Hi all.
Found the link below that made mirror iPhone screen on ESP32_TFT without code attached.
I didn't get much idea how to code it, need help on clue of code, or other source may have similar project?
Thanks
Adam
Hi all.
Thanks
Adam
Have you tried the ESP32 forum?
I tried there also, because I used Arduino IDE, here so.
it's not an iPhone, it's Android. Android devices can stream their screens using RTSP with some apps. These apps allow you to broadcast your screen over the network, and you can connect to it from other devices using an RTSP client.
The code running on the ESP32 is likely an RTSP client
You won't get that with an iPhone, screen sharing would be through AirPlay and whilst there are hacks to get Airplay audio to work, I'm not aware of any workaround for video.
Great!
Thank you J-M-LJackson.
Can you please help me because I also want to make a thing like this
It’s not possible without heavy development on the iPhone side and likely special entitlement . What’s your skillset ?
I am not using iPhone I am using Android
then hijacking a topic called "How to mirror iPhone screen on ESP32_TFT ?" is probably not the best idea...
➜ I would suggest you start your own topic.
Please read How to get the best out of this forum and post accordingly with the necessary documentation for your ask
Truly I don't have any idea about it
That is the reason why you should really read
I'm pretty sure that you agree and will follow the way how to solve your problem mimimum 200 minutes faster.
This requires to invest 20 minutes of your precious time to read how to speedup solving your problems.
Directly after registering you got presented informations how to speed up solving your problem.
You should really read it.
best regards Stefan
About what ? creating your own topic ?
