How to increasing numbers by button?
Hi all.
The sketch below shown a menu with scroll up/down arrows that scroll the content of the list, my question is how to get natural number increasing/decreasing by up/down arrow pressed like 1-2-3... ?
reference:
also, where is the code for the UP/DOWN arrows? is that from image? which one?
just can submit half of the code by size, so link is:
Thanks
Adam
  example in how to implement the menu library for and ESP32 and Adafruit libraries. This is an example that
  uses both menu types
  1) a simple selection menu (ItemMenu) where the user can scroll up/down and select
  an item and some action be performed such as drawing a screen or activating a sub menu
  2) an menu with in-line where the user can scroll up/down the list and select an item
  however the difference is that move/up down on a selected item will scroll the values of that
  menu item and NOT scroll the list, selecing a selected item will restor control to moving up/down
  3) a EditMenu menu with in-line an no icons (down and dirty)
  highlights
  1. menu items exceeds screen size but library handles wrapping
  2. each item selection has a range, increment and decimal readout
  3. items can also be read from a char array
// required libraries
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
#include "Adafruit_ILI9341_Menu.h"
#include "fonts\FreeSans18pt7b.h"
#include "fonts\FreeSans12pt7b.h"
#include "fonts\FreeSansBold12pt7b.h"
#include "fonts\FreeSansBold9pt7b.h"
#include "fonts\FreeSans9pt7b.h"
#include <ESP32Encoder.h>
#include <XPT2046_Touchscreen.h>  // touch driver for a TFT display
// pins for LED and select button on encoder
#define SE_PIN A2
#define ROW_HEIGHT          35
#define ROWS                5
#define DATA_COLUMN         190
#define LED_PIN 26
#define T_CS   12
#define T_IRQ  27
#define TFT_DC 2
#define TFT_CS 5
#define TFT_RST 25
#define PIN_LED   26
// easy way to include fonts but change globally
#define FONT_SMALL  FreeSansBold9pt7b        // font for menus
#define FONT_EDITTITLE  FreeSans18pt7b            // font for menus
#define FONT_ITEM   FreeSans12pt7b         // font for menus
#define FONT_TITLE  FreeSans18pt7b      // font for all headings
#define DEBOUNCE    60
int MenuOption = 0;
int AllowColorMenu = 0;
// global x y for touch stuff
int BtnX, BtnY;
// must have variables for each menu item
// best to have these global so you can use them in processing functions
int MenuOption1 = 0, MenuOption2 = 0, MenuOption3 = 0, MenuOption4 = 0, MenuOption5 = 0;
int MenuOption6 = 0, MenuOption7 = 0, MenuOption8 = 0, MenuOption9 = 0;
int OptionOption1 = 0, OptionOption2 = 0, OptionOption3 = 0, OptionOption4 = 0, OptionOption5 = 0;
int OptionOption6 = 0, OptionOption7 = 0, OptionOption8 = 0, OptionOption9 = 0;
int ColorOption1 = 0, ColorOption2 = 0, ColorOption3 = 0, ColorOption4 = 0, ColorOption5 = 0;
int ColorOption6 = 0, ColorOption7 = 0, ColorOption8 = 0, ColorOption9 = 0, ColorOption10 = 0, ColorOption11 = 0;
int WirelessOption1 = 0, WirelessOption2 = 0, WirelessOption3 = 0, WirelessOption4 = 0, WirelessOption5 = 0;
int WirelessOption6 = 0, WirelessOption7 = 0, WirelessOption8 = 0, WirelessOption9 = 0;
int WirelessOption10 = 0, WirelessOption11 = 0, WirelessOption12 = 0, WirelessOption13 = 0;
float Temp1Adj = 0.2, Temp2Adj = -.3, AlarmVal = 1;
long Position = 0, oldPosition = 0;
// create some selectable menu sub-items, these are lists inside a menu item
const char *ReadoutItems[] =   {"Absolute", "Deg F", "Deg C"
const char *RefreshItems[] =   {"Off", "1 second", "2 seconds", "10 seconds",
                                "30 seconds", "1 minute", "5 minutes"
const char *PrecisionItems[] =   {"10", "0", "0.0", "0.00", "0.000"
const char *TuneItems[] =   {"Slope/Offset", "Simple", "Linear", "2nd order ", "3rd order", "Log"
const char *OffOnItems[] =   {"Off", "On"
const char *DataRateItems[] =   {"300 baud", "1.2 kbd", "2.4 kbd", "4.8 kbd", "9.6 kbd", "19.2 kbd", "56 kbd"
// OK i'm going crazy with examples, but this will help show more processing when an int is needed but a float returned
// from the menu code
const char *C_NAMES[] = {"White", "Black", "Grey", "Blue", "Red", "Green", "Cyan", "Magenta",
                         "Yellow", "Teal", "Orange", "Pink", "Purple", "Lt Grey", "Lt Blue", "Lt Red",
                         "Lt Green", "Lt Cyan", "Lt Magenta", "Lt Yellow", "Lt Teal", "Lt Orange", "Lt Pink", "Lt Purple",
                         "Medium Grey", "Medium Blue", "Medium Red", "Medium Green", "Medium Cyan", "Medium Magenta", "Medium Yellow", "Medium Teal",
                         "Medium Orange", "Medium Pink", "Medium Purple", "Dk Grey", "Dk Blue", "Dk Red", "Dk Green", "Dk Cyan",
                         "Dk Magenta", "Dk Yellow", "Dk Teal", "Dk Orange", "Dk Pink", "Dk Purple"
const uint16_t  C_VALUES[] = {  0XFFFF, 0X0000, 0XC618, 0X001F, 0XF800, 0X07E0, 0X07FF, 0XF81F, //7
                                0XFFE0, 0X0438, 0XFD20, 0XF81F, 0X801F, 0XE71C, 0X73DF, 0XFBAE, //15
                                0X7FEE, 0X77BF, 0XFBB7, 0XF7EE, 0X77FE, 0XFDEE, 0XFBBA, 0XD3BF, //23
                                0X7BCF, 0X1016, 0XB000, 0X0584, 0X04B6, 0XB010, 0XAD80, 0X0594, //31
                                0XB340, 0XB00E, 0X8816, 0X4A49, 0X0812, 0X9000, 0X04A3, 0X0372, //39
                                0X900B, 0X94A0, 0X0452, 0X92E0, 0X9009, 0X8012 //45
// set default colors
uint16_t MENU_TEXT = C_VALUES[1];
uint16_t MENU_BACKGROUND = C_VALUES[0];
uint16_t MENU_HIGHLIGHTTEXT = C_VALUES[1];
uint16_t MENU_HIGHLIGHT = C_VALUES[21];
uint16_t MENU_HIGHBORDER = C_VALUES[10];
uint16_t MENU_SELECTTEXT = C_VALUES[0];
uint16_t MENU_SELECT = C_VALUES[4];
uint16_t MENU_SELECTBORDER = C_VALUES[37];
uint16_t MENU_DISABLE = C_VALUES[2];
uint16_t TITLE_TEXT = C_VALUES[13];
uint16_t TITLE_BACK = C_VALUES[36];
// this next rediciously long section is merely the icon image data
// scroll down to 1540 or so for the actual code
// Website for generating icons
// https://javl.github.io/image2cpp/
// all icons created at that site and copy / pasted here
// '64_wireless', 64x64px
const uint16_t epd_bitmap_64_wireless [] PROGMEM = {
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xf7df, 0xefdf, 0xefdf, 0xe7df, 0xe7df, 0xe7df,
  0xe7df, 0xefdf, 0xefdf, 0xf7df, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xefdf, 0xe7df, 0xd7bf, 0xcf9f, 0xbf7f, 0xb77f, 0xa75f, 0xa75f, 0xa75f, 0xa75f,
  0xa75f, 0xa75f, 0xb77f, 0xbf7f, 0xcf9f, 0xd7bf, 0xe7df, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xf7ff, 0xe7df, 0xd79f, 0xbf7f, 0xa75f, 0xaf7f, 0xcfbf, 0xe7df, 0xcfbf, 0xbf9f, 0xbf7f, 0xb77f, 0xb77f,
  0xbf7f, 0xbf9f, 0xcfbf, 0xe7df, 0xcfbf, 0xaf7f, 0xa75f, 0xbf7f, 0xd79f, 0xe7df, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xf7ff, 0xdfbf, 0xc79f, 0xaf5f, 0xb77f, 0xdfdf, 0xb77f, 0xa75f, 0xaf5f, 0xbf7f, 0xcf9f, 0xcf9f, 0xd7bf, 0xd7bf, 0xd7bf,
  0xd7bf, 0xcf9f, 0xcf9f, 0xbf7f, 0xaf5f, 0xa75f, 0xb77f, 0xdfdf, 0xb77f, 0xaf5f, 0xc79f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff,
  0xe7df, 0xc79f, 0xa75f, 0xcfbf, 0xbf9f, 0xa75f, 0xbf7f, 0xd79f, 0xdfbf, 0xefdf, 0xf7df, 0xf7ff, 0xf7ff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xf7ff, 0xf7ff, 0xf7df, 0xefdf, 0xdfbf, 0xd79f, 0xbf7f, 0xa75f, 0xbf9f, 0xcfbf, 0xa75f, 0xc79f, 0xe7df, 0xf7ff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xd7bf,
  0xaf5f, 0xc79f, 0xb77f, 0xaf5f, 0xcf9f, 0xe7bf, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xefdf, 0xe7bf, 0xcf9f, 0xaf5f, 0xb77f, 0xc79f, 0xaf5f, 0xd7bf, 0xefdf,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xe7df, 0xc79f, 0xaf7f,
  0xc7bf, 0xaf5f, 0xcf9f, 0xe7df, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xf7df, 0xefdf, 0xe7df, 0xe7bf, 0xe7bf, 0xe7bf,
  0xe7bf, 0xe7df, 0xefdf, 0xf7df, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xe7df, 0xcf9f, 0xaf5f, 0xc7bf, 0xaf7f, 0xc79f,
  0xe7df, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xdfbf, 0xb77f, 0xbf9f, 0xaf5f,
