How to Make a solar tracker automatically with RTC
I want to make a solar tracker automatically by adding data that contains the angles of the sun’s movement. I am asking you for a software code to implement this system, knowing that I will be using the RTC DS1307, so please help me
Is this how all the students learn their stuff?
Hi
Please do not try to insert whole message to the title....
Why do not use something shorter as the topic header - for example "I want to make a solar tracker " ?
Please edit the title.
It is not a way how the forum works.
It is your project. We can only to help you.
But you should try to write code yourself.
If you will experience a troubles - come here and ask.
Hello Muhammad Hassan Muhammad
  • side angle = time
  • elevation = week of year
The SolarPosition library gives the sun's altitude and azimuth, at any time of day, anywhere in the world.
One might expect students to research stuff and learn how to produce thier own code.
