Hello,
I'm trying to use Nano Every to generate two TCA0 based interrupts by using two compare channels. This is supposed to be a simple task and I've read though ATmega4808 DS multiple times, especially the TCA0 chapter, and manipulated almost all the register configurations, but still could get both compared channel ints working at the same time. Below is the my full test code:
#include <avr/io.h>
#include <avr/interrupt.h>
volatile bool flag = false;
PORTA.DIR |= PIN0_bm; /* set PORT PA0 (pin20.D2) as output */
PORTA.OUT |= PIN0_bm; /* Set initial level of PA0 */
PORTA.DIR |= PIN1_bm; /* set PORT PA1 (pin25.D7) as output */
PORTA.OUT |= PIN1_bm; /* Set initial level of PA0 */
unsigned int per_value;
cli();
per_value = 0xF423; // set period value for 2Hz freq
//TCA0.SINGLE.CTRLB = TCA_SINGLE_WGMODE_FRQ_gc;
TCA0.SINGLE.CTRLB = TCA_SINGLE_WGMODE_NORMAL_gc;
TCA0.SINGLE.CTRLA = TCA_SINGLE_CLKSEL_DIV64_gc;
TCA0.SINGLE.INTCTRL = TCA_SINGLE_CMP1_bm | TCA_SINGLE_CMP0_bm;
TCA0.SINGLE.CNT = 0;
TCA0.SINGLE.EVCTRL &= ~(TCA_SINGLE_CNTEI_bm);
TCA0.SINGLE.PER = per_value;
TCA0.SINGLE.CMP1 = 0x7FFF; // set some arbitrary number for comp channel 1
TCA0.SINGLE.CMP0 = 0x3FFF; // set some arbitrary number for comp channel 0
TCA0.SINGLE.CTRLA |= TCA_SINGLE_ENABLE_bm;
Serial.print("TCA0.SINGLE.INTCTRL= ");
Serial.println(TCA0.SINGLE.INTCTRL);
Serial.print("TCA0.SINGLE.CTRLA= ");
Serial.println(TCA0.SINGLE.CTRLA);
Serial.print("TCA0.SINGLE.CTRLB= ");
Serial.println(TCA0.SINGLE.CTRLB);
Serial.print("TCA0.SINGLE.EVCTRL= ");
Serial.println(TCA0.SINGLE.EVCTRL);
Serial.print("TCA0.SINGLE.PER= ");
Serial.println(TCA0.SINGLE.PER);
Serial.print("TCA0.SINGLE.CMP1= ");
Serial.println(TCA0.SINGLE.CMP1);
Serial.print("TCA0.SINGLE.CMP0= ");
Serial.println(TCA0.SINGLE.CMP0);
sei();
ISR(TCA0_CMP1_vect) {
flag = true;
TCA0.SINGLE.INTFLAGS |= TCA_SINGLE_CMP1_bm; // Clears the interrupt flag. Rather confusingly,
//TCA0.SINGLE.CNT = 0;
PORTA.OUTTGL = PIN1_bm; /* Toggle PIN 1 of PORT A (PA1=D7) for debugging */
ISR(TCA0_CMP0_vect) {
TCA0.SINGLE.INTFLAGS |= TCA_SINGLE_CMP0_bm; // Clears the interrupt flag. Rather confusingly,
PORTA.OUTTGL = PIN0_bm; /* Toggle PIN 0 of PORT A (PA0=D2) for debugging */
A few notes to quickly explain my test codes:
- Using TCA0 normal mode, keep default DIV64 prescale (so not to mess delay or millis functions);
- Enable both CMP0 and CMP1 channels and set different (arbitrary) CMP values;
- I read some example codes suggesting use 'TCA0.SINGLE.CNT = 0;' to ensure correct counting. And even used in ISR to clear interrupt, that's why that line of code currently commented out in both ISRs.
My problem is, while running above codes, and monitor both D2 and D7 test pin outputs with digital scope, I can see both channels are outputting 2Hz waveform, as if both interrupts are generated by PER value (TOP value here) overflow. I'm supposed to expect see two waveforms with different frequencies. But that's not what I observed. Please see the waveform snapshot below.
I've tried everything I could, but just couldn't figure out how to make both interrupts working as expected. Is it possible to generate two ints with different compare values on two channels? or Nano every only support one channel at one time?
Please help take a look and let me know where I did wrong. Any help would be greatly appreciated!
Terry
