Hi all!
I have a question that might sound elementary to someone with coding experience but I’m still new to coding.
I’m using a feather huzzah esp8266 to send and receive data to/from adafruit IO website (IoT).
In their provided examples, they have a function onMessage() that receives data from website if any data is available. The argument for onMessage() is a function that will do what the user needs to do with the data, but does NOT return a value.
calib_test->onMessage(handleMessage2);
Here calib_test is the name of the feed where the data comes from and handleMessage2 is a function that prints the action and the value. (I dont understand the concept of the arrow ->)
And that is my problem right there. I’d like to be able to use the received number from the website to adjust other values that are being sent out (calibrating sensor data based on input from the website).
I would appreciate it if anyone could provide any help!
/************************ Adafruit IO Configuration *******************************/
// Adafruit info
#define IO_USERNAME ""
#define IO_KEY ""
/******************************* WIFI Configuration *******************************/
#define WIFI_SSID ""
#define WIFI_PASS ""
#include "AdafruitIO_WiFi.h"
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
/************************ Main Program Starts Here *******************************/
#include <ESP8266WiFi.h> //related to IoT
#include <AdafruitIO.h>
#include <Adafruit_MQTT.h>
#include <ArduinoHttpClient.h>
#include <Arduino.h> //related to sensor
#include <Wire.h>
#include "Adafruit_SHT31.h"
// set up the feeds to adafruit io
AdafruitIO_Feed *hum_test = io.feed("hum_test");
AdafruitIO_Feed *temp_test = io.feed("temp_test");
AdafruitIO_Feed *led_test = io.feed("led_test");
AdafruitIO_Feed *calib_test = io.feed("calib_test");
// initiating the sensor
Adafruit_SHT31 sht31 = Adafruit_SHT31();
// initiating constatns
unsigned long previousMillis = 0; // used to count time in the loop
const long interval = 10000; // sampling interval of sensor in milli seconds
int cal_val = 0; // calibration value
// start the serial connection
pinMode(0, OUTPUT); // red LED
pinMode(2, OUTPUT); // blue LED
// connect to io.adafruit.com
Serial.print("Connecting to Adafruit IO");
io.connect();
// set up a message handler for the 'temp_test' feed.
// the handleMessage function (defined below)
// will be called whenever a message is
// received from adafruit io.
led_test->onMessage(handleMessage);
// wait for a connection
while(io.status() < AIO_CONNECTED) {
Serial.print(".");
// we are connected
Serial.println(io.statusText());
if (! sht31.begin(0x44)) {
Serial.print("Could not find SHT31");
while (1) delay(1);
// io.run(); is required for all sketches.
// it should always be present at the top of your loop
// function. it keeps the client connected to
// io.adafruit.com, and processes any incoming data.
io.run();
// reading sensor info
float t = sht31.readTemperature();
float h = sht31.readHumidity() + cal_val;
float hF = h * 1.8 + 32.0; // Celsius to Fahrenheit
if (currentMillis - previousMillis >= interval) {
digitalWrite(2, LOW); //turning on blue LED
// printing and uploading sensor info to feeds on Adafruit
Serial.println("Sending data -> ");
if (! isnan(t)) {
Serial.print("Temp *C = "); Serial.println(t);
temp_test->save(t);
Serial.println("Failed to read Tempreture");
if (! isnan(h)) {
Serial.print("Hum. % = "); Serial.println(h);
hum_test->save(h);
Serial.println("Failed to read Humidity");
//delay(5000);
digitalWrite(2, HIGH); //turning off blue LED
// This function is called whenever a 'led_test' message
// is received from Adafruit IO. it is attached to
// the led_test feed in the setup() function above.
void handleMessage(AdafruitIO_Data *data) {
digitalWrite(0, data->toPinLevel());
int led_test = data->toInt();
Serial.print("received LED value <- ");
Serial.println(led_test);
// This function is called whenever a 'calib_test' message
// is recieved from Adafruit IO. it is attached to
// the calib_test feed in setup() function above.
void handleMessage2(AdafruitIO_Data *data2) {
int cal_val = data2->toInt();
Serial.print("received Calibration value <- ");
Serial.println(cal_val);
//return cal_val;
