Hello Everyone!
I am prototyping a dual-axis solar tracker based on RTC, GPS, and LDR readings (For feedback mechanism, I am thinking if I should include it or not). I have created a code based on other related studies and tutorials on how to do so. However, I am having trouble debugging the sketch and the mechanism isn't, somehow, working as intended. I am thinking maybe it is from the wirings/on how the modules are connected to its pins or the code is the problem itself.
Please help me correct the code, to what should be implemented, removed, added, adjusted, etc. I am very open to suggestions and feedback that would help me improve my work. The details are given below. Thank you in Advance!
A Dual-axis solar tracker composed of 6 solar panels positioned like a Sunflower. The system is based on RTC and GPS reading for the calculation of the sun position, and the code implements a feedback mechanism using 5 sets of LDRs which help position the servo motors accordingly. Moreover, if the LDR readings are low the gear moves clockwise which serves as a closing mechanism. Conversely, if the LDR detects light the gear moves counter-clockwise which is the opening of the panels. Additionally, the code utilizes a smart monitoring system using a Bluetooth module which would direct the data outputs (Average Voltage, time, date, etc) to an android app created in MIT App inventor. Specifically, this uses a DS3231 RTC, NEO 6m GPS with antenna, HC-05 Bluetooth module, 2 MG90s Servo motors, DC Gear motor, L293D Dual H-Bridge Motor Driver IC, 6 pieces of 5V 60mA mini solar panels, and a microcontroller Arduino Uno R3.
NOTE: I am not a professional nor an expert on this matter, the sketch is might be incomplete, very unorganized and some parts might not even make sense. This is very stressful, please bear with me ![]()
#include <RTClib.h>
#include <SoftwareSerial.h>
#include <TinyGPS++.h>
#include <Servo.h>
Servo horizontal; // horizontal servo
int servoh = 180;
int servohLimitHigh = 175;
int servohLimitLow = 5;
// 65 degrees MAX
Servo vertical; // vertical servo
int servov = 45;
int servovLimitHigh = 100;
int servovLimitLow = 1;
// LDR pin connections
// name = analogpin;
int ldrlt = A1; //LDR top left - BOTTOM LEFT <--- BDG
int ldrrt = A2; //LDR top right - BOTTOM RIGHT
int ldrld = A3; //LDR down left - TOP LEFT
int ldrrd = A4; //ldr down right - TOP RIGHT
int ldrmt = A5;
const int button1 = 9;
const int button2 = 10;
const int motorA = 7;
const int motorB = 8;
const int pvPin = 1; // +V from PV is connected to analog pin 1
int buttonStateA = 0;
int buttonStateB = 0;
int angle = 0;
int angle_ref = 110; // angle of horizontal array; facing the sky
int pos = 0;
int pos2 = 0;
int oldvalue;
int oldvalue2;
// Define BT variables
long previousMillis = 0; // will store last time data was sent
long interval = 8000; // interval at which to send data (ms)
// Define running average variables
const int numReadings = 6; // number of sample for the running average (*****)
int readings[numReadings][5]; // the readings from the 6 analog inputs
int index = 0; // the index of the current reading
int total[5] = { 0, 0, 0, 0, 0 }; // the running total
int average_diff = 0; // the average of the difference
//GPS variables
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 9600;
TinyGPSPlus gps;
SoftwareSerial ss(RXPin, TXPin); // RX, TX
RTC_DS3231 rtc;
SoftwareSerial BTSerial(2, 3); // RX, TX
ss.begin(GPSBaud);
angle = angle_ref;
horizontal.attach(5);
vertical.attach(6);
horizontal.write(180);
vertical.write(0); //45? //0?
