Hello friend... I'm newbie in arduino
I have motor driver like this for 2 motor DC:
I'm trying to convert a code from 4 motors into 2 dc motors.
And I don't understand how to make a car go backwards ...
Can any of my dear colleagues help me convert the code into 2 engines correctly for this driver ??
I commented on the lines that I thought were unnecessary ...
//geeky singh 14th dec 2015 for instructables.com
#define SRC_NEUTRAL 1500
#define SRC_MAX 2000
#define SRC_MIN 1000
#define TRC_NEUTRAL 1500
#define TRC_MAX 2000
#define TRC_MIN 1000
#define RC_DEADBAND 50
#define ERROR_center 50
#define pERROR 100
uint16_t unSteeringMin = SRC_MIN + pERROR;
uint16_t unSteeringMax = SRC_MAX - pERROR;
uint16_t unSteeringCenter = SRC_NEUTRAL;
uint16_t unThrottleMin = TRC_MIN + pERROR;
uint16_t unThrottleMax = TRC_MAX - pERROR;
uint16_t unThrottleCenter = TRC_NEUTRAL;
#define PWM_MIN 0
#define PWM_MAX 255
#define GEAR_NONE 1
#define GEAR_IDLE 1
#define GEAR_FULL 2
#define PWM_SPEED_LEFT 10
#define PWM_SPEED_RIGHT 11
#define LEFT1 5
// #define LEFT2 6
#define RIGHT1 7
// #define RIGHT2 8
#define PROGRAM_PIN 9
// Assign your channel in pins
#define THROTTLE_IN_PIN 2
#define STEERING_IN_PIN 3
// These bit flags are set in bUpdateFlagsShared to indicate which
// channels have new signals
#define THROTTLE_FLAG 1
#define STEERING_FLAG 2
// holds the update flags defined above
volatile uint8_t bUpdateFlagsShared;
volatile uint16_t unThrottleInShared;
volatile uint16_t unSteeringInShared;
uint32_t ulThrottleStart;
uint32_t ulSteeringStart;
uint8_t gThrottle = 0;
uint8_t gGear = GEAR_NONE;
uint8_t gOldGear = GEAR_NONE;
#define DIRECTION_STOP 0
#define DIRECTION_FORWARD 1
#define DIRECTION_REVERSE 2
#define DIRECTION_ROTATE_RIGHT 3
#define DIRECTION_ROTATE_LEFT 4
uint8_t gThrottleDirection = DIRECTION_STOP;
uint8_t gDirection = DIRECTION_STOP;
uint8_t gOldDirection = DIRECTION_STOP;
#define IDLE_MAX 50
#define MODE_RUN 0
uint8_t gMode = MODE_RUN;
unsigned long pulse_time ;
Serial.println("hello");
attachInterrupt(0 /* INT0 = THROTTLE_IN_PIN */,calcThrottle,CHANGE);
attachInterrupt(1 /* INT1 = STEERING_IN_PIN */,calcSteering,CHANGE);
pinMode(PWM_SPEED_LEFT,OUTPUT);
pinMode(PWM_SPEED_RIGHT,OUTPUT);
pinMode(LEFT1,OUTPUT);
\\ pinMode(LEFT2,OUTPUT);
pinMode(RIGHT1,OUTPUT);
\\pinMode(RIGHT2,OUTPUT);
pinMode(12,OUTPUT);
pulse_time =millis() ;
pinMode(PROGRAM_PIN,INPUT);
static uint16_t unThrottleIn;
static uint8_t bUpdateFlags;
if(bUpdateFlagsShared)
noInterrupts();
bUpdateFlags = bUpdateFlagsShared;
if(bUpdateFlags & THROTTLE_FLAG)
unThrottleIn = unThrottleInShared;
if(bUpdateFlags & STEERING_FLAG)
unSteeringIn = unSteeringInShared;
// clear shared copy of updated flags as we have already taken the updates
// we still have a local copy if we need to use it in bUpdateFlags
bUpdateFlagsShared = 0;
interrupts(); // we have local copies of the inputs, so now we can turn interrupts back on
// as soon as interrupts are back on, we can no longer use the shared copies, the interrupt
// service routines own these and could update them at any time. During the update, the
// shared copies may contain junk. Luckily we have our local copies to work with :-)
// do any processing from here onwards
// only use the local values unAuxIn, unThrottleIn and unSteeringIn, the shared
// variables unAuxInShared, unThrottleInShared, unSteeringInShared are always owned by
// the interrupt routines and should not be used in loop
if(gMode == MODE_RUN)
// we are checking to see if the channel value has changed, this is indicated
// by the flags. For the simple pass through we don't really need this check,
// but for a more complex project where a new signal requires significant processing
// this allows us to only calculate new values when we have new inputs, rather than
// on every cycle.
