Hello!
I'm new to Arduino, but for school I have to make a 4 wire fan that is adjustable. I want to make it that way that I give in the frequentie of the pulse, and the Arduino transers it in to a value between 0 and 255. I already did some math and I have the formulas to get the value. But where do I have to implement these?
Formulas:
Calabration formula --> f(Hz)=5,1143∙U-2,2012
Into this --> U=(f+2,2012)/5,1143
Calculate when motor starts --> 2,2012/5,1143=0,43 <-- motor starts at 0,43V
Between 0,43V en 9,991V the Arduino goes in 255 steps --> (9,991-0,43)/255=0,037V each step
The formula of your speed is --> ((U-0,43))/0,037V=x(in steps between 0 and 255)
float fanSpeed = 0; // A0 op de Arduino / Loper van de Potmeter
float fanPWM = 3; // Pin D3 op de Arduino. / Instellen van toerental 0/255
int fanSensor = 8; // Pin D8 op de Arduino / Uitlezen van toerental 0/1023
int Puls = 4; // Hier het aantal pulsen per omwenteling van de fan. Te vinden in specs van de fan.
int Speed = x; // Var die nodig is om de snelheid in te stellen van 0 tot 255
unsigned long SensorPulsTijd;
pinMode(fanSensor, INPUT);
pinMode(fanSpeed, INPUT);
digitalWrite(fanSensor, HIGH);
analogWrite(3, Speed); // RPM snelheid instellen
SensorPulsTijd = pulseIn(fanSensor, LOW);
double frequency = 1000000/SensorPulsTijd; // 1000000 microsec / SensorPulsTijd = aantal microsec per puls.
Serial.print("Pulsduur in microsec. = ");
Serial.println(SensorPulsTijd);
Serial.print("Rotatietijd in microsec. = ");
Serial.println(SensorPulsTijd*Puls);
Serial.print("Frequentie in Herz = ");
Serial.println(frequency/Puls, 0);
Serial.print("Toerental per Minuut = ");
Serial.println(frequency/Puls*60);