  0xc79f, 0xe7bf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xefdf, 0xdfbf, 0xcf9f, 0xc77f, 0xb77f, 0xa75f, 0xa75f, 0xa75f, 0xa75f,
  0xa75f, 0xa75f, 0xb77f, 0xc77f, 0xd79f, 0xdfbf, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xe7bf, 0xc79f, 0xaf5f, 0xbf9f,
  0xb77f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xdfbf, 0xaf5f, 0xc7bf, 0xa75f, 0xd7bf,
  0xefdf, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xe7df, 0xd79f, 0xbf7f, 0xa75f, 0xb77f, 0xc7bf, 0xbf9f, 0xaf5f, 0xa75f, 0xa75f, 0xa75f,
  0xa75f, 0xaf5f, 0xbf9f, 0xc7bf, 0xb77f, 0xa75f, 0xbf7f, 0xd79f, 0xe7df, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xd7bf, 0xa75f,
  0xc7bf, 0xaf5f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xdfbf, 0xaf5f, 0xc7bf, 0xb77f, 0xdfbf, 0xf7ff,
  0xffff, 0xffff, 0xf7ff, 0xe7df, 0xcf9f, 0xaf5f, 0xaf7f, 0xbf9f, 0xa75f, 0xaf5f, 0xbf7f, 0xcf9f, 0xd7bf, 0xd7bf, 0xdfbf, 0xdfbf,
  0xd7bf, 0xd7bf, 0xcf9f, 0xbf7f, 0xaf5f, 0xa75f, 0xbf9f, 0xaf7f, 0xaf5f, 0xcf9f, 0xe7df, 0xf7ff, 0xffff, 0xffff, 0xf7ff, 0xdfbf,
  0xb77f, 0xc7bf, 0xaf5f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xe7bf, 0xaf5f, 0xbfbf, 0xb77f, 0xe7bf, 0xf7ff, 0xffff,
  0xffff, 0xf7df, 0xdfbf, 0xb77f, 0xaf7f, 0xb77f, 0xa75f, 0xc77f, 0xd7bf, 0xe7df, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xf7ff, 0xefdf, 0xe7df, 0xd7bf, 0xc77f, 0xa75f, 0xb77f, 0xaf7f, 0xb77f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xf7ff,
  0xe7bf, 0xb77f, 0xbfbf, 0xaf5f, 0xe7bf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xe7df, 0xb77f, 0xbfbf, 0xb77f, 0xe7df, 0xffff, 0xffff, 0xffff,
  0xefdf, 0xcf9f, 0xa75f, 0xbf9f, 0xa75f, 0xc79f, 0xe7bf, 0xf7df, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7df, 0xe7bf, 0xc79f, 0xa75f, 0xbf9f, 0xa75f, 0xcf9f, 0xefdf, 0xffff, 0xffff,
  0xffff, 0xe7df, 0xb77f, 0xbfbf, 0xb77f, 0xe7df, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xcf9f, 0xbf9f, 0xb75f, 0xe7bf, 0xffff, 0xffff, 0xffff, 0xefdf,
  0xc79f, 0xaf5f, 0xa75f, 0xbf7f, 0xdfbf, 0xf7df, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xefdf, 0xefdf, 0xe7df, 0xe7bf, 0xe7bf,
  0xe7df, 0xefdf, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7df, 0xdfbf, 0xbf7f, 0xa75f, 0xaf5f, 0xc79f, 0xefdf, 0xffff,
  0xffff, 0xffff, 0xe7bf, 0xaf5f, 0xbf9f, 0xcf9f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xd7bf, 0xaf7f, 0xa75f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xc79f,
  0xaf7f, 0xa75f, 0xcf9f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xdfbf, 0xcf9f, 0xbf7f, 0xaf5f, 0xa75f, 0xa75f, 0xa75f,
  0xa75f, 0xaf5f, 0xbf7f, 0xcf9f, 0xdfbf, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xcf9f, 0xa75f, 0xaf7f, 0xc79f, 0xefdf,
  0xffff, 0xffff, 0xf7ff, 0xdfbf, 0xa75f, 0xaf7f, 0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xe7df, 0xb75f, 0xaf7f, 0xd79f, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xc79f, 0xaf7f,
  0xa75f, 0xd7bf, 0xf7df, 0xffff, 0xffff, 0xffff, 0xefdf, 0xd7bf, 0xbf7f, 0xa75f, 0xb77f, 0xbf9f, 0xaf7f, 0xa75f, 0xa75f, 0xa75f,
  0xa75f, 0xaf7f, 0xbf9f, 0xb77f, 0xa75f, 0xbf7f, 0xd7bf, 0xefdf, 0xffff, 0xffff, 0xffff, 0xf7df, 0xd7bf, 0xa75f, 0xaf7f, 0xc79f,
  0xefdf, 0xffff, 0xffff, 0xf7ff, 0xd79f, 0xaf7f, 0xb75f, 0xe7df, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xcf9f, 0xb79f, 0xbf7f, 0xefdf, 0xffff, 0xffff, 0xf7ff, 0xcf9f, 0xa75f, 0xa75f,
  0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xf7ff, 0xe7bf, 0xc77f, 0xa75f, 0xbf9f, 0xa75f, 0xaf5f, 0xc77f, 0xcf9f, 0xd7bf, 0xdfbf, 0xdfbf,
  0xd7bf, 0xcf9f, 0xc77f, 0xaf5f, 0xa75f, 0xbf9f, 0xa75f, 0xc77f, 0xe7bf, 0xf7ff, 0xffff, 0xffff, 0xf7ff, 0xd7bf, 0xa75f, 0xa75f,
  0xcf9f, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xbf7f, 0xb79f, 0xcf9f, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xe7df, 0xaf5f, 0xa75f, 0xdfbf, 0xffff, 0xffff, 0xffff, 0xdfbf, 0xa75f, 0xa75f, 0xd79f,
  0xf7ff, 0xffff, 0xffff, 0xf7ff, 0xdfbf, 0xaf5f, 0xb79f, 0xa75f, 0xbf7f, 0xd7bf, 0xe7df, 0xf7ff, 0xf7ff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xf7ff, 0xf7ff, 0xe7df, 0xd7bf, 0xbf7f, 0xa75f, 0xb79f, 0xaf5f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xf7ff, 0xd79f, 0xa75f,
  0xa75f, 0xdfbf, 0xffff, 0xffff, 0xffff, 0xdfbf, 0xa75f, 0xaf5f, 0xe7df, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xcf9f, 0xb79f, 0xcf9f, 0xefdf, 0xffff, 0xffff, 0xefdf, 0xbf7f, 0xaf7f, 0xcf9f, 0xefdf,
  0xffff, 0xffff, 0xf7ff, 0xd7bf, 0xa75f, 0xb77f, 0xb75f, 0xd7bf, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xd7bf, 0xb75f, 0xb77f, 0xa75f, 0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xcf9f,
  0xaf7f, 0xbf7f, 0xefdf, 0xffff, 0xffff, 0xefdf, 0xcf9f, 0xb79f, 0xcf9f, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xe7df, 0xaf7f, 0xaf5f, 0xdfbf, 0xffff, 0xffff, 0xf7ff, 0xd7bf, 0xaf7f, 0xbf7f, 0xe7df, 0xffff,
  0xffff, 0xf7ff, 0xdfbf, 0xaf5f, 0xaf7f, 0xbf7f, 0xe7bf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xefdf, 0xe7df, 0xe7df,
  0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xe7bf, 0xbf7f, 0xaf7f, 0xaf5f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xe7df,
  0xbf7f, 0xaf7f, 0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xdfbf, 0xaf5f, 0xaf7f, 0xe7df, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xdfbf, 0xb77f, 0xc79f, 0xefdf, 0xffff, 0xffff, 0xefdf, 0xb77f, 0xaf5f, 0xdfbf, 0xf7ff, 0xffff,
  0xffff, 0xe7df, 0xb77f, 0xaf7f, 0xc79f, 0xe7df, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xefdf, 0xd7bf, 0xc77f, 0xb75f, 0xa75f, 0xa75f,
  0xb75f, 0xc77f, 0xd7bf, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xe7df, 0xc79f, 0xaf7f, 0xb77f, 0xe7df, 0xffff, 0xffff, 0xf7ff,
  0xdfbf, 0xaf5f, 0xb77f, 0xefdf, 0xffff, 0xffff, 0xefdf, 0xc79f, 0xb77f, 0xdfbf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xf7df, 0xcf9f, 0xb77f, 0xdfbf, 0xffff, 0xffff, 0xf7ff, 0xd7bf, 0xaf7f, 0xc79f, 0xefdf, 0xffff, 0xffff,
  0xefdf, 0xcf9f, 0xaf7f, 0xbf7f, 0xe7df, 0xffff, 0xffff, 0xffff, 0xefdf, 0xd7bf, 0xb77f, 0xb77f, 0xcfbf, 0xbf7f, 0xaf5f, 0xaf5f,
  0xbf7f, 0xcfbf, 0xb77f, 0xb77f, 0xd7bf, 0xefdf, 0xffff, 0xffff, 0xffff, 0xe7df, 0xbf7f, 0xaf7f, 0xcf9f, 0xefdf, 0xffff, 0xffff,
  0xefdf, 0xc79f, 0xaf7f, 0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xdfbf, 0xb77f, 0xcf9f, 0xf7df, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xefdf, 0xaf7f, 0xaf7f, 0xe7df, 0xffff, 0xffff, 0xefdf, 0xc79f, 0xaf7f, 0xdfbf, 0xffff, 0xffff, 0xffff,
  0xdfbf, 0xaf5f, 0xaf5f, 0xdfbf, 0xffff, 0xffff, 0xffff, 0xefdf, 0xcf9f, 0xa75f, 0xbf9f, 0xa75f, 0xbf7f, 0xcf9f, 0xd79f, 0xd79f,
  0xcf9f, 0xbf7f, 0xa75f, 0xbf9f, 0xa75f, 0xcf9f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xdfbf, 0xaf5f, 0xaf5f, 0xdfbf, 0xffff, 0xffff,
  0xffff, 0xdfbf, 0xaf7f, 0xc79f, 0xefdf, 0xffff, 0xffff, 0xe7df, 0xaf7f, 0xaf7f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xdfbf, 0xaf7f, 0xcf9f, 0xf7df, 0xffff, 0xffff, 0xe7df, 0xaf5f, 0xbf7f, 0xefdf, 0xffff, 0xffff, 0xefdf,
  0xc79f, 0xaf7f, 0xd79f, 0xf7ff, 0xffff, 0xffff, 0xf7df, 0xcf9f, 0xaf7f, 0xa75f, 0xc79f, 0xdfbf, 0xefdf, 0xf7ff, 0xffff, 0xffff,
  0xf7ff, 0xefdf, 0xdfbf, 0xc79f, 0xa75f, 0xaf7f, 0xcf9f, 0xf7df, 0xffff, 0xffff, 0xf7ff, 0xd79f, 0xaf7f, 0xc79f, 0xefdf, 0xffff,
  0xffff, 0xefdf, 0xbf7f, 0xaf5f, 0xe7df, 0xffff, 0xffff, 0xf7df, 0xcf9f, 0xaf7f, 0xdfbf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xf7ff, 0xd7bf, 0xb77f, 0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xdfbf, 0xaf7f, 0xd79f, 0xf7ff, 0xffff, 0xffff, 0xe7bf,
  0xaf5f, 0xb77f, 0xe7df, 0xffff, 0xffff, 0xf7ff, 0xdfbf, 0xa75f, 0xa75f, 0xcf9f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xefdf, 0xcf9f, 0xa75f, 0xa75f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xe7df, 0xb77f, 0xaf5f, 0xe7bf, 0xffff,
  0xffff, 0xf7ff, 0xd79f, 0xaf7f, 0xdfbf, 0xffff, 0xffff, 0xf7ff, 0xd7bf, 0xb77f, 0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xf7ff, 0xd79f, 0xaf7f, 0xe7bf, 0xffff, 0xffff, 0xf7ff, 0xd7bf, 0xb77f, 0xdfbf, 0xffff, 0xffff, 0xf7ff, 0xd7bf,
  0xaf7f, 0xd79f, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xbf7f, 0xaf7f, 0xcf9f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xcf9f, 0xaf7f, 0xbf7f, 0xefdf, 0xffff, 0xffff, 0xf7ff, 0xd79f, 0xaf7f, 0xd7bf, 0xf7ff,
