How to implement ESPAsyncWebServer - callBack function does not work
my project is about changing credential automatically with hardcoding in esp32 and then after that esp32 connected to the router, I want to send my photo to the server using button.
so my project has 2 stage: 1-changing credential is done using WebServer.h library and 2-taking photo is done using ESPAsyncWebServer.h library.
first stage is done successfully but some botton like "CAPTURE PHOTO" button in ESPAsyncWebServer.h (second stage) does not work.
my code is here:
#include <WiFi.h>
#include <HTTPClient.h>
#include <WebServer.h>
#include <EEPROM.h>
#include <ESPAsyncWebServer.h>
#include "WiFi.h"
#include "esp_camera.h"
#include "esp_timer.h"
#include "img_converters.h"
#include "Arduino.h"
#include "soc/soc.h"           // Disable brownour problems
#include "soc/rtc_cntl_reg.h"  // Disable brownour problems
#include "driver/rtc_io.h"
#include <StringArray.h>
#include <SPIFFS.h>
#include <FS.h>
#include <AsyncTCP.h>
boolean takeNewPhoto=false;
char buff1[100];
char buff2[100];
#define FILE_PHOTO "/photo.jpg"
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <style>
    body { text-align:center; }
    .vert { margin-bottom: 10%; }
    .hori{ margin-bottom: 0%; }
  </style>
</head>
<body>
  <div id="container">
    <h2>ESP32-CAM Last Photo</h2>
    <p>It might take more than 5 seconds to capture a photo.</p>
    <p>
      <button onclick="rotatePhoto()">ROTATE</button>
      <button onclick="capturePhoto()">CAPTURE PHOTO</button>
      <button onclick="location.reload();">REFRESH PAGE</button>
    </p>
  </div>
  <div><img src="saved-photo" id="photo" width="70%"></div>
</body>
<script>
  var deg = 0;
  function capturePhoto() {
    var xhr = new XMLHttpRequest();
    xhr.open('GET', "/capture", true);
    xhr.send();
  function rotatePhoto() {
    var img = document.getElementById("photo");
    deg += 90;
    if(isOdd(deg/90)){ document.getElementById("container").className = "vert"; ,}
    else{ document.getElementById("container").className = "hori"; }
    img.style.transform = "rotate(" + deg + "deg)";
  function isOdd(n) { return Math.abs(n % 2) == 1; }
</script>
</html>)rawliteral";
//Variables
int i = 0;
int statusCode;
const char* ssid = "Default SSID";
const char* passphrase = "Default passord";
String st;
String content;
int first=0;
String esid;
String epass = "";
//Function Decalration
bool testWifi(void);
void launchWeb(void);
void setupAP(void);
void startSecond();
bool checkPhoto( fs::FS &fs );
void capturePhotoSaveSpiffs( void );
//Establishing Local server at port 80
AsyncWebServer asyncServer(80);
WebServer server(80);
  Serial.begin(115200); //Initialising if(DEBUG)Serial Monitor
  Serial.println("Disconnecting current wifi connection");
  WiFi.disconnect();
  EEPROM.begin(512); //Initialasing EEPROM
  delay(10);
  pinMode(15, INPUT);
  Serial.println("Startup");
  if (!SPIFFS.begin(true)) {
    Serial.println("An Error has occurred while mounting SPIFFS");
    ESP.restart();
  else {
    Serial.println("SPIFFS mounted successfully");
   camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  if (psramFound()) {
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 10;
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // Camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    ESP.restart();
  //---------------------------------------- Read eeprom for ssid and pass
  Serial.println("Reading EEPROM ssid");
  for (int i = 0; i < 32; ++i)
    esid += char(EEPROM.read(i));
  Serial.print("SSID: ");
  Serial.println(esid);
  Serial.println("Reading EEPROM pass");
  for (int i = 32; i < 96; ++i)
    epass += char(EEPROM.read(i));
  Serial.print("PASS: ");
  Serial.println(epass);
  WiFi.begin(esid.c_str(), epass.c_str());
  if ((WiFi.status() == WL_CONNECTED))
    if(first==0){
    Serial.print("local ip is: \\http: ");
    first=1;
      Serial.print("Connected to ");
      Serial.print(esid);
      Serial.println(" Successfully");
      delay(100);
   startSecond();
  }else{
    if (testWifi()  /*(digitalRead(15) != 1)*/)
    return;
    launchWeb();
    setupAP();// Setup HotSpot
  Serial.println("Waiting.");
  while ((WiFi.status() != WL_CONNECTED))
    Serial.print(".");
    delay(100);
    server.handleClient();
 if (takeNewPhoto) {
    capturePhotoSaveSpiffs();
    takeNewPhoto = false;
  delay(100);
//----------------------------------------------- Fuctions used for WiFi credentials saving and connecting to it which you do not need to change
bool testWifi(void)
  int c = 0;
  //Serial.println("Waiting for Wifi to connect");
  while ( c < 20 ) {
    if (WiFi.status() == WL_CONNECTED)
      return true;
    Serial.print("*");
    c++;
  Serial.println("");
  Serial.println("Connect timed out, opening AP");
  return false;
void launchWeb()
  Serial.println("");
    Serial.println("WiFi connected");
  Serial.print("Local IP: ");
  Serial.print("SoftAP IP: ");
  Serial.println(WiFi.softAPIP());
  createWebServer();
  // Start the server
  server.begin();
  Serial.println("Server started");
void setupAP(void)
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  int n = WiFi.scanNetworks();
  Serial.println("scan done");
  if (n == 0)
    Serial.println("no networks found");
    Serial.print(n);
    Serial.println(" networks found");
    for (int i = 0; i < n; ++i)
      // Print SSID and RSSI for each network found
