I have an UPS I want to control through its DB9 RS232 port. (I know its pinout is pin 5 for GND, 2 for Tx and 3 for its Rx)
I already managed to communicate with the UPS from a PC running linux and screen:
screen /dev/sttyUSB0 2400
Q1
For instance !
Sending a "Q1" retrieves data from the UPS
Sending a "S1R000" will stop it in 1 minute.
Sending a "C" would resume to normal mode,(power ON again)
I've been doing so using a general purpose USB to RS232/RS485/TTL converter that works ok.
But I'm aware that normal RS232 can go from something like -12 to +12V, some UART are on 5.0V (UNOs) and some others on 3.3V (ESP8266).
I'd like to remove this converter and use directly the Arduino's or ESP8266's UART, so I need to know the voltage level of that UPS's RS232 port.
I've been checking with a voltmeter between pin 5 and 3 then between pin 5 and 2 of the UPS but can't find any voltage !
But which output do you use on that converter? It has RS232, RS485, 3V3 TTL and 5V TTL.
And is the device sending anything when in rest? Otherwise, you should be able to measure something between 3 and 5 (device Txo). +5V / +3V3 for TTL and -3V to -15V for RS232.
I have to say the PL2303HX is confusing indeed. After a quick scan through the datasheet I'm not even sure what it outputs... But dongle you have now (with dedicated inputs for all different types of signal) seems to make it pretty clear
Most other common serial-USB chips (like the CH340 or FT232R) output TTL serial (at switchable voltage levels).
Q1
For instance !
I've been doing so using a general purpose [USB to RS232/RS485/TTL](https://www.ebay.fr/itm/USB-to-RS232-RS485-TTL-Embedded-FT232RL-Industrial-Isolated-Interface-Converter/183739598879?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649) converter that works ok.
Would you have any advice to get that voltage ?
Legacy RS232 systems use DB9 connectors and the signals can be anything fron (-12V, +12V) to (-18V, +18V)
later RS232 devices such as PC's can use signal levels all the way down to -5V to +5V.
The rs232 line will idle (not transmitting anything) in negative voltage say -12V
Normally you should be able to read some negative voltage (-12V or -5V) between pins 5 and 2 on your UPS's DB9 port.
You can easily build a simple transistor circuit to convert the RS232 signals to TTL and vice versa.
What would I need to communicate with my UPS (RS232 port) from a microcontroler, say arduino or ESP8266 ?
@HellasT
By the way, reading some stuff on RS232, it looks like even in standalone state I should get between -3 and -25V on Tx (Tx/GND) or Rx (Rx/GND). I can't see any on the UPS side.
On the converter side I can get -5.72V between GND and pin #3.
hary:
septillion:
Simply use a RS232 tot TTL chip like a MAX232 or MAX3232.
hary:
To communicate directly from a 3.3V or 5V logic level serial output with a true RS232 device (with +/- voltages and inverted logic), I recommend this converter from Pololu. There is a partial kit if you don't need the DB9 connector.
septillion:
That's indeed an option. But the core of that board is once again a MAX chip, the MAX3238
You're absolutely right !
There are a bunch of RS232 transceiver chip.
The max232 is now well outdated and can be replaced with a lots of new core maw232 with nice added features (see link above) (lower power consumption, shutdown when not in use, better transfer quality, ESD protection, ....etc....
In fact, coming back to one of my previous question why I couldn't read any voltage on UPS side in standalone mode (when no RS232 cable connected), I now understand !
I re-checked it with the USB =>RS232 converter connected (and USB powered !) to the UPS and I now can read -4.5V !
So, I guess the UPS is equipped with an updated power saving MAX 232 chip like "Autoshutdown" or "Autoshutdown Plus" feature described in the link.
All this now make sense.
Thank you very much to you helping me to sort this out ! I got things much clearer now.