  0xffff, 0xffff, 0xdfbf, 0xb77f, 0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xe7bf, 0xaf7f, 0xd79f, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xf7df, 0xc79f, 0xaf7f, 0xe7df, 0xffff, 0xffff, 0xefdf, 0xcf9f, 0xb77f, 0xe7df, 0xffff, 0xffff, 0xf7df, 0xcf9f,
  0xaf7f, 0xdfbf, 0xffff, 0xffff, 0xffff, 0xdfbf, 0xaf7f, 0xbf7f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xbf7f, 0xaf7f, 0xdfbf, 0xffff, 0xffff, 0xffff, 0xdfbf, 0xaf7f, 0xcf9f, 0xf7df,
  0xffff, 0xffff, 0xe7df, 0xb77f, 0xcf9f, 0xefdf, 0xffff, 0xffff, 0xe7df, 0xaf7f, 0xc79f, 0xf7df, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xefdf, 0xb77f, 0xb77f, 0xefdf, 0xffff, 0xffff, 0xefdf, 0xbf7f, 0xc79f, 0xefdf, 0xffff, 0xffff, 0xefdf, 0xbf7f,
  0xbf7f, 0xefdf, 0xffff, 0xffff, 0xf7ff, 0xd79f, 0xaf7f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xdefc, 0xa535, 0x636e,
  0xb5d7, 0xffdf, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xdfbf, 0xaf7f, 0xd79f, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xbf7f, 0xbf7f, 0xefdf,
  0xffff, 0xffff, 0xefdf, 0xc79f, 0xbf7f, 0xefdf, 0xffff, 0xffff, 0xefdf, 0xb77f, 0xb77f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xefdf, 0xb77f, 0xc79f, 0xf7df, 0xffff, 0xffff, 0xefdf, 0xb77f, 0xd79f, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xb77f,
  0xcf9f, 0xefdf, 0xffff, 0xffff, 0xefdf, 0xc79f, 0xb77f, 0xe7df, 0xffff, 0xffff, 0xffff, 0xffff, 0xd6bb, 0xf77e, 0xef7e, 0x9d76,
  0x8c92, 0xce9a, 0xffff, 0xffff, 0xffff, 0xffff, 0xe7df, 0xb77f, 0xc79f, 0xefdf, 0xffff, 0xffff, 0xefdf, 0xcf9f, 0xb77f, 0xefdf,
  0xffff, 0xffff, 0xf7df, 0xd79f, 0xb77f, 0xefdf, 0xffff, 0xffff, 0xefdf, 0xc79f, 0xb77f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xefdf, 0xb77f, 0xcf9f, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xbf7f, 0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xbf9f,
  0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xb77f, 0xc79f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0x9cd4, 0xd69b, 0xf79e, 0x9d14,
  0x6b8e, 0xc659, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xc79f, 0xb77f, 0xefdf, 0xffff, 0xffff, 0xf7ff, 0xd7bf, 0xbf9f, 0xefdf,
  0xffff, 0xffff, 0xf7ff, 0xd7bf, 0xbf7f, 0xefdf, 0xffff, 0xffff, 0xf7ff, 0xcf9f, 0xb77f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xefdf, 0xb77f, 0xcf9f, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xc79f, 0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xc79f,
  0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xb77f, 0xd7bf, 0xf7df, 0xffff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7df, 0xd7bf, 0xb77f, 0xefdf, 0xffff, 0xffff, 0xf7ff, 0xd7bf, 0xc79f, 0xefdf,
  0xffff, 0xffff, 0xf7ff, 0xd7bf, 0xc79f, 0xefdf, 0xffff, 0xffff, 0xf7ff, 0xcf9f, 0xb77f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xefdf, 0xb77f, 0xcf9f, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xbf7f, 0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xc79f,
  0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xf7ff, 0xcf9f, 0xd79f, 0xf7df, 0xffff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7df, 0xd79f, 0xcf9f, 0xf7ff, 0xffff, 0xffff, 0xf7ff, 0xdfbf, 0xc79f, 0xefdf,
  0xffff, 0xffff, 0xefdf, 0xbf7f, 0xc79f, 0xf7df, 0xffff, 0xffff, 0xefdf, 0xc79f, 0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xf7df, 0xcf9f,
  0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xf7ff, 0xdfbf, 0xcf9f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xcf9f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xf7ff, 0xd7bf, 0xcf9f, 0xf7df,
  0xffff, 0xffff, 0xf7ff, 0xd7bf, 0xc79f, 0xefdf, 0xffff, 0xffff, 0xf7df, 0xc79f, 0xbf7f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xf7ff, 0xcf9f, 0xbf7f, 0xefdf, 0xffff, 0xffff, 0xf7ff, 0xd7bf, 0xd79f, 0xf7df, 0xffff, 0xffff, 0xf7ff, 0xdfbf,
  0xd7bf, 0xefdf, 0xffff, 0xffff, 0xffff, 0xefdf, 0xd7bf, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xd7bf, 0xefdf, 0xffff, 0xffff, 0xffff, 0xefdf, 0xd7bf, 0xdfbf, 0xf7ff,
  0xffff, 0xffff, 0xf7df, 0xd79f, 0xd7bf, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xbf7f, 0xcf9f, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xf7ff, 0xdfbf, 0xbf7f, 0xefdf, 0xffff, 0xffff, 0xf7ff, 0xdfbf, 0xcf9f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xe7df,
  0xd7bf, 0xefdf, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xe7df, 0xe7df, 0xf7ff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xe7df, 0xe7df, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xd7bf, 0xe7df, 0xffff,
  0xffff, 0xffff, 0xefdf, 0xcf9f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xefdf, 0xbf7f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xe7bf, 0xbf7f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xe7df, 0xcf9f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xefdf,
  0xdfbf, 0xe7df, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xefdf, 0xf7df, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xf7df, 0xefdf, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xe7df, 0xdfbf, 0xefdf, 0xffff,
  0xffff, 0xffff, 0xefdf, 0xcf9f, 0xe7df, 0xffff, 0xffff, 0xffff, 0xefdf, 0xbf7f, 0xe7bf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xefdf, 0xbf9f, 0xe7df, 0xffff, 0xffff, 0xffff, 0xefdf, 0xdfbf, 0xe7df, 0xf7ff, 0xffff, 0xffff, 0xf7ff,
  0xe7df, 0xe7df, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7df, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xf7ff, 0xefdf, 0xf7df, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xe7df, 0xe7df, 0xf7ff, 0xffff,
  0xffff, 0xf7ff, 0xe7df, 0xdfbf, 0xefdf, 0xffff, 0xffff, 0xffff, 0xe7df, 0xbf9f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xefdf, 0xc79f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xf7ff, 0xe7bf, 0xdfbf, 0xf7df, 0xffff, 0xffff, 0xffff,
  0xefdf, 0xe7df, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xf7ff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xf7ff, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xe7df, 0xefdf, 0xffff, 0xffff,
  0xffff, 0xf7df, 0xdfbf, 0xe7bf, 0xf7ff, 0xffff, 0xffff, 0xf7ff, 0xdfbf, 0xc79f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xf7ff, 0xdfbf, 0xcf9f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xefdf, 0xdfbf, 0xefdf, 0xffff, 0xffff, 0xffff,
  0xf7ff, 0xefdf, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xefdf, 0xefdf, 0xf7ff, 0xffff, 0xffff,
  0xffff, 0xefdf, 0xdfbf, 0xefdf, 0xffff, 0xffff, 0xffff, 0xefdf, 0xcf9f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xc79f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xe7df, 0xe7df, 0xf7ff, 0xffff, 0xffff,
  0xffff, 0xf7ff, 0xefdf, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xefdf, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff,
  0xf7ff, 0xe7df, 0xe7df, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xc79f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xcf9f, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xe7df, 0xefdf, 0xffff, 0xffff,
  0xffff, 0xffff, 0xf7ff, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xefdf, 0xe7df, 0xefdf, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xdfbf, 0xcf9f, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xe7df, 0xcf9f, 0xefdf, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xefdf, 0xefdf, 0xf7ff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xf7ff, 0xf7ff, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xf7ff, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff,
  0xefdf, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xcf9f, 0xe7df, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7df, 0xd7bf, 0xe7df, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xf7df, 0xefdf, 0xefdf, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xf7ff, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xf7ff, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf,
  0xefdf, 0xf7df, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xe7df, 0xd7bf, 0xf7df, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xd7bf, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xefdf, 0xf7ff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xefdf,
