how to increment and decrement ?
for example
{time = 4;
time += 1;}
so how to incremnet
so for example it's 4 after a loop it's 5 after a loop it's 6 after a loop it's 7....
for example
{time = 4;
time += 1;}
so how to incremnet
something like this:
int time = 0;
setup()
time = 4;
loop()
time++;
In your case, time is set to 4 each time loop is entered.
http://arduino.cc/en/Reference/Increment
Check the above reference. If you are a newbie, I would first explore the references provided on the official website.
He knows how to increment, I think he was wondering why it started from 4 all the time!
btw, JHjh,
time += 1;
is perfectly fine, too.
Short hand
time++;
long hand
time=time+1
decrement - not +
Note time++; is NOT the same as ++time; time++; means increment AFTER use ++time means increment before use.
Can you spot the in joke that names a computer language?
Mark
Did you look here?
http://arduino.cc/en/Reference/For
Useing a for loop sounds like it would work too
KeithRB:
He knows how to increment, I think he was wondering why it started from 4 all the time!btw, JHjh,
time += 1;is perfectly fine, too.
I personally prefer "time += 1;" to "time++;" because then I can easily edit if I want a different increment amount. Yeah, I'm lazy! ![]()
Thank you KeithRB but I want that my code take the last value incremented and continue incrementing
for example
{time ++;}
so then if time is 4 and it increment one it will be 5
and next loop it will start 5 and be 6
thank you everyone!!!
You will have to put an extra increment at the end of the loop function, or increment by 2:
time +=2
long startTime ; // start time for stop watch
long elapsedTime ;
int preincrementation = 8;
int vrai = 9;
float prevtension;// global variables are retained on each iteration of loop()
long time;
int valeurLue;
int analogPin = A0;
const int led = 13;
float tension; //variable pour stocker la valeur lue après conversion
pinMode(analogPin, INPUT);
pinMode( led, OUTPUT );
digitalWrite(led, HIGH);
delay (500);
digitalWrite(led, LOW); // 2.5cm
prevtension = tension;
valeurLue = analogRead(analogPin);
//on traduit la valeur brute en tension (produit en croix)
tension = valeurLue * 5.0 / 1024;
long RPMactuel = 60000000 / elapsedTime;
long initime = 0.3 * elapsedTime;
long RPMconsigne = 3000;
long consigne = 60000000 / RPMconsigne;
if (tension < 2.8)
{if (tension < (prevtension - 0.005)) { // compare them
elapsedTime = micros() - startTime;
startTime = micros();
if(elapsedTime > consigne)
{time = initime;} // 4%
if(elapsedTime < consigne)
{time = 4;
if ( (consigne - (consigne * 0.02)) < elapsedTime < (consigne + (consigne * 0.02)))
digitalWrite (preincrementation, HIGH);
{ if ( elapsedTime < consigne )
if ( elapsedTime > (consigne - (consigne * 0.0001)) )
time += 0.001;}
if ( elapsedTime < (consigne + (consigne * 0.0001)) )
time -= 0.001;}
if ((consigne - (consigne * 0.0001)) < elapsedTime < (consigne + (consigne * 0.0001)))
{digitalWrite (vrai, HIGH);}} }
delayMicroseconds (time);
digitalWrite(led, LOW); // do something, they are different
Serial.print("elapsedTime = ");
Serial.println(elapsedTime);
Serial.print("consigne = ");
Serial.println(consigne);
Serial.print("rpm actuel = ");
Serial.println(RPMactuel);
Serial.print("rpm consigne = ");
Serial.println(RPMconsigne);
Serial.print("initime = ");
Serial.println(initime);
Serial.print("time = ");
Serial.println(time);
so I change it is it good now please thank you
Use the auto format in the tools section to layout your code - it will help you and if you post the code us! Good code layout is not just something you do it helps you find bugs!
Mark
Don't you just hate it when that happens?
No I like the artistic value of it - that four lines of code let me think of spring, when birds return in flocks.
(yeah it was a cold wind today)
robtillaart:
No I like the artistic value of it - that four lines of code let me think of spring, when birds return in flocks.(yeah it was a cold wind today)
But one of them is upside-down ( or, conversely, depending on which way you tilt your head, four of them are upside down)
AWOL:
robtillaart:
that's not upside-down, that's just the rebel of the flock, the rest are flying South, and that fella's going North...
