Is there anyone out there who has a kind heart to help me?
For an arduino to read the value constantly or for a human user?
How about using a DO (dissolved oxygen) sensor?
zwieblum:
For an Arduino
As wvmarle wrote google for "Dissolved Oxygen Sensor" ... but it's not cheap. There are some handheld warter quality meters from PCE that come with rs232
I had a similar requirement few months ago. I ended up using this sensor
Instead of providing data via a serial port, it connects via Analog Pin on the arduino.
It does have some UART commands for calibration I suppose, there is arduino code at the bottom of the description which explains the same.
The UART commands will go to the Arduino, not to the sensor. There's a big chunk of code on that page, I didn't analyse it.
Calibration is as usual: take a few samples with known DO, see what value the sensor gives. If linear, two points are enough (or if the slope is known a single point can do). That gives you the calibration value and allows you to calculate the DO of an unknown sample.