  0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xd7bf, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xdfbf, 0xe7df, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7df, 0xefdf,
  0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xefdf, 0xf7df,
  0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xe7df, 0xdfbf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xe7df, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff,
  0xf7df, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xf7df, 0xf7ff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xe7df, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xefdf, 0xe7df, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xf7ff, 0xf7ff, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xf7ff, 0xf7ff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xf7ff, 0xe7df, 0xefdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xefdf, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xf7ff, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xf7ff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xf7ff, 0xefdf, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xefdf, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xf7ff, 0xefdf, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xefdf, 0xf7df, 0xffff, 0xffff, 0xffff,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xf7df, 0xefdf, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xf7ff, 0xf7ff, 0xffff, 0xffff,
  0xf7ff, 0xf7ff, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xf7ff, 0xffff,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff,
  0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xf7ff,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xf7ff, 0xf7ff,
  0xf7ff, 0xf7ff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xf7ff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7bf, 0xf79e, 0xef5d, 0xe71c, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xe71c, 0xef5d, 0xf79e, 0xf7bf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xefbe, 0xdf1d, 0xd6dc, 0xce7a, 0xce5a, 0xce5a, 0xce5a, 0xce5a, 0xce5a, 0x8c73, 0xce5a, 0xf79e, 0xa555,
  0x636e, 0xc639, 0xce5a, 0xce5a, 0xce5a, 0xce5a, 0xce5a, 0xce7a, 0xd6dc, 0xe73d, 0xf7bf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xc65a, 0xd6db, 0xd6dc, 0xd6dc, 0xd6dc, 0xd6dc, 0xd6dc, 0xd6dc, 0xd6dc, 0x9cf5, 0xc5f8, 0xef3d, 0xa535,
  0x6baf, 0xc638, 0xd6fc, 0xd6fc, 0xd6fc, 0xd6dc, 0xd6dc, 0xd6dc, 0xd6dc, 0xd6dc, 0xd6fc, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xa536, 0x9cf5, 0x9cf5, 0xb597, 0xc619, 0xd67a, 0xdedb, 0xe6fc, 0xe71d, 0xbdd8, 0xd69b, 0xf77e, 0xbdd8,
  0x94d3, 0xc639, 0xb5b7, 0xb5b7, 0xb597, 0xad96, 0xb5b7, 0xbdf8, 0xc659, 0xd69a, 0xdefb, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0x9d16, 0x9cd5, 0x9494, 0x9cd4, 0xad56, 0xc5f9, 0xd69b, 0xef3d, 0xffbf, 0xffbf, 0xf79e, 0xef7e, 0xef5d,
  0xe73d, 0x9d35, 0x29c8, 0x3a49, 0x5b0c, 0x73cf, 0x8c92, 0xad55, 0xc618, 0xd69a, 0xd6ba, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xc619, 0x9cd4, 0x8432, 0x8432, 0x9cd4, 0xb5b7, 0xd69b, 0xef3d, 0xffbf, 0xffbf, 0xf79e, 0xef7e, 0xef5d,
  0xe73d, 0x9d15, 0x29c8, 0x3a49, 0x530c, 0x6bae, 0x8430, 0x94b3, 0xad55, 0xbdf7, 0xdefb, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xef7e, 0xdefc, 0xd69a, 0xce5a, 0xce59, 0xce59, 0xce59, 0xce7a, 0xd6ba, 0xd6ba, 0xd69a, 0xd67a, 0xce79,
  0xce59, 0xa514, 0x634d, 0x6bae, 0x8451, 0xa534, 0xbdf7, 0xd69a, 0xe73c, 0xef7d, 0xf7bf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xf7be, 0xf7be, 0xf7be, 0xf7be, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffdf, 0xffdf,
  0xffdf, 0xe75d, 0xce7a, 0xd6ba, 0xdefc, 0xef5d, 0xef9e, 0xf7be, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
// 'Alarm', 32x32px
const uint16_t epd_bitmap_Alarm [] PROGMEM = {
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0x5b2e,
  0x4acd, 0x5b2e, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xe75d, 0x52ed, 0x9536,
  0xadd9, 0x4acd, 0xce7a, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xbdf8, 0x5b4f, 0x9d77, 0x5b2e,
  0xa5b8, 0x4aac, 0xc659, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0x8472, 0x6bd1, 0x9d57, 0x5b2e, 0x52ed,
  0xa5b8, 0x4aac, 0xc639, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0x5b2e, 0x8494, 0x8cd5, 0x6390, 0x636f, 0x5b4f,
  0xa5b8, 0x4aac, 0xc639, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffdf, 0x1bd8, 0x3439, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xe75d, 0x52ed, 0x9536, 0x84b4, 0x63b0, 0x6bb0, 0x6bb0, 0x6390,
  0xa5b8, 0x4aac, 0xc639, 0xffdf, 0xffff, 0xffff, 0xffff, 0xf7be, 0xdefb, 0x1398, 0x1398, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xbdf8, 0x5b2e, 0x9d77, 0x8494, 0x6bd1, 0x6bf1, 0x73f1, 0x6bf1, 0x6bd1,
  0xa5b8, 0x4aac, 0xc639, 0xffdf, 0xffff, 0xf7be, 0x1bd8, 0x9dfb, 0xe71c, 0xce79, 0x3418, 0x4c99, 0xffdf, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0x8472, 0x6bd1, 0x9d77, 0x7c73, 0x7412, 0x7432, 0x7432, 0x7432, 0x7432, 0x7412,
  0xa598, 0x4aac, 0xc639, 0xffdf, 0xffff, 0xef7d, 0x64f9, 0x0b77, 0x64fa, 0xe71c, 0xd69a, 0x1398, 0xa63b, 0xffff, 0xffff, 0xffff,
  0xedce, 0xece6, 0xece6, 0xcc67, 0x3a8d, 0x428c, 0x8473, 0x9d57, 0x7c73, 0x7c53, 0x7c73, 0x7c73, 0x7c73, 0x7c73, 0x7c73, 0x7c53,
  0xa598, 0x4aac, 0xc639, 0xffdf, 0xffff, 0xf79e, 0xdedb, 0xa5d9, 0x0b77, 0x95db, 0xe73c, 0xa5f9, 0x0b77, 0xf7be, 0xffff, 0xffff,
  0xece6, 0xfffb, 0xfffa, 0xfffa, 0x9558, 0x9d78, 0x9536, 0x8494, 0x8494, 0x8494, 0x8494, 0x8494, 0x8494, 0x8494, 0x8494, 0x8494,
  0xa598, 0x4aac, 0xc639, 0xffdf, 0xcefd, 0x23d8, 0xcedc, 0xdedb, 0x9599, 0x0b77, 0xef7d, 0xdefb, 0x1398, 0xa61b, 0xffff, 0xffff,
  0xece6, 0xffd9, 0xedc6, 0xf5e6, 0x84b6, 0x8cd5, 0x8cd5, 0x8cd5, 0x8cd5, 0x8cd5, 0x8cd5, 0x8cd5, 0x8cd5, 0x8cd5, 0x8cd5, 0x8cd5,
  0xa598, 0x4aac, 0xc639, 0xffdf, 0xef5d, 0x3438, 0x0b77, 0xef7d, 0xdedb, 0x23d8, 0x857a, 0xe73c, 0x64d8, 0x4478, 0xffdf, 0xffff,
  0xece6, 0xffd8, 0xf649, 0xfe69, 0x8cf7, 0x9516, 0x9516, 0x9516, 0x9516, 0x9516, 0x9516, 0x9516, 0x9516, 0x9516, 0x9516, 0x9536,
  0xa598, 0x4aac, 0xc659, 0xffdf, 0xef7d, 0xd69a, 0x3418, 0x4c99, 0xe73c, 0x8d79, 0x1398, 0xef5d, 0xae1a, 0x0b77, 0xf79e, 0xffff,
  0xecc6, 0xffb7, 0xfecc, 0xff0c, 0x8d17, 0x9536, 0x9d36, 0x9d36, 0x9d36, 0x9d36, 0x9d36, 0x9d36, 0x9d36, 0x9d36, 0x9536, 0x9d36,
  0xa598, 0x4aac, 0xce59, 0x5cfa, 0x4c99, 0xe71c, 0xb619, 0x0b77, 0xef5d, 0xbe7a, 0x0b77, 0xe73c, 0xd6db, 0x0b77, 0xef5d, 0xffff,
  0xecc6, 0xffb6, 0xfeed, 0xff2d, 0x7475, 0x84b4, 0x84b4, 0x84b4, 0x84b4, 0x84b4, 0x84b4, 0x84b4, 0x84b4, 0x84b4, 0x84b4, 0x84b4,
  0xa598, 0x4aac, 0xc638, 0xdefb, 0x0b78, 0xef5d, 0xdefb, 0x0b77, 0xe73c, 0xe71c, 0x0b77, 0xe73c, 0xe73c, 0x0b77, 0xef5d, 0xffff,
  0xece6, 0xffb5, 0xf628, 0xfe48, 0x63d3, 0x6c12, 0x6c12, 0x6c12, 0x6c12, 0x6c12, 0x6c12, 0x6c12, 0x6c12, 0x6c12, 0x6c12, 0x6bf2,
  0xa598, 0x4aac, 0xce59, 0xdefb, 0x0b78, 0xef5d, 0xe73c, 0x0b77, 0xef5d, 0xe73c, 0x0b77, 0xef5d, 0xef5d, 0x0b77, 0xef5d, 0xffff,
  0xece6, 0xffb4, 0xf64a, 0xfe8a, 0x5391, 0x63d1, 0x63d1, 0x63d1, 0x63d1, 0x63d1, 0x63d1, 0x63d1, 0x63d1, 0x63d1, 0x63d0, 0x63b0,
  0xa5b8, 0x4aac, 0xce59, 0x651a, 0x1bd8, 0xef5d, 0xcedc, 0x0b77, 0xef5d, 0xcedc, 0x0b77, 0xef5d, 0xef5d, 0x0b77, 0xef5d, 0xffff,
  0xece6, 0xff93, 0xfecc, 0xff0c, 0x5bb2, 0x6bf1, 0x6bf1, 0x6bf1, 0x6bf1, 0x6bf1, 0x6bf1, 0x6bf1, 0x6bf1, 0x6bf1, 0x6bf1, 0x63f1,
  0xa5b8, 0x4aac, 0xc638, 0xdefb, 0xdedb, 0xef5d, 0x3c38, 0x4458, 0xe73c, 0x95ba, 0x1398, 0xef5d, 0xb67b, 0x0b77, 0xef5d, 0xffff,
  0xece6, 0xff92, 0xff2e, 0xff4e, 0x63d2, 0x6c12, 0x6c12, 0x6c12, 0x7432, 0x7432, 0x7432, 0x7432, 0x7432, 0x7432, 0x6c32, 0x6c12,
  0xa5b8, 0x4aac, 0xc638, 0xef7d, 0xc6bc, 0x23f8, 0x0b77, 0xd6ba, 0xef5d, 0x23f8, 0x64d8, 0xe73c, 0x7d5a, 0x3418, 0xef5d, 0xffff,
  0xece7, 0xffb1, 0xffb1, 0xffd0, 0x9d79, 0xa598, 0x9d36, 0x7453, 0x7432, 0x7452, 0x7452, 0x7452, 0x7452, 0x7452, 0x7452, 0x7432,
  0xa598, 0x4aac, 0xc639, 0xffdf, 0xc6bc, 0x2bf8, 0xb5f9, 0xe73c, 0xbe9c, 0x0b77, 0xd6ba, 0xef5d, 0x23d8, 0x8559, 0xef7d, 0xffff,
