How to initiate a class within a class definition
Hello
I want to create a wrapper library around the TFT library in order to manage e.g. deletion of the screen before writing new text and to implement a kind of screen saver if the application in waiting for user input and thus not changing for a while.
In order to do that I created a new class that holds some variables (such as the text to erase before writing new text) and has some functions to write to different areas of the Adafruit TFT display.
I need to initialize an instance of the TFT class from the TFT library. I tried different ways to do that. The last one was to insert a forward declaration as private variable in the class definition within the header file and to actually create the instance in the constructor code of the new class variable.
So my code fragments look like this:
// ***** TFTNew.h *****
#include <TFT.h>
class NewTFT {
public:
NewTFT(void); // constructor
void WriteText(char *text);
private:
TFT TFTScreen(uint8_t, uint8_t, uint8_t);
char oldstr[8];
// ***** TFTNew.cpp *****
include "TFTNew.h"
include <TFT.h>
NewTFT::NewTFT(void)
TFT TFTscreen(10, 9, 8 );
TFTscreen.begin();
void NewTFT::WriteText(char *text)
TFTscreen.setTextSize(2);
TFTscreen.stroke(0);
TFTscreen.text(oldstr,0,0);
TFTscreen.stroke(0xFFFF);
TFTscreen.text(text,0,0);
Now the Arduino IDE compiler gives me an error message, that the TFTScreen is out of scope for the member function. The error message is as follows:
NewTFT.cpp: In member function 'void NewTFT::WriteText(char)':
NewTFT.cpp:36: error: 'TFTscreen' was not declared in this scope
How to you declare and initiate a class within a class definition?
Thanks for help.
In the constructor:
NewTFT::NewTFT(void):TFTscreen(10, 9, 8 )
  TFTscreen.begin();
You should NOT be calling the begin() method for the TFTscreen instance in the constructor of your class. You to need a begin() method.
Hello again,
after the previous reply and some further reading I understand, that I should inherit the TFT class in the NewTFT class. So i modified the code as below (btw: I am using the Ardiono 1.0.5 IDE):
TFTNew.h
#ifndef _TFTNew_H
#define _TFTNew_H
#include <TFT.h>
class NewTFT : public TFT {    //line 35: in original file
public:
  /// constructor
  NewTFT(uint8_t CS, uint8_t RS, uint8_t RST);
private:
  char oldstr[8];
#endif // _TFTNew_H
TFTNew.cpp
include "TFTNew.h"
include <TFT.h>
NewTFT::NewTFT(uint8_t CS, uint8_t RS, uint8_t RST)
  : TFT(CS, RS, RST)                                                        //line 24: in original file
  setTextSize(2);                                                       //line 37: in original file
Main sketch
#include "TFTNew.h"
include <TFT.h>
NewTFT td = NewTFT(10,9,8);
char txt[] = "Hello";
// I know that the TFT.begin() method is still missing but I am still stuck with the compile errors
td.WriteText(txt);
I put all files in the same directory in order to avoid the library path complexity I read about in other postings.
So when I compile check this sketch I get the following error log:
In file included from TFTNew.cpp:1:
TFTNew.h:35: error: expected class-name before '{' token
TFTNew.cpp: In constructor 'NewTFT::NewTFT(uint8_t, uint8_t, uint8_t)':
TFTNew.cpp:24: error: class 'NewTFT' does not have any field named 'TFT'
TFTNew.cpp: In member function 'void NewTFT::WriteText(char *)':
TFTNew.cpp:37: error: 'setTextsize' was not declared in this scope
I maybe blind, but I could not find anything wrong with the above code.
PaulS: Thanks for directing my, however, I am not sure which part should go into the .h or .cpp file (or even the .ino)
Thanks for your help.
Thomas
C++ is complex and non-intuitive in these areas I reckon.
Best is to find an existing example of inheritance somewhere and work from that, whilst reading
up on C++ constructors and scope and so forth. Start with the simplest class and make one change
at a time.
