How to let the arduino know if sim800 received message from specific number
hi everyone.
I'm using SIM800C and it's working great to call and receive calls.
I want to turn led ON when i receive SMS message from a particular number, until now all tutorials show you how to constantly read serial to print the message received without the possibility to detect that and do something with it.
i don't have a code to post here but to show my progress, this is the code to receive and print the message to serial.
#include <SoftwareSerial.h>
//Create software serial object to communicate with SIM800L
SoftwareSerial mySerial(3, 2); //SIM800L Tx & Rx is connected to Arduino #3 & #2
  //Begin serial communication with Arduino and Arduino IDE (Serial Monitor)
  //Begin serial communication with Arduino and SIM800L
  mySerial.begin(9600);
  Serial.println("Initializing...");
  mySerial.println("AT"); //Once the handshake test is successful, it will back to OK
  updateSerial();
  mySerial.println("AT+CMGF=1"); // Configuring TEXT mode
  updateSerial();
  mySerial.println("AT+CNMI=1,2,0,0,0"); // Decides how newly arrived SMS messages should be handled
  updateSerial();
  updateSerial();
void updateSerial()
  while (Serial.available())
    mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port
  while(mySerial.available())
    Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
Take a look at this
/* Code Written and tested by:
 *  Youtube- Hyper_makes(https://www.youtube.com/channel/UCrCxVyN2idCxPNOwCwK6qtQ)
 *  Github:https://github.com/Kruze17/Parsing-SMS-with-SIM800L
String PHONE = "";
String msg;
#define rxPin D5
#define txPin D6
SoftwareSerial sim800(rxPin, txPin);
  sim800.begin(19200);
  initSIM();
  while (sim800.available())
    parseData(sim800.readString());  //Calls the parseData function to parse SMS
    if (PHONE != "")
      doAction();  //Does necessary action according to SMS message
void parseData(String buff)
  Serial.println(buff);
  unsigned int index;
  //Remove sent "AT Command" from the response string.
  index = buff.indexOf("\r");
  buff.remove(0, index + 2);
  buff.trim();
  if (buff != "OK")
    index = buff.indexOf(":");
    String cmd = buff.substring(0, index);
    cmd.trim();
    //Parse necessary message from SIM800L Serial buffer string
    if (cmd == "+CMT")
      //get newly arrived memory location and store it in temp
      index = buff.lastIndexOf(0x0D);                  //Looking for position of CR(Carriage Return)
      msg = buff.substring(index + 2, buff.length());  //Writes message to variable "msg"
      msg.toLowerCase();                               //Whole message gets changed to lower case
                                                       //  Serial.println(msg);
      index = buff.indexOf(0x22);                      //Looking for position of first double quotes-> "
      PHONE = buff.substring(index + 1, index + 14);   //Writes phone number to variable "PHONE"
      //  Serial.println(PHONE);
void doAction()
  //code to respond to text based on text or number goes here
  Serial.print("Received : ");
  Serial.print("from :");
  PHONE = "";  //Clears string
  msg = "";    //Clears message string
void initSIM()
  Serial.println(F("Initializing GSM..."));
  sim800.print("AT + CMGF = 1\r");
  sim800.print("AT + CMGD = 1, 4\r");
  sim800.print("AT + CNMI = 2, 2, 0, 0, 0\r");
  Serial.println(F("SMS initialised"));
As you will see from the comments, it is not my code, but I believe that it works to parse an SMS message
Note that even if it works this might not be the best way to do it
Actually i found a good solution which i will post here for a future visitors.
It record everything from the received sms including the phone number and message then i can check if the particular number is there or not.
That is what the code I posted does
I know but its a bit complicated as it includ removing some parts.
But overall the same