pinMode(motorA, OUTPUT);
pinMode(motorB, OUTPUT);
pinMode(button1, INPUT);
pinMode(pvPin, INPUT);
delay(2500);
Wire.begin();
rtc.begin();
//Set the RTC time
//rtc.adjust(DateTime(F(12, 3, 2023), F(10, 00, 00))); // day, month, year // hour, minute, second
rtc.adjust(DateTime(2023, 3, 13, 15, 30, 0)); // set time to March 13, 2023, 3:30 PM
//BTSerial.begin(9600);
// Calculate the equation of time for a given date
double equationOfTime(int year, int month, int day) {
double B = 360 / 365.24 * (day - 81);
double EOT = B + 9.87 * sin(radians(2 * B)) - 7.53 * cos(radians(B)) - 1.5 * sin(radians(B));
return EOT;
while (ss.available() > 0) {
gps.encode(ss.read());
if (gps.location.isUpdated()) {
double latitude = gps.location.lat();
double longitude = gps.location.lng();
double currentHour = gps.time.hour();
double currentMinute = gps.time.minute();
double currentSecond = gps.time.second();
Serial.print("Latitude= ");
Serial.println(gps.location.lat(), 6);
Serial.print("Longitude= ");
Serial.println(gps.location.lng(), 6);
calculateSunPosition();
DateTime now = rtc.now(); // Get the current time from the RTC
// calculate the position of the sun based on current time and location
float latitude, longitude;
float altitude, azimuth;
calculateSunPosition(now, latitude, longitude, altitude, azimuth);
Serial.print("Altitude: ");
Serial.println(altitude);
Serial.print(", Azimuth: ");
Serial.println(azimuth);
int year = now.year();
int month = now.month();
int day = now.day();
int hour = now.hour();
int minute = now.minute();
int second = now.second();
// Calculate the current day of the year
int N = now.day();
// Calculate the decimal hour
float h = now.hour() + now.minute() / 60.0 + now.second() / 3600.0;
// Calculate the solar declination angle
float delta = 23.45 * sin(2 * PI * (N - 81) / 365);
// Calculate the solar hour angle
float H = 15 * (h - 12) + longitude;
// Calculate the solar altitude angle
float sinAlt = sin(radians(latitude)) * sin(radians(delta)) + cos(radians(latitude)) * cos(radians(delta)) * cos(radians(H));
float alt = degrees(asin(sinAlt));
// Calculate the solar azimuth angle
float cosAz = (sin(radians(delta)) - sin(radians(latitude)) * sin(radians(alt))) / (cos(radians(altitude)) * cos(radians(alt)));
float az = degrees(acos(cosAz));
if (H > 0)
az = 360 - az;
// Calculate the sun's position for the given date and time
// Convert latitude and longitude to radians
float latRad = radians(latitude);
float longRad = radians(longitude);
// Calculate the declination angle
float sinDeclination = sin(radians(23.45)) * sin(radians(360 / 365.24 * (day - 81))); //sin(radians(altitude));
float cosDeclination = sqrt(1 - pow(sinDeclination, 2));
float declination = degrees(atan2(sinDeclination, cosDeclination));
// Calculate the hour angle
float solarTime = hour + minute / 60.0 + second / 3600.0;
float solarNoon = 12.0 - (longitude / 15.0) - (4 * (longitude - 15 * equationOfTime(year, month, day)) / 60.0);
float hourAngle = 15.0 * (solarTime - solarNoon);
// Calculate the altitude angle
float sinAltitude = sin(latRad) * sin(radians(declination)) + cos(latRad) * cos(radians(declination)) * cos(radians(hourAngle));
altitude = degrees(asin(sinAltitude));
// Calculate the azimuth angle
float cosAzimuth = (sin(radians(declination)) - sin(latRad) * sin(radians(altitude))) / (cos(latRad) * cos(radians(altitude)));
azimuth = degrees(acos(cosAzimuth));
if (hourAngle > 0) {
azimuth = 360 - azimuth;
// convert altitude and azimuth angles to servo motor positions
// control the servo motors to move to the desired positions
int servohNew = map(azimuth, 0, 360, servohLimitLow, servohLimitHigh);
int servovNew = map(altitude, 0, 90, servovLimitLow, servovLimitHigh);
// move the servo motors to the desired positions
if (abs(servohNew - servoh) > 2) {
if (servohNew > servoh) {
for (pos = servoh; pos <= servohNew; pos += 1) {