  0xe508, 0xece7, 0xece6, 0xc468, 0x3a8d, 0x42ac, 0x7c32, 0x9d57, 0x7c94, 0x7c53, 0x7c73, 0x7c73, 0x7c73, 0x7c73, 0x7c73, 0x7453,
  0xa598, 0x4aac, 0xc639, 0xffdf, 0xef5d, 0xdedb, 0xe71c, 0xd71d, 0x0b77, 0x7519, 0xe73c, 0xbe7b, 0x0b77, 0xdedb, 0xf7be, 0xffff,
  0xce79, 0xc5b3, 0xc5b3, 0xc5b3, 0xbdd7, 0xbdd7, 0x8431, 0x6bd1, 0x9d57, 0x84d4, 0x7c94, 0x7c94, 0x7c94, 0x7c94, 0x7c94, 0x7c73,
  0xa598, 0x4aac, 0xc639, 0xffdf, 0xffdf, 0xf79e, 0x6d3a, 0x0b77, 0x4458, 0xdedb, 0xef7d, 0x1398, 0x8559, 0xef5d, 0xffff, 0xffff,
  0xef7d, 0xe71c, 0xe71c, 0xe71c, 0xe73c, 0xe71c, 0xd69a, 0x9d14, 0x5b4f, 0x9d57, 0x8d15, 0x84b4, 0x84b4, 0x84b4, 0x84b4, 0x84b4,
  0xa598, 0x4aac, 0xc639, 0xffdf, 0xffff, 0xef7e, 0x0b78, 0x74f8, 0xd69a, 0xef5d, 0x4c99, 0x3418, 0xdedb, 0xf7be, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffdf, 0xffff, 0xffff, 0xffff, 0xf79e, 0xdedb, 0xb596, 0x530e, 0x8cf5, 0x9536, 0x8cd5, 0x8cd5, 0x8cd5, 0x84d5,
  0xa598, 0x4aac, 0xc639, 0xffdf, 0xffff, 0xf79e, 0xdedb, 0xdedb, 0xef5d, 0x3439, 0x1398, 0xd69a, 0xef7d, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7be, 0xe71c, 0xc618, 0x5b4e, 0x8473, 0x9d57, 0x8cf5, 0x8cf5, 0x8cf5,
  0xa598, 0x4aac, 0xc639, 0xffdf, 0xffff, 0xffdf, 0xf79e, 0xf79e, 0x3c59, 0x1bd8, 0xce79, 0xe73c, 0xffdf, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xe73c, 0xce59, 0x73f0, 0x6bd1, 0x9d77, 0x9536, 0x9516,
  0xa598, 0x4aac, 0xc639, 0xffdf, 0xffff, 0xffff, 0xffff, 0xf7be, 0xd6db, 0xd6ba, 0xe73c, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xef5d, 0xd69a, 0x94b3, 0x5b2e, 0x9d57, 0x9d57,
  0xa598, 0x4aac, 0xc639, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffdf, 0xf79e, 0xf79e, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xef7d, 0xdedb, 0xb596, 0x52ed, 0x9516,
  0xa5b8, 0x4acd, 0xc639, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7be, 0xdefb, 0xc618, 0x530e,
  0x4acd, 0x530e, 0xe71c, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xe71c, 0xce59,
  0xbdf7, 0xce79, 0xef7d, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xef7d,
  0xef5d, 0xef7d, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff
// 'drivers', 64x64px
const uint16_t epd_bitmap_drivers [] PROGMEM = {
  0xffff, 0xffff, 0xfffe, 0xffda, 0xffb6, 0xff92, 0xff4f, 0xff4e, 0xff2d, 0xff4d, 0xff4d, 0xff4d, 0xff4d, 0xff4d, 0xff4d, 0xff4e,
  0xff4d, 0xff4d, 0xff4d, 0xff4d, 0xff4d, 0xff4d, 0xff4d, 0xff2d, 0xff4e, 0xff4f, 0xff92, 0xffb6, 0xffda, 0xfffe, 0xffff, 0xffff,
  0xffd9, 0xff72, 0xff4c, 0xff6b, 0xffab, 0xffab, 0xff6b, 0xff6a, 0xff4a, 0xff4a, 0xff4a, 0xff4b, 0xff4b, 0xff4b, 0xff6b, 0xff6b,
  0xff6b, 0xff6b, 0xff6b, 0xff6b, 0xff4b, 0xff4b, 0xff4a, 0xff4a, 0xff6b, 0xff6b, 0xffab, 0xffab, 0xff6b, 0xff4c, 0xff72, 0xffd9,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xff96, 0xff4d,
  0xff6a, 0xff8b, 0xff2a, 0xfee9, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfee8, 0xfee8,
  0xfee8, 0xfee8, 0xfee8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfee9, 0xff2a, 0xff8b, 0xff6b,
  0xff4e, 0xff97, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffb8, 0xff4d, 0xff8a, 0xff4a,
  0xfec8, 0xfea8, 0xfea7, 0xfea7, 0xfea7, 0xfea8, 0xfea8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfee8,
  0xfee8, 0xfee8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfea8, 0xfea7, 0xfea7, 0xfea7, 0xfea8, 0xfec9,
  0xff4a, 0xff8a, 0xff4d, 0xffb8, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xfffe, 0xff71, 0xff6a, 0xff49, 0xfea8, 0xfe87,
  0xfe87, 0xfe87, 0xfea7, 0xfea7, 0xfea7, 0xfea8, 0xfea8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8,
  0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfea8, 0xfea8, 0xfea8, 0xfea7, 0xfe87, 0xfe87,
  0xfe87, 0xfea8, 0xff49, 0xff6a, 0xff72, 0xfffe, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffbb, 0xff4d, 0xff8a, 0xfea8, 0xfe67, 0xfe67, 0xfe87,
  0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfea8, 0xfea8, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfe87,
  0xfe87, 0xfe67, 0xfe87, 0xfec8, 0xff8a, 0xff4d, 0xffbb, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffba, 0xff2a, 0xff49, 0xfe87, 0xfe67, 0xfe67, 0xfe87, 0xfe87,
  0xfe87, 0xfe87, 0xfe87, 0xfea7, 0xfea7, 0xfea7, 0xfea8, 0xfea8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8,
  0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfea8, 0xfea8, 0xfea8, 0xfea7, 0xfea7, 0xfe87, 0xfe87, 0xfe87,
  0xfe87, 0xfe87, 0xfe67, 0xfe67, 0xfe87, 0xff49, 0xff2b, 0xffb9, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffba, 0xff0a, 0xff09, 0xfe47, 0xfe47, 0xfe67, 0xfe67, 0xfe87, 0xfe87,
  0xfe87, 0xfe87, 0xfe87, 0xfea7, 0xfea7, 0xfea7, 0xfea8, 0xfea7, 0xfea8, 0xfea8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8,
  0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfea8, 0xfea8, 0xfea8, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfe87, 0xfe87, 0xfe87,
  0xfe87, 0xfe67, 0xfe67, 0xfe67, 0xfe47, 0xfe67, 0xff09, 0xff2a, 0xffb9, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdb, 0xff0a, 0xff08, 0xfe46, 0xfe46, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67,
  0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea8, 0xfea8, 0xfea8, 0xfea8, 0xfec8, 0xfec8, 0xfec8,
  0xfec8, 0xfec8, 0xfec8, 0xfec8, 0xfea8, 0xfea8, 0xfea8, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfe87, 0xfe87, 0xfe87, 0xfe87,
  0xfe87, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe47, 0xfe46, 0xfee8, 0xff0a, 0xffbb, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xfffe, 0xff0c, 0xff08, 0xfe26, 0xfe46, 0xfe47, 0xfe47, 0xfe67, 0xfe67, 0xfe67, 0xfe67,
  0xfe67, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea8, 0xfea8, 0xfea8, 0xfea8, 0xfea8,
  0xfea8, 0xfea8, 0xfea8, 0xfea8, 0xfea7, 0xfea8, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87,
  0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe47, 0xfe46, 0xfe26, 0xff08, 0xff0c, 0xfffe, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xff30, 0xff28, 0xfe26, 0xfe26, 0xfe46, 0xfe46, 0xfe47, 0xfe47, 0xfe67, 0xfe67, 0xfe67,
  0xfe67, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea8,
  0xfea8, 0xfea8, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe67,
  0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe47, 0xfe46, 0xfe46, 0xfe26, 0xfe26, 0xff29, 0xff30, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xff98, 0xff08, 0xfe46, 0xfe26, 0xfe26, 0xfe26, 0xfe46, 0xfe46, 0xfe47, 0xfe47, 0xfe67, 0xfe67,
  0xfe67, 0xfe67, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7,
  0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe67, 0xfe67,
  0xfe67, 0xfe67, 0xfe67, 0xfe47, 0xfe46, 0xfe46, 0xfe26, 0xfe26, 0xfe26, 0xfe46, 0xff29, 0xff98, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xfecb, 0xfea7, 0xfe06, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe46, 0xfe46, 0xfe46, 0xfe47, 0xfe67,
  0xfe67, 0xfe67, 0xfe67, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7,
  0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfea7, 0xfe87, 0xfe87, 0xfe86, 0xfe66, 0xfe86, 0xfe87, 0xfe87, 0xfe87, 0xfe67, 0xfe67,
  0xfe67, 0xfe67, 0xfe47, 0xfe46, 0xfe46, 0xfe46, 0xfe26, 0xfe26, 0xfe26, 0xfe06, 0xfea7, 0xfecb, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xff76, 0xff08, 0xfe06, 0xfe06, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe67,
  0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfea7, 0xfea7,
  0xfea7, 0xfea7, 0xfea7, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe66, 0xfea9, 0xfecc, 0xfe89, 0xfe65, 0xfe87, 0xfe67, 0xfe67, 0xfe67,
  0xfe67, 0xfe47, 0xfe46, 0xfe46, 0xfe46, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe06, 0xfe06, 0xff08, 0xff75, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xfeab, 0xfe67, 0xfde6, 0xfe06, 0xfe06, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe46, 0xfe46, 0xfe46, 0xfe46,
  0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87,
  0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe66, 0xff10, 0xffdd, 0xffff, 0xffdd, 0xff10, 0xfe45, 0xfe66, 0xfe67, 0xfe67,
  0xfe47, 0xfe46, 0xfe46, 0xfe46, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe06, 0xfe06, 0xfde6, 0xfe67, 0xfecb, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xff98, 0xfec7, 0xfde6, 0xfe06, 0xfe06, 0xfe06, 0xfe06, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe46, 0xfe46, 0xfe46,
