Hello Masters ![]()
I have a final year project for my diploma degree, I want to build a device with arduino uno. The function is to measure the pressure of a fuel pump (in tank - electronic pump) on common japan cars : daihatsu, toyota, etc.
It will measures the pressure directly from outlet hose of the pump (not from the pressure regulator).
From the result of the pressure measurement so i can analyze the condition of the fuel pump (is the pump should be replaced or not).
and then, the result data will be printed out on a paper (i plan to use a thermal printer for arduino)
could you tell me what sensor i should use, please?
i found this sensor on online shop : http://www.lazada.co.id/liquid-water-oil-air-pressure-level-controller-sensor-2576686.html
can i use it? or any better idea?
i'm glad if you could give me any suggestion for my better project.
Thanks a lot. ![]()