// A good idea would be to check the before and after value,
// if they are not equal we are receiving out of range signals
// this could be an error, interference or a transmitter setting change
// in any case its a good idea to at least flag it to the user somehow
unThrottleIn = constrain(unThrottleIn,unThrottleMin,unThrottleMax);
if(unThrottleIn > (unThrottleCenter + ERROR_center))
gThrottle = map(unThrottleIn,(unThrottleCenter + ERROR_center),unThrottleMax,PWM_MIN,PWM_MAX);
gThrottleDirection = DIRECTION_FORWARD;
else if (unThrottleIn < (unThrottleCenter - ERROR_center))
gThrottle = map(unThrottleIn,unThrottleMin,(unThrottleCenter- ERROR_center),PWM_MAX,PWM_MIN);
gThrottleDirection = DIRECTION_REVERSE;
gThrottleDirection =DIRECTION_STOP;
gThrottle=0;
if(gThrottle < IDLE_MAX)
gGear = GEAR_IDLE;
gGear = GEAR_FULL;
uint8_t throttleLeft = gThrottle;
uint8_t throttleRight = gThrottle;
gDirection = gThrottleDirection;
// see previous comments regarding trapping out of range errors
// this is left for the user to decide how to handle and flag
unSteeringIn = constrain(unSteeringIn,unSteeringMin,unSteeringMax);
// if idle spin on spot
switch(gGear)
case GEAR_IDLE:
if(unSteeringIn > (unSteeringCenter + RC_DEADBAND))
gDirection = DIRECTION_ROTATE_RIGHT;
// use steering to set throttle
throttleRight = throttleLeft = map(unSteeringIn,unSteeringCenter,unSteeringMax,PWM_MIN,PWM_MAX);
else if(unSteeringIn < (unSteeringCenter - RC_DEADBAND))
gDirection = DIRECTION_ROTATE_LEFT;
throttleRight = throttleLeft = map(unSteeringIn,unSteeringMin,unSteeringCenter,PWM_MAX,PWM_MIN);
// if not idle proportionally restrain inside track to turn vehicle around it
case GEAR_FULL:
throttleLeft = map(unSteeringIn,unSteeringCenter,unSteeringMax,gThrottle,PWM_MIN);
throttleRight = map(unSteeringIn,unSteeringMin,unSteeringCenter,PWM_MIN,gThrottle);
analogWrite(PWM_SPEED_LEFT,throttleLeft);
analogWrite(PWM_SPEED_RIGHT,throttleRight);
if((gDirection != gOldDirection) || (gGear != gOldGear))
gOldDirection = gDirection;
gOldGear = gGear;
digitalWrite(LEFT1,LOW);
// digitalWrite(LEFT2,LOW);
digitalWrite(RIGHT1,LOW);
//digitalWrite(RIGHT2,LOW);
switch(gDirection)
case DIRECTION_FORWARD:
//digitalWrite(LEFT2,HIGH);
//digitalWrite(RIGHT2,HIGH);
case DIRECTION_REVERSE:
digitalWrite(LEFT1,HIGH);
//digitalWrite(LEFT2,LOW);
digitalWrite(RIGHT1,HIGH);
case DIRECTION_ROTATE_RIGHT:
case DIRECTION_ROTATE_LEFT:
case DIRECTION_STOP:
// digitalWrite(RIGHT2,LOW);
bUpdateFlags = 0;
void calcThrottle()
if(digitalRead(THROTTLE_IN_PIN) == HIGH)
ulThrottleStart = micros();
unThrottleInShared = (uint16_t)(micros() - ulThrottleStart);
bUpdateFlagsShared |= THROTTLE_FLAG;
void calcSteering()
if(digitalRead(STEERING_IN_PIN) == HIGH)
ulSteeringStart = micros();
unSteeringInShared = (uint16_t)(micros() - ulSteeringStart);
bUpdateFlagsShared |= STEERING_FLAG;
Thank you for all the answers ....
Maybe I should buy another driver ?? like this??
