 2=2143, 3=3412, 4=4321.
int done = 0; // lerned number of switches.
int last_off = 1;
unsigned long time_out = millis(); // to calculate time_out.
pinMode(pin_sw1, INPUT_PULLUP); // pin_sw1 (switch 1) connected to digital pin 2 and ground.
pinMode(pin_sw2, INPUT_PULLUP); // internal pullup used.
pinMode(pin_sw3, INPUT_PULLUP);
pinMode(pin_sw4, INPUT_PULLUP);
attachPCINT(digitalPinToPCINT(pin_sw1), Int_swi, CHANGE);
attachPCINT(digitalPinToPCINT(pin_sw2), Int_swi, CHANGE);
attachPCINT(digitalPinToPCINT(pin_sw3), Int_swi, CHANGE);
attachPCINT(digitalPinToPCINT(pin_sw4), Int_swi, CHANGE);
pinMode(pin_la1, OUTPUT); // lamp pin is an output.
pinMode(pin_la2, OUTPUT);
pinMode(pin_la3, OUTPUT);
pinMode(pin_la4, OUTPUT);
digitalWrite(pin_la1, LOW); // turn off all lamps.
digitalWrite(pin_la2, LOW);
digitalWrite(pin_la3, LOW);
digitalWrite(pin_la4, LOW);
Serial.begin(9600); // enable serial monitor for debugging.
uint8_t i;
void loop() // MAIN LOOP ---------------------------
do
latest_interrupted_pin = ? ;
last_off = latest_interrupted_pin - 1;
// Serial.print("latest_interrupted_pin");
if (seq < 1)
seq = 1;
} // You may comment out all Serial.print when serial monitor not in use.
Serial.print("swi[0]: ");
Serial.print(swi[0]);
Serial.print(" stat[0]: ");
Serial.println(stat[0]);
Serial.print("swi[1]: ");
Serial.print(swi[1]);
Serial.print(" stat[1]: ");
Serial.println(stat[1]);
Serial.print("swi[2]: ");
Serial.print(swi[2]);
Serial.print(" stat[2]: ");
Serial.println(stat[2]);
Serial.print("swi[3]: ");
Serial.print(swi[3]);
Serial.print(" stat[3]: ");
Serial.println(stat[3]);
Serial.print(" done: ");
Serial.println(done);
Serial.print(" seq: ");
Serial.println(seq);
Serial.println("------------------------------------------------");
} while (millis() < ((time_out) + 4000)); // set to preferred time out (4 sec).
Serial.println("Timed out !!! ...");
if ((stat[0] == 1) && (stat[1] == 1) && (stat[2] == 1) && (stat[3] == 1) && (done > 0))
Serial.println("Running reset");
seq = latest_interrupted_pin - 1;
if (seq < 1)
seq = 1;
swi[0] = 0;
swi[1] = 0;
swi[2] = 0;
swi[3] = 0; // lamps related to switches.
done = 0;
} // END MAIN LOOP. -------------------------------
void Int_swi() // interrupt trigged by switches, CHANGE. ---------------------------------------
int sw = latest_interrupted_pin - 2;
Serial.print("latest_interrupted_pin :");
Serial.println(latest_interrupted_pin);
if (swi[sw] > 0)
stat[sw] = !stat[sw];
digitalWrite(swi[sw], stat[sw]);
} // turn on/off lamp
switch (seq)
case 1:
swi[sw] = done + 10;
case 2:
swi[sw] = 11 - done;
if (swi[sw] < 10)
swi[sw] = (10 + done);
case 3:
swi[sw] = 12 + done;
if (swi[sw] > 13)
swi[sw] = (8 + done);
case 4:
swi[sw] = 13 - done;
digitalWrite(swi[sw], LOW);
stat[sw] = !stat[sw]; // turn on lamp
++done; // increment counter for switches learned.
I'm working with an arduino nano V3, IDE: arduino IDE 2.2.1
Here are the connections :
Thanks for your help, I hope the problem comes from there.