  0xfe46, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87,
  0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe66, 0xfe8b, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xff11, 0xfe44, 0xfe66, 0xfe47,
  0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe06, 0xfe06, 0xfe06, 0xfde6, 0xfec7, 0xff98, 0xffff, 0xffff,
  0xffff, 0xffff, 0xff0f, 0xfe87, 0xfde5, 0xfe06, 0xfe06, 0xfe06, 0xfe06, 0xfe06, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe46, 0xfe46,
  0xfe46, 0xfe46, 0xfe46, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87,
  0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe87, 0xfe65, 0xf6b0, 0xf7df, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xfef1, 0xfe24, 0xfe46,
  0xfe46, 0xfe46, 0xfe46, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe06, 0xfe06, 0xfe06, 0xfe06, 0xfde6, 0xfe87, 0xff0f, 0xffff, 0xffff,
  0xffff, 0xfffe, 0xfe69, 0xfe06, 0xfde5, 0xfde6, 0xfde6, 0xfe06, 0xfe06, 0xfe06, 0xfe06, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe46,
  0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67,
  0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe65, 0xf62c, 0xe75f, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xfef1, 0xfe24,
  0xfe46, 0xfe46, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe06, 0xfe06, 0xfe06, 0xfe06, 0xfde6, 0xfde6, 0xfe06, 0xfe89, 0xfffe, 0xffff,
  0xffff, 0xff99, 0xfe67, 0xfdc5, 0xfde5, 0xfde6, 0xfde6, 0xfde6, 0xfe06, 0xfe06, 0xfe06, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe26,
  0xfe26, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe47, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67,
  0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe66, 0xfd63, 0xe696, 0xe77f, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xfef0,
  0xfe04, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe06, 0xfe06, 0xfe06, 0xfe06, 0xfde6, 0xfde6, 0xfde5, 0xfdc5, 0xfe87, 0xff99, 0xffff,
  0xffff, 0xff54, 0xfe86, 0xfdc5, 0xfdc5, 0xfde5, 0xfde6, 0xfde6, 0xfde6, 0xfe06, 0xfe06, 0xfe06, 0xfe26, 0xfe26, 0xfe26, 0xfe26,
  0xfe26, 0xfe26, 0xfe26, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe66,
  0xfe66, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfe67, 0xfd83, 0xfd24, 0xe697, 0xe77f, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xfef0, 0xfe04, 0xfe06, 0xfe26, 0xfe06, 0xfe06, 0xfe06, 0xfe06, 0xfde6, 0xfde6, 0xfde5, 0xfdc5, 0xfdc5, 0xfe86, 0xff54, 0xffff,
  0xffff, 0xfeef, 0xfe46, 0xfdc5, 0xfdc5, 0xfdc5, 0xfde5, 0xfde6, 0xfde6, 0xfde6, 0xfe06, 0xfe06, 0xfe06, 0xfe06, 0xfe06, 0xfe26,
  0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46,
  0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe66, 0xfe26, 0xfd22, 0xfd04, 0xe697, 0xe77f, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xfed0, 0xfde4, 0xfe06, 0xfe06, 0xfe06, 0xfe06, 0xfde6, 0xfde6, 0xfde5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfe46, 0xfecf, 0xffff,
  0xffff, 0xfeac, 0xfe05, 0xfda5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfde5, 0xfde5, 0xfde6, 0xfde6, 0xfe06, 0xfe06, 0xfe06, 0xfe06, 0xfe06,
  0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe25, 0xfe25,
  0xfe25, 0xfe25, 0xfe25, 0xfe25, 0xfe25, 0xfe25, 0xfe45, 0xfe04, 0xfce0, 0xfce2, 0xe655, 0xef7e, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xfed0, 0xfde3, 0xfe05, 0xfe06, 0xfde5, 0xfde6, 0xfde5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfe06, 0xfeac, 0xffff,
  0xffff, 0xfe4a, 0xfde5, 0xfda5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfde5, 0xfde5, 0xfde5, 0xfe06, 0xfe06, 0xfe06, 0xfe06,
  0xfe06, 0xfe06, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe26, 0xfe46, 0xfe46, 0xfe46, 0xfe46, 0xfe25, 0xfe26, 0xfe8b, 0xfeac,
  0xfeac, 0xfeac, 0xfeac, 0xfeac, 0xfeac, 0xfeac, 0xfeac, 0xfeac, 0xfe6c, 0xfd88, 0xfdab, 0xf77c, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xfed0, 0xfdc3, 0xfde5, 0xfde5, 0xfde5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfde5, 0xfe4a, 0xffff,
  0xffff, 0xfe29, 0xfdc5, 0xfda5, 0xfda5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfde5, 0xfde5, 0xfde5, 0xfde6, 0xfde6, 0xfe06,
  0xfe06, 0xfe06, 0xfe06, 0xfe26, 0xfe05, 0xfe04, 0xfe04, 0xfe04, 0xfe25, 0xfe26, 0xfe26, 0xfe25, 0xfe47, 0xff78, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xfeaf, 0xfdc4, 0xfde5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfda5, 0xfda5, 0xfdc5, 0xfe28, 0xfffe,
  0xfffe, 0xfe08, 0xfdc5, 0xfda5, 0xfda5, 0xfda5, 0xfda5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfde5, 0xfde5, 0xfde5, 0xfde5, 0xfde6,
  0xfde6, 0xfe06, 0xfe06, 0xfde5, 0xfe06, 0xfef2, 0xff57, 0xff13, 0xfe27, 0xfe05, 0xfe26, 0xfe04, 0xf6f4, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xf608, 0xfdc4, 0xfdc5, 0xfdc5, 0xfdc5, 0xfda5, 0xfda5, 0xfda5, 0xfdc5, 0xfe08, 0xfffe,
  0xfffe, 0xfde8, 0xfda5, 0xfd85, 0xfda5, 0xfda5, 0xfda5, 0xfda5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfde5, 0xfde5, 0xfde5, 0xfde5,
  0xfde6, 0xfde6, 0xfde4, 0xfe06, 0xff79, 0xffff, 0xffff, 0xffff, 0xff7a, 0xfe06, 0xfe05, 0xfe05, 0xeef8, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xf7bf, 0xee0d, 0xfda4, 0xfdc5, 0xfdc5, 0xfda5, 0xfda5, 0xfda5, 0xfda5, 0xfdc5, 0xfe08, 0xfffe,
  0xfffe, 0xfde8, 0xfda5, 0xfd85, 0xfd85, 0xfda5, 0xfda5, 0xfda5, 0xfda5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfde5, 0xfde5,
  0xfde6, 0xfdc4, 0xfde6, 0xff9a, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf66e, 0xfe04, 0xfda4, 0xe634, 0xef9f, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xdf1d, 0xf549, 0xfda4, 0xfdc5, 0xfda5, 0xfda5, 0xfda5, 0xfda5, 0xfd85, 0xfda5, 0xfe08, 0xfffe,
  0xfffe, 0xfde8, 0xfda5, 0xfd85, 0xfd85, 0xfd85, 0xfda5, 0xfda5, 0xfda5, 0xfda5, 0xfda5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfdc5,
  0xfdc4, 0xfde6, 0xff7a, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xef9f, 0xee0f, 0xfe04, 0xfd63, 0xf4e8, 0xdedb, 0xdf3e, 0xe75e,
  0xe75e, 0xe75e, 0xe75e, 0xe75e, 0xdf3e, 0xdf3e, 0xdf3e, 0xdf3d, 0xdf3d, 0xdf3d, 0xdf1d, 0xef5d, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffdf, 0xdf3e, 0xe5d3, 0xfc62, 0xfda5, 0xfda5, 0xfda5, 0xfda5, 0xfd85, 0xfd85, 0xfd85, 0xfda5, 0xfde8, 0xfffe,
  0xfffe, 0xfde8, 0xfda5, 0xfd65, 0xfd85, 0xfd85, 0xfd85, 0xfd85, 0xfda5, 0xfda5, 0xfda5, 0xfda5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfda4,
  0xfdc6, 0xff7a, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7bf, 0xdedb, 0xf507, 0xfde4, 0xfde5, 0xfc61, 0xf4c6, 0xedd0, 0xe5f2,
  0xe5f2, 0xe5f2, 0xe5f2, 0xe5f2, 0xe5f2, 0xe5f2, 0xe5f2, 0xe5f2, 0xe5f2, 0xe5d1, 0xe5b0, 0xf75c, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffdf, 0xdf3d, 0xddf4, 0xfbe2, 0xfca3, 0xfdc5, 0xfda5, 0xfda5, 0xfd85, 0xfd85, 0xfd85, 0xfd85, 0xfda5, 0xfde8, 0xfffe,
  0xfffe, 0xfde8, 0xfd85, 0xfd65, 0xfd65, 0xfd85, 0xfd85, 0xfd85, 0xfd85, 0xfda5, 0xfda5, 0xfda5, 0xfda5, 0xfda5, 0xfda4, 0xfdc6,
  0xff7a, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7be, 0xd6fc, 0xed2c, 0xfc81, 0xfde5, 0xfe06, 0xfd64, 0xfc21, 0xfc00, 0xfc21,
  0xfc21, 0xfc21, 0xfc01, 0xfc01, 0xfc01, 0xfc01, 0xfc01, 0xfc01, 0xfc00, 0xfbc0, 0xfdef, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffdf, 0xdf3d, 0xddf4, 0xfbe2, 0xfc22, 0xfd85, 0xfda5, 0xfd85, 0xfd85, 0xfd85, 0xfd85, 0xfd85, 0xfd65, 0xfd85, 0xfde8, 0xfffe,
  0xfffe, 0xfde8, 0xfd85, 0xfd65, 0xfd65, 0xfd65, 0xfd85, 0xfd85, 0xfd85, 0xfd85, 0xfd85, 0xfda5, 0xfda5, 0xfd83, 0xfda6, 0xff79,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7be, 0xd6fc, 0xed4c, 0xfbe0, 0xfd44, 0xfe06, 0xfde5, 0xfde5, 0xfda5, 0xfd04, 0xfce3,
  0xfd03, 0xfd03, 0xfd03, 0xfce3, 0xfce3, 0xfce3, 0xfce3, 0xfce3, 0xfca1, 0xfe31, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf,
  0xdf3d, 0xddf4, 0xfbe2, 0xfc21, 0xfd85, 0xfda5, 0xfd85, 0xfd85, 0xfd85, 0xfd85, 0xfd65, 0xfd65, 0xfd64, 0xfd85, 0xfdc8, 0xfffe,
  0xfffe, 0xfdc8, 0xfd65, 0xfd44, 0xfd64, 0xfd65, 0xfd65, 0xfd85, 0xfd85, 0xfd85, 0xfd85, 0xfd85, 0xfd63, 0xfda5, 0xff79, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xef9e, 0xd6fc, 0xed2c, 0xfbc0, 0xfce3, 0xfde5, 0xfdc5, 0xfdc5, 0xfdc5, 0xfde5, 0xfde5, 0xfde5,
