Nick_Pyner:
It sounds a reasonable request but I have only seen them included in a short length of pipe. This may be simply because they are intended to go in where a mechanical meter came out.
It sounds like you have a seriously large house and go through water like there is no tomorrow, but there are plenty meters of that type with 1" fittings and screw-up, not solder-in. Since this is an Arduino forum, you might be better off considering a plain-vanilla hall effect sensor for about 1/10th the price, even with 1" fittings.
eBay 291298769800.
I've only seen the ultrasonics online, and they look like they could be applied to the outside of mor or less any pipe.
That listing is for a dinky plastic sensor that I would not trust to be a long life item. This seems mitt appropriate for a temporary gardening project rather than a permemant plumbing installing for one's home.
dave-in-nj:
an ultrasonic flow sensor does indeed use an existing pipe.
often they can clamp on and are then calibrated.
although they are not that expensive, typically under $10,000 for one, the plus side is that the device will be field calibrated by the technician who has very elaborate and sophisticated equipment.
if you are looking for a casual reading, a paddle wheel sensor would work fine.
if you want exacting accuracy, you will need to look at custody transfer instrumentation. IIRC, these devices start well over $5,000 USD and can go up depending on the level if NIST traceability your application requires.
What world are you from that 10 grand for measuring a homes water flow is "not that expensive"? This isn't a business opportunity or a university research project. 10k is about 50 fold over budget. Suggesting this when people playing with arduino's seems grossly inappropriate.
TomGeorge:
What does the front of your current water meter look like, what is its make/model?
Does it have an indicator of some sort on its face?
Tom...
That's a good idea, I'll take a look tomorrow. In know its on the street in front of the house, not sure if there is a tamper proof lock of some sort on it.
mikb55:
You can buy Pelton wheel Hall effect flow sensors on Ebay for less than $10.
Use a bypass shunt with an adjustable valve if you think the flow rate is going to be higher than the sensor rating.
For that price you could install multiple sensors on the branches to find out where the water is going.
As above, I've seen the plastic 10 dollar ones, but I would not put that in my home. Looks like the first thing that would fail.
dave-in-nj:
this is a worthwhile examination.
there are a few devices that already have a pulse output that you could tie into.
your water company may also offer an outside reading meter if you request. that would swap out your meter for a new one an the new one would have that pulse output.
the size of the line is interesting. I has swapped out a lot of 1" water meters for 3/4 inch because the water company charged a premium for the larger line. in the end, the lower monthly bill paid for the swap.
I contacted the city, they don't provide a means of getting the data, at least not in any useful way. Appears there's no chance of getting them to budge on it.