      Serial.print(i + 1);
      Serial.print(": ");
      Serial.print(WiFi.SSID(i));
      Serial.print(" (");
      Serial.print(WiFi.RSSI(i));
      Serial.print(")");
      //Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE) ? " " : "*");
      delay(10);
  Serial.println("");
  st = "<ol>";
    st += "<li>";
    st += WiFi.SSID(i);
    st += " (";
    st += WiFi.RSSI(i);
    st += ")";
    //st += (WiFi.encryptionType(i) == ENC_TYPE_NONE) ? " " : "*";
    st += "</li>";
  st += "</ol>";
  delay(100);
  WiFi.softAP("ElectronicsInnovation", "");
  Serial.println("Initializing_softap_for_wifi credentials_modification");
  launchWeb();
  Serial.println("over");
void createWebServer()
    server.on("/", []() {
      IPAddress ip = WiFi.softAPIP();
      String ipStr = String(ip[0]) + '.' + String(ip[1]) + '.' + String(ip[2]) + '.' + String(ip[3]);
      content = "<!DOCTYPE HTML>\r\n<html>Welcome to Wifi Credentials Update page";
      content += "<form action=\"/scan\" method=\"POST\"><input type=\"submit\" value=\"scan\"></form>";
      content += ipStr;
      content += "<p>";
      content += st;
      content += "</p><form method='get' action='setting'><label>SSID: </label><input name='ssid' length=32><input name='pass' length=64><input type='submit'></form>";
      content += "</html>";
      server.send(200, "text/html", content);
    server.on("/scan", []() {
      //setupAP();
      content = "<!DOCTYPE HTML>\r\n<html>go back";
    server.on("/setting", []() {
      String qsid = server.arg("ssid");
      String qpass = server.arg("pass");
      if (qsid.length() > 0 && qpass.length() > 0) {
        Serial.println("clearing eeprom");
        for (int i = 0; i < 96; ++i) {
          EEPROM.write(i, 0);
        Serial.println(qsid);
        Serial.println("");
        Serial.println(qpass);
        Serial.println("");
        Serial.println("writing eeprom ssid:");
        for (int i = 0; i < qsid.length(); ++i)
          EEPROM.write(i, qsid[i]);
          Serial.print("Wrote: ");
          Serial.println(qsid[i]);
        Serial.println("writing eeprom pass:");
        for (int i = 0; i < qpass.length(); ++i)
          EEPROM.write(32 + i, qpass[i]);
          Serial.println(qpass[i]);
        EEPROM.commit();
        content = "{\"Success\":\"saved to eeprom... reset to boot into new wifi\"}";
        statusCode = 200;
        ESP.restart();
        content = "{\"Error\":\"404 not found\"}";
        statusCode = 404;
        Serial.println("Sending 404");
      server.sendHeader("Access-Control-Allow-Origin", "*");
      server.send(statusCode, "application/json", content);
void startSecond(){
server.close();
  delay(10);
asyncServer.on("/", HTTP_GET, [](AsyncWebServerRequest * request) {
//    Serial.println("your request for ssid and password is said.");
    request->send_P(200, "text/html", index_html);
  asyncServer.on("/capture", HTTP_GET, [](AsyncWebServerRequest * request1) {
    takeNewPhoto = true;
    request1->send_P(200, "text/plain", "Taking Photo");
  asyncServer.on("/saved-photo", HTTP_GET, [](AsyncWebServerRequest * request2) {
    request2->send(SPIFFS, FILE_PHOTO, "image/jpg", false);
asyncServer.begin();
delay(10);
Serial.println("SERVER2 STARTED.");
bool checkPhoto( fs::FS &fs ) {
  File f_pic = fs.open( FILE_PHOTO );
  unsigned int pic_sz = f_pic.size();
  return ( pic_sz > 100 );
// Capture Photo and Save it to SPIFFS
void capturePhotoSaveSpiffs( void ) {
  camera_fb_t * fb = NULL; // pointer
  bool ok = 0; // Boolean indicating if the picture has been taken correctly
  do {
    // Take a photo with the camera
    Serial.println("Taking a photo...");
    fb = esp_camera_fb_get();
    if (!fb) {
      Serial.println("Camera capture failed");
      return;
    // Photo file name
    //    Serial.printf("Picture file name: %s\n", FILE_PHOTO);
        File file = SPIFFS.open(FILE_PHOTO, FILE_WRITE);
        // Insert the data in the photo file
        if (!file) {
          Serial.println("Failed to open file in writing mode");
        else {
          file.write(fb->buf, fb->len); // payload (image), payload length
          Serial.print("The picture has been saved in ");
          Serial.print(FILE_PHOTO);
          Serial.print(" - Size: ");
          Serial.print(file.size());
          Serial.println(" bytes");
        // Close the file
        file.close();
    esp_camera_fb_return(fb);
    // check if file has been correctly saved in SPIFFS
    ok = checkPhoto(SPIFFS);
  } while ( !ok );
in fact, I merged two code below to complete my project:
1- [ESP32-CAM Take Photo and Display in Web Server | Random Nerd Tutorials]
2- (5) Change & Store ESP32 WiFi credentials in EEPROM without uploading code - YouTube
Why do you need two webServer libraries? Why don’t you use ESPAsyncWebServer for everything?
@ J-M-L
Hi, actually first time I've done what you said, but i was not successful(maybe there was a problem). anyway, we need two server . one for local.softAPIP(for changing credentials) and another one for localIP( router IP that we need to show our image.
also, I am new to the webserver programming. so I decided to merge two code above instead of creating one in my own. maybe it is better for beginner.
surprising point is that mechanism written for each button is the same but first two button( i mean "rotate" and "capture photo" button) do not have any callback.