  0xfde5, 0xfde5, 0xfde5, 0xfde5, 0xfde5, 0xfde5, 0xfde5, 0xfdc3, 0xfef3, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xdf3d,
  0xddf4, 0xfbc2, 0xfc21, 0xfd85, 0xfda5, 0xfd85, 0xfd85, 0xfd85, 0xfd65, 0xfd65, 0xfd65, 0xfd64, 0xfd64, 0xfd85, 0xfdc8, 0xfffe,
  0xfffe, 0xfdc7, 0xfd64, 0xfd44, 0xfd44, 0xfd64, 0xfd64, 0xfd65, 0xfd65, 0xfd65, 0xfd85, 0xfd63, 0xfd85, 0xff79, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xe73c, 0xecea, 0xfb80, 0xfca2, 0xfdc4, 0xfda4, 0xfda4, 0xfda4, 0xfda4, 0xfda4, 0xfda4, 0xfda4,
  0xfda4, 0xfda3, 0xfda4, 0xfdc5, 0xfdc5, 0xfdc5, 0xfda3, 0xfeb2, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xdf3d, 0xddf4,
  0xfbc2, 0xfc01, 0xfd85, 0xfda5, 0xfd85, 0xfd85, 0xfd85, 0xfd65, 0xfd65, 0xfd65, 0xfd64, 0xfd64, 0xfd44, 0xfd64, 0xfdc7, 0xfffe,
  0xfffe, 0xf5c7, 0xfd64, 0xfd44, 0xfd44, 0xfd44, 0xfd64, 0xfd64, 0xfd65, 0xfd65, 0xfd64, 0xfd85, 0xff79, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffbe, 0xfe96, 0xfed7, 0xff58, 0xff58, 0xff58, 0xff58, 0xff58, 0xff58, 0xff58, 0xff58, 0xff58,
  0xff58, 0xff36, 0xfe4c, 0xfda4, 0xfdc5, 0xfda4, 0xf5e9, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xdf3d, 0xddf4, 0xfbc2,
  0xfc01, 0xfd65, 0xfda5, 0xfd85, 0xfd84, 0xfd64, 0xfd65, 0xfd65, 0xfd64, 0xfd64, 0xfd44, 0xfd44, 0xfd44, 0xfd64, 0xfdc7, 0xfffe,
  0xfffe, 0xf5a7, 0xfd64, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd64, 0xfd64, 0xfd44, 0xff38, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xfe4c, 0xfd83, 0xfd83, 0xedee, 0xf7df, 0xffff, 0xffff, 0xffff, 0xffdf, 0xdf3d, 0xddd4, 0xfba2, 0xfbe1,
  0xfd65, 0xfda5, 0xfd65, 0xfd64, 0xfd64, 0xfd64, 0xfd64, 0xfd64, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfdc7, 0xfffe,
  0xfffe, 0xfda7, 0xfd44, 0xfd24, 0xfd24, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd43, 0xf5aa, 0xf7df, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xeef7, 0xfd84, 0xfd63, 0xed0a, 0xdf1d, 0xf7be, 0xffff, 0xf7be, 0xdf3d, 0xddd3, 0xfba2, 0xfbe1, 0xfd64,
  0xfd85, 0xfd65, 0xfd64, 0xfd64, 0xfd64, 0xfd64, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd24, 0xfd24, 0xfd44, 0xfda7, 0xfffe,
  0xfffe, 0xfda7, 0xfd44, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd44, 0xfd44, 0xfd23, 0xed2a, 0xe73e, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xf7ff, 0xde57, 0xfd44, 0xfd84, 0xfc02, 0xe592, 0xd6fd, 0xd71d, 0xd6fd, 0xddd3, 0xfb82, 0xfbc1, 0xfd64, 0xfd85,
  0xfd64, 0xfd64, 0xfd64, 0xfd64, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd44, 0xfda7, 0xfffe,
  0xfffe, 0xfda7, 0xfd24, 0xfd04, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd44, 0xfd23, 0xf404, 0xd638, 0xe77e, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xf79e, 0xef7d, 0xef7e, 0xef7e, 0xef7e, 0xef7e, 0xef7e, 0xef9e, 0xef9e, 0xef9e, 0xef9e, 0xef9e,
  0xef9e, 0xef7d, 0xd73e, 0xe52e, 0xfca2, 0xfdc5, 0xfc62, 0xfb62, 0xeccb, 0xe570, 0xeccb, 0xfb81, 0xfbc1, 0xfd44, 0xfd85, 0xfd64,
  0xfd64, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd04, 0xfd24, 0xfda7, 0xfffe,
  0xfffe, 0xf587, 0xfd24, 0xfd04, 0xfd04, 0xfd04, 0xfd24, 0xfd24, 0xfd24, 0xfd44, 0xfbc1, 0xec28, 0xce79, 0xe77e, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xe71b, 0xce38, 0xd699, 0xd699, 0xd699, 0xd699, 0xd699, 0xd69a, 0xd69a, 0xd69a, 0xd69a, 0xd69a,
  0xd69a, 0xd679, 0xe571, 0xfb82, 0xfce3, 0xfda5, 0xfd64, 0xfbe2, 0xfb40, 0xfb20, 0xfb20, 0xfbe2, 0xfd44, 0xfd85, 0xfd44, 0xfd44,
  0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd04, 0xfd04, 0xfd04, 0xfd24, 0xf5a7, 0xfffe,
  0xffff, 0xf588, 0xfd24, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd24, 0xfd44, 0xfca3, 0xfb00, 0xec28, 0xce79, 0xe77e, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffbd, 0xf4aa, 0xf3a4, 0xf406, 0xf406, 0xf406, 0xf406, 0xf406, 0xf406, 0xf406, 0xf406, 0xf406,
  0xf406, 0xf3c4, 0xfb20, 0xfbe2, 0xfd64, 0xfd64, 0xfd65, 0xfd44, 0xfca3, 0xfc43, 0xfca3, 0xfd44, 0xfd64, 0xfd44, 0xfd44, 0xfd44,
  0xfd44, 0xfd44, 0xfd44, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd24, 0xf588, 0xffff,
  0xffff, 0xf5ca, 0xfd24, 0xfce4, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd44, 0xfc63, 0xfae0, 0xec28, 0xce79, 0xe77e,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xff5b, 0xfbe4, 0xfb20, 0xfb61, 0xfb61, 0xfb61, 0xfb61, 0xfb61, 0xfb61, 0xfb61, 0xfb61,
  0xfb61, 0xfb81, 0xfc23, 0xfd44, 0xfd64, 0xfd44, 0xfd44, 0xfd64, 0xfd64, 0xfd64, 0xfd64, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44,
  0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfce4, 0xfd24, 0xf5aa, 0xffff,
  0xffff, 0xf5ed, 0xfd44, 0xfce4, 0xfce4, 0xfce4, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd44, 0xfc43, 0xfae0, 0xec28, 0xce79,
  0xe77e, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xff9c, 0xfd47, 0xfcc2, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04,
  0xfd04, 0xfd24, 0xfd64, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd24, 0xfd24, 0xfd24, 0xfd24,
  0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfce4, 0xfce4, 0xfce4, 0xfd44, 0xf5ec, 0xffff,
  0xffff, 0xf651, 0xfd44, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd24, 0xfc43, 0xfac0, 0xec08,
  0xce79, 0xe77e, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffbc, 0xfd87, 0xfd23, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44,
  0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd44, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24,
  0xfd24, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfd44, 0xf651, 0xffff,
  0xffff, 0xeed6, 0xfd24, 0xfcc4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfd04, 0xfd04, 0xfd24, 0xfc43, 0xfac0,
  0xec08, 0xce79, 0xe77e, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xff7b, 0xfd25, 0xfd23, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24,
  0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd04, 0xfd04, 0xfd04,
  0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfcc4, 0xfd24, 0xeed6, 0xffff,
  0xffff, 0xf77c, 0xf4c5, 0xfce4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfd04, 0xfd24, 0xfc43,
  0xfac0, 0xec08, 0xce79, 0xe77e, 0xffff, 0xffff, 0xffff, 0xffff, 0xf7ff, 0xedac, 0xfd02, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24,
  0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd24, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04,
  0xfd04, 0xfd04, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfcc4, 0xfcc4, 0xfce4, 0xf4c4, 0xf77c, 0xffff,
  0xffff, 0xffff, 0xed4a, 0xfd04, 0xfcc3, 0xfcc3, 0xfcc4, 0xfcc4, 0xfcc4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfd24,
  0xfc23, 0xfaa0, 0xebe8, 0xce59, 0xe75d, 0xffff, 0xffff, 0xffff, 0xe75e, 0xe50d, 0xfce2, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04,
  0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfce4,
  0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc3, 0xfcc3, 0xfd04, 0xed4a, 0xffff, 0xffff,
  0xffff, 0xffff, 0xe633, 0xfd04, 0xfca3, 0xfcc3, 0xfcc3, 0xfcc3, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfce4, 0xfce4, 0xfce4,
  0xfd04, 0xfc23, 0xfaa0, 0xebe8, 0xce79, 0xdf3d, 0xe75d, 0xdf3d, 0xce59, 0xf3c5, 0xfcc3, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04,
  0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfd04, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4,
  0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc3, 0xfcc3, 0xfcc3, 0xfca3, 0xfd04, 0xe633, 0xffff, 0xffff,
  0xffff, 0xffff, 0xf77d, 0xeca5, 0xfce4, 0xfca3, 0xfca3, 0xfcc3, 0xfcc3, 0xfcc3, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfce4,
  0xfce4, 0xfd04, 0xfc23, 0xfaa0, 0xebc7, 0xd5d5, 0xce38, 0xcdd6, 0xebe8, 0xfb21, 0xfd04, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4,
  0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4,
  0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc3, 0xfcc3, 0xfca3, 0xfca3, 0xfca3, 0xfce4, 0xeca5, 0xef7d, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xdd8f, 0xfd04, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfcc3, 0xfcc3, 0xfcc3, 0xfcc4, 0xfcc4,