horizontal.write(pos);
delay(100); //10(.1 second)? maybe adjusted (mm)
for (pos = servoh; pos >= servohNew; pos -= 1) {
delay(100); //10(.1 second)?maybe adjusted (mm)
servoh = servohNew;
if (abs(servovNew - servov) > 2) {
if (servovNew > servov) {
for (pos2 = servov; pos2 <= servovNew; pos2 += 1) {
vertical.write(pos2);
delay(100); //maybe adjusted (mm)
for (pos2 = servov; pos2 >= servovNew; pos2 -= 1) {
servov = servovNew;
int ldrStatus = analogRead(ldrmt);
if (ldrStatus > 30) {
buttonStateA = digitalRead(button1);
if (buttonStateA == LOW) {
digitalWrite(motorA, HIGH); //COUNTER clockwise
digitalWrite(motorB, LOW);
digitalWrite(motorA, LOW);
buttonStateB = digitalRead(button2);
if (buttonStateB == LOW) {
digitalWrite(motorA, LOW); //clockwise
digitalWrite(motorB, HIGH);
// Feedback Mechanism using LDR readings
//void feedbackMechanism() {
int lt = analogRead(ldrlt); // top left
int rt = analogRead(ldrrt); // top right
int ld = analogRead(ldrld); // down left
int rd = analogRead(ldrrd); // down right
int dtime = 10;
int tol = 90; // dtime=diffirence time, tol=toleransi
int avt = (lt + rt) / 2; // average value top
int avd = (ld + rd) / 2; // average value down
int avl = (lt + ld) / 2; // average value left
int avr = (rt + rd) / 2; // average value right
int dvert = avt - avd; // check the diffirence of up and down
int dhoriz = avl - avr; // check the diffirence og left and rigt
//if(lt>90){
//if(Switch_a==LOW){
// digitalWrite(9==HIGH);
// digitalWrite(10==LOW);
// delay(1000);
if (-1 * tol > dvert || dvert > tol) {
if (avt > avd) {
servov = ++servov;
if (servov > servovLimitHigh) {
servov = servovLimitHigh;
} else if (avt < avd) {
servov = --servov;
if (servov < servovLimitLow) {
servov = servovLimitLow;
vertical.write(servov);
if (-1 * tol > dhoriz || dhoriz > tol) // check if the diffirence is in the tolerance else change horizontal angle
if (avl > avr) {
servoh = --servoh;
if (servoh < servohLimitLow) {
servoh = servohLimitLow;
} else if (avl < avr) {
servoh = ++servoh;
if (servoh > servohLimitHigh) {
servoh = servohLimitHigh;
} else if (avl = avr) {
delay(10);
horizontal.write(servoh);
delay(dtime);
oldvalue = horizontal.read();
oldvalue2 = vertical.read();
for (pos = oldvalue; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
delay(15);
for (pos2 = oldvalue2; pos2 <= 0; pos2 += 1) { // goes from 0 degrees to 180 degrees
vertical.write(pos2); // tell servo to go to position in variable 'pos'
delay(15);
if (BTSerial.available()) {
// handle Bluetooth commands here
//Calculate the runnning average
total[3] -= readings[index][3];
readings[index][3] = analogRead(pvPin);
total[3] += readings[index][3];
float ref_voltage = (total[1] / numReadings) / 1000.0; // return the runnning average of Vcc
float average_pv = total[3] / numReadings; // return the runnning average of batt
//Update PV voltage
float voltage_pv = average_pv * ref_voltage * 2.0 / 1024.0; // /(R2/(R1 + R2))
float power_pv = voltage_pv * 0.150 * 5;
// Correct angle for display
float angle_corr = angle * (148 - 110) / 45 - 100 * (148 - 110) / 45;
// Datalogging over bluetooth every X seconds
unsigned long currentTime = millis(); // 3600000.0;
if (currentMillis - previousMillis > interval) {
Serial.print("Time = ");
Serial.print(millis() / 3600000.0);
Serial.print(" s | ");
Serial.print("Array angle = ");
Serial.print(angle_corr);
Serial.println(" deg");
//Serial.print("Temperature = "); Serial.print(temperatureC); Serial.println(" deg C");
//Serial.print("Battery SOC = "); Serial.print( (int) battery_capa); Serial.print("% | ");
//Serial.print("V batt = "); Serial.print(voltage_batt); Serial.println(" V");
Serial.print("V pv = ");
Serial.print(voltage_pv);
Serial.print(" V | ");
Serial.print("P pv (estimate) = ");
Serial.print(power_pv);
Serial.println(" W");
Serial.print("Vcc = ");
Serial.print(ref_voltage);
