Hi
Uncommenting RMS program is causing noisy RMS on serial plotter. Any suggestions ?
https://github.com/diyelectromusic/sdemp/blob/main/src/SDEMP/ArduinoESP32PWM2/ArduinoESP32PWM2.ino
// Simple DIY Electronic Music Projects
// diyelectromusic.wordpress.com
// Arduino ESP32 PWM - Part 2
// https://diyelectromusic.wordpress.com/2024/04/01/esp32-and-pwm-part-2/
Using principles from the following Arduino tutorials:
ESP32 for Arduino - https://docs.espressif.com/projects/arduino-esp32/
ESP32 Arduino LEDC - https://espressif-docs.readthedocs-hosted.com/projects/arduino-esp32/en/latest/api/ledc.html
//#define TIMING_PIN 12
#define NUM_PWM_PINS 4
int pwm_pins[NUM_PWM_PINS] = {13, 12, 14, 27}; // 27 square,14 triangle, 12 saw, 13 sin
int U1;
int U2;
double Ux = 0;
long sumOfSquares = 0;
int numSamples = 100; // Adjust for accuracy
// NB: Rely on fact we're using an 8-bit index to auto wrap for our 256 samples
#define NUM_SAMPLES 256
uint8_t sinedata[NUM_SAMPLES] = {
128, 131, 134, 137, 140, 144, 147, 150, 153, 156, 159, 162, 165, 168, 171, 174,
177, 179, 182, 185, 188, 191, 193, 196, 199, 201, 204, 206, 209, 211, 213, 216,
218, 220, 222, 224, 226, 228, 230, 232, 234, 235, 237, 239, 240, 241, 243, 244,
245, 246, 248, 249, 250, 250, 251, 252, 253, 253, 254, 254, 254, 255, 255, 255,
255, 255, 255, 255, 254, 254, 254, 253, 253, 252, 251, 250, 250, 249, 248, 246,
245, 244, 243, 241, 240, 239, 237, 235, 234, 232, 230, 228, 226, 224, 222, 220,
218, 216, 213, 211, 209, 206, 204, 201, 199, 196, 193, 191, 188, 185, 182, 179,
177, 174, 171, 168, 165, 162, 159, 156, 153, 150, 147, 144, 140, 137, 134, 131,
128, 125, 122, 119, 116, 112, 109, 106, 103, 100, 97, 94, 91, 88, 85, 82,
79, 77, 74, 71, 68, 65, 63, 60, 57, 55, 52, 50, 47, 45, 43, 40,
38, 36, 34, 32, 30, 28, 26, 24, 22, 21, 19, 17, 16, 15, 13, 12,
11, 10, 8, 7, 6, 6, 5, 4, 3, 3, 2, 2, 2, 1, 1, 1,
1, 1, 1, 1, 2, 2, 2, 3, 3, 4, 5, 6, 6, 7, 8, 10,
11, 12, 13, 15, 16, 17, 19, 21, 22, 24, 26, 28, 30, 32, 34, 36,
38, 40, 43, 45, 47, 50, 52, 55, 57, 60, 63, 65, 68, 71, 74, 77,
79, 82, 85, 88, 91, 94, 97, 100, 103, 106, 109, 112, 116, 119, 122, 125
// Following wavetables are calculated...
uint8_t sawdata[NUM_SAMPLES];
uint8_t tridata[NUM_SAMPLES];
uint8_t sqdata[NUM_SAMPLES];
// Use a SAMPLE_RATE that is a multiple of the basic wavetable
#define BASE_FREQ_MULT 128
#define SAMPLE_RATE (NUM_SAMPLES*BASE_FREQ_MULT) // i.e. 256*128 = 32768 Hz
// 10 bit resoution for PWM will mean 78277 Hz PWM frequency
// 9 bit resoution for PWM will mean 156555 Hz PWM frequency
// 8 bit resoution for PWM will mean 313111 Hz PWM frequency
#define PWM_RESOLUTION 8
#define PWM_FREQUENCY 313111
// Timer configuration
// NB: CPU Freq = 80MHz so dividers used to get other
// frequencies for syncing to other operations.
// For a timer frequency of 1000000Hz i.e. divider of 80,
// the Timer alarms would be configured in uS.
// So need to convert required sample rate into uS.
