Actually, I try to run the codes written by someone who used LEDs to show election result. But I found there is an problem on serial port.
I just modify this code: SERIAL_PORT = "/dev/ttyUSB0"
into SERIAL_PORT = "COM5", but it doesn't work.. Thanks~
This is the full codes:
#!/usr/bin/python
Quick and dirty AmbientOrb code to scrape and report election results
most of this code came from:
import serial
import urllib2
import re
import time
from optparse import OptionParser
BAUD = 9600
UPDATE = 600
class ElectionWon(Exception):
pass
class CNN(object):
def init(self):
self.url = "President - Election Center 2008 - Elections & Politics from CNN.com"
def get(self):
"""return the electoral balance
(dpopular, delectoral), (rpopular, relectoral)
u = urllib2.urlopen(self.url)
for line in u.readlines():
res = re.search(r'var CNN_NData=(.*?);', line)
if res is not None:
data = res.group(1)
data = data.replace("true", "True")
data = data.replace("false", "False")
data = eval(data)
d,r = None, None
for candidate in data['P']['candidates']:
if candidate['party'] == 'D':
d = candidate['votes'], candidate['evotes']
if candidate['winner']:
raise ElectionWon("D")
elif candidate['party'] == 'R':
r = candidate['votes'], candidate['evotes']
raise ElectionWon("R")
return d,r
def normalize(d,r, interval=0.5):
"""normalize to
-1 => democrat winning
+1 => republican winning
abs(1.0) is having "2interval" higher percent than the other guy
if d+r == 0: return 0.0
rnorm = 2.0(1.0r/(d+r) - 0.5) / (2interval)
if rnorm > 1.0: rnorm = 1.0
if rnorm < -1.0: rnorm = -1.0
return rnorm
def calc_color(value):
Assumes a normaized -1:1 range and returns 0000FF through FF0000
Only manipulates the Red and Blue values
-1 ==> 0000FF
0 ==> 000000
1 ==> FF0000
red = 0
blue = 0
if(value < 0):
blue = (value * -128) + 127
if(value > 0):
red = (value * 128) + 127
return('%02x00%02x' % (red, blue))
if name=='main':
POP_VOTE = 0
ELECTORAL_VOTE = 1
parser = OptionParser()
parser.add_option("-e", "--electoral", dest="vote_sel", action="store_const",
const=ELECTORAL_VOTE, help="Report based on electoral vote (default)")
parser.add_option("-p", "--popular", dest="vote_sel", action="store_const",
const=POP_VOTE, help="Report based on popular vote")
(options, args) = parser.parse_args()
vote_sel = options.vote_sel
if(vote_sel is None):
vote_sel = ELECTORAL_VOTE
cnn = CNN()
ser = serial.Serial(SERIAL_PORT, BAUD, timeout=1)
time.sleep(10)
try:
while True:
(d,r) = cnn.get()
ser.write("#" + calc_color(normalize(d[vote_sel], r[vote_sel])))
time.sleep(UPDATE)
except ElectionWon, elewon:
if(elewon.message == 'D'):
ser.write("%0000FF")
elif(elewon.message == 'R'):
ser.write("%FF0000")
while True:
time.sleep(UPDATE)
