Hi! I am using Arduino NANO with ATmega168PA microprocessor. My task is to check the operation of interrupts and timers for their joint work. I use three LEDs: red, yellow and green.
I wrote the following code:
int32_t volatile i;
int32_t volatile j;
int32_t volatile u;
Serial.begin(9600); // setting the port speed (bps, baud)
cli(); // instruction to disable interrupts immediately
DDRD = 0xFF; // port D to OUTPUT
//SMCR |= (0 << SM0) | (0 << SM1) | (0 << SM2);
TCCR1A = 0b00000000; // OC1A Disabled
TCCR1B = 0b00001100; // divider 256, reset on match 1A (CTC mode)
TIMSK1 = 0b00000110; // start interrupt A and B timer 1
OCR1A = 0xF424; // 1s 0xC350 0.8s 0x30D4 0.2s 0xF424 1s
OCR1B = 0x7A12; // 0xF424 0.5s
//TCCR1A = 0b00000000; // OC1A Disabled
//TCCR1B = 0b00001100; // divider 256, reset on match 1B (CTC mode)
//TIMSK1 = 0b0000100; // start interrupt B timer 1
TCCR2A = 0b00000000; // OC2A Disabled
TCCR2B = 0b00001101; // divider 1024, reset on match 2V (CTC mode)
OCR2A = 0xFFFF; // 0.016s
//TIMSK2 = 0b00000010; // start interrupt B timer 2
TIMSK2 |= (1 << OCIE2A);
sei(); // instruction to enable interrupts
ISR(TIMER1_COMPA_vect) { //timer 1 coincident interrupt handler A, counter reset to 0
Serial.println('i');
Serial.println(i);
i ++;
if (i % 2 == 0)
PORTD = 0b00000100;
if (i % 2 == 1)
PORTD = 0b00000000;
ISR(TIMER1_COMPB_vect) { //timer 1 coincident interrupt handler A, counter reset to 0
j ++;
Serial.println('j');
Serial.println(j);
if (j % 2 == 0)
PORTD = 0b00010000;
if (j % 2 == 1)
PORTD = 0b00000000;
ISR(TIMER2_COMPA_vect) { //timer 2 coincident interrupt handler A, counter reset to 0
u ++;
Serial.println('u');
Serial.println(u);
if (u % 2 == 0)
PORTD = 0b00001000;
if (u % 2 == 1)
PORTD = 0b00000000;
If both the first timer interrupt and the second timer interrupt are enabled, only the interrupt of the first timer is triggered. If both the first timer interrupt and the second timer interrupt are enabled, only the interrupt of the first timer is triggered. If interrupts of the first timer are enabled separately, then the first interrupt works (LEDs red (1 second), green (0.5 seconds) blink). I have the yellow LED set to interrupt the second timer. I do not understand why all the LEDs do not light up together (only the yellow LED blinks when working together)? If you change the second timer to a zero timer, then the LEDs all blink together (each at its own time). Why is it not possible to start interrupts of the second and first interrupts together? Interestingly, when the zero and second timer interrupts work together, only the second timer interrupts are triggered.
Thank you! When I removed Serial from interrupts, the LEDs lit up, though the yellow LED blinks worse (just glows) when blinking occurs on an interrupt from the second timer than when blinking occurs from an interrupt from the zero timer (the LED actually blinks and the light is brighter).
In addition to the @DrDiettrich post#6 - you are turning your LEDs on and off in interrupts completely wrong:
The line PORTD = 0b00000100; not only turn D2 pin HIGH, but also turn off all others pins on PORTD.
The same is true for two other interrupts. Each of them influences the others two.
To turn pins on and off independently you need to change the defined pin ONLY.
For example
i ++;
if (i % 2 == 0)
PORTD | = 0b00000100; // turn D2 HIGH exclusively
if (i % 2 == 1)
PORTD &= ~ 0b00000100; // turn D2 LOW
Yes, I'll ask for more help. I can’t understand, the red and green LEDs blink (the first timer), and for some reason the yellow LED only glows when I blink the yellow LED according to the second timer. If I switch the work of the yellow LED to the zero timer, there are no questions (there is blinking). Why is that? After all, both the zero and second timers are 8-bit timers, they are similar.