// Period = 1 / Sample Rate = 1 / 32768 = 30.5uS
// However, if up the timer frequency to 10MHz then
// alarms will be set in 0.1uS.
#define TIMER_FREQ 10000000 // 1MHz * 10
#define TIMER_RATE 305 // 30.5uS * 10
// For direct digital synthesis from a wavetable
// we have an accumulator to store the index into
// the table and an increment based on the sample
// rate and frequency.
// Increment = Frequency * (Number of Samples in wavetable / Sample Rate)
// Increment = Frequency * (256 / 32768)
// Increment = Frequency / 128
// But using a 8.8 fixed-point accumulator and increment:
// Increment = 256 * Frequency / 128
// Increment = Frequency * 2
#define FREQ2INC(f) (f*2)
uint16_t acc[NUM_PWM_PINS];
uint16_t inc[NUM_PWM_PINS];
#if 1
uint16_t mul[NUM_PWM_PINS] = {1, 1, 1, 1};
uint8_t *pWT[NUM_PWM_PINS] = {sinedata, sawdata, tridata, sqdata};
#else
uint16_t mul[NUM_PWM_PINS] = {1, 2, 3, 4}; // Optional frequency multipliers
uint8_t *pWT[NUM_PWM_PINS] = {sinedata, sinedata, sinedata, sinedata};
#endif
void setFreq (int ch, unsigned freq) {
if (ch < NUM_PWM_PINS) {
// First apply any optional frequency multipliers
freq = freq * mul[ch];
inc[ch] = FREQ2INC(freq);
Serial.print(ch);
Serial.print("\tFreq: ");
Serial.print(freq);
Serial.print("\tIncrement: ");
Serial.println(inc[ch]);
void setAllFreq (unsigned freq) {
for (int i = 0; i < NUM_PWM_PINS; i++) {
setFreq(i, freq);
// Assumed to be running at SAMPLE_RATE
void ddsUpdate (int ch) {
acc[ch] += inc[ch];
ledcWrite (pwm_pins[ch], pWT[ch][acc[ch] >> 8]);
// Use the ESP32 timer routines
hw_timer_t *timer = NULL;
int toggle;
void ARDUINO_ISR_ATTR timerIsr (void) {
#ifdef TIMING_PIN
toggle = !toggle;
digitalWrite(TIMING_PIN, toggle);
#endif
ddsUpdate(i);
void setupWavetables () {
for (int i = 0; i < NUM_SAMPLES; i++) {
sawdata[i] = i;
if (i < NUM_SAMPLES / 2) {
tridata[i] = i * 2;
sqdata[i] = 255;
tridata[i] = 255 - (i - 128) * 2;
sqdata[i] = 0;
void setup () {
setupWavetables();
#ifdef TIMING_PIN
pinMode(TIMING_PIN, OUTPUT);
digitalWrite(TIMING_PIN, LOW);
#endif
timer = timerBegin(TIMER_FREQ);
timerAttachInterrupt(timer, &timerIsr);
timerAlarm(timer, TIMER_RATE, true, 0);
// Serial.print("Timer frequency: ");
// Serial.println(timerGetFrequency(timer));
ledcAttach(pwm_pins[i], PWM_FREQUENCY, PWM_RESOLUTION);
//setAllFreq(440);
setAllFreq(400);
void loop () {
U1 = analogRead(36) - 2048;
if (digitalRead(27) == HIGH)
U2 = U1;
U2 = - U1;
sumOfSquares = 0; // Reset for each reading
for (int i = 0; i < numSamples; i++) {
// int reading = analogRead(sensorPin);
int reading = U2;
sumOfSquares += (long)reading * reading; // Square and add (use long!)
delayMicroseconds(100); // Adjust for frequency
float averageSquare = (float)sumOfSquares / numSamples;
float vrms = sqrt(averageSquare);
//Serial.print(" U2 = ");Serial.print( U2);
//Serial.print(" Ux = "); Serial.print( Ux);
// Serial.print(" U2 = "); Serial.print( analogRead(36));
Serial.print(" U2 = "); Serial.print( U2);
Serial.print(" Q = "); Serial.print(( digitalRead(27) * 4096) - 2048);
// Serial.print(" vrms = "); Serial.print(vrms);
//Serial.print(" U2 = "); Serial.print( analogRead(36)-2048);
//Serial.print(" U2 = "); Serial.print( analogRead(36));
delay(30);
