Hello everyone!
I wanted to test a project with the following code, which seems to work for many people:
// This software uses an ARDUINO NANO to make a "MAGIC SWITCH BOX". A great magic illusion trick.
// If you using other type of ARDUINO board, please adjust for used light- and switch- pins.
// What is a "MAGIC SWITCH BOX"?? .... check on youtube! http://www.youtube.com/watch?v=0lGP8nQLANU
// My verion have the function for user to secretly select 4 versions of lamp-light sequense.
// Written by Hans Naesstroem Stockholm SWEDEN jun 2014. The program is free to use by anyone.
// The order of lamps is default 1-2-3-4 and after that set by last switch turned off and time out.
// If last switch off = 2 gets seq 2 = 2-1-3-4. 3 gets seq 3 = 3-4-1-2. and 4 gets seq 4 = 4-3-2-1.
// Condition for reset is: All switches off AND done>0 AND reset_time elapsed --- then resets to new
// seq determent by last switch off, 1-2-3 or 4.
// Remember to start unit with all switches in OFF (open) state.
#include "PinChangeInt.h" // multi interrupt pins handler. download if you dont have it installed.
#define pin_sw1 2 // defines for interrups.
#define pin_sw2 3 // pin_sw2 (switch 2) is connected to digital pin 3 and Ground. Switch NO.
#define pin_sw3 4
#define pin_sw4 5
// #define NO_PORTB_PINCHANGES ( Port B is all needed for this project).
#define NO_PORTC_PINCHANGES // not used, so save time and memory.
#define NO_PORTD_PINCHANGES
uint8_t latest_interrupted_pin;
// `latest_interrupted_pin` will allways show what pin that trigged the latest interrupt
const int pin_la1 = 10; // pin_la1 (lamp 1) connected to digital pin 10 and Ground.
const int pin_la2 = 11;
const int pin_la3 = 12;
const int pin_la4 = 13;
int swi[]={0,0,0,0}; // switches related to lamps, (to be lerned in program run).
int stat[]={1,1,1,1}; // initiate status of switches, active low.
int seq=1; // sequence to lit lamps, 1=1234, 2=2143, 3=3412, 4=4321.
int done=0; // lerned number of switches.
int last_off=1;
unsigned long time_out = millis(); // to calculate time_out.
pinMode(pin_sw1,INPUT_PULLUP); // pin_sw1 (switch 1) connected to digital pin 2 and ground.
pinMode(pin_sw2,INPUT_PULLUP); // internal pullup used.
pinMode(pin_sw3,INPUT_PULLUP);
pinMode(pin_sw4,INPUT_PULLUP);
PCintPort::attachInterrupt (pin_sw1, Int_swi, CHANGE); // call Int_swi when pin_sw1 changes status.
PCintPort::attachInterrupt (pin_sw2, Int_swi, CHANGE);
PCintPort::attachInterrupt (pin_sw3, Int_swi, CHANGE);
PCintPort::attachInterrupt (pin_sw4, Int_swi, CHANGE);
pinMode(pin_la1,OUTPUT); // lamp pin is an output.
pinMode(pin_la2,OUTPUT);
pinMode(pin_la3,OUTPUT);
pinMode(pin_la4,OUTPUT);
digitalWrite(pin_la1,LOW); // turn off all lamps.
digitalWrite(pin_la2,LOW);
digitalWrite(pin_la3,LOW);
digitalWrite(pin_la4,LOW);
Serial.begin(9600); // enable serial monitor for debugging.
uint8_t i;
void loop() // MAIN LOOP ---------------------------
time_out=millis();
do {
latest_interrupted_pin=PCintPort::arduinoPin ;
last_off = latest_interrupted_pin-1;
if (seq<1) {seq=1;} // You may comment out all Serial.print when serial monitor not in use.
Serial.print ("swi[0]: "); Serial.print (swi[0]); Serial.print (" stat[0]: "); Serial.println (stat[0]);
Serial.print ("swi[1]: "); Serial.print (swi[1]); Serial.print (" stat[1]: "); Serial.println (stat[1]);
Serial.print ("swi[2]: "); Serial.print (swi[2]); Serial.print (" stat[2]: "); Serial.println (stat[2]);
Serial.print ("swi[3]: "); Serial.print (swi[3]); Serial.print (" stat[3]: "); Serial.println (stat[3]);
Serial.print (" done: ");
Serial.println (done);
Serial.print (" seq: ");
Serial.println (seq);
Serial.println ("------------------------------------------------");
delay (1000);
while (millis()<((time_out)+4000)); // set to preferred time out (4 sec).
Serial.println ("Timed out !!! ...");
if ((stat[0]==1) && (stat[1]==1) && (stat[2]==1) && (stat[3]==1)&& (done>0)){
Serial.println ("Running reset");
seq=latest_interrupted_pin-1;
if (seq<1) {seq=1;}
swi[0] =0; swi[1] =0; swi[2] =0; swi[3] =0; // lamps related to switches.
done=0;
} // END MAIN LOOP. -------------------------------
void Int_swi() // interrupt trigged by switches, CHANGE. ---------------------------------------
int sw = latest_interrupted_pin-2; // sw = 0,1,2 or 3
if (swi[sw] > 0) {stat[sw] = !stat[sw]; digitalWrite(swi[sw],stat[sw]); } // turn on/off lamp
else {
switch (seq){
case 1: {swi[sw] = done+10;} break;
case 2: {{swi[sw] = 11-done;}
if (swi[sw]<10) {swi[sw]= (10+done);}} break;
case 3: {{swi[sw] = 12+done;}
if (swi[sw]>13) {swi[sw] = (8+done);}} break;
case 4: {swi[sw] = 13-done;} break;
digitalWrite (swi[sw],LOW); stat[sw] = !stat[sw]; // turn on lamp
++done; // increment counter for switches learned.
It was developed with an Arduino Nano. Currently, I only have a Mega 2560 board and I'd like to run this code on it.
Here's how the board is connected:
I've tested many combinations for the pins, with no effect, notably on the assumption that D2 to D13 on the Nano correspond respectively to D22 to D33 on the Mega.
Nothing happens and nothing is displayed in the serial monitor. By adding a "Serial.println("End Setup");" at the end of the setup function, the serial monitor displays: 22:45:18.034 -> "�����C�C�C��C�C�C�C�C�C
The original code comes from this post: Final MAGIC SWITCH BOX a great magic illusion trick
Thanks for your help!
