Hello, I'm trying to make a class which stores an int array, and I want to input it to the constructor like this:
Example test = {3,4,5,6,7};
But I dont know how to make a constructor which can have this input. Any help?
With this syntax:
3 implementations are accepted.
If you implement both 2 and 3, 2 will have priority.
A fourth option: the class has a single public member of type int [5] and no user-provided constructor.
This is how std::array is implemented.
std::vector uses std::initializer_list. The problem is that there's no way to check the number of elements at compile-time.
Pieter
arduino_new:
3) A constructor that takes "std::initializer_list<>" as an argument.
I tried to do this, as it's the best solution for my case, but the compiler says that std::initializer_list is not defined, even if I try to pass in a class for the template
xdddman:
#include <initializer_list>
class Example {
private:
public:
Example(std::initializer_list<int> list) {
Example exam = {10,10,10,10,10};
I tried the code you posted and the compiler says initializer_list does not exist
Did you include the header?
The code I posted compiled for ESP board but not for Uno. It seems like AVR boards do not have stl libraries.
I tried the same code with my ESP and it worked fine, so it is that the AVR boards dont include stl. Do you know of any other way I could implement initializer_list or of making the constructor?
xdddman:
I don't have an idea how it's implemented. But there are several custom stl libraries for avr boards if you want to search and pick one.
Alright! Thanks for the help!
This should work:
[color=#00979c]class[/color] [color=#000000]Example[/color] [color=#000000]{[/color]
[color=#00979c]public[/color][color=#434f54]:[/color]
[color=#00979c]int[/color] [color=#00979c]array[/color][color=#000000][[/color][color=#000000]5[/color][color=#000000]][/color][color=#000000];[/color]
[color=#00979c]void[/color] [color=#d35400]print[/color][color=#000000]([/color][color=#000000])[/color] [color=#00979c]const[/color] [color=#000000]{[/color]
[color=#5e6d03]for[/color] [color=#000000]([/color][color=#00979c]int[/color] [color=#000000]elem[/color] [color=#434f54]:[/color] [color=#00979c]array[/color][color=#000000])[/color]
[b][color=#d35400]Serial[/color][/b][color=#434f54].[/color][color=#d35400]println[/color][color=#000000]([/color][color=#000000]elem[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]}[/color]
[color=#000000]}[/color][color=#000000];[/color]
[color=#000000]Example[/color] [color=#000000]test[/color] [color=#434f54]=[/color] [color=#000000]{[/color][color=#000000]3[/color][color=#434f54],[/color] [color=#000000]4[/color][color=#434f54],[/color] [color=#000000]5[/color][color=#434f54],[/color] [color=#000000]6[/color][color=#434f54],[/color] [color=#000000]7[/color][color=#000000]}[/color][color=#000000]; [/color]
[color=#00979c]void[/color] [color=#5e6d03]setup[/color][color=#000000]([/color][color=#000000])[/color] [color=#000000]{[/color]
[b][color=#d35400]Serial[/color][/b][color=#434f54].[/color][color=#d35400]begin[/color][color=#000000]([/color][color=#000000]115200[/color][color=#000000])[/color][color=#000000];[/color]
[color=#5e6d03]while[/color] [color=#000000]([/color][color=#434f54]![/color][b][color=#d35400]Serial[/color][/b][color=#000000])[/color][color=#000000];[/color]
[color=#000000]test[/color][color=#434f54].[/color][color=#d35400]print[/color][color=#000000]([/color][color=#000000])[/color][color=#000000];[/color]
[color=#00979c]void[/color] [color=#5e6d03]loop[/color][color=#000000]([/color][color=#000000])[/color] [color=#000000]{[/color][color=#000000]}[/color]
