How to mount a platform onto the shaft of a stepper motor
I have a little side project I want to play with which consists of stepper motor rotating a round platform (similar to a record player) - the stepper motor points shaft up and a small platform is attached to the shaft such that when the arduino signals the motor to rotate x-number of steps in either direction the platform would rotate also. As an example, imagine a small laster pointer attached, on its side, to the platform and the stepper motor rotating 180 degrees back and forth thus creating a continuously moving red dot of light for a cat to chase after.
Here is my problem...other than shaft couplers and collars I have found nothing which I could use to securely attach the platform to the shaft. I imagine I would have to obtain a pulley/wheel of some kind, which has a set screw (as my motor's shaft has a flat side on it) and then jerry-rig the platform to the pulley/wheel but I have yet to find such a pulley/wheel. Maybe I am just using wrong search words. Can anyone point me in a direction either via URLs or search terms or maybe even personal suggestions?
Thanks,
Randy
If your project is lightweight enough you can use one of these clamping hubs which any platform could be made to work with.
In general there's rarely any cut-and-dried answer when it comes to mechanical linkages. Just be precise in explaining what you're doing and someone should be able to help you.
BINGO!!! I can make one of those clamping hubs work - that's exactly the type of 'thingie' I was looking for.
Yea, I will be lightweight - just several sensors on the platform.
Thanks Chagrin, I really appreciate the link.
Randy
For similar simple attacments to a shaft, I made my own collar from a piece of wood with a hole the size of the shaft drilled in it, and then drilled a small hole in the side of the wood to the hole in the center. Put the piece of wood on the shaft, then a small bolt/screw is threaded in the side hole to go against the shaft flat spot. Hot glue the wood to what ever needs to be rotated.
