How to make strobe flasher
I'm new to electronics and I was wondering how to take my Arduino Uno processor and make it flash 12v led lights in a strobe pattern similar to police or fire? I'm on the fire dept and wanted to make my own flasher unit for my lights. Thanks
This should do it for you.
http://nootropicdesign.com/projectlab/2010/01/08/arduino-police-lights/
Add the appropriate 12V drivers for your LEDs.
Thanks, got one issue, how do I DRIVE 12V led's off of board? Everywhere I hook wires to, the light flashes very dim. Apparently I'm missing something.
Technically you don't have "12v LEDs" but often LEDs are packaged with a resistor that is suitable for use with 12v.
Assuming that's what you have you can connect the anode of the LED to 12v, cathode to a transistor's collector and the emitter to GND then control the transistor's base with an Arduino output pin through a resistor.
There is an example somewhere in the playground but I can never find anything there. Hopefully somebody can provide a link.
EDIT: Found something
Just pretend the solenoid is your 12v LED and don't use D1.
Rob