You actual problem can be done in two ways, either inherit/extend or delegate - if I were delegating I'd
try to make the target class passed as a reference in the constructor of the wrapper class. Delegating
involves less assumptions about the class you are referring to, but you may have to write lots of
boilerplate.
You also have the option of not using a class which may be simpler!
hello all - i am equally interested in this topic as tlingenthal is. Any latest guidance on his thread. I have a similar need to address in my project (http://alibe.codeplex.com/)
thanks
nagi
Really? Look in the TFT.h file in the TFT library. There is no class called TFT. You can't inherit from a non-existent class.
PaulS:
Uuu that sounds bad? :wink:
I gave up going to class over 40 years ago.
Hello all
I am trying to inherit from the "Servo" class to implement a few additional methods that address my project needs. I must also be blind, what am i missing to get this resolved. any and all help is greatly appreciated. Thanks all in advance
The code snippets and the compilation error details are below:
// ALIBESteer.h file
#ifndef ALIBESteer_h
	#define ALIBESteer_h
	#include <Arduino.h>
	#include <Servo.h>
	#define ALIBE_STEER_SERVO_PIN 	9
	class ALIBESteer : public Servo {
		public:
			ALIBESteer();
			bool turnLeft();
			bool turnRight();
			bool turnStraight();
		private:
			Servo _steer;
#endif
// ALIBESteer.cpp file
#include <Servo.h>
#include <ALIBESteer.h>
	ALIBESteer::ALIBESteer(){
		// attaches the servo on pin 	ALIBE_STEER_SERVO_PIN to the servo object
		_steer.attach(ALIBE_STEER_SERVO_PIN);
		turnStraight();
	//public
	bool ALIBESteer::turnLeft(){
		_steer.write(0);             	// tell servo to go to position 0d - left
		delay(15);                       	// waits 15ms for the servo to reach the position
	bool ALIBESteer::turnRight(){
		_steer.write(180);             // tell servo to go to position 180d - right
	bool ALIBESteer::turnStraight(){
		_steer.write(90);             // tell servo to go to position 90d - straight ahead
#include "ALIBESteer.h"
ALIBESteer _s;
void setup(){
	_s.turnLeft();
	_s.turnRight();
	_s.turnStraight();
void loop(){
Error message on compilation:
In file included from ALIBESteer.ino:1:
C:\Arduino\libraries\ALIBESteer/ALIBESteer.h:8: error: expected class-name before '{' token
C:\Arduino\libraries\ALIBESteer/ALIBESteer.h:15: error: 'Servo' does not name a type
You are missing an include statement in your .ino file. You can NOT hide the use of the Servo library.
@PaulS - Than you - indeed that took care of the problem.
i was too quick in lighting the cigar.
The code compiled just fine. but, the servo does not work. It is supposed to turn the servo on pin 9 to 0d, 90d and 180d. But, does nothing.
just to confirm that the wiring is all good, i uploaded the "Sweep" example and that works w/o any issues whatsoever.
any guidance on what might be wrong.
thank you in advance
Yes. Do you know when your constructor is called, relative to when the pin is ready to have a servo attached to it?
You'll undoubtedly, have noticed that there are methods like Serial.begin(), EthernetClient.begin(), EthernetServer.begin(), etc.
In the begin() method is where you do the hardware-related stuff, NOT in the constructor.
@PaulS - thank you yet again Paul. That fixed the problem;
here's the final code based on the recommendations @PaulS made (thanks again @PaulS):
	#include <Servo.h>
		public:
			ALIBESteer();
			void begin();
			bool turnLeft();
			bool turnRight();
		private:
			Servo _steer;
#endif
#include <Servo.h>
	//public
	void ALIBESteer::begin(){
		turnStraight();
#include <Servo.h>
ALIBESteer _s;
void setup(){
	_s.begin();
void loop(){
	_s.turnLeft();
	_s.turnRight();
	_s.turnStraight();
...now onto the next few left module libs....
thanks all.
https://alibe.codeplex.com/
