Im currently working on this project in which i need to measure dV/dt at the terminals of a battery. Is there a function i can use? I am now able to get the voltage by using the analogRead(), but how can i get the rate of change in that voltage?
Measure it and check the time. Store the values.
Measure it and check the time again. Store the values someplace else.
Repeat a few times to get more data to work with.
Shpaget:
Use millis to get the time.
I modified a piece of code from the tuorial. Here's what i did:
ReadAnalogVoltage
Reads an analog input on pin 0, converts it to voltage, and prints the result to the serial monitor.
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
float voltage;
float LastVoltage;
float rate;
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
LastVoltage = voltage;
Serial.print("Last voltage: ");
Serial.println(LastVoltage);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.0 / 1023.0);
// print out the value you read:
Serial.println(voltage);
// Calculate the rate of change in voltage, in V/s
rate = (voltage-LastVoltage);
Serial.print("dV: ");
Serial.println(rate);
However the LastVoltage is always 0, do you know why?
float voltage;
float LastVoltage;
float rate;
float voltage = sensorValue * (5.0 / 1023.0); // voltage is redeclared here, masking the global variable
Also note that you should divide by 1024. And you are not calculating a rate since there is no reference to millis() or micros().
Besides, you don't really need to convert to voltage: an int value ranging from 0 to 1023 is as good to detect change as a float value ranging from 0 to 5, but the conversion from int to float is computationally expensive and you'll get less samples.
Finally, don't forget to put your code in code tags.
It is assigned 0 as voltage did not get its value yet.
This is caused by the "float voltage" in the loop which create a second variable inside the loop called voltage .
slightly modified your code
ReadAnalogVoltage
float voltage = 0;
float LastVoltage = 0;
float rate = 0;
unsigned long lastTime = 0;
unsigned long dt = 100; // dt in milliseconds
if (millis() - lastTime >= dt) // wait for dt milliseconds
lastTime = millis();
voltage = sensorValue * (5.0 / 1023.0); // this line changed !!
Serial.print("SensorValue: ");
Serial.println(sensorValue);
Serial.println(LastVoltage, 4);
Serial.print("Current voltage: ");
Serial.println(voltage, 4 );
Serial.print("dV/dt: ");
Serial.println(1000*rate/dt, 4);