  0xfcc4, 0xfcc4, 0xfd04, 0xfc03, 0xfaa0, 0xfac1, 0xf344, 0xfae2, 0xfaa0, 0xfc23, 0xfd04, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4,
  0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfce4, 0xfcc4, 0xfcc4, 0xfcc4,
  0xfcc4, 0xfcc4, 0xfcc4, 0xfcc3, 0xfcc3, 0xfcc3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfd04, 0xdd8f, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xef3c, 0xec85, 0xfcc4, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfcc3, 0xfcc3,
  0xfcc3, 0xfcc4, 0xfcc4, 0xfce4, 0xfc23, 0xfb22, 0xfac1, 0xfb01, 0xfc03, 0xfce4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfce4, 0xfce4,
  0xfce4, 0xfce4, 0xfce4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4,
  0xfcc3, 0xfcc3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfcc3, 0xec85, 0xef3c, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xd5b2, 0xfce4, 0xfca3, 0xfc83, 0xfc83, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3,
  0xfca3, 0xfca3, 0xfca3, 0xfcc3, 0xfce4, 0xfcc4, 0xfc83, 0xfcc4, 0xfce4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4,
  0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc4, 0xfcc3, 0xfcc3, 0xfca3, 0xfca3,
  0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfc83, 0xfc83, 0xfca3, 0xfce4, 0xd591, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xf7be, 0xdca9, 0xfce4, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfca3, 0xfca3, 0xfca3, 0xfca3,
  0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfcc3, 0xfcc3, 0xfcc3, 0xfcc3, 0xfcc3, 0xfcc3, 0xfcc3, 0xfcc3, 0xfcc4, 0xfcc4, 0xfcc4,
  0xfcc3, 0xfcc3, 0xfcc4, 0xfcc3, 0xfcc4, 0xfcc3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3,
  0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfce4, 0xdc88, 0xf7be, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xdeb9, 0xe465, 0xfcc4, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfca3,
  0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3,
  0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfcc4, 0xe465, 0xdeb9, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xcdf5, 0xf463, 0xfca3, 0xfc63, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83,
  0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3,
  0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfca3, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83,
  0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc63, 0xfca3, 0xf463, 0xcdd4, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xcd72, 0xf463, 0xfca3, 0xfc63, 0xfc63, 0xfc63, 0xfc83, 0xfc83, 0xfc83,
  0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83,
  0xfc83, 0xfc83, 0xfc83, 0xfc63, 0xfc63, 0xfc63, 0xfca3, 0xf463, 0xcd71, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xcd51, 0xec43, 0xfca3, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63,
  0xfc63, 0xfc63, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83,
  0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc63,
  0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfca3, 0xec43, 0xcd51, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xc593, 0xe445, 0xfcc3, 0xfc63, 0xfc63, 0xfc63, 0xfc63,
  0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83, 0xfc83,
  0xfc83, 0xfc83, 0xfc83, 0xfc63, 0xfc83, 0xfc83, 0xfc63, 0xfc83, 0xfc83, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63,
  0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfcc3, 0xe445, 0xcd93, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xce38, 0xd468, 0xfca3, 0xfc83, 0xfc63, 0xfc63,
  0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63,
  0xfc63, 0xfc43, 0xfc83, 0xfca3, 0xd468, 0xce37, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xe71c, 0xc50f, 0xe445, 0xfca3, 0xfc83,
  0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63,
  0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc43, 0xfc43, 0xfc43,
  0xfc83, 0xfca3, 0xe444, 0xc50f, 0xe71c, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xce38, 0xcccc, 0xec45,
  0xfc83, 0xfca3, 0xfc63, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc63, 0xfc43, 0xfc43,
  0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc43, 0xfc63, 0xfca3, 0xfc83,
  0xec44, 0xccac, 0xce37, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xc638,
  0xc4ef, 0xd468, 0xec24, 0xfc63, 0xfca3, 0xfc83, 0xfc83, 0xfc83, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63,
  0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc63, 0xfc83, 0xfc83, 0xfca3, 0xfc63, 0xec24, 0xd468, 0xc50f,
  0xce38, 0xf7be, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff,
  0xffff, 0xe71c, 0xc5f6, 0xc531, 0xcc8b, 0xd468, 0xdc26, 0xe425, 0xec24, 0xec24, 0xec24, 0xec24, 0xec24, 0xec24, 0xec24, 0xec24,
  0xec24, 0xec24, 0xec24, 0xec24, 0xec24, 0xec24, 0xec24, 0xec24, 0xe425, 0xdc26, 0xd468, 0xcc8b, 0xc530, 0xc5f6, 0xe71c, 0xffff,
  0xffff, 0xffff, 0xffff, 0xffff, 0xf7be, 0xe73c, 0xd69a, 0xc638, 0xc5f7, 0xc5f7, 0xc5f7, 0xc5f7, 0xc5f7, 0xc5f7, 0xc5f7, 0xc5f7,
  0xc5f7, 0xc5f7, 0xc5f7, 0xc5f7, 0xc5f7, 0xc5f7, 0xc5f7, 0xc5f7, 0xc638, 0xd69a, 0xe73c, 0xf7be, 0xffff, 0xffff, 0xffff, 0xffff,
Are there any kinds of sign code for UP/DOWN arrow like the one for '>' ?
Captureascii
v - ASCII Code 118 - Lowercase v
^ - ASCII Code 94 - Caret - circumflex
That display has a resistive touchscreen. When you press on the screen, the library for the touchscreen will give you the resistance values for the horizontal and vertical coordinates (X and Y), and the pressure (Z) to indicate how hard you are pressing down. You have to experimentally determine the minimum and maximum resistance values for the X and Y axis on your particular display (usually the library has a calibration example for this), then the map() instruction is used to convert the resistance into an actual X,Y pixel coordinate on the screen.
void ProcessTouch() {
  TouchPoint = Touch.getPoint();
  BtnX = TouchPoint.x;
  BtnY = TouchPoint.y;
  // consistency between displays is a mess...
  // this is some debug code to help show
  // where you pressed and the resulting map
  // Serial.print("real: ");
  // Serial.print(BtnX);
  // Serial.print(",");
  // Serial.print(BtnY);
  // Display.drawPixel(BtnX, BtnY, C_RED);
  // different values depending on where Touch happened
  // x  = map(x, real left, real right, 0, width-1);
  // y  = map(y, real bottom, real top, 0, height-1);
  // tft with black headers, yellow headers will be different
  BtnX  = map(BtnX, 3700, 300, 319, 0);
  BtnY  = map(BtnY, 3800, 280, 239, 0);
  // Serial.print(", Mapped: ");
  // Serial.println(BtnY);
  // Display.fillCircle(BtnX, BtnY, 3, ILI9341_RED);
  // delay(5);
Once you have the X,Y coordinates, you can check to see if this falls within the area of the image where the button is being displayed. In the sketch you posted, this is done in the menu library, but I'm not familiar with how that library operates. Without a library, you can just compare the X, Y coordinates to see if they fall within the X and Y values for a (usually) square or rectangular button area. What you do with the button press after that is up to you.
int ProcessButtonPress(ItemMenu &TheMenu) {
  int TheItem = 0, NewItem = 0;
  TheItem = TheMenu.press(BtnX, BtnY);
  TheMenu.drawRow(TheItem, BUTTON_PRESSED);
  while (Touch.touched()) {
    ProcessTouch();
    NewItem = TheMenu.press(BtnX, BtnY);
    if (TheItem != NewItem) {
      TheMenu.drawRow(TheItem, BUTTON_NOTPRESSED);
      return -1;
  if (TheItem == NewItem) {
    return TheItem;
  return -1;
Thanks.
how to get natural number increasing/decreasing by up/down arrow pressed like 1-2-3... ?
Thanks.
Youtube/upir has a good menu demonstration here...
Thank you.
Mention the devices you are using early.
Youtube/dronebotworkshop has a demonstration for seven segment displays using a library
https://dronebotworkshop.com/led-displays/
If you want to use a shift register, this will help:
I found the graphic for ^ and v - on a TFT. The values are 286 and 287.
Thank you and I'll check there.
Your code needs to react to "long press"... try the Button.h library.
You are not using a seven segment display.
